> MazdaSpeed 6 - How-To's
 Old 12-21-2013, 03:37 PM   #1
ciezczak1's Avatar
Posts: 416   (View Stats)
ciezczak1 is the leader of the worldciezczak1 is the leader of the worldciezczak1 is the leader of the worldciezczak1 is the leader of the worldciezczak1 is the leader of the worldciezczak1 is the leader of the worldciezczak1 is the leader of the worldciezczak1 is the leader of the worldciezczak1 is the leader of the worldciezczak1 is the leader of the worldciezczak1 is the leader of the world
Default How to Change Your Shifter Cable
hey guys this is long overdue been busy with stuff and finally have time to make a thread on this.
First off disconnect your battery
then remove your battery and intake
pop off the cables
this is right by the turbo
then you go inside and start removing the center console and radio
if you need help in this part i can get pics on that too
after that just pop off the cables same way you did before
Next pull the carpet back so you got room to work with and unplug the box and there are three bolts holding it down one on the drivers side and two on passenger
you also gotta shift the plugs and the vents going to the rear so you can maneuver the plate out
if you want you can cut a patch out off the plate or attempt to move it aside your choice
I couldn't get the pics of where the bolts are but if you get a descent sized 10mm wrench you could loosen the nuts and back them by hand barely and torque on them
at this part you should probably have a friend help you here pushing the cables through find the way you do best and not crack the hvac case and have a huge hole lol (my mistake)
after you get it out get yourself a beer the hard part is over and the easy part begins
then just do everything in reverse order and done!
Cheapspeed likes this.
GT3076/ catless dp/ FMIC/ 3.5" CP-E Intake/ 3" Exhaust/autotech internals/ built block/ 3-port/denso itv22/ 6th-port
ciezczak1 is offline   Reply With Quote
The Following 15 Users Say Thank You to ciezczak1 For This Useful Post:
6Y MAZDA (02-13-2014), AzS13 (09-18-2016), Badlstar75 (08-06-2014), Bleupit80 (01-12-2014), Cheapspeed (12-22-2013), Code Monkey (12-22-2013), Enki (12-09-2015), Fail_6 (02-08-2014), jm211 (12-22-2013), Micha (02-11-2014), Nliiitend1 (12-22-2013), nybe0010 (12-11-2014), Playaj (12-21-2013), Raider (08-06-2014), WetzMS3 (12-27-2013)
 Old 12-22-2013, 07:23 AM   #2
jm211's Avatar
Posts: 943   (View Stats)
Awesome, happy to see we can avoid gutting the interior.
Much appreciated.
The Following 2 Users Say Thank You to jm211 For This Useful Post:
Badlstar75 (08-06-2014), ciezczak1 (12-24-2013)
 Old 12-22-2013, 08:41 AM   #3
Cheapspeed's Avatar
Posts: 4,481   (View Stats)
Are those stock shifter cables?
I have a TWM full replacement and I'm wondering if I should pick up some shorter cables because right now it forces the stock cables down to the floor, so they're curved. I've heard about people having kinked cables because of this.
 Old 12-22-2013, 10:57 AM   #4
ciezczak1's Avatar
yeah they are stock not sure the speed6 has aftermarket cables for you swapping them should take the most 3 hours bc you got speed3
 Old 12-27-2013, 07:17 AM   #5
DVM17's Avatar
Posts: 1,283   (View Stats)
I know I'm late on this one, but that's awesome that you did that without (like mentioned above) gutting the entire dash.
How much did you get the new shifter cables for and where? If you don't mind. I've been needing some and I think I found the right part, but it's about $260. Just wanted to double check @ciezczak1;
12.07 @ 116 on 205 snow tires
hunting for 11's on 245's
 Old 12-27-2013, 08:10 AM   #6
jm211's Avatar
Sounds about right for price, unless used.
Also, for the dude above, @Cheapspeed; no aftermarket is available.
