 Old 04-02-2014, 01:14 PM   #1
dtrackstar's Avatar
Posts: 72   (View Stats)
dtrackstar is a splendid one to beholddtrackstar is a splendid one to beholddtrackstar is a splendid one to beholddtrackstar is a splendid one to beholddtrackstar is a splendid one to beholddtrackstar is a splendid one to beholddtrackstar is a splendid one to behold
Default When do I need to upgraded my intercooler?
So at what power level does the stocker become obsolete?
Sent from my Nexus 4 using Tapatalk
dtrackstar is offline   Reply With Quote
 Old 04-02-2014, 01:24 PM   #2
when it rolls off the assembly line.
The Following 13 Users Say Thank You to Raider For This Useful Post:
5LOWMS6 (04-02-2014), bstover17 (04-02-2014), chaser27 (04-02-2014), Code Monkey (04-02-2014), Cujo (04-02-2014), Elwood617 (04-03-2014), faeker (04-03-2014), Gr8Speed (04-15-2014), ItsNox (04-03-2014), kolosok17 (04-14-2014), rbflurry (04-02-2014), swsmailman (04-02-2014), VR11 (04-02-2014)
 Old 04-02-2014, 01:26 PM   #3
dtrackstar's Avatar
Haha. They can't be that bad for a stock turbo set up?
 Old 04-02-2014, 01:36 PM   #4
ihasmazda's Avatar
Posts: 1,011   (View Stats)
From what I've read, the stock TMIC can support around 400hp, but the ms6's lack of good air ducting to it makes it a bottleneck even at stock levels, so you'll see a benefit upgrading it no matter how much power you're putting down.
This is my $.02 gathered from what i've collected in reading here...
2007 Mazdaspeed 6 GT
2003 Ford Ranger XLT
The Following 2 Users Say Thank You to ihasmazda For This Useful Post:
dtrackstar (04-02-2014), Vansquish (04-02-2014)
 Old 04-02-2014, 01:38 PM   #5
dtrackstar's Avatar
I wonder if the added weight and the cost is worth it. Thanks for your input
 Old 04-02-2014, 02:49 PM   #6
Cujo's Avatar
Posts: 1,192   (View Stats)
Groaned at 6 Times in 4 Posts
Neutral  :  -1 score
FMIC is the way to go. If you really think about it the "added weight" is only maybe 10/15 lbs of pipes (if that) depending on the kit. You can shed that weight easy just by modding the exhaust wiether it be CBE, test/track pipe or even just a DP on.
And if you do go FMIC invest in good T-bolt clamps.
2012 Mazdaspeed3 Black Mica
 Old 04-02-2014, 01:52 PM   #7
dtrackstar's Avatar
My plans are tbe, tih, Sri, bov, hpfp, tune. I was hoping to get away with not upgrading the IC.
 Old 04-02-2014, 02:11 PM   #8
Police - Grammarhead
Vansquish's Avatar
You will be limited on the stock intercooler with those mods. The tune will end up not freeing up all the power you could have, as the OE intercooler heat soaks surprisingly fast, and you'll end up with knock-limited power very early without a more efficient, aftermarket intercooler.
Also, you should absolutely have the HPFP installed before you get to the TBE unless you want to risk blowing up.
Agent_Orange (04-02-2014)
 Old 04-02-2014, 02:07 PM   #9
Mazdazilla6's Avatar
Posts: 3,657   (View Stats)
You don't have to upgrade it but cool air is happy air. Also I don't know if you are planning on upgrading in that order but hpfp before tbe.
VersaTuner = Versatune
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Autotech = HPFP Internals
Grimmspeed = EBCS
 Old 04-02-2014, 02:09 PM   #10
new thread made.
 Old 04-02-2014, 02:31 PM   #11
dtrackstar's Avatar
The mods will not be completed in that order. Looks like I'll have to start looking into purchasing one.
Ideally I'd like to go 12s.
 Old 04-14-2014, 12:29 PM   #12
Snip's Avatar
Posts: 329   (View Stats)
Talking from own experience, go along for a ride in one with stock TMIC, then with one with FMIC and keep an eye on the intake temperature.
You'll see the difference there that the FMIC will stay cooler for a much longer time then a TMIC.
And we all now when air is most/best compressed, and that is when it's cold, so, the longer you keep the intake air cool, the more efficient and more HP you'll have in the end.
So theoretical, a FMIC is even useful for the simplest of tuning you do.
MazdaSpeed3 GT '07
AccessPort V2 Self tuned
 Old 04-02-2014, 03:14 PM   #13
bwspeed's Avatar
Posts: 286   (View Stats)
bwspeed is the leader of the worldbwspeed is the leader of the worldbwspeed is the leader of the worldbwspeed is the leader of the worldbwspeed is the leader of the worldbwspeed is the leader of the worldbwspeed is the leader of the worldbwspeed is the leader of the worldbwspeed is the leader of the worldbwspeed is the leader of the worldbwspeed is the leader of the world
11`s was just achieved on the stock tmic stock turbo. I say invest in e85 or meth tune first
Cobb AP, CNT TBE, Jbr intake CPE TMIC, JBR PMM & 88 Duro RMM, GTX 3071R turbo, Grimmspeed EBC, AEM methanol kit, 3 bar map sensor, Freektune
Moore Automotive 10/19/13
397whp 392wtq
bwspeed is offline   Reply With Quote
 Old 04-02-2014, 03:30 PM   #14
jm211's Avatar
Posts: 943   (View Stats)
If i could do it over...
