> MazdaSpeed 6 - How-To's
 Old 02-26-2009, 03:17 PM   #1
danesti's Avatar
Posts: 4,186   (View Stats)
Groans: 137
Default How to - Balance shaft delete
First off..
some of you will know this info, others wont so here is a brief reason of why i did it.
why?
A 17 pound cast iron monster lives right under cylinder # 3, blocking potential oil capacity and provides what i would guess is a pound or two of rotating mass ( rotating mass robs power from each revolution of a piston, so taking off or reducing rotating mass essentially gives you a motor that has to work less to produce power; lightweight pullys, flywheels, wheels, ect.)
The oil capacity goes up a quart or so with the removal of the balance shaft, which is a major selling point to me.
Ill let the blown motor threads and the speculation that the B/S (balance shaft) is causing some blown motors through inadequate oil distribution to be discovered elsewhere.
for some stages, i do not have pictures, because they are basic steps, and if you are not able of performing them on your own, you shouldn`t be attempting this install.
Jack up the car.
remove oil cap.
use a 17mm socket to pull drain plug.
drain oil.
remove oil filter.
next, remove the 12 10mm bolts that secure the oil pan from the bottom.
remove the 4 8mm bolts that lay parallel to the ground on the passanger side, next to a hard line covered in rubber/silicon.
remove the 4 14mm oil pan bolts that parallel to the ground on the drivers side, near the flywheel area. (two point one way, two point the opposite)
Do not worry about this black hard line, it is for you oil dipstick and will simply slide off when you pull the pan.
Use a hammer or similar to pry the oil pan and break the seal of the stock gasket material.
I pried off the front, near where the oil filter goes.
carefully, remove pan. some finaggling (haha) might be needed.
Next, there is some type of oil feed system(made of black plastic) which is held on by two 8mm bolts, remove them, and pull the plastic piece.
Remove the 4 14mm bolts that connect the balance shaft to the rest of the block.
(note: when these are removed the balance shaft will come out, so have a friend hold the shaft or keep a hand holding it up to remove last one or two bolts)
I did NOT remove the ring that turns the balance shaft. I did not have any tools to do it and i didnt quite know what it entailed. if someone has info feel free to chime in.
use the delete kit and 8mm alan bolt to plug the old oil feed hole of the balance shaft. (if i have my cylinder #`d correctly, it is between # 3 and #4 cylinders; the two closest to the drivers side.)
remove all the gasket material that was left on the block where the oil pan met up to it.
reinstall the black oil feed thing with the two 8mm bolts.
now back to that oil pan, remove any of that stock gasket material that may still be on it.
the oil baffle is optional, but i would recommend it, and there is also a windage tray coming to the market soon i believe.
also i cleaned out my oil pan to see how dirty it was. it was pretty bad.
remove the stock oil baffles ( if you bought a new one to install), which are connected by 10mm bolts, then install a baffle as seen here.
apply grey tube gasket material to outside of pan (mostly on top, but i believe the passenger side where the 8 mm bolts went was on the side of the pan for gasketing.)
reinstalling the oil pan is going to be hit or miss. for me it took a few attempts but i knew right when i had it, and having the help of babs was a plus. make sure the dipstick line gets in there and everything lines up. mine lined up quite well.
reinstall the 12 10mm bolts, the 4 8mm bolt on the passanger side, and the 4 14mm bolts near the flywheel area.
reinstall filter, drain plug, and fill with oil ( an extra quart at least)
reward yourself with a beer.
enjoy working on your car (yours truely)
and watch babs lift some weights
NOTES!!!!
after pulling my pan, i realized how much oil was still in there. an oil change doesnt get all of it out thats for sure.
This thing is huge a ridiculous.
Impressions...
well. i have some piece of mind now. extra oil and a free`d up oil pan with good oil access to all parts of crank make me feel good.
Did i notice a huge difference, probably in my head but maybe. not really. but my butt dyno rarely feels anything ever.
Vibrations.
at idle, i noticed no difference what so ever.
driving, i noticed a bit from 2500-4000 under certain load types, but not enough to make me regret doing it, not even close.
hope this helps some one out.
and thanks to babs for drinking beer and giving me a hand.