The Following 3 Users Say Thank You to jm211 For This Useful Post:
Cheapspeed (12-27-2013), ciezczak1 (12-27-2013), DVM17 (12-27-2013)
 Old 12-27-2013, 09:04 AM   #7
ciezczak1's Avatar
Yeah i got mine for 290 free shipping from onlinemazdaparts.com other places were cheaper but charged an arm and leg for shipping
Sent from my SGH-T989 using Tapatalk 2
The Following User Says Thank You to ciezczak1 For This Useful Post:
DVM17 (12-27-2013)
 Old 12-27-2013, 09:05 AM   #8
DVM17's Avatar
Awesome, thanks guys.
Last edited by DVM17; 12-27-2013 at 09:06 AM. Reason: MSF Database - Automerged Doublepost
jm211 (12-27-2013)
 Old 01-12-2014, 01:13 PM   #9
Bleupit80's Avatar
Posts: 62   (View Stats)
Bleupit80 has much to be proud ofBleupit80 has much to be proud ofBleupit80 has much to be proud ofBleupit80 has much to be proud ofBleupit80 has much to be proud ofBleupit80 has much to be proud ofBleupit80 has much to be proud ofBleupit80 has much to be proud ofBleupit80 has much to be proud of
This is exactly how I changed mine about a year ago. I kept reading that you had to take the entire dash apart and I was determined that I wasn't going to do that. And I didn't.
2006 Whitewater Pearl Mazdaspeed 6 GT #355
FJ BUILT LONG BLOCK
BNR S4
JBR TRU 3"
SURE BOOST TUBES
JBR SSP
JBR CHROME MOLLY RMM
COBB AP
AUTOTECH HPFP INTERNALS
EBAY DP
3.5 BAR
PURPLE DRANK TUNED
WAITING TO BE INSTALLED
PROSPORT EVO BOOST GAUGE
TR1035 w/ CXRACING PIPING
JMF INTAKE
AWR PASSENGER MOTOR MOUNT
AWR TRANSMISSION MOUNT
Bleupit80 is offline   Reply With Quote
The Following 2 Users Say Thank You to Bleupit80 For This Useful Post:
ciezczak1 (01-12-2014), DVM17 (01-12-2014)
 Old 01-12-2014, 01:46 PM   #10
ciezczak1's Avatar
Haha same I said fuck that if rather drive on a broken shifter cable
 Old 01-12-2014, 07:13 PM   #11
Bleupit80's Avatar
I actually rigged mine with zip ties and drove like that for about 3 months...lol. My cable wasn't snapped I just broke the plastic sleeve under the rubber boot by the end of the cable because I installed the JBR SSP and didn't put in the spacers that go under the bracket...lol.
FJ BUILT LONG BLOCK
BNR S4
JBR TRU 3"
SURE BOOST TUBES
JBR SSP
COBB AP
EBAY DP
3.5 BAR
PURPLE DRANK TUNED
JMF INTAKE
The Following User Says Thank You to Bleupit80 For This Useful Post:
6Y MAZDA (01-19-2014)
 Old 01-27-2014, 05:24 PM   #12
bislag's Avatar
Posts: 395   (View Stats)
bislag is the leader of the worldbislag is the leader of the worldbislag is the leader of the worldbislag is the leader of the worldbislag is the leader of the worldbislag is the leader of the worldbislag is the leader of the worldbislag is the leader of the worldbislag is the leader of the worldbislag is the leader of the worldbislag is the leader of the world
Just did the shift cables over the weekend. A few notes that people doing this in the future might find handy:
  • Have a buddy help out. It can be done alone, but don't do it that way unless you must.
  • Be aggressive as hell when cutting back that rubber and insulation that is covering the shifter cable's mounting point. If you think you have enough to get to the nuts, remove more. I was able to get a ratcheting wrench on both the nuts without too much issue after doing so.
Thanks to @ciezczak1; for answering the questions I had, including a particularly stupid one about a clip. Big thanks to @Ryguy; for coming by to help despite his desire to burn my car to the ground.
bislag is offline   Reply With Quote
The Following 3 Users Say Thank You to bislag For This Useful Post:
ciezczak1 (01-27-2014), DVM17 (01-27-2014), Ryguy (01-27-2014)
 Old 02-08-2014, 06:53 PM   #13
weakdog85's Avatar
Posts: 493   (View Stats)
weakdog85 is the leader of the worldweakdog85 is the leader of the worldweakdog85 is the leader of the worldweakdog85 is the leader of the worldweakdog85 is the leader of the worldweakdog85 is the leader of the worldweakdog85 is the leader of the worldweakdog85 is the leader of the worldweakdog85 is the leader of the worldweakdog85 is the leader of the worldweakdog85 is the leader of the world
i'm so glad this write up was done. i'll be attempting this soon. my zip ties are only holding a couple months at a time.
