 Old 01-04-2010, 01:28 PM   #1
socks's Avatar
Posts: 3,250   (View Stats)
Groans: 125
Default VCTS troubleshooting
Well, with emissions coming up, i need to clear this up.
For a long while, I had my VCTS deleted. It was nice to have a bit of extra power from a mild port job on the intake manifold.
Well now, its time to pass emissions, and I need to get rid of the CEL to do so.
Speedsixxx and i made a swap, my ported manifold with VCTS delete, for his stock manifold. win win for both parties.
Well, i got it installed, and what do you know? i still have VCTS codes. P2004, and P2010. I get 2010 even with the VCTS gone.
I know there was an adjustment procedure for the actuator, but that would cause P2006.
P2004: Variable swirl control system shutter valve stuck open
P2010: Variable swirl solenoid valve control circuit high input
I've attached both Service Manual Documents, and have noted common "possible causes" of short to power along 2AS to terminal b, and ECM malfunction.
My intentions are to try to run a jumper from the ecu at 2AS to the solenoid, hopefully avoiding a short to power.... my fear is that there is an ECU malfunction on the VCTS circuit because i had the VCTS deleted like SSinstaller, with the diode and everything, and eventually the VCTS CEL trick stopped working, and the vcts came back, so either, it developed a short or the ecu developed a problem.
Anyone else have any other ideas?
 Old 01-04-2010, 02:12 PM   #2
SSinstaller's Avatar
Posts: 3,989   (View Stats)
Groans: 60
P2010 is fairly easy to diagnose, clear your codes then unplug the solenoid at the vacuum reservoir on the top of the IM... After a short while you should now be throwing p2009 instead of p2010. If you are, swap in a know good vacuum solenoid, if you are still getting p2010 you have a wiring problem, or a PCM issue.
You will need to fix the solenoid issue before you can really do anything about the p2004...
I still have the original VTCS delete circuit on my vehicle, it's been going strong for about two years now... You can adjust the plunger mounting bracket, but this code is most likely from the vacuum solenoid not working properly..
 Old 01-06-2010, 09:27 PM   #3
Groans: 60
Did you ever get this fixed??
 Old 01-06-2010, 09:29 PM   #4
lol sean why dont u just do the relay circuit? it gets rid of all those codes and you can have a ported mani all day long
 Old 01-07-2010, 05:56 AM   #5
socks's Avatar
Groans: 125
I did. At some point even with the relay the codes came back.
No, i have not fixed this yet. In all honesty, the VCTS was a mess to get back. The harness plugs were cut off so that i could wire in the relay.
 Old 01-07-2010, 06:09 AM   #6
Deadman's Avatar
Posts: 868   (View Stats)
Deadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the world
Groaned at 31 Times in 16 Posts
i never cut off the harness plugs... i wnoder if you could just hook the little black box back up and good to go?! ha
Deadman is offline   Reply With Quote
 Old 01-07-2010, 08:42 PM   #7
socks's Avatar
Groans: 125
i soldered the wires to the pins in the solenoid.
 Old 07-20-2015, 07:23 PM   #8
mcdonut420's Avatar
Posts: 10   (View Stats)
mcdonut420 is an unknown quantity at this point
Does anyone have the part numbers for the black box on the intake runners and the grey actuater behind the bov valve.
mcdonut420 is offline   Reply With Quote
 Old 07-20-2015, 07:25 PM   #9
Micha (08-09-2015)
 Old 07-20-2015, 08:18 PM   #10
HaXiR's Avatar
Posts: 315   (View Stats)
HaXiR has much to be proud ofHaXiR has much to be proud ofHaXiR has much to be proud ofHaXiR has much to be proud ofHaXiR has much to be proud ofHaXiR has much to be proud ofHaXiR has much to be proud ofHaXiR has much to be proud ofHaXiR has much to be proud of
lol! We've all been there though
2008 Ms3 Black Mica R.I.P. March 2008 - March 2016. MODS: HTP 3" intake, CX Racing FMIC with TR8 core, BNR S3, AP V3, Kozmic EGR delete, Matt Damond OCC, JBR short shift plate with bushings, HIDS, CP-E injector seals, TIG, 1 step colder plugs, Grimspeed EBCS, CS RMM, JBR passenger MM, motor craft tranny fluid, Autotech Internals
Current:
08.5 Ms3 cwp GT: Built block (sp63 4032 pistons, eagle h beams, CA625+ rod bolts/head studs, arp main studs, key'd crank, supertech 55lb valve springs, bsd delete, Block/pistons/rings/bearings WPC treated), HTP 4" intake, bnr S5 turbo (when it comes out), HTP hotside under route pipes, TR8 core, custom made cold pipes, ST intake mani, TIG, CP-E downpipe, CNT CBE, autotech hpfp, AP V3, grimmspeed ebcs, GA v3, TWM short shift assembly, JBR short shift plate, HFS-4 Meth kit, HTP front mount custom meth tank, damond motor mount trilogy, damond 3 port pcv plate, dual damond catch cans (one vented), step colder plugs, corksport injector seals, GFB bov, 51r battery, Bilstein B8 shocks, OZ ultralegga rims, custom oem clutch with Kevlar, Gen 2 trans.
2003 Mazdaspeed protégé (spicy orange); pope E manifold and DP, injen cai, PoS fmic kit, Twisted motion gt2871 turbo, aem fic-6.
HaXiR is offline   Reply With Quote
 Old 07-20-2015, 08:37 PM   #11
Sent from my HTC M9
 Old 07-20-2015, 08:42 PM   #12
Feline Führer
neganox's Avatar
Posts: 1,790   (View Stats)
Look at me throwing a brownie a bone.
2013 Mazda 3 INLET MANIFOLD (2300CC)
Bookmark that site brownie.
Micha (08-09-2015)
 Old 07-21-2015, 07:31 PM   #13
mcdonut420's Avatar
Thank you been searching for this for awhile. New here and ya super old thread. Just trying to solve my p2009 code with out taking it to the dealer. Is this the only main cause of the code? Anything else I should replace while I'm at it? Is a bad ground a possible cause notice 2 corroded grounds on the passenger side wheel well. 2006 speed6 gt.
 Old 07-21-2015, 08:04 PM   #14
Feline Führer
neganox's Avatar
It's not going to be the blackbox part. p2009 is a low voltage code.
 Old 07-21-2015, 08:22 PM   #15
mcdonut420's Avatar
Ok visually can't see any wire problems. The did happen after in rinsed off my engine bay. Could it be just the solenoid part on the black box.
Any tuning issues when you delete vcts flaps, bypassing egr to flow clean cool air? Wenis Prinkle MazdaSpeed 3/6 - ECU Computer Tuning 6 07-27-2009 01:47 AM
any engine light when you remove the VCTS flaps in the IM? Wenis Prinkle MazdaSpeed 3 - Engine, Transmission & Driveline 5 07-25-2009 09:02 PM
EGR delete/VCTS delete codes Speedie6 Mazdaspeed3/6 General Discussion 7 07-24-2009 10:22 AM
VCTS delete..? Jarods7920 MazdaSpeed 3 - Engine, Transmission & Driveline 5 06-13-2009 09:57 AM
EGR & VCTS Delete? bioevolve MazdaSpeed 3 - How-To's 15 01-05-2009 10:38 PM
Page generated in 0.34711 seconds with 29 queries