2008 STi
Intake
Turboback
AP
The Following 47 Users Say Thank You to danesti For This Useful Post:
08.5MS3 (09-01-2012), 2.3speed06 (08-21-2014), 802MS3 (02-26-2009), 94jedi (02-27-2009), ATAZ (01-02-2010), bioevolve (02-26-2009), BolvangaR (03-05-2010), boosted3 (02-27-2009), Colin1337 (06-30-2013), cxz (02-01-2010), dougefresh_ (04-08-2011), Flaverre (04-09-2011), Fobio (04-11-2009), gsrtype1 (02-27-2009), Jonp (06-06-2009), jracer (11-11-2010), karl-hungus (07-04-2009), Kennosuke (04-29-2009), kevinblack (01-19-2014), LiEast (06-21-2009), localnj (05-17-2014), MadOzodi (02-26-2009), masskaos (07-20-2009), mexicant (06-10-2010), miguelbates (12-15-2009), mike8748 (03-06-2009), mouse0330 (02-26-2009), MS6FL (11-27-2011), Muzzybud (12-06-2015), Nataphen (11-24-2010), phantom3 (10-01-2009), phillyb (02-26-2009), Phoenix Speed3 (07-12-2011), Qwik6 (05-04-2009), RayRayBauder (07-07-2009), SharkDiver (03-25-2009), skeeter149 (04-01-2009), SparkySparks (01-16-2014), spike589 (03-23-2010), stitchyad (04-24-2010), tbot (02-17-2010), toprock (12-17-2009), Twofer (03-15-2013), WAHBAM (06-09-2012), wolly6973 (01-17-2012), y2kc0wb0y (04-02-2009)
 Old 02-26-2009, 03:32 PM   #2
Alittle Faster
bioevolve's Avatar
Posts: 3,522   (View Stats)
bioevolve is the leader of the worldbioevolve is the leader of the worldbioevolve is the leader of the worldbioevolve is the leader of the worldbioevolve is the leader of the worldbioevolve is the leader of the worldbioevolve is the leader of the worldbioevolve is the leader of the worldbioevolve is the leader of the worldbioevolve is the leader of the worldbioevolve is the leader of the world
Great write up!
I''m guessing you didn't have to put that plastic oil feeder/router back in?
bioevolve is offline   Reply With Quote
The Following User Says Thank You to bioevolve For This Useful Post:
danesti (02-26-2009)
 Old 02-26-2009, 03:33 PM   #3
danesti's Avatar
Groans: 137
Originally Posted by bioevolve View Post
Great write up!
no idea...
i put it back in because the way the baffle was designed it fit in there just right with a cut out for it, so i figured i should.
2008 STi
Intake
Turboback
AP
The Following User Says Thank You to danesti For This Useful Post:
 Old 02-26-2009, 03:34 PM   #4
phillyb's Avatar
Posts: 14,702   (View Stats)
Groans: 1,940
DOPE. thanks dane
 Old 02-26-2009, 06:04 PM   #5
TopazM3's Avatar
Posts: 87   (View Stats)
TopazM3 is just really niceTopazM3 is just really niceTopazM3 is just really niceTopazM3 is just really niceTopazM3 is just really nice
Great write up. Thanks for your effort!
TopazM3 is offline   Reply With Quote
The Following User Says Thank You to TopazM3 For This Useful Post:
 Old 02-26-2009, 07:01 PM   #6
MadOzodi's Avatar
Posts: 686   (View Stats)
Mother Hampster! I had no idea the BS assembly blocked that wide of an area. Nice write-up and thanks for taking a pic showing the assembly still attached.
07 COSMIC BLUE MS3 GT
MadOzodi is offline   Reply With Quote
The Following User Says Thank You to MadOzodi For This Useful Post:
 Old 02-27-2009, 02:43 PM   #7
SLS MS3's Avatar
Posts: 1,254   (View Stats)
SLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the world
Great write up!
I hope you aren't talking about the oil pickup tube. If so, it's kind of important. Not sure how long the engine would run without it.
2007 Sunlight Silver MS3
Graphite RX8 Rims · 235/40R18 Kumho SPTs
BC Coilovers · Cobb Swaybars · DBA 4000 Slotted Rotors · Technafit SS Brake Lines · SU Rear MM · TRZ Trans Mount · TopSpeed Passenger MM
Cobb AP · MS CAI w/ AEM Straightener · Cobb Turbo Inlet · Cobb FMIC · Black HKS SSQV (recirc) · PG Exhaust Manifold · Corksport Downpipe · Vibrant Exhaust
mrlilguy CDFP · Denso ITV22s plugs · Cobb STS, Shift Knob, & Shifter Weight · F2 Balance Shaft Delete & Oil Baffle
Stock is just plain, gay.
