![]() Join Date: Nov 2009 Location: Lagrange,IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 85
(Thread Starter) | Not Ranked : 0 score thanks in advance for all your wisdom
__________________ 08.5 true red gt, 35/20% tint, resonators deleted, Tenzo R type M's,Cobb SRI, Hypertech tuned, MSD Dashhawk, SU test pipe, AWR RMM, BC coilovers, Turbosmart duel port bov [SIGPIC][/SIGPIC] |
![]() Join Date: May 2010
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2
Groaned at 74 Times in 15 Posts
| Not Ranked : 0 score at low psi i do not believe its bad, however when i had a turbosmart dual port in full recir it still ran like shit. if you continue to have problems i would just say get a Forge BPV
__________________ 2010 ms3 celestial blue! RIP Jake Guzewicz miss u bro |
![]() Join Date: Jan 2009 Location: Newark, NJ
Rep Power: 1040 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,110
Groans: 661
| Not Ranked : 0 score take it apart and oil it I'm running it 50/50 and don't flutter nor backfire |
| The Following User Says Thank You to manelscout4life For This Useful Post: | rfinkle2 (05-14-2011) |
(Thread Starter) | Not Ranked : 0 score should i need to oil it being as its brand new?
Groans: 661
| Not Ranked : 0 score |
(Thread Starter) | Not Ranked : 0 score ok thanks def worth i try i guess, i kinda like the sound but would much rather not fuck something up
![]() Join Date: Oct 2009 Location: Andersen AFB, Guam
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 53
| Not Ranked : 0 score or you could just buy a forge like posted above or the HKS SSQV3 bov with recirc kit! i have the HKS and it runs so much better than the Turbosmart Dual port that i had
__________________ RichTuned Ultimate Racing DP V2 flange\35W 6000k DDM HID's\HKS SSQV3 VTA\GTX2867R\Tanabe STB\HTP 3.5" intake\PTP HPFP\UR FMIC\Ultimate Racing turbo-back exhaust\JBR RSB\JBR 80Duro Trilogy mounts\Cobb AP v3\Stage 2\22.5PSI \Sonic Tuning Coilovers\TWM full replacement shifter and SSP\PnP Intake Manifold/CP-e EWG Exhaust Manifold/Tial 44mm EWG 11/10/2012 NATOR DC DYNO day 304Whp/356 FT lbs Tqe Uncorrected 4/13/2013 Mega NATOR Meat Dyno Day 300WHP/ 344ft lbs/wtqe Corrected |
(Thread Starter) | Not Ranked : 0 score [QUOTE=BlueDmnSpeed;849350]or you could just buy a forge like posted above or the HKS SSQV3 bov with recirc kit! i have the HKS and it runs so much better than the Turbosmart Dual port that i had[/QUOTE well i got it for a good price and hate the way the forge sounds ill give it a lil time before i get rid of it as long as i know the flutter is not goin to harm the turbo or anything
| Not Ranked : 0 score yeah my TS one did the same thing. never had any problems with it. but i have noticed that the HKS holds the boost a lot better than the TS
Groans: 661
| Not Ranked : 0 score After oiling it up just tighten it all the way and loosen it 2 full turns. That's how I've had mine set from when I was running just an intake to now being fully bolted and I am holding boost no problem. |
(Thread Starter) | Not Ranked : 0 score thanks for the advise, i took it apart it looked oiled but i put a little air tool oil on there and put it two turns from loose haven't gotten a chance to drive it, ill let you know how it goes
| The Following User Says Thank You to 02stang951 For This Useful Post: | manelscout4life (05-12-2011) |
Groans: 661
| Not Ranked : 0 score Well i tighten it all the way and loosen it too turns, I'm not sure if that's what you meant |
![]() Join Date: Feb 2011 Location: Edmonton Alberta
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
| Not Ranked : 0 score The forge version 2 does not make the ping sound. sounds like a regular bpv
__________________ 2007 CWP mazdaspeed 3 GT, Cobb access port stage 1 sf , Cobb SRI, Cobb turbo inlet, Forge bypass valve V2, One step colder plugs, Sure RMM, Corksport CBE, JBR ssp stage 2, kmd internals version 2 , Spin on oil coversion with sandwich plate, H & R coilovers, 18 x 8 Enkie fujin black, lamin x fog light covers, 35% front 20% rear tint, more to come... |
| Turbosmart BPV question | shpankey | MazdaSpeed 3 - Engine, Transmission & Driveline | 12 | 07-15-2010 07:22 PM |
| Turbosmart 50/50 bpv | GFish | MazdaSpeed 3/6 - Turbo Induction | 5 | 08-19-2008 04:00 PM |
