> MazdaSpeed 6 - How-To's
Like Tree35Likes
 Old 02-24-2009, 11:16 PM   #1
SpdFreak's Avatar
Posts: 364   (View Stats)
SpdFreak is the leader of the worldSpdFreak is the leader of the worldSpdFreak is the leader of the worldSpdFreak is the leader of the worldSpdFreak is the leader of the worldSpdFreak is the leader of the worldSpdFreak is the leader of the worldSpdFreak is the leader of the worldSpdFreak is the leader of the worldSpdFreak is the leader of the worldSpdFreak is the leader of the world
Neutral  :  +2 score
Default DIY: Sea Foam
DIY: Sea Foam
1. Warm up your car.
2. Park the car on a level surface and turn off the engine.
3. Disconnect the brake booster vacuum hose from the insulator pipe on the fire wall.
4. Get a see through container to pour the Sea Foam into.
I used a plastic water bottle cut in half. Wipe down the container or bottle with a clean paper towel, till the bottle is dry and clean.
5. Pour roughly 12 oz of Sea Foam into your see through container and set aside for a moment.
6. Turn on the car. Turn off AC.
7. Using the brake booster vacuum hose, siphon the Sea Foam out of your container. Try not to stall the engine. It is not necessary to rev the motor at all. When there is about one ounce of Sea Foam left in the see through container, fully emerge the vacuum hose causing the engine to stall.
8. Wait ten minutes.
9. With the vacuum hose still disconnected start the car. This removes left over Sea Foam remaining in the line.
10. Reconnect the brake booster vacuum hose.
11. Idle the car for 10 minutes while it smokes.
Tip: Turn off your climate control in order not to get the smoke & smell in to the car.
12. Take a few mile ride using the 'right pedal' more often then not.
(Allow the car to idle for 2 minutes before it is turned off to allow the engine to cool down.)
13. Time for an oil change.
Disclaimer: Perform this DIY at your own risk. I am not liable for damage or injuries.
dead-zone, Gangles, Jetech and 4 others like this.
DIY: Sea Foam
SpdFreak is offline   Reply With Quote
The Following 128 Users Say Thank You to SpdFreak For This Useful Post:
2008MS3H (08-29-2012), 802MS3 (02-25-2009), Addikted To Boost (05-20-2009), Alpha (09-07-2011), aromig (04-26-2014), Babyface (08-06-2009), badams118 (02-25-2009), Benny71 (09-23-2012), Bill6639 (07-26-2014), blacksin (05-04-2011), Boosted Beluga (06-14-2009), boost_me (03-18-2009), breakfstincluded (09-03-2011), Brian MP5T (09-07-2011), Broxer (09-23-2011), BudUMfan (12-29-2009), cabrone (08-01-2011), cbusby (07-08-2009), Constantin (05-08-2012), corbs (01-16-2010), Crarrs (09-30-2011), Czar Quanovan (06-10-2009), Dahouse702 (01-09-2012), dale_gribble (03-29-2013), dantes5823 (01-08-2012), Dash08 (12-09-2009), dead-zone (06-15-2012), djthom (01-02-2010), Doc-1 (03-30-2010), doubleflusher (03-17-2011), dougefresh_ (05-04-2011), eagle20g (11-08-2013), edmsmallcash (01-31-2013), England15j (08-04-2012), enkiddu (04-07-2011), Esteban123toro (11-14-2013), Fail_6 (03-11-2014), Ferdball (04-30-2013), Funkster777 (06-25-2011), Gangles (03-18-2012), ganque (01-04-2010), gsrtype1 (03-16-2009), Gtmo1826 (02-05-2016), helmetface (02-28-2012), i8urgti (05-29-2013), impossible (08-13-2014), Ingle (01-30-2012), J Dragon (03-22-2009), J-villa (04-12-2009), JacksonMS30 (07-08-2010), Jetech (07-03-2013), JNR5005 (04-28-2011), jo.jacques (06-16-2010), jracer (03-31-2011), jscape83 (05-22-2011), jwilkins88 (11-26-2010), K3N (04-17-2013), karl-hungus (05-01-2009), KevMS6 (09-10-2012), kgb (04-11-2009), kingpin748 (02-27-2009), kylec_2003 (11-18-2010), LiEast (03-09-2011), lifeownedme (06-01-2011), lightspeed3 (05-20-2011), lovatoj (02-08-2014), Mazdazilla6 (03-22-2012), meeker13 (02-10-2011), mg446 (08-29-2013), mglavina (06-29-2011), MGM_GT3 (12-03-2011), miguelbates (03-11-2009), Mistersix (01-31-2011), MrPrime (05-08-2013), MS3 Ventura (04-03-2010), MS3_65 (05-14-2010), ms6mil (03-26-2013), Mythyk (07-21-2012), Nataphen (11-21-2010), Night Wolf (02-03-2011), nighthawk358 (02-25-2009), OMGWTFHAX (01-14-2010), PiKA West (11-26-2010), pipe (05-22-2009), redboat (03-04-2013), riott (01-12-2011), RobLoMS3 (10-23-2011), sadak (08-19-2013), Scare Dem (01-10-2014), SgtP (02-27-2009), Shin Gouki (12-27-2010), SKiZ0TT (07-21-2011), SLS MS3 (02-25-2009), SoyBean (03-24-2010), speed23 (02-04-2010), SpeedSixxx (07-07-2009), spoolin00 (02-20-2011), steven88 (05-14-2009), stogi1knobi (03-21-2013), sweetpickles (02-25-2009), Tedspeed6 (12-19-2012), TexasSpeed3 (05-12-2012), thabigo (03-30-2010), thatsmrgimp2u (05-05-2011), TheFlash (12-17-2012), thehead (05-23-2011), the_caruch (04-05-2010), Tommy (01-18-2011), TopazM3 (01-14-2010), toprock (02-25-2009), treyclash (07-22-2010), triplejumper18 (03-30-2009), tunersteve (12-22-2009), uncorked11 (03-18-2012), weakdog85 (04-04-2013), Whiteboy (03-29-2013), whoo-sa (06-25-2013), xandrake (04-01-2009), xcoldricex (09-19-2009), xfeejayx (05-11-2011), xSP33Dx3x (04-29-2009), yearzero (04-03-2010), Z32_MS3 (06-15-2014), zer010gic (02-26-2011), Zeya (03-30-2010), ZoomingNH (03-09-2011), zpele (05-21-2011), zxhoya (05-06-2013)
 Old 02-24-2009, 11:53 PM   #2
danesti's Avatar
Posts: 4,186   (View Stats)
Groans: 137
i think im going to do this soon.
thanks for the right up!!!!
seems easy enough
2008 STi
Intake
Turboback
AP
 Old 02-25-2009, 04:54 AM   #3
bova's Avatar
Posts: 3,820   (View Stats)
Groans: 45
you really only need to change the oil if you put it in the crankcase
The Following 11 Users Say Thank You to bova For This Useful Post:
Addikted To Boost (08-27-2009), Constantin (05-08-2012), dougefresh_ (05-04-2011), FenixTX717 (05-05-2010), lovatoj (02-08-2014), ms_3 (05-31-2010), phillyb (02-25-2009), TheProYodler (01-28-2016), the_caruch (04-05-2010), whos_MS3 (06-13-2011), xfeejayx (04-18-2011)
 Old 02-25-2009, 08:31 AM   #4
Axle Breaker
jmhinkle's Avatar
Posts: 4,639   (View Stats)
Groans: 162
Thanks for adding pics to my instructions. Bova is correct about the oil change.
The Following 2 Users Say Thank You to jmhinkle For This Useful Post:
 Old 02-25-2009, 08:38 AM   #5
badams118's Avatar
Posts: 821   (View Stats)
badams118 is the leader of the worldbadams118 is the leader of the worldbadams118 is the leader of the worldbadams118 is the leader of the worldbadams118 is the leader of the worldbadams118 is the leader of the worldbadams118 is the leader of the worldbadams118 is the leader of the worldbadams118 is the leader of the worldbadams118 is the leader of the worldbadams118 is the leader of the world
Groaned at 126 Times in 71 Posts
I would still do this right before an oil change. All the carbon broken loose by the Seafoam will end up in your engine oil and filter.