07 MS6 Sport.............
JBR Shifter Bushings * JBR RMM * JBR PMM * SURE SRI * VG Sharkfin Antenna * 20% Tint * Cobb AP * Grimmspeed EBCS * Coolant Bypass * PG TIP * Autotech Internals *
weakdog85 is offline   Reply With Quote
The Following User Says Thank You to weakdog85 For This Useful Post:
ciezczak1 (02-08-2014)
 Old 02-09-2014, 12:07 PM   #14
Fail_6's Avatar
Posts: 2,305   (View Stats)
Fail_6 is the leader of the worldFail_6 is the leader of the worldFail_6 is the leader of the worldFail_6 is the leader of the worldFail_6 is the leader of the worldFail_6 is the leader of the worldFail_6 is the leader of the worldFail_6 is the leader of the worldFail_6 is the leader of the worldFail_6 is the leader of the worldFail_6 is the leader of the world
Very good write up, indeed I did end up using your method. With a machine shop and 30 hands at your disposal, it really is quite easy.
Only thing missing was pictures of the actual area you're working, the nuts and what not, which I have below.
Start to finish, first pic is the actual plate on the cables held down by the 2 10 mm nuts, next a close up of the plate, next the nuts themselves, next sliding them out, next the opening left when they're out and finally using the pry bar to get the new ones in.
Couple necessary tools, 10 mm racketing wrench, powerful magnet (for when you drop the nuts trying to put them back on lol), a pry bar to create space and a shit load of patience. Also, be careful with the airbag module (3 yellow plugs and gray box), and I opted to remove the metal clip on the rubber "holster" for the cables, it's easier sliding them in 1 at a time vs both thru the tiny ass opening.
Working diligently, this can be accomplished in a little over 1 hr 30 mins, no dash removal necessary, only the center console.
@ciezczak1; Thank you again for the blueprint!
2006 Black Mica MS6 GT
FreekBuilt Longblock, Manley 9.5:1, Manley H Beams, BW S300SX 6268 1.00 A/R, Dual Tial 38mm MVR EWG, Twinscroll Tubular Top Mount, EGR Delete, Labontes Stage 2 Meth Kit w/ D10, Grimmspeed 3 port EBCS, 3 Bar Map Sensor w/ Matt Jackson Harness, PERM 4" Intake, Cp-E HPFP, CX Racing FMIC, HKS SSQV V3, NGK IX 6510's, Toyota Injector Seals, PERM Catless 3" Turboback w/ dual Magnaflow Magnapaks, PERM Top Mount Valve Cover, PNP Intake Mani, BSD, ACT ZX4-HDG6, Bilstein HD Shocks, H & R Springs, Stoptech Slotted Rotors w/ API Ceramic Pads, JBR Heavy Shift Knob
Stock motor w/ GT2871r:
380 awhp, 375 awtq @ 24 psi (e85 only)
- 13.1 @ 110, 2.1 60 ft
Fail_6 is offline   Reply With Quote
The Following 6 Users Say Thank You to Fail_6 For This Useful Post:
AzS13 (09-18-2016), brandonnicholson (02-13-2014), derp_ms6 (12-27-2015), DVM17 (02-13-2014), Micha (02-11-2014), weakdog85 (02-09-2014)
 Old 02-13-2014, 03:53 PM   #15
spd-demon's Avatar
Posts: 12   (View Stats)
spd-demon is on a distinguished road
I'm changing mine out right now...good right up.
spd-demon is offline   Reply With Quote
 Old 02-13-2014, 05:13 PM   #16
weakdog85's Avatar
Let us know how it goes an add any advice you may have
"Tap tap tap it in"
Fail_6 (02-14-2014)
 Old 02-13-2014, 05:24 PM   #17
ciezczak1's Avatar
If you have any questions pm me and ill get back to asap
 Old 02-13-2014, 09:22 PM   #18
spd-demon's Avatar
Well...I got the shift cables changed out with the help of a buddy of mine. ciezczak1 thanks for the how to. It helped me out greatly.
