 Old 04-19-2013, 10:24 PM   #1
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
Default Warped Exhaust Manifold Flange
So I picked up the CPBoost manifold that was for sale a couple weeks ago and its a pile of shit and its brand new. I knew that Carlos's manifolds are mild steel, ok not great but he swears it works. This thing is warped like a wave, its unreal. I can see the wave in the flange without a straight edge. To make things even better, the entire manifold is painted, including the flange surfaces. The T3 flange is also warped, not as badly but still warped.
I also need to port the flange because the exhaust port holes arent even round, a 3 year old could cut a better circle. The ports dont even meet the tubes, there is a lip on the inside that is going to hurt flow significantly.
Now to the important questions:
On the T3 flange thats warped, the grade 8 steel bolts are welded in and have to be removed to machine the flange flat. My problem is that the weld bead meets the weld bead going around the joint where the tu es meet the flange. Do I cut it and hope its fully welded behind the bolt?
Machining the head flange shouldnt be an issue
What do you guys recommend I recoat this this with? I dont want some rusty pos.
2006 Mazdaspeed 6
The Following 4 Users Say Thank You to 06Speed6 For This Useful Post:
El_Diablo (04-20-2013), RichieRichness (04-20-2013), Roddiy (04-20-2013), theschrum (04-20-2013)
 Old 04-20-2013, 02:28 AM   #2
Fatguy729's Avatar
Posts: 1,685   (View Stats)
Groans: 82
Pics?
TRADED : 07 MS3 GT Silver... fully bolted w/K04
CURRENT : 06 MS6 GT Silver....
KMD V2.something ~ Cobb AP ~ SURE SRI ~ Cobb TIH ~ Forge V1 BPV ~ SLS TP ~ SURE Torq R6
Fatguy729 is offline   Reply With Quote
The Following 2 Users Say Thank You to Fatguy729 For This Useful Post:
 Old 04-20-2013, 06:53 AM   #3
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
Jet hot or swain tech coating.
cut off the bolt heads with a cutoff wheel on an angle grinder and hope you can pop the bolt out that way, maybe convert it to a stud next time.
07 MS3
The original Genpoo Hater
06Speed6 (04-20-2013), El_Diablo (04-20-2013)
 Old 04-20-2013, 08:07 AM   #4
El_Diablo's Avatar
Posts: 2,770   (View Stats)
Groans: 769
Swain Tech... nothin better.
 Old 04-20-2013, 12:23 PM   #5
Speeeeeed
06Speed6's Avatar
Alright ill give it a go and see what happens, I thought of the angle grinder also, I am just worried that it will be too hard to control and I wont be able to get an even cut out of it.
Edit: I will be converting it to studs.
2006 Mazdaspeed 6
Last edited by 06Speed6; 04-20-2013 at 12:23 PM. Reason: MSF Database - Automerged Doublepost
 Old 04-20-2013, 12:27 PM   #6
btstarcher's Avatar
Posts: 4,852   (View Stats)
Wait, you're still going to use it?
SnailTune in progress
 Old 04-20-2013, 06:06 PM   #7
Speeeeeed
06Speed6's Avatar
Yeah its built like a brick shit house, it just has the tolerances of a brick shit house. The Holset HX35 is pretty heavy too and I am very woried about cracking the manifold, im not worried about this one cracking.
I am thinking that I should do the porting and then do the surfacing in case I nick it while working with it.
2006 Mazdaspeed 6
btstarcher (04-21-2013)
exhaust flange pearl_ms3 MazdaSpeed 3 - Engine, Transmission & Driveline 6 01-29-2011 09:05 PM
V-band to stock exhaust flange -cj- MazdaSpeed 3/6 - Turbo Induction 10 11-17-2010 04:12 PM
GI: T3 Flanged Manifold w/External Wastegate Flange CaptainKRM Mazdaspeed3/6 General Discussion 13 11-13-2008 08:57 AM
Page generated in 0.27953 seconds with 24 queries