SLS MS3 is offline   Reply With Quote
The Following 3 Users Say Thank You to SLS MS3 For This Useful Post:
danesti (02-27-2009), kaelin (08-13-2018), rigor (02-11-2011)
 Old 02-27-2009, 09:09 PM   #8
babcockxmx's Avatar
Posts: 539   (View Stats)
babcockxmx is the leader of the worldbabcockxmx is the leader of the worldbabcockxmx is the leader of the worldbabcockxmx is the leader of the worldbabcockxmx is the leader of the worldbabcockxmx is the leader of the worldbabcockxmx is the leader of the worldbabcockxmx is the leader of the worldbabcockxmx is the leader of the worldbabcockxmx is the leader of the worldbabcockxmx is the leader of the world
mmmm beer
stella ftw
2007 BM MS3
babcockxmx is offline   Reply With Quote
The Following User Says Thank You to babcockxmx For This Useful Post:
 Old 02-27-2009, 10:29 PM   #9
Driverman5777's Avatar
Posts: 685   (View Stats)
Driverman5777 is the leader of the worldDriverman5777 is the leader of the worldDriverman5777 is the leader of the worldDriverman5777 is the leader of the worldDriverman5777 is the leader of the worldDriverman5777 is the leader of the worldDriverman5777 is the leader of the worldDriverman5777 is the leader of the worldDriverman5777 is the leader of the worldDriverman5777 is the leader of the worldDriverman5777 is the leader of the world
Groans: 76
thanks a lot dane!!! I had no idea that thing was that big. So did mazda only put that in there to reduce vibration?
Driverman5777 is offline   Reply With Quote
 Old 02-27-2009, 10:36 PM   #10
danesti's Avatar
Groans: 137
from what i understand that was the reason for it...
seems like a bit much to me
2008 STi
Intake
Turboback
AP
Driverman5777 (02-27-2009)
 Old 03-09-2009, 09:04 PM   #11
dubi0us's Avatar
Posts: 30   (View Stats)
dubi0us is a jewel in the roughdubi0us is a jewel in the roughdubi0us is a jewel in the rough
Jeezus did you have to re-adjust the ride height in the front after pulling that monster! Way to not fall prey to that money-costing "as long as we've got it apart" monster.
dubi0us is offline   Reply With Quote
The Following User Says Thank You to dubi0us For This Useful Post:
danesti (03-09-2009)
 Old 03-09-2009, 09:28 PM   #12
dadasracecar's Avatar
Posts: 741   (View Stats)
dadasracecar is the leader of the worlddadasracecar is the leader of the worlddadasracecar is the leader of the worlddadasracecar is the leader of the worlddadasracecar is the leader of the worlddadasracecar is the leader of the worlddadasracecar is the leader of the worlddadasracecar is the leader of the worlddadasracecar is the leader of the worlddadasracecar is the leader of the worlddadasracecar is the leader of the world
Great write-up. I wholeheartedly recommend this mod. I sort of wish I had my ms6 just so I could do it.
2008 BMW 335i 6MT black on black
www.p3performance.net
dadasracecar is offline   Reply With Quote
The Following User Says Thank You to dadasracecar For This Useful Post:
 Old 03-09-2009, 09:30 PM   #13
danesti's Avatar
Groans: 137
ill trade you for the 335 dada...
let me know..
haha
2008 STi
Intake
Turboback
AP
triple_threat (02-02-2011)
 Old 04-01-2009, 10:39 AM   #14
Speed6 Guy's Avatar
Posts: 59   (View Stats)
Speed6 Guy is the leader of the worldSpeed6 Guy is the leader of the worldSpeed6 Guy is the leader of the worldSpeed6 Guy is the leader of the worldSpeed6 Guy is the leader of the worldSpeed6 Guy is the leader of the worldSpeed6 Guy is the leader of the worldSpeed6 Guy is the leader of the worldSpeed6 Guy is the leader of the worldSpeed6 Guy is the leader of the worldSpeed6 Guy is the leader of the world
Please post the info on where I can get the kit. Great write up.