 Old 02-13-2014, 09:23 PM   #19
weakdog85's Avatar
So about 4 hours or so?
"Tap tap tap it in"
 Old 02-13-2014, 09:26 PM   #20
spd-demon's Avatar
Now on to changing out the rear diff mounts.
Would of been done sooner but I took my time. I wasn't in any rush.
Last edited by spd-demon; 02-13-2014 at 09:26 PM. Reason: MSF Database - Automerged Doublepost
 Old 02-13-2014, 09:27 PM   #21
weakdog85's Avatar
Well that is very good to know
"Tap tap tap it in"
 Old 02-17-2014, 09:53 PM   #22
N!NJA's Avatar
Posts: 418   (View Stats)
N!NJA has a reputation beyond reputeN!NJA has a reputation beyond reputeN!NJA has a reputation beyond reputeN!NJA has a reputation beyond reputeN!NJA has a reputation beyond reputeN!NJA has a reputation beyond reputeN!NJA has a reputation beyond reputeN!NJA has a reputation beyond reputeN!NJA has a reputation beyond reputeN!NJA has a reputation beyond reputeN!NJA has a reputation beyond repute
Omfg I payed a shop to do this last year cost me an ass load of money. If I knew that I could have done it like this would have saved that money for go-fast shit. A+ Sr like u said long needed how-to.
N!NJA is offline   Reply With Quote
 Old 02-28-2014, 10:21 PM   #23
weakdog85's Avatar
And Done!! Well that was not a fun job at all. Getting the cables out wasn't too bad. It was getting the plate back over the studs. then trying to get the nuts back on the studs that was the bitch. With the sharp plastic pieces hanging down i cut both hands all to shit.
My only advice for this job would be when trying to get the nuts back on, use an extension magnet, have one person hold the nut over the stud with the magnet and the other screw the nut back on.
another bit of advice, don't ever break one of the white pieces that go inside the ends of the cables that go over the ball. we spent another hour breaking out one off the old cables and shaving it down to fit in the new cables. The mechanism is pressed together and glued so there is no taking it apart easily.
this how to definitely saved us a lot of time though not having to tear the dash apart.
 Old 03-01-2014, 04:13 PM   #24
DVM17's Avatar
Doing this now.... have the center console and head unit off. Have the cables disconnected from the transmission and from the shifter as well as the rubber grommet by the turbo and I'm stuck on the stupid bracket. Can't even see it. Do you need to just put a wrench up there and hope it gets on the nut? Lol.
 Old 03-02-2014, 09:17 AM   #25
ciezczak1's Avatar
Pretty much lol but you should see it if you found the plate
Sent from my SGH-T999 using Tapatalk
DVM17 (03-04-2014)
 Old 03-02-2014, 02:21 PM   #26
weakdog85's Avatar
If you clear enough sound deadening and carpet you should be able to see the driver side nut easily. Passenger side is more of a feel around game
"Tap tap tap it in"
DVM17 (03-04-2014)
 Old 03-07-2014, 08:45 AM   #27
DVM17's Avatar
Thanks for the insight of this thread guys! Got it all buttoned up last night and I couldn't be happier.
ALL of my previous issues that I assumed was the shifter cage, was actually the shifter cable. So now it's crisp and notchy. didn't take the dash out, just cut back a lot of the insulation as suggested and got the stupid bracket on the studs. (took forever)
but now at least I have really good shifts. Coupled with my twm STS and jbr ssp, it's amazing.
Thanks Again!