2011 WRX | Cobb AP | Cobb DP | SPT CBE | AEM CAI
Whiteline F/R Sways | SPT SSK | TWM M1 Abrams
badams118 is offline   Reply With Quote
 Old 02-25-2009, 08:42 AM   #6
Axle Breaker
jmhinkle's Avatar
Groans: 162
It better not unless you have some serious issues in your engine. Anything that it might loosen up had better go out the exhaust path and never touch your oil.
King_6 likes this.
lovatoj (02-08-2014), oh10speed3 (03-17-2011)
 Old 02-25-2009, 09:00 AM   #7
badams118's Avatar
Why wouldn't it? The carbon will be in contact with the engine oil until it reaches the exhaust. Most will exit with the exhaust, but some will inevitably come into contact with the oil coating the internal parts & end up in the filter.
 Old 02-25-2009, 09:04 AM   #8
danesti's Avatar
Groans: 137
maybe i dont know much about the internal workings of an engine but shouldnt the rings on the pistons create a seal or close to it not allowing anything into the crankcase? itsnt that how we have compression and are able to have boost?
i dont know, il be changing my oil either way, cant hurt and my car needs it. haha
MS3BPS2286 likes this.
2008 STi
Intake
Turboback
AP
 Old 02-25-2009, 09:05 AM   #9
Axle Breaker
jmhinkle's Avatar
Groans: 162
The carbon builup that this removes is on the valves and tops of the pistions. The carbon area of the valves and the tops of your pistons should not be in contact with your oil supply.
Dane, correct.
King_6 likes this.
 Old 02-25-2009, 09:18 AM   #10
SLS MS3's Avatar
Posts: 1,254   (View Stats)
SLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the world
Those pics will help a lot of people out. I prefer to use the other end of this line where it connects to the intake manifold. It's easier to me to work at the front of the engine.
Dane, correct.
+1 on doing an oil change after the seafoam treatment. Gas shouldn't come in contact with the oil supply either, but these motors have a well documented history of fuel-dilution issues. After seeing how dirty my oil has been after the two times I've seafoamed my car, there was definitely some carbon that found it's way in.
2007 Sunlight Silver MS3
Graphite RX8 Rims · 235/40R18 Kumho SPTs
BC Coilovers · Cobb Swaybars · DBA 4000 Slotted Rotors · Technafit SS Brake Lines · SU Rear MM · TRZ Trans Mount · TopSpeed Passenger MM
Cobb AP · MS CAI w/ AEM Straightener · Cobb Turbo Inlet · Cobb FMIC · Black HKS SSQV (recirc) · PG Exhaust Manifold · Corksport Downpipe · Vibrant Exhaust
mrlilguy CDFP · Denso ITV22s plugs · Cobb STS, Shift Knob, & Shifter Weight · F2 Balance Shaft Delete & Oil Baffle
Stock is just plain, gay.
SLS MS3 is offline   Reply With Quote
 Old 02-25-2009, 09:40 AM   #11
badams118's Avatar
No oil on the cylinder walls, either, right?
 Old 02-25-2009, 09:48 AM   #12
danesti's Avatar
Groans: 137
below the rings there should be, those rings should be scraping the oil back down into the crank area. there shouldnt be oil above the rings in the combustion chamber...
the main reason i would say seafoam is a good idea for the disi is the fact we dont have any gas running on the back of our intake valves so we get a large amount of carbon build up, but i think we all had that idea in our head. jmhinkle hit it right on the $$$$
2008 STi
Intake
Turboback
AP
 Old 02-25-2009, 10:25 AM   #13
Axle Breaker
jmhinkle's Avatar
Groans: 162
^^ exactly. Oil in your combustion chamber is not wanted and if it is getting passed your oil ring then your rings are shot.