Blackcherry Mazdaspeed6 06'
Speed6 Guy is offline   Reply With Quote
The Following User Says Thank You to Speed6 Guy For This Useful Post:
danesti (04-02-2009)
 Old 04-02-2009, 12:48 AM   #15
danesti's Avatar
Groans: 137
pretty sure you can order one through jeff at PG, PTP has a windage tray and balance shaft delete...
PM wassup61 i think is the S/N for jeff. see what he can do..
also ordering through f2USA is probably possible too...
2008 STi
Intake
Turboback
AP
 Old 04-02-2009, 10:26 AM   #16
dallasms3gt's Avatar
Posts: 665   (View Stats)
dallasms3gt has a reputation beyond reputedallasms3gt has a reputation beyond reputedallasms3gt has a reputation beyond reputedallasms3gt has a reputation beyond reputedallasms3gt has a reputation beyond reputedallasms3gt has a reputation beyond reputedallasms3gt has a reputation beyond reputedallasms3gt has a reputation beyond reputedallasms3gt has a reputation beyond reputedallasms3gt has a reputation beyond reputedallasms3gt has a reputation beyond repute
Very Nice Writeup Dane... WTF is that freaking shit???
Looks like the Gawwdaaam Lockness Monstah... Did it ask you for Tree Fitty??
CPE-SRI - HKS-SSQV - CPE-MM - TWM SB - Cobb AP
Cobb FMIC - Cobb CBE - DP
18x8 +48 HP Design 235/40/18 BFG Riken, H&R Springs
dallasms3gt is offline   Reply With Quote
 Old 04-02-2009, 10:48 AM   #17
danesti's Avatar
Groans: 137
i already gave him my damn tree fiddy... haha
2008 STi
Intake
Turboback
AP
dallasms3gt (04-02-2009)
 Old 04-02-2009, 12:15 PM   #18
HA....
So, is this pretty much the same procedure for the MS3?
 Old 04-02-2009, 12:16 PM   #19
danesti's Avatar
Groans: 137
yup... Phillyb and i did his not too long ago
2008 STi
Intake
Turboback
AP
phillyb (04-02-2009)
 Old 04-02-2009, 02:10 PM   #20
Thanks, I am going to tackle this soon...
 Old 04-02-2009, 02:31 PM   #21
phillyb's Avatar
Groans: 1,940
same shit. mad straightforward uninstall and install
 Old 04-11-2009, 09:05 AM   #22
dagmz6s's Avatar
Posts: 17   (View Stats)
dagmz6s will become famous soon enoughdagmz6s will become famous soon enough
This actually looks easier than I thought it was. Great writeup, will be doing it soon.
dagmz6s is offline   Reply With Quote
The Following User Says Thank You to dagmz6s For This Useful Post:
danesti (04-11-2009)
 Old 04-11-2009, 04:12 PM   #23
danesti's Avatar
Groans: 137
^^^ DO IT!!!!
if you know righty tighty/ lefty loosey,
and how to change oil thats all there is too it
i recommend doing it soon!!!
2008 STi
Intake
Turboback
AP
 Old 04-11-2009, 04:22 PM   #24
Fuck sushi rolls
rodrigo's Avatar
Posts: 18,719   (View Stats)
Groans: 356
looks good, only one question dane. You say that as you are unbolting the balance assembly to have a friend hold your shaft?? is that waht the beer is for? to get the other guy in the mood?
p057 likes this.
The Following 5 Users Say Thank You to rodrigo For This Useful Post:
Flaverre (04-09-2011), OMGWTFHAX (01-15-2010), p057 (12-29-2011), phillyb (04-24-2009), rigor (02-11-2011)
 Old 04-11-2009, 05:03 PM   #25
danesti's Avatar
Groans: 137
not required, but recommended..
like the first time YOU got another guy in the mood, would have been much easier with lube, know what i mean? :phillyb:
get what im saying???
2008 STi
Intake
Turboback
AP
 Old 04-11-2009, 05:04 PM   #26
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
oh, but i do.
