  • 1 Post By superskaterxes
 Old 10-18-2013, 07:22 AM   #1
Voltwings's Avatar
Posts: 3,713   (View Stats)
Default Wastegate on Coldside pipe
Yes, you read the thread title correctly. Was looking at centrifugal superchargers the other day and saw they have whats called a "torque booster." For those unfamiliar with Centri-chargeres, basically its belt driven, and the boost goes up as RPMs increase, netting your peak boost at redline. Its a very flat torque curve and a very linear powerband. However, with a "Torque booster," you end up with a nice fat mid range for torque. What it essentially is, is a smaller pulley that would net you around 20+ psi (most systems run 7-9 for reference), but uses a wastegate on the coldside pipe to control boost to 7-9 psi. With this system, you basically get your boost the entire rev range, not just at redline. Seems pretty spiffy.
I can think of a few good reasons why this would be cool on a turbo setup, but can also think of several as to why its a bad idea, but just wanted to shoot the shit and see what everyone else thought. I havent come across any super interesting discussion threads lately, and to be quite honest, its friday and i dont feel like doin shit at work lol.
Past:
-Sold-
-Sold-
Current:
2012 Loaded Speed3 - Stock
2001 Miata - Basically stock
 Old 10-18-2013, 07:41 AM   #2
2.0t03speed's Avatar
Posts: 1,302   (View Stats)
so basically you would block off your current wastegate and run your turbo flat out then use their cold side wastegate to vent the charge pipe to bring the boost down. i could see this being a bitch to tune for without a relocated maf. That and not being good for the life of the turbo.
The Following User Says Thank You to 2.0t03speed For This Useful Post:
superskaterxes (10-18-2013)
 Old 10-18-2013, 08:10 AM   #3
Voltwings's Avatar
you know haha, these setups are blow through, i didnt even think about the MAF.
Honestly i feel this only works with medium sized turbos.
Too small like the K04, we're already running it wide open so it means nothing
Too big like a 6262, 6466 ... and yeah you're putting like 40-45 psi into your system and then bleeding a lot of it off. Granted people making power on these turbos are running 30+ anyways, so maybe its not too bad in that case.
Imagine like a 2871 - 3071 though, 100 WGDC would ramp that shit up stupid quick and then just have what i feel would be a slick power band... granted i think thats the point of a manual boost controller anways ... maybe this thread is pointless haha.
Past:
-Sold-
-Sold-
Current:
 Old 10-18-2013, 08:35 AM   #4
Outlaw4shrt's Avatar
Posts: 751   (View Stats)
Outlaw4shrt is the leader of the worldOutlaw4shrt is the leader of the worldOutlaw4shrt is the leader of the worldOutlaw4shrt is the leader of the worldOutlaw4shrt is the leader of the worldOutlaw4shrt is the leader of the worldOutlaw4shrt is the leader of the worldOutlaw4shrt is the leader of the worldOutlaw4shrt is the leader of the worldOutlaw4shrt is the leader of the worldOutlaw4shrt is the leader of the world
doesn't the guardian angel already allow you to do this?
2006 TGM MS6
Cobb AP w/ SELFtune // Split Second AIC1-V4H // Stratified Guardian Angel // Stratified Boost Dial // ATP GTX3071r IWG // Devils Own Stage 1 WMI // JMF v2 Intake Manifold // 4 x Siemens DEKA IV 60 lph Injectors // Outlaw4shrt In-Tank Fuel Pump Kit w/ 255 lph pump // CP-E CDFP // CP-E SAFEseals // Clutchmasters 350 & flywheel // CX Racing FMIC // HTP 3.5" Intake // 3.5 Bar MAP // Cobb EBCS // Forge BPV v1 // XS Power Exhaust Manifold // M2 Downpipe w/ Highflow Cat // Corksport 80mm CBE // Blackworks Racing VTA OCC // NGK +1's // JBR EGR delete // Speedy 17x7.5 Lite Fin's w/ Hankook Ventus V2 225/50/R17 // TooLateTuning Springs // Bilstein B6 HD Shocks // Whiteline RSB // SPC Adjustable Ball Joints // Airlift 1000 "Drag Bags" // JBR 80 duro RMM // JBR 80 duro TMM // JBR 80 duro PMM // CP-E RDM // Turbine Tech FDM // OEM Spin-On Oil Filter Conversion // Prosport Oil Pressure and Oil Temp Gauge with Oil Filter Adapter Plate, Boost and EGT Gauges // AEM UEGO Wideband O2 & Fuel Pressure Gauges // Block8head MS6 dual 52mm vent pod // Lotek triple 52mm gauge pod // Prosport EVO Single Gauge Pod // Cobb Knob // Corksport LED Kit // Corksport LED Fogs // LED Tails // Audi LED DRL's
2008 MazdaSpeed 3 - R.I.P. 1/3/13
- from ENM 2014
well actually, if you count the number of holes you'll see we have just enough
Outlaw4shrt is offline   Reply With Quote
 Old 10-18-2013, 08:37 AM   #5
the guardian angel is a fail safe not a active all the time means of boost control.