"+1 on doing an oil change after the seafoam treatment. Gas shouldn't come in contact with the oil supply either, but these motors have a well documented history of fuel-dilution issues. After seeing how dirty my oil has been after the two times I've seafoamed my car, there was definitely some carbon that found it's way in. "
This is the only legitimate argument for the oil change. Yes it is no secret the motors get fuel dilution, but does it come at idle with a 14.7 AFR target under high vacuum when you are doing seafoam or does it come when the ECU commands an unbelievable 9.xx AFR under boost?
 Old 02-25-2009, 04:31 PM   #14
shadesofgray19's Avatar
Posts: 794   (View Stats)
Is there a noticeable difference after doing this? Anyone recommend changing the spark plugs as well? I didn't know if they would foul with this?
 Old 02-25-2009, 04:40 PM   #15
SpdFreak's Avatar
My take on changing the oil after performing the Sea Foam treatment is as follows. The Sea Foam is an alcohol based liquid, which is thin and when added to the engine in a plentifully manner may pass the piston rings.
DIY: Sea Foam
 Old 02-25-2009, 05:04 PM   #16
sweetpickles's Avatar
Posts: 375   (View Stats)
sweetpickles is the leader of the worldsweetpickles is the leader of the worldsweetpickles is the leader of the worldsweetpickles is the leader of the worldsweetpickles is the leader of the worldsweetpickles is the leader of the worldsweetpickles is the leader of the worldsweetpickles is the leader of the worldsweetpickles is the leader of the worldsweetpickles is the leader of the worldsweetpickles is the leader of the world
Thanks for the pics - helps me out a ton since I dunno where anything is on this car w/o pics I was about to stick a banana in the tailpipe and see if that helped somehow.
Quick clarification; do you have 4oz leftover in the original Seafoam canister when you're done then, or did I misread somehow?
sweetpickles is offline   Reply With Quote
 Old 02-25-2009, 05:47 PM   #17
SpdFreak's Avatar
I used about 3/4 of the can.
DIY: Sea Foam
 Old 02-25-2009, 06:36 PM   #18
Axle Breaker
jmhinkle's Avatar
Groans: 162
Neutral  :  -1 score
Sparkplugs: It has been recommended to changed them afterwards. I swapped over to Denso 2 step when I did the first seafoam. I was have boost control issue related to elevation so I swapped back in my stockers did another seafoam and am still running the stockers without any issues. Hell if anything it cleaned them up.
Leftover: is recommended to go in your gas tank to clean out the fuel system. I did the 1/2 and 1/2 both times.
 Old 02-26-2009, 08:56 AM   #19
badams118's Avatar
How often should we Seafoam?
 Old 02-26-2009, 01:39 PM   #20
danesti's Avatar
Groans: 137
bump for this...
i would like to do it every oil change but that seems a bit excessive... but i plan on changing my plugs soon so i might as well do it once more before that.
2008 STi
Intake
Turboback
AP
 Old 02-26-2009, 01:40 PM   #21
bova's Avatar
Groans: 45
i would say every 10-15k miles? maybe even more.
 Old 02-26-2009, 01:50 PM   #22
vballbwing's Avatar
Posts: 174   (View Stats)
vballbwing has a brilliant futurevballbwing has a brilliant futurevballbwing has a brilliant futurevballbwing has a brilliant futurevballbwing has a brilliant futurevballbwing has a brilliant futurevballbwing has a brilliant futurevballbwing has a brilliant futurevballbwing has a brilliant futurevballbwing has a brilliant futurevballbwing has a brilliant future
Great write up. I've been thinking about doing this.
I've been reading up on BG44 which is what the dealership sells vs. Seafoam. Anyone have thoughts on both? BG44 is only put in the gas though.
vballbwing is offline   Reply With Quote
 Old 02-26-2009, 02:08 PM   #23
bova's Avatar
Groans: 45
well if its only put in the gas that really would do nothing for cleaning your intake manifold now would it? or your intake valves for that matter.
The Following 2 Users Say Thank You to bova For This Useful Post:
danesti (02-26-2009), J-villa (04-12-2009)
 Old 02-26-2009, 07:17 PM   #24
Addikted To Boost's Avatar
Posts: 1,837   (View Stats)
Just got done doing mine. Thanks for the write up man. Got a pretty good sized cloud and smoke trail with only 9000 miles. Feels good gettin all that shit thats built up out of there.