 Old 04-11-2009, 09:00 PM   #27
babcockxmx's Avatar
i had to use tweezers to hold danes shaft though with is hard when ur drunk
2007 BM MS3
 Old 04-11-2009, 09:15 PM   #28
danesti's Avatar
Groans: 137
at least you asked me to cum on your face...
made it a little better for me...
cant believe you asked for it. lol fag
2008 STi
Intake
Turboback
AP
 Old 04-24-2009, 04:28 PM   #29
MSF Punished Member
BlackMS6BTO's Avatar
Posts: 6   (View Stats)
BlackMS6BTO will become famous soon enoughBlackMS6BTO will become famous soon enough
very nice write up .. ill be doing that mod later this summer
BlackMS6BTO is offline   Reply With Quote
The Following User Says Thank You to BlackMS6BTO For This Useful Post:
danesti (04-24-2009)
 Old 04-24-2009, 05:09 PM   #30
mike8748's Avatar
Posts: 396   (View Stats)
mike8748 is the leader of the worldmike8748 is the leader of the worldmike8748 is the leader of the worldmike8748 is the leader of the worldmike8748 is the leader of the worldmike8748 is the leader of the worldmike8748 is the leader of the worldmike8748 is the leader of the worldmike8748 is the leader of the worldmike8748 is the leader of the worldmike8748 is the leader of the world
Done! Thanks for the great write up w/ pics.
I did the Oil filter conversion at the same time.
After everything was back in.... 8 qts!
07'MazdaSpeed3 Stage2+SF 93 FMIC Custom Map
Current Mods: COBB AP, COBB SRI, COBB Inlet, COBB Cold Air Box, COBB Shift Weight, COBB STS, COBB PCV Catch Can, COBB Rear Sway Bar, M3M FMIC, TWM Shifter Bushings, FORGE BPV, Nator Rear MM, TurboXS DP, TurboXS RP, TB BYPASS MOD, MSD Dash Hawk, Denso 2-Step Colder plugs, Eibach Springs, BSD, KMD ver2 internals, EGR delete, PTP intake cooler kit, CNT Racing CBE, PG Exhaust Manifold
mike8748 is offline   Reply With Quote
The Following 2 Users Say Thank You to mike8748 For This Useful Post:
danesti (04-24-2009), phillyb (04-24-2009)
 Old 04-24-2009, 05:21 PM   #31
phillyb's Avatar
Groans: 1,940
d00000d, i need spin on conversion
 Old 04-24-2009, 09:52 PM   #32
danesti's Avatar
Groans: 137
im sensing a phillyb visit soon with spin on and bowls :phillyb:
bring a girlfriend this time too damn it.
2008 STi
Intake
Turboback
AP
phillyb (04-25-2009)
 Old 04-25-2009, 06:08 PM   #33
phillyb's Avatar
Groans: 1,940
lol, so she can just wander around your house
danesti (04-25-2009)
 Old 05-02-2009, 02:20 PM   #34
Qwik6's Avatar
Posts: 695   (View Stats)
Qwik6 is the leader of the worldQwik6 is the leader of the worldQwik6 is the leader of the worldQwik6 is the leader of the worldQwik6 is the leader of the worldQwik6 is the leader of the worldQwik6 is the leader of the worldQwik6 is the leader of the worldQwik6 is the leader of the worldQwik6 is the leader of the worldQwik6 is the leader of the world
Thanx for the how-to! Im doing mine now as we speak.
2006 MAZDASPEED6
FREEKTUNED @ 20PSI // COBB AP V3 // CPE TMIC // COBB SF // PG TIH // DENSO ITV22s // AUTOTECH INTERNALS // SURE TP // MAGNAFLOW CATBACK // JBR OCC // JBR IM SPACER // JBR PASSENGER & TRANNY MOUNT // SURE RMM // H&R SPRINGS // XXR 530 18X8.75 +35 // CAR LED TAILS // CPE REAR DIF MOUNT // TURBINE TECH FRONT DIF MOUNT // CPE TOW HOOK // 35% TINT // 3M DINOC WRAPPED ROOF // AUTOEXE CARBON FIBER BADGELESS GRILL
Qwik6 is offline   Reply With Quote
 Old 05-02-2009, 10:47 PM   #35
Qwik6's Avatar
Alright. Finished the bsd, kinda... When I was torqueing the bolts on the oil pan one of the last bolts broke. Thank god we heard the snap and backed it out easy. Once the bolt was out it snapped in half. So the car sits on jackstands for the time being since no1 sells these bolts! It was the skinny bolt on the bottom towards the transmission. I misread the instructions from another site that said to torque the bolts the 35 ft. lbs. Come to fine out they are supposed to be 15.
