![]() Join Date: Oct 2013 Location: King of Prussia, PA
Rep Power: 0 ![]() Thanks: 7
Groaned at 5 Times in 2 Posts
(Thread Starter) | Not Ranked : 0 score I have a Forge bpv on the car, set up to recirc..I didn an experiment fueled by curiousity as to what it sounded like venting to atmos. and of course it sounds better but i became curious. I got no check engine light, stalled twice initially, then i let it idle a bit, surged only a bit from time to time..took it for a test drive. Slight throttle seemed a bit touchier if that makes sense. I didnt mind the backfire because it didnt happen often enough. So i drove it home to see if it would "relearn" this new setup and adjust accordingly. Got to a point where backfire happened not so often, surge/maybe stall only happened until operating temp was reached. I switch it back to recirc the next day but my main question is, after that long explanation, what kind of tune would need to be achieved to have the car run normally with a VTA setup?
__________________ Its not just a love for mazda, or things awd turbo, but a love for all things automotive. Build it right, respect. |
| The Following 4 Users Say NO Thank You to Qual1ty For This Un-useful Post: |
![]() Join Date: Oct 2012 Location: Arden, nc
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 34
Groaned at 32 Times in 14 Posts
Guardian Angel Overboost Protection [GUARDIAN_ANGEL (0100-0003.3)] - $199.00CAD : Stratified Automotive Controls
__________________ ATP GTX3067R, ATP Catted DP, HTP 3" Intake, UR FMIC, Stratified GA, Stratified EBCS, Bilstein B8's, Cobb Springs, JBR RSB, JBR Mudflaps, JBR OCC, GFB 50/50 BPV, Autotech Internals, JBR Shifter Bushing, Cobb RMM, Cobb AP | |
| The Following 5 Users Say Thank You to Zpuhalla For This Useful Post: | El_Diablo (10-23-2013), Lex (10-17-2013), Mike@Stratified (10-17-2013), Qual1ty (10-17-2013), trancehead (10-18-2013) |
![]() Join Date: Jan 2012 Location: Milwaukee, WI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 975
| Not Ranked : 0 score But why all the stalling and shit running? Thats like shooting your leg cause you like the color red.
__________________ Black Mica 2006 Speed6 GT | 62,000 Miles Cobb AP | Stratified Tune Stage 1 OTS | JBR Stage II Intake | cp-e 3'' Straight Exhaust | JBR RMM | SURE AGS 600 Gram Shift Knob | SURE Anchors | SURE Return | SURE SSP/Weight | All Redline Fluids | Shell T6 | Forge V1 ms6db.com I'm Registered. Are You? |
(Thread Starter) | Not Ranked : 0 score ? its running fine now..i put it back to its normal recirculation mode because i didnt want to have all the issues.
| Not Ranked : 0 score Seriously man, I'm starting to think you're trolling us. The answers to your questions are on here. If you are serious about a BOV and tuning for it, contact a tuner, pay them for a tune. If you're just asking questions because you don't want to read, then just stop. Read every thread you can find about BPV's and BOV's on here, and you'll have a better idea of what your issues are. The search button is your friend.
__________________ Its not just a love for mazda, or things awd turbo, but a love for all things automotive. Build it right, respect. | |
| The Following User Says Thank You to Qual1ty For This Useful Post: | himurax13 (10-17-2013) |
| nothing to see here.... ![]() Join Date: Jul 2010 Location: Round Lake, IL
Rep Power: 279 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 455
Groans: 39
Groaned at 43 Times in 18 Posts
| Not Ranked : 0 score This is a forum..... what the fuck did you expect..... to get answers to your questions.!?! o wait...
