 Old 12-04-2014, 09:06 AM   #1
rturpin's Avatar
Posts: 34   (View Stats)
rturpin is an unknown quantity at this point
Default Yet another turbo smoke questions- sorry
I have been searching for the past couple of days and can't find an answer to my problem. My turbo was smoking badly, so i added a restriction bolt and raised the idle to 1k. After a fresh oil change the car does not smoke, but after 2k miles it starts smoking again and just keeps getting worse. I am using Rotella synthetic oil. Is there anything else i can do or do i need to replace the turbo at this point? I use the car for a long commute, and need it to keep getting decent mileage, so i have no desire to go with a bigger turbo, i am just looking for this one to stop smoking.
rturpin is offline   Reply With Quote
 Old 12-04-2014, 09:08 AM   #2
Gr8Speed's Avatar
Posts: 5,702   (View Stats)
1. Look to see if the PCV system is failing before replacing the turbo.
2. A bigger turbo will not hurt your highway MPG. I would even venture to say you will get better gas mileage if you don't drive like an idiot because of a slower spool. Realistically, gains/losses in MPG will be negligible.
 Old 12-04-2014, 09:12 AM   #3
rturpin's Avatar
I will do some searching, but how does one test the pcv system? I have already installed a OCC in this car.
 Old 12-04-2014, 09:50 AM   #4
Turbo_Steve's Avatar
Posts: 944   (View Stats)
What year and how many miles on your car? They extended the warranty on the turbo to 7 years / 70,000 miles.
Soon to come.
WHO KNOWS? A.D.D. FTW!
 Old 12-04-2014, 09:51 AM   #5
rturpin's Avatar
its a 07 with 90k so i am out of luck.
 Old 12-04-2014, 09:52 AM   #6
youngwonder's Avatar
Posts: 147   (View Stats)
youngwonder has a reputation beyond reputeyoungwonder has a reputation beyond reputeyoungwonder has a reputation beyond reputeyoungwonder has a reputation beyond reputeyoungwonder has a reputation beyond reputeyoungwonder has a reputation beyond reputeyoungwonder has a reputation beyond reputeyoungwonder has a reputation beyond reputeyoungwonder has a reputation beyond reputeyoungwonder has a reputation beyond reputeyoungwonder has a reputation beyond repute
This year my turbo smoked very badly. One of the locals took apart the turbo to rebuild it and saw that all the seals went bad and the turbo was filled with built up oil crud. I took all those steps (oil restrictive bolt, T6, 1k idle). If the PCV system is not the issue then you probably can trade somebody with your smokey turbo for a non-smokey turbo.
08 Mazdaspeed3
Hypnotic Tuned: e85
BNR s3 v2
AEM Meth Kit 100% Meth w/ DO10 (not using now)
Accessport V3
DNP Exhaust Manifold
Corksport Exhaust
JBR OCC s2
TR8 FMIC
CPE RMM Stage 2
HTP 3" Full Intake
Autotech Internals
CP-E downpipe - Catless
JBR short throw shifter
JBR shift knob
Corksport short shift plate
SS brakelines
Koni Yellow
H&R Springs
Low beam headlights - HID 6000k
Fog lights - HID 6000k
youngwonder is offline   Reply With Quote
 Old 12-04-2014, 09:54 AM   #7
Check the for sale section and/or put up a wtb for a low mileage k04. This will be your cheapest good option.
Soon to come.
 Old 12-04-2014, 10:05 AM   #8
rturpin's Avatar
Any thoughts on how to determine whether i might be a PCV or a turbo problem. I don't want to spend a bunch of time replacing something that doesn't need to be if i can avoid it.
How long does it take to swap out the turbo on these cars? To me it doesn't look terrible, but looks can be deceiving.
Thanks for all of the help so far.
 Old 12-04-2014, 10:27 AM   #9
If you have some help with people that knows what they are doing it's very quick. It wasn't as difficult as I thought it would be.
08 Mazdaspeed3
Hypnotic Tuned: e85
BNR s3 v2
Accessport V3
Corksport Exhaust
JBR OCC s2
TR8 FMIC
CPE RMM Stage 2
HTP 3" Full Intake
Autotech Internals
JBR shift knob
SS brakelines
Koni Yellow
H&R Springs
 Old 12-04-2014, 10:29 AM   #10
rturpin's Avatar
I have done several turbo swaps over the years, but always on trucks. These little engines are a new animal for me.
 Old 12-04-2014, 10:33 AM   #11
taf0422's Avatar
Posts: 4,689   (View Stats)
Groans: 192
You can swap a new turbo in a couple of hours if you know what you're doing. Block off some coolant lines, pull the battery, intake system, egr valve, bolts on top of turbo, bolts connecting to DP, pull the oil drain and just slide it out the drivers side top.