Voltwings (10-18-2013)
 Old 10-18-2013, 09:00 AM   #6
what's the difference? it lets the bpv or bov open when a certain boost target is exceeded. it's just a boost controller for the bpv instead of the wastegate, correct? you could use it as an active all the time means of boost control if you wanted to.
2006 TGM MS6
- from ENM 2014
 Old 10-18-2013, 09:32 AM   #7
Voltwings's Avatar
that saves over boost, BPV's only have two functions, opened or closed. They're not actually designed for CONTROL.
Past:
-Sold-
-Sold-
Current:
Outlaw4shrt (10-18-2013)
 Old 10-18-2013, 10:01 AM   #8
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
a waste gate only has two functions. open and closed.
"Exclusivity" - CP-enis
Demodded.
The Seals
 Old 10-18-2013, 10:12 AM   #9
El_Diablo's Avatar
Posts: 2,770   (View Stats)
Groans: 769
Wastegates in some cases can be regulatory devices, slowly cracking open until enough flow is reached and then staying there or slowly closing as more compressor flow is needed.
Either way, his doesn't work for turbo's. I was actually one of the earlier guys to do this back in the day on my Mustang.
The idea is that you put an incredibly small pulley on your supercharger and the wastegate then bleeds off the excess boost back into the intake pre-supercharger which does work with MAF systems (mine was a draw through) but can cause some funky readings from time to time. In doing this you basically spin the supercharger faster so that your desired boost hits sooner and then you bleed the rest to maintain your desired boost until redline. This does create quite a bit of heat however.
The reason it doesn't work on a turbo is because you cant make a larger turbo spin faster and then bleed off boost. The wastegate already performs a boost control function in the exhaust. Basically the closest you could get would be to run something like a K04 with no wastegate, letting it spin as high as possible but bleeding off anything above that which would mean you're making all kinds of heat for no benifit and you would also be overspinning the turbo.
The Following 5 Users Say Thank You to El_Diablo For This Useful Post:
Downmented (10-18-2013), Easter Bunny (10-18-2013), Mauro_Penguin (10-18-2013), Sterling (12-01-2013), Tokay444 (10-18-2013)
 Old 10-18-2013, 10:14 AM   #10
The exhaust wg slows down the turbo by diverting gases. The compressor wg will speed up the turbo instead and shorten its life as well as drastically reduce efficiency.
The GA operates on this principle but not meant to control boost - just lower it to a safe level if it runs away.
Mauro_Penguin (10-18-2013), Outlaw4shrt (10-18-2013), Tokay444 (10-18-2013)
 Old 10-18-2013, 10:22 AM   #11
El_Diablo's Avatar
Groans: 769
http://youtu.be/LStlqe64m4M?t=1m
@Tokay444; This shows how a wastegate can start to crack open prior to full boost and therefor "float" in a regulation position, opening and closing further as needed.
 Old 10-18-2013, 11:07 AM   #12
Matrix311's Avatar
Posts: 2,133   (View Stats)
So you want to run a setup like this? I saw this at a local car show last Saturday and this guy is pushing out 2,250whp. It's pretty insane!
Oh yeah and check out this video. Just listen to that thing spool up when they show the video of the rear of the car.
 Old 10-18-2013, 12:02 PM   #13
Tokay444's Avatar
Groans: 793
Wastegate Spring Rate and Spring Pre-Load Explained - YouTube
Oh no doubt.
But it still only has two modes. Open, and closed. Anything that isn't closed, is open. Regardless of how much.
Demodded.
The Seals
 Old 10-18-2013, 12:15 PM   #14
Oh no doubt.
Downmented likes this.
Downmented (10-18-2013), Voltwings (10-18-2013)
 Old 10-18-2013, 01:03 PM   #15
Tokay444's Avatar
Groans: 793
i have that same feeling.
like when people think compound turbo systems only work in theory.
Demodded.
The Seals
Coldside Forign object damage rebuild? Silverspec06 MazdaSpeed 3/6 - Turbo Induction 15 12-23-2012 12:49 PM
Page generated in 0.39610 seconds with 27 queries