09 MGM MS3
 Old 02-26-2009, 10:13 PM   #25
Axle Breaker
jmhinkle's Avatar
Groans: 162
I think how often you do it depends on if you have OCC, 2nd OCC, and EGR delete. Each one of those will extend the time in between.
 Old 02-27-2009, 05:44 AM   #26
Qluber's Avatar
Posts: 267   (View Stats)
Qluber has much to be proud ofQluber has much to be proud ofQluber has much to be proud ofQluber has much to be proud ofQluber has much to be proud ofQluber has much to be proud ofQluber has much to be proud ofQluber has much to be proud of
Guys, I have been performing this type service professionally for about 15 years now, I did my MS3 yesterday for the first time with about 13k on the clock, I have never witnessed that much black smoke before on any car..............wow, these things really run rich, subsequently causing an ass load of carbon buildup, we should benefit from doing this service every 10-15,000 miles..............
08.5 BLACK MICA GT,
CP-e CAI,
Black Forge bov
DEBADGED
Magnaflow Catback
Corksport Test Pipe
TRZ Rear Mount
1 Step Colder NGK's
Qluber is offline   Reply With Quote
 Old 02-27-2009, 03:39 PM   #27
So is it bad that mine had white smoke? Ive always read thats a coolant leak or something?
09 MGM MS3
 Old 02-27-2009, 05:15 PM   #28
badams118's Avatar
White smoke is normal
 Old 02-27-2009, 06:08 PM   #29
YammerR1's Avatar
Posts: 109   (View Stats)
YammerR1 has much to be proud ofYammerR1 has much to be proud ofYammerR1 has much to be proud ofYammerR1 has much to be proud ofYammerR1 has much to be proud ofYammerR1 has much to be proud ofYammerR1 has much to be proud ofYammerR1 has much to be proud ofYammerR1 has much to be proud of
So it won't cause any long term damage to seals, injectors or cats? I'm still debating using this stuff. I guess letting carbon build up without cleaning it out would be worse than any possibility of seafoam hurting the engine.
How does seafoam affect O2 sensors if it's causing all the crap to blow out the exhaust? Kind of like what happens after eating a bad burrito....
YammerR1 is offline   Reply With Quote
 Old 02-28-2009, 05:26 PM   #30
kao_lor's Avatar
Posts: 27   (View Stats)
kao_lor will become famous soon enough
so wat does this do. just clean out carbon build up.
kao_lor is offline   Reply With Quote
 Old 03-06-2009, 11:49 PM   #31
NorCal_MP3's Avatar
Posts: 16   (View Stats)
NorCal_MP3 has a spectacular aura aboutNorCal_MP3 has a spectacular aura about
I am not totally sure about a few of the instructions...when you "siphon" the seafoam with the hose in the clear container, is the hose only partially in the seafoam so that it sucks air too or do you put the hose in all the way...I was confused since the next step is to fully emerge the hose, does that mean just in the liquid or to push it to the bottom so that the hose is plugged by the bottom of the container plastic?
NorCal_MP3 is offline   Reply With Quote
The Following User Says Thank You to NorCal_MP3 For This Useful Post:
 Old 03-10-2009, 11:56 AM   #32
david097's Avatar
Posts: 9   (View Stats)
david097 will become famous soon enough
Thanks for the pics that helps a lot!
david097 is offline   Reply With Quote
 Old 03-10-2009, 01:17 PM   #33
phillyb's Avatar
Posts: 14,702   (View Stats)
Groans: 1,940
submerge the hose so that it sucks in some air as well...yes...
when you've done that and about half of the seafoam is gone, fully submerge the hose so that it cannot suck in any more air. don't worry about pressing it down to the bottom. this should kill the engine.
i did this to a 2000 civic over the weekend and it smoked for about 20 minutes. it was awesome!
