> MazdaSpeed 6 - How-To's
 Old 07-12-2018, 04:34 PM   #1
njdurkin's Avatar
Posts: 68   (View Stats)
njdurkin is an unknown quantity at this point
Default Can't hit more than 10psi
I can't get more than 10psi peak boost. It doesn't sound like I have an air leak but I am thinking that might be the problem. What do you guys think? I attached some logs from a couple short pulls. I went around and tightened up everything I could find but still can't get much boost.
2007 MS6
SRI - CorkSport with K&N filter
TIP - CorkSport
FMIC - unknown brand, probably ebay special
Cobb AP V3 - Stage 1+IC map
BPV - CorkSport
RMM - CorkSport
HPFP - Upgraded internals from Autotech
Power Steering Cooler Upgrade - DamondMotorsport
njdurkin is offline   Reply With Quote
Only 10psi doctavus Gen2 MS3 General Discussion 7 07-04-2013 01:24 PM
only reading 10psi 2006MS6 Mazdaspeed3/6 General Discussion 18 03-03-2012 04:24 AM
Installed CAI and now only have 10psi of boost dbrier MazdaSpeed 3/6 - Turbo Induction 2 06-08-2009 01:57 PM
Only boosting 10PSI ?? glocK23 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 6 05-18-2009 02:35 PM
took off mbc and only seeing 10psi b-ron MazdaSpeed 3/6 - Turbo Induction 2 07-29-2008 11:01 PM
Page generated in 0.46403 seconds with 30 queries
