![]() Join Date: Dec 2017
Rep Power: 0 ![]() Thanks: 1
(Thread Starter) | Not Ranked : 0 score Sorry, I forgot to mention I have a 2008 speed 3 if that is needed. |
![]() Join Date: Feb 2011 Location: Chicago
Rep Power: 365 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 183
Groans: 74
| Not Ranked : 0 score I'm going with CS instead. You will need intake, ebcs, AP, and turbo, this is the bare minimum. I guess you could technically run the turbo with stock everything and just get a AP + tune.
__________________ 2007 TR MazdaSpeed3:Autotech FP inernals, CorkSport Turbo, TR8 Front Mount w/CX piping, JBR 3" intake, COBB EBCS, Cobb AP, Toyota Injector Seals, FR stud mod, Fidanza flywheel/LUK clutch, Forge BPV v2, cp-e xFlex stage 2 RMM, Wiseco .20 Pistons/Manley Rods/BSD, Dual DM catch cans, Koni Yellows/H&R springs, FD wheels, eBay downpipe, stock CBE 2005 Mazda 3 SP23: mods include rusty quarter panels and grinding 3rd gear. It does have a fusion motor, so I guess that's a mod too. |
(Thread Starter) | Not Ranked : 0 score Why are you going with the cork sport over the s3? And through my research wouldn’t I need a coupler to adapt the stock intake to the larger inlet on the turbo? And would I need a new boost controller? |
Rep Power: 3746 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,744
AP = Accessport, controls boost via a tune that uses the electronic boost control solenoid. Stock intake coupler will fit the S3. To run the S3, you absolutely, 100% must have a custom tune. There is no way to run it without it. You also absolutely need upgraded HPFP (high pressure fuel pump) internals to run the turbo safely.
__________________ Having trouble finding something on MSF? Use MS3Shadow's search tool:SEARCH MSF HERE! | |
| The Following User Says Thank You to Vansquish For This Useful Post: | Clay46 (04-01-2018) |
| The Following User Says NO Thank You to Clay46 For This Un-useful Post: | Vansquish (04-01-2018) |
![]() Join Date: May 2012 Location: FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 62
__________________ 12' black mica w/tech: BNR S4 V2; CM STG 2 WMI; DAMOND TB SPACER; GUARDIAN ANGEL V3; KOZMIC OCC; CP-E SAFE SEALS; DAMOND EGR DELETE; WHITEWIDOW INTAKE GASKET; Cobb AP V3 CP-E Xcel XL SRI; CP-E 4" TIP; CP-E Catted DP; CP-E Cat-back exhaust; CP-E TMIC; Cobb BPV; JBR EBCS; Cobb RMM; CorkSport HPFP internals; JBR turbo hoses; NGK (6510) LTR7IX-11 Iridium IX Spark Plugs; JBR short shifter; JBR Small battery tray; Optima 51r Battery Rice--CorkSport interior lights and carbon fiber hood scoop ETH/METH tune by Stratified in progress |
| The Following User Says NO Thank You to flyhigh For This Un-useful Post: | Hoyoman (04-07-2018) |
![]() Join Date: Feb 2017 Location: Indiana
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 32
| Not Ranked : 0 score You’ll need upgraded high pressure fuel pump (HPFP) internals as well.
__________________ 2007 Sunlight Silver Mazdaspeed3 Engine: \\ JBR Solid RMM \\ AWR PMM \\ TRZ TMM \\ JBR PCV OCC \\ HTP 4" Intake \\ BNR S3 \\ CPE 3.25" TMIC \\ eBay 3" Catless DP \\ Autotech HPFP Internals \\ Ford Transit Van Spin-on Oil Filter Adapter \\ Full EGR Delete \\ Throttle Body Coolant Bypass \\ Corksport Injector Seals \\ Greddy Type FV BPV \\ Tuning: \\Cobb AP V3\\ Freektune Custom Tune \\ Suspension/Brakes: \\ BC Racing BR Type Coilovers \\ StopTech Street Pads F&R \\ Centric Drilled & Slotted Rotors \\ OZ Alleggerita Wheels 18x8 et48 \\ |
| The Following User Says Thank You to flapjack For This Useful Post: | Vansquish (04-02-2018) |
Groans: 211
I run Grimspeed. There you go. A big 'ol spoonful of info.