 Old 03-10-2009, 07:19 PM   #34
06turbospeed's Avatar
Posts: 10   (View Stats)
06turbospeed will become famous soon enough
thinking abot doing this ... is it safe with the seals and anything else that it could damange
Mazdaspeed CAI/ Turbo xs bov/ WOT Box/ CPE rear mount/ DSD-SLM II Boost gauge/ 20% tint (much more this spring)
06turbospeed is offline   Reply With Quote
 Old 03-12-2009, 02:56 PM   #35
SLinKK's Avatar
Posts: 21   (View Stats)
SLinKK will become famous soon enoughSLinKK will become famous soon enough
I've used sea foam for about 12 yrs on all my cars and never had a problem with any of them but I was warned several times doing this could foul out O2 sensors...I always put a can in the gas, half in the crank case and half down the vacuum brake line. Always worked great and sometimes it drastcally improved power on some of my friends cars who never done this and they were at about 60k miles.
Megatron1979 likes this.
SLinKK is offline   Reply With Quote
The Following User Says Thank You to SLinKK For This Useful Post:
wompa (12-31-2014)
 Old 03-13-2009, 09:58 PM   #36
toprock's Avatar
Posts: 749   (View Stats)
toprock is the leader of the worldtoprock is the leader of the worldtoprock is the leader of the worldtoprock is the leader of the worldtoprock is the leader of the worldtoprock is the leader of the worldtoprock is the leader of the worldtoprock is the leader of the worldtoprock is the leader of the worldtoprock is the leader of the worldtoprock is the leader of the world
Groans: 40
Groaned at 27 Times in 21 Posts
I'm thinking about trying this on my car...
1 Can in Gas Tank
1/2 Can in Crankcase
1/2 in Vacuum line
Does anyone else recommend this method?
MikeSkillZ likes this.
toprock is offline   Reply With Quote
 Old 03-13-2009, 10:57 PM   #37
Axle Breaker
jmhinkle's Avatar
Groans: 162
I don't think we need it in the crankcase especially if you still have the Balance shaft holding back a quart of crap. Vacuum line and tank is good enough.
The Following User Says Thank You to jmhinkle For This Useful Post:
toprock (03-14-2009)
 Old 03-17-2009, 08:57 PM   #38
toprock's Avatar
Groans: 40
Ummm...this method works...I just did it this weekend by myself, without revving the motor. You just make sure the vac tube can suck in air as well as seafoam and it works. Sure it takes a little while, but it does suck all of it in...I did splash seafoam on my intake though, trying to get it to feed into a bottle lol but that's not the OP's fault just cuz the vac tube is stiff and short...
CP-E SRI / Forge BPV / Corksport TP / Corksport CBE
 Old 03-17-2009, 09:54 PM   #39
Axle Breaker
jmhinkle's Avatar
Groans: 162
No shit. If you follow the directions, it is easy, works and is a one man job.
cbusby (07-08-2009), Nitr0EngiE (09-21-2009)
The Following User Says NO Thank You to jmhinkle For This Un-useful Post:
 Old 03-18-2009, 08:16 AM   #40
gsrtype1's Avatar
Posts: 7,514   (View Stats)
Groans: 102
Ummmm BULLSHIT! the engine doesnt run more than 5-10 seconds with that vacuum hose off. It boggles down to 200rpm and shakes like crazy.
