 Old 03-11-2009, 09:26 PM   #1
Arrowpoint's Avatar
Posts: 364   (View Stats)
Arrowpoint is the leader of the worldArrowpoint is the leader of the worldArrowpoint is the leader of the worldArrowpoint is the leader of the worldArrowpoint is the leader of the worldArrowpoint is the leader of the worldArrowpoint is the leader of the worldArrowpoint is the leader of the worldArrowpoint is the leader of the worldArrowpoint is the leader of the worldArrowpoint is the leader of the world
Your fuel pressure is fine, the stutter you feel coincides with the PCM pulling timing during midrange spoolup. If you go WOT, it wont be as noticeable because you will go rich quickly and make torque. At part throttle in this region you end up with a lean spot of approximately 15.0:1 on the stock wideband hence the tiny bit of KR.
Let me know if there's anything else I can do to help.
-Jeff at PG
Is there anything I can do to smooth this out? Maybe I should just drive at wot all the time.LOL. Maybe you could define " stock wideband" for me. I'm not familiar with this term. Thanks for your input and everyone else's as well.
Arrowpoint is offline   Reply With Quote
Do I have a boost leak? Redsand426 MazdaSpeed 3/6 - Turbo Induction 15 03-28-2009 06:05 AM
Symptoms of an exhaust leak? Baseballpler Mazdaspeed3/6 General Discussion 10 01-19-2009 08:55 PM
Intermittent Boost Leak? phantom6294 MazdaSpeed 3/6 - Turbo Induction 2 08-28-2008 06:04 PM
Boost leak test Laloosh Mazdaspeed3/6 General Discussion 17 07-06-2008 08:48 AM
Boost leak or what? TotallyNotAmused MazdaSpeed 3/6 - Turbo Induction 12 04-15-2008 05:33 AM
Page generated in 0.23535 seconds with 21 queries