Anywho got the balance shaft out and capped with ptp's bsd kit. Also cleaned the oil pan up and put on ptp's windage tray. Will be posting pics later. Also on the balance shaft I noticed there was discoloration like some have mentioned. Dane's looks brand new in that 3rd to last pic. On mine the rod pieces were blue. Im assuming over heating. Also the teeth on the balance shaft were showing signs of wear. There were small chips comming off the top of the teeth on the gears. Good thing I just got this thing off.
2006 MAZDASPEED6
The Following 2 Users Say Thank You to Qwik6 For This Useful Post:
danesti (05-03-2009), dougefresh_ (04-08-2011)
 Old 05-03-2009, 10:59 AM   #36
danesti's Avatar
Groans: 137
my car only had about 20k on it i think.
i dont know how many miles phillyb had when we did his but i think it looked similar to mine.
interested in windage tray pics..
they have a cut out for the oil feed tube?
2008 STi
Intake
Turboback
AP
 Old 05-03-2009, 06:10 PM   #37
Qwik6's Avatar
Looks like this.
Windage tray
2006 MAZDASPEED6
danesti (05-03-2009), rodger14s (05-09-2016)
 Old 05-03-2009, 07:21 PM   #38
phillyb's Avatar
Groans: 1,940
dane, about 30k on my car.
i just did this to morris's car too, idk how many miles on his. he also had the ptp windage tray. pics look good quik6
 Old 05-04-2009, 12:01 AM   #39
phillyb's Avatar
Groans: 1,940
for those of you that clean out the pan, what do you use?
 Old 05-04-2009, 04:07 PM   #40
Qwik6's Avatar
I used carb and choke cleaner. Then rinsed with water.
2006 MAZDASPEED6
The Following User Says Thank You to Qwik6 For This Useful Post:
phillyb (05-04-2009)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f111/how-balance-shaft-delete-22203/
Any known issues with oil pans? : mazda3 This thread Refback 08-14-2014 07:29 AM
BSD ? Mazda MPS Owners Club This thread Refback 11-08-2013 09:28 AM
What You Need to Know to Build a Motor | SpeedForums.org This thread Refback 02-02-2013 05:59 AM
Ölfüllmenge des L3-Turbomotors (2.3l DISI Turbo) - Seite 11 This thread Refback 12-20-2012 12:49 PM
lfllmenge des L3-Turbomotors (2.3l DISI Turbo) - Seite 11 This thread Refback 07-23-2012 06:56 AM
Mazda MPS Owners Club • View topic - BSD This thread Refback 02-27-2012 05:10 PM
How To TOP MOUNT TURBO SET UP! Easy, Breezy, Beautiful MS6 only because Race Car | SpeedForums.org This thread Refback 12-12-2011 10:27 PM
Mazda MPS Owners Club • View topic - BSD This thread Refback 07-28-2011 11:45 PM
How to: Top mount turbo set up!! - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Refback 07-21-2011 10:03 AM
HOW TO: Top Mount Turbo Set Up This thread Refback 07-07-2011 07:19 PM
lfllmenge des L3-Turbomotors (2.3l DISI Turbo) This thread Refback 01-08-2011 11:17 AM
Mazda MPS Owners Club • View topic - BSD This thread Refback 07-05-2010 01:01 PM
Untitled document This thread Refback 06-21-2010 11:59 AM
Balance Shaft Delete? yes or no - MN Mazda Forums This thread Refback 04-02-2009 09:31 AM
Gainesville, FL - Page 11 - StreetUnitForum.com This thread Refback 03-07-2009 05:24 AM
Cosworth balance shaft delete/F2 oil pan baffle installed whoosh@Realtune MazdaSpeed 3 - Engine, Transmission & Driveline 41 02-21-2011 11:08 PM
F2 oil sump baffel and balance shaft delete... ATE BALLER Hot Deals Section 7 08-29-2009 01:28 PM
F2 Balance Shaft Delete Kit & Oil Sump Baffle Kit, UPDATE WITH PROMO CODE - Package deal through F2 sbspeed MazdaSpeed 3 - Engine, Transmission & Driveline 2 07-08-2008 10:15 PM
Page generated in 0.56685 seconds with 36 queries
