 Old 09-22-2008, 08:36 AM   #1
94jedi's Avatar
Posts: 2,200   (View Stats)
94jedi is the leader of the world94jedi is the leader of the world94jedi is the leader of the world94jedi is the leader of the world94jedi is the leader of the world94jedi is the leader of the world94jedi is the leader of the world94jedi is the leader of the world94jedi is the leader of the world94jedi is the leader of the world94jedi is the leader of the world
Groaned at 7 Times in 5 Posts
Default <<<Woohoo! Finally installed my CS DP - went Stg 2!!!>>>
First off, what a fucking nightmare. The DP install on this car is a fucken beyotch. I have a "decent" set of hand tools so thank God I had plenty of swivels and extensions. I had to rig up some really off the wall combos. People told me to warm up the car a bit and to be honest, it really helped. I was at the point of giving up more than a few times but I just plowed through the install as best as I could. The hardest part by far is getting the 5 DP nuts off. Everything else is easy as long as you have the proper tools. I have to say that this might have been the hardest job I've ever done on a car. I've installed turbo kits on non oem turbo VW's, I've pulled mustang 5.0 and Audi 1.8T engines, I've done Timing belt jobs on 1.8T's....all of those don't compare with this job. Still, if you have patience and some know-how, it's a job that a fairly competent enthusiast can do in a day. I don't know how some of you guys pull it off in less than 5 hours...you must have lifts + air tools. With jackstands and hand tools, count on at least 6 hours, maybe a tad less if you don't have trouble w/ the DP nuts. It took me 12 hours total but I'm the type that likes to take breaks and step away from things for a few hours at a time. One other thing - PB blaster FTW!!! can't have enough of this stuff!!! Pics to come!
BONE STOCK.
94jedi is offline   Reply With Quote
 Old 09-22-2008, 09:31 AM   #2
gsrtype1's Avatar
Posts: 7,514   (View Stats)
Groans: 102
cool so how does it drive?
 Old 09-22-2008, 09:37 AM   #3
94jedi's Avatar
I'm on an old v102 Cobb stg2 + MSCAI map. needless to say, thanks to the ETS, I'm stuttering and cutting all over. My car is Emo.
I'll flash to a new map at lunch time.
BONE STOCK.
 Old 09-22-2008, 09:52 AM   #4
ChrisK's Avatar
Posts: 1,168   (View Stats)
ChrisK is the leader of the worldChrisK is the leader of the worldChrisK is the leader of the worldChrisK is the leader of the worldChrisK is the leader of the worldChrisK is the leader of the worldChrisK is the leader of the worldChrisK is the leader of the worldChrisK is the leader of the worldChrisK is the leader of the worldChrisK is the leader of the world
Groans: 56
Mine is shuttering too! mine is boost cut though, spiking over 19psi. I can let the boost build and hold it at like 3500 rpm and then punch it and it's insane.
I agree with the DP being a bitch. I did the install a few weeks back.
ChrisK is offline   Reply With Quote
 Old 09-22-2008, 10:03 AM   #5
arkenzo's Avatar
Posts: 218   (View Stats)
arkenzo is a jewel in the rougharkenzo is a jewel in the rougharkenzo is a jewel in the rougharkenzo is a jewel in the rough
Groaned at 84 Times in 39 Posts
Downpipe isn't that hard...It took me 2hours to install
arkenzo is offline   Reply With Quote
 Old 09-22-2008, 10:05 AM   #6
94jedi's Avatar
lol...don't know how man. I followed all your tips...took me alot longer than two hours lol. I do like to take my time though.
BONE STOCK.
 Old 09-22-2008, 02:10 PM   #7
arkenzo's Avatar
You forgot one very important step, use the force.
I used it, worked well, the damn thing nearly installed itself
 Old 09-22-2008, 02:19 PM   #8
Lymerock's Avatar
Posts: 1,436   (View Stats)
Lymerock is the leader of the worldLymerock is the leader of the worldLymerock is the leader of the worldLymerock is the leader of the worldLymerock is the leader of the worldLymerock is the leader of the worldLymerock is the leader of the worldLymerock is the leader of the worldLymerock is the leader of the worldLymerock is the leader of the worldLymerock is the leader of the world
which map are you uprgrading to jedi? 102's just straight blow
Lymerock is offline   Reply With Quote
 Old 09-22-2008, 02:38 PM   #9
94jedi's Avatar
a friend emailed me the v103j and k versions of stg2+ SRI FMIC. I'm trying those out and keeping an eye on things. the v102 version stuttered and cut all over the place. I do still have to get some new plugs in the car. I've got them on my work bench, just need to put them in and stretch the coil springs at the same time.
BONE STOCK.
 Old 09-22-2008, 02:41 PM   #10
gsrtype1's Avatar
Groans: 102
eh.. i just installed a downpipe with a new turbo, changed the oil and took coffe brakes. Took all of 2hours...lol
 Old 09-22-2008, 02:46 PM   #11
Lymerock's Avatar
very cool, I dont know what the difference is with K or L, but J is working nice on my setup and you have most of the same stuff I do. get off your ass and install those plugs and take a drive
I will be interested to see how your boost responds in 3rd and 4th with the stock bov. keep us updated
 Old 09-22-2008, 03:04 PM   #12
94jedi's Avatar
do you think I'll be leaking boost w/ the stock BPV? I think that's my weak link in my setup right now. After I get a forge BPV, the a CDFP upgrade for safety, I'm done modding for a bit.
BONE STOCK.
 Old 09-22-2008, 03:12 PM   #13
Lymerock's Avatar
everyone suspects the stocker is weak, so thats why im interested to see. You should most likely be hitting 20 in 3rd like me, but the stocker was designed for a bit less im guessing. One way to find out
 Old 09-22-2008, 03:53 PM   #14
The Angry Goose
Hectik1's Avatar
Posts: 3,219   (View Stats)
Hectik1 is the leader of the worldHectik1 is the leader of the worldHectik1 is the leader of the worldHectik1 is the leader of the worldHectik1 is the leader of the worldHectik1 is the leader of the worldHectik1 is the leader of the worldHectik1 is the leader of the worldHectik1 is the leader of the worldHectik1 is the leader of the worldHectik1 is the leader of the world
Groaned at 9 Times in 6 Posts
I gained 1-1.5psi just upgrading my BPV to a Forge.
Hector
2014 Mazda 3
2008 Mazdaspeed3-SOLD
1979 Mazda Rx7
Hectik1 is offline   Reply With Quote
 Old 09-22-2008, 04:06 PM   #15
aaronc7's Avatar
Posts: 8,057   (View Stats)
Groans: 370
94- you will probably be fine with the stocker. i felt zero difference going from the stocker to HKS. I've also had the turbosmart and forge... I think the reason the stocker leaks in the upper rpm is when the stock map starts closing the throttle in the upper rpms. The closing throttle creates a pressure differential and the bpv vents air (just doing its job). Get a forge with a super stiff spring and the pressure difference needs to be much greater for it to vent, this it 'holding' more boost in the upper rpms. So really, (IMO...in my theory lol), the throttle is the issue here, not the stock bpv (unless your particular one just sucks, or something), but the throttle! Get a full throttle flash or have an AP the throttle is held wide open- problem solved and stock should be just fine.
WI Progressive kit installed finally. flashfrenzy MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 40 11-25-2008 11:45 AM
Page generated in 0.33471 seconds with 26 queries