[SIZE="1"]07 MS3 GT..
GTX3076r --- 479/412
S4-460/400
Highest HP BNR S3
BNR-S3 424/397
taf0422 is online now   Reply With Quote
 Old 12-04-2014, 10:35 AM   #12
rturpin's Avatar
Thanks guys.
I have been searching, but cant find out how to test pcv without removing everything, any ideas?
 Old 12-04-2014, 10:57 AM   #13
Mattyhawk1's Avatar
Posts: 739   (View Stats)
Originally Posted by rturpin View Post
Thanks guys.
Stock PCV Valve Removal
 Old 12-04-2014, 11:06 AM   #14
rturpin's Avatar
Thank you that is what i was looking for. My OCC has been filling up so i know it isn't stuck shut, but will have to check whether it will hold pressure. It looks like my OCC check valve should help mitigate any problems that the PCV might be causing so i might need a new turbo. It looks like a rebuilt K04 can be had cheaply.
 Old 12-08-2014, 08:46 AM   #15
Ahh, new info. If your occ keeps filling up you probably have other issues causing your smoking than the turbo. It would be worth replacing the pcv valve as a cheap first step. If it leaks boost and you are pressurizing the crank case you can get excess oil vapor out of the valve cover vent. I'm not sure how you have your occ setup, but it is possible that if installed wrong, this too can cause excessive crankcase pressure and can cause the turbo to push oil.
I would also suggest getting a compression & leak down test done to rule out smoking from a cracked ring land.
Soon to come.
 Old 12-08-2014, 08:52 AM   #16
rturpin's Avatar
Thanks for the info. How often should the OCC be filling? I drain it every couple of weeks (1.5K miles) and it isn't full but has some liquid in it. I have acquired a used K04, and will rebuild it and throw it in when i get a chance. If i have to pull the intake to put the turbo in i will replace the pcv while i have it off. I am planning on doing a compression check when i get a little fee time also. Depending on how that comes out i may do a leak down also.
 Old 12-08-2014, 08:57 AM   #17
Well getting some condensation about a couple tablespoons worth in that time is normal, but if filling up with oil like a half a quart or something is a problem.
Soon to come.
 Old 12-08-2014, 09:02 AM   #18
rturpin's Avatar
I might be getting more than a couple tablespoons, but not near a half quart. I will measure it the next time i drain it.
Another not: i changed the oil this weekend and the smoke has completely stopped. As the oil wears it get worse. I realize this is common, but i wasn't expecting such a drastic difference.
 Old 12-08-2014, 09:15 AM   #19
I would start with a pcv valve. While you are changing it out may not be a bad time to get a tig(thermal insulation gasket) and do a valve cleaning. Also do you have someone's occ kit or did you do a diy setup?
Soon to come.
 Old 12-08-2014, 09:18 AM   #20
rturpin's Avatar
i will look at doing a tig (first i had ever heard of it) i was planning on cleaning the valves while i was there also. I am using a damond OCC. Do you really think this could be a PCV issue and not a turbo issue?
 Old 12-08-2014, 09:34 AM   #21
Oh, your Damond setup has the check valve so I doubt you are pushing boost into the crankcase. Pcv probably won't make a difference here.
What weight oil are you running? Should be 5w30. If you are using 5w20 I would say that is your problem.
Soon to come.
 Old 12-08-2014, 09:37 AM   #22
rturpin's Avatar
I am actually running rotella T6 synthetic 5W-40.
 Old 12-08-2014, 11:09 AM   #23
Looking more and more like the turbo.
Soon to come.
 Old 12-08-2014, 01:43 PM   #24
rturpin's Avatar
i appreciate all of the info you have provided, that is what i am leaning towards also.
 Old 12-10-2014, 02:10 PM   #25
rturpin's Avatar
is there anyway to check the turbo seals without pulling it out? I don't want to go through the trouble of swapping it to find out it is something else. this smoke is driving me crazy.
Smoke during turbo boost chrismazda 2010 MS3 - Troubleshoot/Diagnostics 7 02-23-2012 02:08 PM
Turbo smoke fix? buckeyepost MazdaSpeed 3 - Engine, Transmission & Driveline 11 07-28-2011 05:36 AM
Turbo lag, smoke, grrr MaverickX3 MazdaSpeed 3/6 - Turbo Induction 0 05-21-2010 11:14 AM
No more Turbo Smoke Addikted To Boost MazdaSpeed 6 - Engine, Transmission & Driveline 12 07-27-2009 06:38 AM
Installed the Turbo xs DP and let it smoke! speed3 MazdaSpeed 3/6 - Turbo Induction 38 04-15-2008 06:20 PM
Page generated in 0.42675 seconds with 25 queries
