 Old 10-06-2014, 09:26 AM   #1
acarmona24's Avatar
Posts: 62   (View Stats)
acarmona24 is a name known to allacarmona24 is a name known to allacarmona24 is a name known to allacarmona24 is a name known to allacarmona24 is a name known to allacarmona24 is a name known to all
Default Weird noise
I don't know if this belongs in here. I installed the COBB SRI and I can hear what it's eaither the air being sucked in by the intake or the turbo spooling. But when the BOV releases the pressure it sounds like a horn. Almost as if the car was honking the horn.lol it doesn't do it all the time but it does happen often. Any ideas of why this happening? It is the stock BOV.
acarmona24 is offline   Reply With Quote
 Old 10-17-2014, 08:59 PM   #2
acarmona24's Avatar
http://flic.kr/p/pA1msg
This is the noise I'm talking about.
 Old 11-09-2014, 01:24 PM   #3
TGiggles's Avatar
Posts: 20   (View Stats)
TGiggles is a jewel in the roughTGiggles is a jewel in the roughTGiggles is a jewel in the rough
Hmmm. Sounds just like my noise. I replaced the stock BPV and it didn't eliminate the noise, just an FYI.
TGiggles is offline   Reply With Quote
The Following User Says Thank You to TGiggles For This Useful Post:
acarmona24 (11-09-2014)
 Old 11-09-2014, 01:39 PM   #4
acarmona24's Avatar
Yeah it was coming from where the BOV and inter cooler connect. I went and bought some silicone sealer and that did the trick.
 Old 11-09-2014, 01:43 PM   #5
TGiggles's Avatar
Had the seal on the BPV failed? Or was it around one of the seams on the inter cooler pieces?
 Old 11-09-2014, 01:47 PM   #6
Turbo_Steve's Avatar
Posts: 944   (View Stats)
Sounds like the cold pipe to tmic gasket failed. Silicone should be a permanent fix.
Soon to come.
WHO KNOWS? A.D.D. FTW!
 Old 11-09-2014, 02:34 PM   #7
acarmona24's Avatar
I had to drill out a bolt that broke on the TMIC and when we did that I lost thread so I had to use a bolt from autozone and it wouldn't tigjt the BOV to the TMIC properly so I was loosing air from there making that honking noise. The silicone sealer helped fill in the gap making the bolt tighter to screw. If that makes any sense.
 Old 11-09-2014, 02:56 PM   #8
TGiggles's Avatar
Neutral  +1 score
Silicone is cheap enough that I will give that a try just for the hell of it. Waiting for it to dry now. Also bought all the parts for a boost leak tester so I'll build that just in case. I can also use it just to make sure there aren't any other leaks in the system.
 Old 11-09-2014, 10:04 PM   #9
acarmona24's Avatar
Did it work?
weird f'n noise BMC Gen2 MS3 General Discussion 10 09-17-2014 07:02 PM
Weird noise... alex_speed13 MazdaSpeed 3 - Engine, Transmission & Driveline 0 01-31-2013 09:46 AM
Weird Noise ms6 envy MazdaSpeed 6 - Engine, Transmission & Driveline 16 05-22-2011 04:52 PM
Weird noise Night Wolf MazdaSpeed 3/6 - Suspension & Brakes 3 04-15-2011 10:02 AM
Page generated in 0.29822 seconds with 22 queries