 Old 05-10-2014, 03:31 PM   #28
Stealthvr4's Avatar
Posts: 84   (View Stats)
Stealthvr4 is a name known to allStealthvr4 is a name known to allStealthvr4 is a name known to allStealthvr4 is a name known to allStealthvr4 is a name known to allStealthvr4 is a name known to all
Thanks for this....I need this done asap and didn't want to remove the dash lol
Stealthvr4 is offline   Reply With Quote
The Following User Says Thank You to Stealthvr4 For This Useful Post:
ciezczak1 (05-10-2014)
 Old 05-10-2014, 10:12 PM   #29
N!NJA's Avatar
You are lucky to have this thread I need up paying for mine
SENT FROM THE DEATH STAR
 Old 05-10-2014, 10:16 PM   #30
ciezczak1's Avatar
I'd help install it if close or bring it to my house
 Old 05-11-2014, 12:40 AM   #31
N!NJA's Avatar
Ended* this was a year ago
 Old 05-15-2014, 04:51 PM   #32
Stealthvr4's Avatar
My shifter cable broke in the same spot I used 4 zip ties to hold it together for a longterm quick fix lol feels great
Bleupit80 (05-16-2014)
 Old 05-17-2014, 12:44 AM   #33
N!NJA's Avatar
It's going to break theirs no long term fix for this other than just doing it
 Old 07-17-2014, 10:32 AM   #34
GingerSpeed's Avatar
Posts: 87   (View Stats)
GingerSpeed has a brilliant futureGingerSpeed has a brilliant futureGingerSpeed has a brilliant futureGingerSpeed has a brilliant futureGingerSpeed has a brilliant futureGingerSpeed has a brilliant futureGingerSpeed has a brilliant futureGingerSpeed has a brilliant futureGingerSpeed has a brilliant futureGingerSpeed has a brilliant futureGingerSpeed has a brilliant future
Groaned at 5 Times in 2 Posts
i've had to this twice and i got it done rather quick with some help but i wanted to know if a lot of people are having problems with theirs. I blame the JBR SSP i had because i owned the car for over two years before i even put that thing on and never had issues. Still love JBR though.
GingerSpeed is offline   Reply With Quote
 Old 07-22-2014, 01:31 PM   #35
ciezczak1's Avatar
Yeah my shifter cable broke bc of the jbr adjustable shift plate
sent from the s5
 Old 07-22-2014, 07:12 PM   #36
Bleupit80's Avatar
Mine broke because I DIDN'T install the two spacers that raise the brace with the JBR SSP. I swapped out my cable without taking the dash out and installed the spacers and haven't had a problem yet.
FJ BUILT LONG BLOCK
BNR S4
JBR TRU 3"
SURE BOOST TUBES
JBR SSP
COBB AP
EBAY DP
3.5 BAR
PURPLE DRANK TUNED
JMF INTAKE
ciezczak1 (07-23-2014)
 Old 08-06-2014, 07:59 AM   #37
Badlstar75's Avatar
Posts: 4   (View Stats)
Badlstar75 will become famous soon enoughBadlstar75 will become famous soon enough
Default Control Cable GP9A46500J
Just ordered the cable today, hope it gets here quick. Cost was $325.00/w shipping. Local dealers wanted $374.00 plus tax. Hope replacing it isn't to difficult
Badlstar75 is offline   Reply With Quote
 Old 08-06-2014, 10:28 AM   #38
weakdog85's Avatar
Well it will be. Just take your time and cut away as much sound deadening as possible
 Old 01-02-2016, 01:34 AM   #39
Di4bLo's Avatar
Di4bLo is an unknown quantity at this point
I have ordered my cables today. So are you pushing the cables from inside the car through the hole or pushing the cables from the engine inside the cabin?
Di4bLo is offline   Reply With Quote
 Old 01-02-2016, 04:02 AM   #40
Hargarbl's Avatar
Posts: 642   (View Stats)
Groans: 51
when removing the cables they come into the cabin. when installing, start in the cabin and push through. I highly recommend having at least a second set of hands under the hood to help guide the cables
The Following User Says Thank You to Hargarbl For This Useful Post:
Bleupit80 (01-10-2016)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f111/how-change-your-shifter-cable-161362/
MS6 shifter seized in neutral? - Page 2 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Refback 10-17-2015 05:29 PM
MS6 shifter seized in neutral? - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 10-16-2015 05:40 PM
adjusting Shifter Cable's Boo5ted MazdaSpeed 6 - Engine, Transmission & Driveline 1 10-02-2013 01:56 PM
Help please. Broken shifter cable? J'sSpeed3 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 8 09-05-2012 05:34 PM
Page generated in 0.58421 seconds with 35 queries
