 Old 04-18-2014, 08:35 PM   #1
CombatVet89's Avatar
Posts: 16   (View Stats)
CombatVet89 has a spectacular aura aboutCombatVet89 has a spectacular aura aboutCombatVet89 has a spectacular aura about
Default Whining sound + no boost (0psi)
Recently, I was upgrading my stock TIP with CP-E TIP and while I was doing that, I broke the ECBS nipple and I had to order a new one from Mazda and waited two days. So, I got the stock ECBS today and installed it with my new CP-E TIP. Now, everything is normal, idling, driving without boosting is normal. My currently problem is when I'm boosting, I wont pass 0psi and I get this whining sound and I know it's not the intake or the bpv making that sound, it doesn't boost at all. It usually start whining at around 3-4k even without boosting. I checked my hoses and clamps, I didn't "find" anything that could be the problem. I did my forum search and Googling. I read multiple solutions, I read that it could be bad bpv, recal MAF sensor, etc. Everything is stock except my intake and TIP. What do you guys think? Thank you.
CombatVet89 is offline   Reply With Quote
 Old 04-18-2014, 08:39 PM   #2
kby
kby's Avatar
Posts: 653   (View Stats)
kby is the leader of the worldkby is the leader of the worldkby is the leader of the worldkby is the leader of the worldkby is the leader of the worldkby is the leader of the worldkby is the leader of the worldkby is the leader of the worldkby is the leader of the worldkby is the leader of the worldkby is the leader of the world
Wastegate stuck open? Accessport? How do you know it isn't passing 0psi, the dash boost gauge or ass'o'meter?
kby is offline   Reply With Quote
 Old 04-18-2014, 08:43 PM   #3
I forgot to mention, nope, no AP yet. Also, how would I know is the WG is stuck open? Well, based on the built-in gauge and plus we all know the feeling when you boost, we get that roller coaster effect. I don't get that at all, like literally I get no boost. Thank you.
The Following User Says Thank You to CombatVet89 For This Useful Post:
kby (04-18-2014)
 Old 04-18-2014, 08:45 PM   #4
ArmanRus's Avatar
Posts: 1,566   (View Stats)
Groans: 42
No paper towels or rags stuck inside intake?
 Old 04-18-2014, 08:48 PM   #5
I know it's funny but no, I triple checked it.
 Old 04-18-2014, 08:49 PM   #6
kby
kby's Avatar
Double check all connections on every part of the EBCS.(also confirm it's installed correctly) Stock BPV right?
 Old 04-18-2014, 08:51 PM   #7
yeah, I checked every single hose that I touched while installing it, but I will try again tomorrow morning.
kby (04-18-2014)
 Old 04-18-2014, 08:55 PM   #8
kby
kby's Avatar
Yeah it has to be either the compresser(shaft play/wheel damage), major boost leak, open wastegate(but would probably see some boost), or open bpv(wouldn't idle too well).
The fact you hit 0 psi has me wondering. Eliminate those and then move on from there.
The Following User Says Thank You to kby For This Useful Post:
CombatVet89 (04-18-2014)
 Old 04-18-2014, 09:08 PM   #9
MTLspeed6's Avatar
Posts: 110   (View Stats)
MTLspeed6 is the leader of the worldMTLspeed6 is the leader of the worldMTLspeed6 is the leader of the worldMTLspeed6 is the leader of the worldMTLspeed6 is the leader of the worldMTLspeed6 is the leader of the worldMTLspeed6 is the leader of the worldMTLspeed6 is the leader of the worldMTLspeed6 is the leader of the worldMTLspeed6 is the leader of the worldMTLspeed6 is the leader of the world
Maybe instead of double checking your connections, take everything apart, from intake to throttle body, inspect all, and put it all back properly
COBB AP | COBB SRI | PG TIP | Autotech HPFP | Corksport TMIC | AWR RMM | SURE TP | 3inch single exit straight pipe exhaust | H&R springs FREEKtuned Videos of the whip : 1. https://www.youtube.com/watch?v=JnWmorhXPKo 2 https://www.youtube.com/watch?v=5JXhI4bFC44
MTLspeed6 is offline   Reply With Quote
 Old 04-18-2014, 09:14 PM   #10
I was told to wait for the ECU to "relearn" but I just got home after driving it for about 20 mins. I'm pretty sure it doesn't take that long to relearn.
I might do that in a few days or so, but right now I'm just trying to figure out the problem without taking it apart.
