> MazdaSpeed 6 - How-To's
  • 1 Post By BigRedSpecial
 Old 01-28-2012, 11:36 PM   #1
2zz mr-s
dooderek's Avatar
Posts: 5,119   (View Stats)
Groans: 239
Default DIY replace belt tensioner
pretty sure its the same for ms3 but i nce bout those pos wagon
remove passenger side wheel also relieve tension off the serpentine belt and remove it
4 plastic screws phillips head, 2 of them arent shown in pic my arrowed. you cant miss em. once those are out bend the plastic piece out of the way
remove two screws, either 10 or 8 mm cant quite remember
viola, your a winner. also becareful my dayco belt tensioner replacement was actually a 1/2 SAE compared to the stock 14mm.
The Following 21 Users Say Thank You to dooderek For This Useful Post:
ak_spray (06-12-2012), aviator79 (01-31-2016), BigRedSpecial (02-14-2012), breakfstincluded (11-28-2012), Captain KR (02-05-2012), crazyp (02-05-2012), dead-zone (06-19-2013), Design (05-14-2015), Ebdiggity (07-23-2015), Ingle (02-15-2012), littleloogy (09-21-2013), meelo88 (04-03-2013), MPSdriver (08-12-2012), mr.speedy3 (03-08-2018), NewCar (03-31-2013), nsdva (09-25-2012), Raider (02-05-2012), sidekick (04-04-2014), tddvrrn (02-14-2012), thatsmrgimp2u (02-14-2012), TWOptSL0W (02-14-2012)
 Old 02-05-2012, 01:26 PM   #2
2zz mr-s
dooderek's Avatar
Groans: 239
not even a single fucking thanks? fuck you fags
The Following 5 Users Say Thank You to dooderek For This Useful Post:
ak_spray (06-12-2012), Chimmike (04-10-2012), karl-hungus (02-05-2012), memin (03-29-2012), Tres3 (12-23-2013)
 Old 02-05-2012, 02:06 PM   #3
Did not see this, ya crybaby. Gave ya a thanx. Want some msf bucks too?
 Old 02-05-2012, 02:28 PM   #4
2zz mr-s
dooderek's Avatar
Groans: 239
LOLOLOL
 Old 02-05-2012, 02:35 PM   #5
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
You mean...
...it's not supposed to come off like this?...
"Exclusivity" - CP-enis
Demodded.
The Seals
Raider (02-05-2012), Speed3Pedro (07-15-2016), TWOptSL0W (02-14-2012)
 Old 02-14-2012, 07:05 PM   #6
thatsmrgimp2u's Avatar
Posts: 834   (View Stats)
Was this a task for you guys? Ive done all my work myself up to this point... Going to drop by the dealer to have them check out the vvt but ive got 45k on my car so i feel like this could be causing my noise as well... I imagine you replaced the belt at the same time?
When I tackle this Ill post some pics of the 3 for reference.
Fluids
Rotella T6 A lot
Rislone Engine Treatment
Motorcraft XT-M5-QS(trans)
VP Methanol
~Splash of E85~
 Old 02-14-2012, 07:21 PM   #7
Tokay444's Avatar
Groans: 793
It's easy as fuck when your shit doesn't break. And yes. Change the belt, and the idler.
Pb blaster on tensioner bolts. The holes are thru holes so the back of the bolts get corroded like mine.
Demodded.
The Seals
 Old 02-14-2012, 07:22 PM   #8
BigRedSpecial's Avatar
Posts: 1,436   (View Stats)
Groans: 56
Mine is making an unholy goddamn racket and needs to be replaced. Good timing on this
nsdva likes this.
Needed: Driver mod
 Old 02-14-2012, 07:26 PM   #9
TWOptSL0W's Avatar
Posts: 3,289   (View Stats)
Groans: 125
check all of the grooves in your belt and pulleys for rocks, thats probably it.
also, when putting the belt back on, its easiest to route the belt around all of the pulleys except the crank first and then put it on the crank as you turn the tensioner bolt.
The Following User Says Thank You to TWOptSL0W For This Useful Post:
 Old 02-15-2012, 06:36 AM   #10
Groans: 56
It is intermittent, and the tensioner was replaced by the previous owner so that could very well be; didn't start until they started sanding the roads.
Needed: Driver mod
 Old 11-28-2012, 10:28 PM   #11
thegeneralmejia's Avatar
Posts: 20   (View Stats)
thegeneralmejia has a spectacular aura aboutthegeneralmejia has a spectacular aura about
Nice writeup
thegeneralmejia is offline   Reply With Quote
 Old 05-17-2013, 11:07 PM   #12
ArmySpeed6's Avatar
Posts: 672   (View Stats)
ArmySpeed6 is the leader of the worldArmySpeed6 is the leader of the worldArmySpeed6 is the leader of the worldArmySpeed6 is the leader of the worldArmySpeed6 is the leader of the worldArmySpeed6 is the leader of the worldArmySpeed6 is the leader of the worldArmySpeed6 is the leader of the worldArmySpeed6 is the leader of the worldArmySpeed6 is the leader of the worldArmySpeed6 is the leader of the world
Groaned at 20 Times in 8 Posts
Derek, you wouldn't happen to have the belt tensioner would you? Same dudes that tried to do your build said that I'd need a new belt, tensioner and actuator due to my belt making this winding sound and rattles at start up...is it necessary to do all 3 or just the tensioner would suffice?