__________________ 2007 MS6- H&R Coilovers/ C-PE Catted DP/Corksport HPFP Internals/ AEM CAI/ ETS TMIC/ CPE Austenite Dual CBE/ CPE TIH/ Synapse Synchronic/ Freektuned/ AP Short Shifter/ AWR RMM and OEM TMM with CS Inserts/ Southbend Stage 2 Endurance/Stop Tech Slotted Rear and DBA T3 4000 Series Front with EBC Reds/CPE xFlex Rear Diff Mount/ Whiteline Rear Sway Bar/DSS Level 2.9 Rear Axles | |
(Thread Starter) | Not Ranked : 0 score I’ve been researching this since I got the car but I could never find the bare minimum needed to get it to work. Everyone always talks about how they are going for big power right away and how they are going to upgrade everything they can. |
![]() Join Date: Mar 2013 Location: Accokeek MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 81
Groaned at 7 Times in 5 Posts
| Not Ranked : 0 score OP, tons of threads on this already. Just search.
__________________ 2013 LSM w/tech Cobb AP V3, CBE CS Turbo tuned by PD Corksport Catted DP/HPFP Internals JBR FMIC Pipe Kit w/TR8 CP-E TIP/3.5" Intake DM OCC/TMM Forge V2 BPV Bilstein B8 w/Swift springs Wilwood 6 pot BBK EBC RedStuff rear pads Konig Hypergram 18x8.5" |
| The Following User Says Thank You to JakeMS3 For This Useful Post: | Vansquish (04-02-2018) |
| Not Ranked : 0 score Not sure about the S3, but the CS turbo works just fine with the stock EBCS.
__________________ 12' black mica w/tech: BNR S4 V2; CM STG 2 WMI; DAMOND TB SPACER; GUARDIAN ANGEL V3; KOZMIC OCC; CP-E SAFE SEALS; DAMOND EGR DELETE; WHITEWIDOW INTAKE GASKET; Cobb AP V3 CP-E Xcel XL SRI; CP-E 4" TIP; CP-E Catted DP; CP-E Cat-back exhaust; CP-E TMIC; Cobb BPV; JBR EBCS; Cobb RMM; CorkSport HPFP internals; JBR turbo hoses; NGK (6510) LTR7IX-11 Iridium IX Spark Plugs; JBR short shifter; JBR Small battery tray; Optima 51r Battery Rice--CorkSport interior lights and carbon fiber hood scoop ETH/METH tune by Stratified in progress | |
| The Following 3 Users Say Thank You to flyhigh For This Useful Post: |
Groans: 211
| Not Ranked : 0 score How long have you had the car? Will you be installing everything yourself?
Try this sub-section: Build Paths and Stages - Mazdaspeed Forums Mazdaspeed 3/6 Wikispeedia This link is also critical if you decide you're going to get your hands dirty with this vehicle. ATR User Manual: Hybrid Tuning for Noobs to Early Advanced - Noddy's Guide
| The Following 2 Users Say Thank You to Vansquish For This Useful Post: | Majin (04-02-2018), Thor Hammer (04-02-2018) |
![]() Join Date: May 2012 Location: Greensboro NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 751
Groans: 27
| Not Ranked : 0 score spoonfeeding people eh? we getting tame lol
__________________ 06 VRM Speed 6 W/Navi 05 Mazda Family Truckster FREEKTUNED\\Cobb AP\\Autotech Internals\\Eibach Pro Springs\\Sure SRI+TIP\\Street Unit TP\\CPE RMM\AWR 88 Duro TMM\\Forge V1\\JBR Shortcut\\JBR SSB\\CPE & Sure Rear Diff Mounts\\Unicorn Blood (Rotella T6) twitter.com/djern instagram.com/djern facebook.com/djern |
| The Following User Says Thank You to djern For This Useful Post: | Vansquish (04-02-2018) |
![]() Join Date: Jun 2017
Rep Power: 0 ![]() Thanks: 0
| Not Ranked : 0 score You will have to change over less parts if you use the Corksport turbo. HPFP, AP, and tune are a must though, but on the plus side you will needs those for any other mods down the road. Just contact Corksport and they will let you know what you need.
__________________ 2008 Mica black Mazdaspeed 3 Corksport TIP, K&N Typhoon SRI, JBR 70 Duro Trilogy, CPE TMIC, Autotech HPFP, UR Test pipe, hybrid BOV, DM catch can, NGK one step colder plugs, AP V3,FREEKtuned. |
| Not Ranked : 0 score Ditto. You can run a corksport turbo with stock everything. Only mods necessary are HPFP and a Tune via AP or VT.
| Best way to tell if your MS6 is running right | Braddles | Mazdaspeed3/6 General Discussion | 6 | 01-19-2014 06:56 PM |
| cant get it running | matty | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 8 | 02-12-2012 03:10 PM |
| Here's what I'll be running | MS3-a(sore)ASS-rex | MazdaSpeed 3/6 - Big Turbo Builds | 40 | 11-19-2010 01:53 PM |
| Running e85? | Buildabong | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 29 | 06-07-2010 11:05 AM |