Larger id intake
Hpfp
Testpipe (or dp)
Tune
All at once
Then add ic and suspension goodies.
The Following User Says Thank You to jm211 For This Useful Post:
ItsNox (04-03-2014)
 Old 04-03-2014, 05:31 PM   #15
ItsNox's Avatar
Posts: 3,076   (View Stats)
Larger id intake
Hpfp
Testpipe (or dp)
Tune
All at once
I did everything you listed above including the TMIC, except the suspension, all at once. Now were tuning for e85 and Im happy as shit with the mod choices ive made.
Definitely the way to go if you can IMO.
Sent via Tapafail
'06 Mazdaspeed 6 GT
- Miltuned
Georgia Motherfucking Nator
jm211 (04-03-2014)
 Old 04-02-2014, 05:47 PM   #16
Big Dog's Avatar
Posts: 730   (View Stats)
Big Dog is the leader of the worldBig Dog is the leader of the worldBig Dog is the leader of the worldBig Dog is the leader of the worldBig Dog is the leader of the worldBig Dog is the leader of the worldBig Dog is the leader of the worldBig Dog is the leader of the worldBig Dog is the leader of the worldBig Dog is the leader of the worldBig Dog is the leader of the world
Groans: 89
Groaned at 9 Times in 9 Posts
Intercooler upgrade should be priority but maybe not a top priority depending on where you live. I live in Arizona where it's dry and hot all the time. I upgraded my intercooler before anything else because after lots of research the stock one, even on a stock car is mediocre. I got a good deal on it so I installed a CorkSport TMIC. I have considered swapping it out for a front mount but the MS6's require more work than the MS3's to install it and I'm working on lots of other things on the car at the moment.
Big Dog is offline   Reply With Quote
The Following User Says Thank You to Big Dog For This Useful Post:
dtrackstar (04-03-2014)
 Old 04-03-2014, 06:47 PM   #17
scubasteve711's Avatar
Posts: 1,238   (View Stats)
Groans: 70
from what ive read on here, the stock TMIC isn't flow limited on a stock turbo. the issue is the heat it will dissipate... if you go with a meth kit, it can offset that.
07' Speed6 Velocity Red Mica
scubasteve711 is offline   Reply With Quote
 Old 04-03-2014, 06:48 PM   #18
dtrackstar's Avatar
What about a step colder spark plugs?
 Old 04-03-2014, 07:50 PM   #19
Big Dog's Avatar
Groans: 89
I would say yes. Although, reading your plugs is always best you should have already gone a step colder as a precautionary step since your starting to add mods. These cars practically needed a step colder from the factory so you won't run into issues with step colder plugs even on a stock car. Go a couple steps colder without first reading your plugs and you are asking for problems.
 Old 04-14-2014, 12:35 PM   #20
dtrackstar's Avatar
I'm sure more power is to be made with the fmic along with cooler temps but my goal is to run 12s spending the least amount of money.
 Old 04-14-2014, 12:39 PM   #21
almcbs's Avatar
Posts: 267   (View Stats)
almcbs has a reputation beyond reputealmcbs has a reputation beyond reputealmcbs has a reputation beyond reputealmcbs has a reputation beyond reputealmcbs has a reputation beyond reputealmcbs has a reputation beyond reputealmcbs has a reputation beyond reputealmcbs has a reputation beyond reputealmcbs has a reputation beyond reputealmcbs has a reputation beyond reputealmcbs has a reputation beyond repute
the answer is never.................. just add meth
07 Speed6
ETS TMIC | HTP 3" Intake | Turboxs Hybrid BOV | JBR RMM | Ralco RZ STS | CP-E Triple Dash Pod | Prosport Gauges | Bilstein HD Shocks | H&R Springs | SPC Adjustable Ball Joints | Corksport Strut Bar | CP-E Diff Mount | Whiteline RSB | Autotech HPFP | Cobb AP V3 | M2 DP | PU Rims | Unicorn Jizz | Rotella T6 Blood
Next to come : ???????????
almcbs is offline   Reply With Quote
 Old 04-14-2014, 12:43 PM   #22
dtrackstar's Avatar
Meth = more boost = more heat?!
 Old 04-14-2014, 02:48 PM   #23
ItsNox's Avatar
Meth = cooler BATs = more power. You can use meth for aux fueling, cooling, or both.
Sent via Tapafail
'06 Mazdaspeed 6 GT
- Miltuned
 Old 04-14-2014, 01:22 PM   #24
jm211's Avatar
Yes, yes, no.
ItsNox (04-17-2014)
Thinking about getting a 2013 speed3 (upgraded intercooler from mazda?) cuethenoise 2010 MS3 - Torque Specs & information 11 01-21-2013 02:50 PM
Fuel trims changed with upgraded intercooler speed23 MazdaSpeed 3/6 - ECU Computer Tuning 5 11-12-2010 08:04 PM
I dont need an upgraded intercooler do i? super_pablo_ MazdaSpeed 3 - Engine, Transmission & Driveline 6 06-06-2010 06:31 PM
Page generated in 0.44018 seconds with 32 queries