GT3076R//Custom FMIC with 13" Core with 3" piping//HTP 3.5 Intake/Inlet System with AEM Cone//CorkSport SS DownPipe//Custom 3inch Exhaust with Single Flowmaster Exit//Autotech Fuel Pump Internals//Prosport OCC//Devils Own Meth//GrimmSpeed EBCS//Bosch 3Bar//Cobb AccessPort V2//MSD DashHawk//TWM Stage 2 Short Throw Shifter//D2 Racing Coilovers//RotorPro Front and Rear Cross Drilled and Slotted Rotors//EBC Green Stuff Front and Rear Pads//ACT 6 Puck Clutch and Flywheel//CorkSport Front Strut Bar//CorkSport Rear Brace Bar//CorksSport Rear Differential Mount//CorkSport Front Sway Bar//Whiteline Rear Sway Bar//CorkSport LED Kit//AWR 80 Duro TMM/RMM/PMM//GTSpec 4 Point Ladder Brace Bar//
////MADSCIENTISTTUNED////
ArmySpeed6 is offline   Reply With Quote
 Old 05-18-2013, 12:58 AM   #13
2zz mr-s
dooderek's Avatar
Groans: 239
aparantly any of the 3 can make a similar noise, test to see if the sound gets worse with ac on/off. in my case it was just the tensioner
 Old 05-18-2013, 03:52 AM   #14
ArmySpeed6's Avatar
It's worse with the ac on...it's not even cold
 Old 07-29-2016, 04:19 PM   #15
MollyW's Avatar
Posts: 1   (View Stats)
MollyW has a little shameless behaviour in the past
Default Damned dealership rips you off!!
I have a 2008 MS3. Bought it new. I barely have 78k on it. This past Monday I was driving home and suddenly there was white smoke pouring from under the hood. I stopped as quickly as I could and raised the hood to make sure there was no fire. It was definitely electrical in smell. Towed to dealership who now, a week later , says it is the compressor and the first estimate was $820.00, then after a few hmms and be right backs it is now $1281.00. WHAT!!!!!!
I asked if they could just take the pulley off or reroute the belt or somehow, but they said no. So I have to either pay them this or I will not have a car. I hate them!!!! I am not overly mechanical with these newer computerized cars. I could rebuild the engine in my '72 Chevelle with no problem, but not this. They see a female and immediately think I know absolutely nothing.
If you are hearing terrible noises, you may be on your way to this as well. Mine was so intermittent which is why I did not take it in sooner. Only after the car reached temp, Only on the way home from work, never on the way there. OK if going at least 40 MPH. Weird!!!
MollyW is offline   Reply With Quote
The Following User Says NO Thank You to MollyW For This Un-useful Post:
g00s3y (08-01-2016)
 Old 08-01-2016, 04:00 PM   #16
g00s3y's Avatar
Posts: 2,127   (View Stats)
Groans: 438
You don't know that much if you are responding to a thread that hasn't been active since 2013...
 Old 07-30-2016, 09:18 AM   #17
Frequentflyer's Avatar
Posts: 1,959   (View Stats)
That was not your belt tensioner. That was your AC compressor clutch bearing exploding. Quite a common occurance with these cars. Happened to me a few years ago. It got so hot that it melted the copper coil right out of the damn clutch. I wound up replacing the compressor myself for under $500. Took me about 4 hours. Good as new.
Sent from my SM-G935V using Tapatalk
 Old 08-01-2016, 03:12 PM   #18
Tokay444's Avatar
Groans: 793
Get the clutch rebuilt kit or find a junkyard compressor.
Still the wrong fucking thread you brownie faggot.
Demodded.
The Seals
g00s3y (08-01-2016)
 Old 04-21-2019, 09:17 AM   #19
jpr
jpr's Avatar
jpr is an unknown quantity at this point
To get the belt on, I left it off the crank pulley, and then used a zip tie to hold it on there while I cranked the engine manually. This stretched the belt a bit, but it seems to be necessary. I tried other methods like trying to slip it on the shiny pulleys without lips or grooves, but there was not enough slack. I watched all the videos I could, and no one showed exactly how to get it on the Mazdaspeed3.
jpr is offline   Reply With Quote
 Old 10-08-2019, 09:19 AM   #20
2zz mr-s
dooderek's Avatar
Groans: 239
wow what a crappy write up
The Following User Says Thank You to dooderek For This Useful Post:
Vansquish (10-08-2019)
2012 BMW X5 diesel recalled over belt tensioner issue Haltech Automotive News 0 06-28-2011 07:00 AM
tensioner pulley TWOptSL0W MazdaSpeed 3/6 - Troubleshoot/Diagnostics 6 06-09-2011 07:21 AM
Tensioner and Belt Noise Rattle - revisited/update? uoftguy MazdaSpeed 3 - Engine, Transmission & Driveline 5 05-06-2009 11:22 AM
Tensioner Pulley WhiteSpeed21 MazdaSpeed 3 - Engine, Transmission & Driveline 10 03-11-2009 04:10 PM
tensioner pulley? danesti MazdaSpeed 3 - Engine, Transmission & Driveline 12 02-15-2009 12:31 AM
Page generated in 0.41709 seconds with 32 queries