Last edited by CombatVet89; 04-18-2014 at 09:14 PM. Reason: MSF Database - Automerged Doublepost
 Old 04-18-2014, 10:10 PM   #11
Big Dog's Avatar
Posts: 730   (View Stats)
Big Dog is the leader of the worldBig Dog is the leader of the worldBig Dog is the leader of the worldBig Dog is the leader of the worldBig Dog is the leader of the worldBig Dog is the leader of the worldBig Dog is the leader of the worldBig Dog is the leader of the worldBig Dog is the leader of the worldBig Dog is the leader of the worldBig Dog is the leader of the world
Groans: 89
Groaned at 9 Times in 9 Posts
It's either a massive leak, a faulty ebcs (even new shit can be faulty), the wastegate stuck.
You really need an AP or dash hawk.
Big Dog is offline   Reply With Quote
 Old 04-18-2014, 10:18 PM   #12
I'd like to get an AP right now but I don't have the money yet. Soon though
 Old 04-18-2014, 10:33 PM   #13
Big Dog's Avatar
Groans: 89
Go VIP and get a DashHawk from the classifieds. It's a cheaper alternative for monitoring the essentials.
The Following User Says Thank You to Big Dog For This Useful Post:
 Old 04-19-2014, 06:05 AM   #14
jm211's Avatar
Posts: 943   (View Stats)
Agreed and its hard to tell 0psi from 1-3. At this point id remove it all, inspect turbo (visual) checks the fins on the turbine.
It was good b4 u touched it, now its not. A bpv wont give you this issue. An airflow leak this big would cause a cel. Missing a boost tube comes to mind.
Check your wastegate arm while the tip is off
 Old 04-19-2014, 06:24 AM   #15
Fuck sushi rolls
rodrigo's Avatar
Posts: 18,719   (View Stats)
Groans: 356
Common sense tells u that the last thing u did is what caused the problem .... Go borrow the boost solenoid from someone , make sure u hook it up correctly ..... Borrow someone's ap and run a log or two and I'm sure the problem will be aparent . Doubt physical damage occurred with anything . There would be no reason to
 Old 04-19-2014, 09:26 PM   #16
Zmcg1995's Avatar
Posts: 258   (View Stats)
Zmcg1995 has a reputation beyond reputeZmcg1995 has a reputation beyond reputeZmcg1995 has a reputation beyond reputeZmcg1995 has a reputation beyond reputeZmcg1995 has a reputation beyond reputeZmcg1995 has a reputation beyond reputeZmcg1995 has a reputation beyond reputeZmcg1995 has a reputation beyond reputeZmcg1995 has a reputation beyond reputeZmcg1995 has a reputation beyond reputeZmcg1995 has a reputation beyond repute
Try doing a boost leak test. A leak that big would cause other problems but still something you can try
2007 Mazdaspeed 3 gt
-HTP 3.5" intake-CXracing Piping with tr8 core-ATP Catless DP-Bnr s3 v2 -NGK 1 Step colder plugs- GFB Fully addjustable BPV/BOV-Autotech HPFP-JBR Trilogy Mounts-Custom Exhaust-BC Coils-Stoptech slotted rotors-Stoptech pads
Freektuned on 93
Zmcg1995 is offline   Reply With Quote
 Old 05-03-2014, 05:43 PM   #17
Red face
Thanks for the replies guys. I'm currently in KY right now and don't have access to my car, but when I get a chance I will take the intake and the TIP out and put everything back together again and see what happens. I thought about buying and replacing my BPV but I'm glad jm211 mentioned that the BPV wouldn't cause this problem.
You were right, it's hard to tell but I've been driving my car for three years now and I know the feeling when you are boosting.
Last edited by CombatVet89; 05-03-2014 at 05:43 PM. Reason: MSF Database - Automerged Doublepost
 Old 05-04-2014, 01:09 PM   #18
Daily Driver
Nitr0EngiE's Avatar
Posts: 2,614   (View Stats)
i bet its a loose boost tube clamp
new sound when entering boost meicalnissyen MazdaSpeed 3/6 - Troubleshoot/Diagnostics 3 04-23-2014 02:18 PM
only hitting 0psi Hamilton69 2010 MS3 - Troubleshoot/Diagnostics 12 02-20-2014 02:47 PM
whining sound? analbumcover Gen2 MS3 General Discussion 4 11-02-2011 09:16 AM
Whining Sound At Idle bewsted 2010 MS3 - Troubleshoot/Diagnostics 5 01-09-2011 09:34 PM
I Know This Doesn't Sound Right But...How to Lower Boost Using ATR? bergj1986
Cobb ATR Support
11 07-20-2010 08:04 AM
Page generated in 0.37225 seconds with 29 queries