__________________ 2008 Mazdaspeed 3 GT in Black Mica: 60ft: 2.167 1/8: 9.052 1/4: 13.922 @ 100.37 (26psi tire pressure & stock tires) CP-E CAI; CP-E Turbo Inlet Pipe; CP-E RMM; Engals ETD; TRZ TM; PG ExhMani; JBarone Shifter Weight, E4 Performance Shift Knob; Solid Shifter bushings; JBarone SSP ![]() ![]() : |
![]() Join Date: Aug 2012 Location: Ripon, CA
Rep Power: 2958 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,390
| Not Ranked : 0 score I run vent to cabin. Every time I let off the gas the pshhhh sound is very loud, ear piercing loud! |
| The Following 2 Users Say Thank You to littleloogy For This Useful Post: | Raider (10-23-2013), Turbo_Steve (10-23-2013) |
(Thread Starter) | Not Ranked : 0 score hahahaha one could only imagine
![]() Join Date: Aug 2008 Location: Pittsburgh, PA
Rep Power: 637 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,048
| Not Ranked : 0 score As lex said the valve will sit open during idle. It's very difficult to tune for this as there really is no fix for what is effectively a hole in the intercooler piping. You could tighten the spring on the bov but then it will flutter at everything other than high throttle shifting. The GA from stratified is really the only thing that makes it liveable. The sound changes slightly because the GA will pull the valve closed very quickly but this is necessary. I have the GA and love my rice served with a side of rice, but shifting still isn't as smooth as when fully recirc'd. The benefit of the GA's overboost protection is good to, so it's a great device to have in general. |
| The Following User Says Thank You to Mistersix For This Useful Post: | Lex (10-23-2013) |
![]() Join Date: Jun 2013 Location: Millersville, MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 16
| Not Ranked : 0 score Also, these cars will always suffer from minor problems even when tuned for VTA. The problem is you can't 100% completely pull the fuel between shifts. A buddy on here was tuned for VTA and recently switched to OEM just for the dyno day and could notice a difference in drivability and response. Sure it will sound better, but it won't ever run as good. |
| Not Ranked : 0 score A stiff spring will also slow down the valve response since a larger pressure differential is needed to open it.
![]() Join Date: Jun 2011 Location: Harrisburg, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 305
Where is your sig at??? Show up to the meet this weekend and we will help you or GTFO.
__________________ 2013 Dodge Ram Laramie GONE 2009 335i xdrive coupe COBB AP V3 CPe DCI SOLD 2009 FREEKED Mazdaspeed3 GT | |
| The Following User Says Thank You to Coats For This Useful Post: | btstarcher (10-23-2013) |
(Thread Starter) | Not Ranked : 0 score Dude I work 2 jobs and a kid, no desktop or laptop readily available to use..weekends im working 9a-230a at both jobs and with my kid..searching for answers via google on my phone is not the easiest, i searched here, still had questions so i posted it here. like i said before sorry to bother people with questions i couldnt seem to find answers to. Might as well get off this forum since i cant make the meets like ya'll want me to.
| Not Ranked : 0 score I can't search from my phone at all. Well not from MSF; I guess I could search from Google and save it as a bookmark....just an idea...
Monitor afr's while driving. My would slowly lean out while cruising iirc, and would do the same while idling. The GA pretty much fixed that. The valve just wants to open when there's not a lot of vacuum in the lines. | |
| The Following User Says Thank You to Mistersix For This Useful Post: | Qual1ty (10-23-2013) |
| How-To: MS3 Dual Radiator Fan Experiment | Novej | MazdaSpeed 3 - How-To's | 47 | 06-04-2016 10:50 AM |
| TPMS experiment | sdiegel5 | MazdaSpeed 3/6 - Wheels & Tires | 10 | 08-08-2015 12:40 PM |
| First logs - stage 1 S-OTS 'experiment' | Yatta | 2010 MS3 - ECU Computer Tuning | 18 | 04-02-2013 08:27 PM |
| My failed LED experiment | Daddy | Exterior | 10 | 01-14-2010 05:58 PM |
| Did an experiment.. got 32mpg | gsrtype1 | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 24 | 10-24-2008 03:35 PM |