The Following User Says NO Thank You to gsrtype1 For This Un-useful Post:
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f111/diy-sea-foam-22041/
Ðàñêîêñîâêà äâèãàòåëÿ 2.3 MZR DISI TURBO - Óêðàèíñêèé Ìàçäà Êëóá :: MazdaClub.UA This thread Refback 01-19-2016 03:01 AM
The Garage - Car Enthusiast Club [Now Motorcycle friendly!] - Page 656 - Off Topic - Linus Tech Tips This thread Refback 05-29-2015 08:54 PM
The Garage - Car Enthusiast Club [Now Motorcycle friendly!] - Page 655 - Off Topic - Linus Tech Tips This thread Refback 05-29-2015 08:50 PM
Seafoam ? ? Mazda MPS Owners Club This thread Refback 01-08-2015 01:14 PM
How to seafoam a mazda 6 - 1Q5A This thread Refback 08-24-2014 08:31 PM
How to seafoam a mazda 3 - 1Q5A This thread Refback 08-10-2014 05:11 PM
How to: Clean your EGR (Speed 3 based instructions, but should help) | Page 2 | MCX7 Community Forums This thread Refback 04-10-2014 11:51 AM
sea foam This thread Refback 01-22-2014 05:43 AM
sea foam ? Mazda MPS Owners Club This thread Refback 01-12-2014 02:39 AM
Need some help or information ? Mazda MPS Owners Club This thread Refback 01-11-2014 07:49 AM
Injecteur ou non?? - Mazda 3 Quebec This thread Refback 07-14-2013 03:16 PM
Fuel injector cleaners? This thread Refback 03-10-2013 04:07 AM
Seafoam ? Mazda MPS Owners Club This thread Refback 01-18-2013 06:26 AM
Comment éviter l'encrassement de l'IM - Mazda 3 Quebec This thread Refback 01-15-2013 04:54 AM
Seafoam • Mazda MPS Owners Club This thread Refback 11-01-2012 07:31 AM
Comment viter l'encrassement de l'IM - Mazda 3 Quebec This thread Refback 10-19-2012 03:01 PM
Update on Stretch's CX-7 (Last Round of Mods)... - Page 2 This thread Refback 09-28-2012 07:05 AM
Intake and Valve cleaning/maintenance This thread Refback 07-31-2012 03:13 PM
Mazda MPS Owners Club • View topic - SeaFoam This thread Refback 07-18-2012 10:07 AM
Mazda MPS Owners Club • View topic - Seafoam ? This thread Refback 05-16-2012 06:15 AM
Mazda MPS Owners Club • View topic - forte gas treatment? This thread Refback 12-17-2011 05:04 AM
??????????. ????????? ????? ???????.. HELP! This thread Refback 12-13-2011 04:42 AM
How to: Clean your EGR (Speed 3 based instructions, but should help) This thread Refback 08-11-2011 01:00 PM
Anyone tried the seafoam yet? This thread Refback 07-06-2011 11:15 AM
How to: Clean your EGR (Speed 3 based instructions, but should help) - Page 3 This thread Refback 04-12-2011 01:59 PM
Update on Stretch's CX-7 (Last Round of Mods)... This thread Refback 04-04-2011 11:21 AM
Motor Reinigen This thread Refback 02-27-2011 05:11 AM
Anyone tried the seafoam yet? This thread Refback 11-19-2010 08:01 AM
Seafoam? or NOT to Seafoam? This thread Refback 04-27-2010 11:17 AM
MattJackson86's Bookmarks on Delicious This thread Refback 02-09-2010 03:51 PM
Seafoam? or NOT to Seafoam? This thread Refback 02-08-2010 08:50 AM
Seafoam? or NOT to Seafoam? - TorontoMazda3 This thread Refback 11-26-2009 06:15 AM
Seafoam? or NOT to Seafoam? - TorontoMazda3 This thread Refback 11-25-2009 12:09 PM
A2SportCompacts :: View topic - Possible injectors clogged? Opinions please. This thread Refback 11-14-2009 01:51 PM
Anyone tried the seafoam yet? - Mazda CX-7 Forums This thread Refback 10-15-2009 12:45 PM
MattJackson86's mazda3 Bookmarks on Delicious This thread Refback 08-28-2009 11:05 AM
Update on Stretch's CX-7 (Last Round of Mods)... - Page 2 - Mazda CX-7 This thread Refback 03-20-2009 06:46 AM
Lithuanian foam sculptor does BMWs too Haltech Automotive News 0 05-31-2008 06:00 PM
Lithuanian builds car from polyurethane foam Haltech Automotive News 0 05-30-2008 02:10 PM
3-inch Highloft Memory Foam Mattress Topper - $55.99 Haltech Hot Deals Section 0 04-04-2008 02:20 PM
Overstock.com 10% off All Memory Foam Haltech Hot Deals Section 0 03-26-2008 02:40 AM
Page generated in 0.62505 seconds with 40 queries
