> MazdaSpeed 6 - How-To's
Like Tree16Likes
 Old 01-10-2012, 06:45 AM   #1
bova's Avatar
Posts: 3,820   (View Stats)
Groans: 45
Neutral  :  +3 score
Default How To: Clutch Pedal Adjustment
Didn't see this how to anywhere so I'll post it up... I didn't write this, but I did have to insert all the pictures for it. Hope this helps anyone wanting to do this and hopefully I didn't overlook some thread that had all this.
Author: Super Car Tastes - Skoda Budget
Okay, took me a while but I got it together. As mentioned earlier I did the clutch adjustment today. It’s a huge improvement, and I made sure there wouldn’t be any issues with insufficient disengagement or re-engagement of the clutch. Also, I formulated a theory as to what’s causing the problems.
Make sure you fully read the instructions and study the pictures and diagrams to ensure you fully understand the process before starting.
Please note: I put these directions together based on my personal experiences. I am not a mechanic and do not have any professional certification. If you try this, you do so at your own risk and release me from any liability, damage, injury, etc. You assume all responsibility!
Here’s the How To, with some explanations and diagrams to avoid mis-adjusting the clutch:
Tools needed:
12mm crescent (open ended) wrench
Light source (I used a head mounted light to put light where I was looking and keep both hands free)
10mm crescent wrench for clutch cylinder actuator rod (not really needed and actually very difficult to use, but just in case you want to try)
Permanent marker such as Sharpie or Staedtler
Steps:
1. Turn off the engine!! Don’t do this while the car is running!! Obvious but you never know.
2. Move the driver’s seat all the way back to give you room to work.
3. Slide in head first on your back and get under the dashboard. Identify the clutch pedal arm stop bolt. It will look like this:
4. Mark the bolt with a dot or line at one side with the Sharpie. This will give you a reference point. When turning the bolt keep track of how many turns you did and you can easily reverse it back to original.
5. Identify the clutch cylinder piston actuator rod. It’s further up the clutch arm from the stop bolt and looks like this:
6. Mark one of the flats on the actuator rod as well. It’s tight in there so do what you can. As long as you can clearly identify your mark you’ll be able to keep track of it’s position. However, it’s not really critical to keep track of it as you’ll see later on.
7. While you’re down there, press the clutch pedal slightly while watching the actuator rod and piston (see diagram above). You should be able to feel and see some free play before the actuator rod actually starts to engage the piston. This is normal and necessary, as this means the clutch cylinder piston is fully released, ensuring the clutch is fully engaged.
8. If you want to keep the amount of free play the same, pay attention to how much it is now, so that you can duplicate it later after making the adjustments.
9. Use the 12mm wrench to loosen off both lock nuts (they’re both 12mm)
10. Push on the clutch pedal to take tension off the stop bolt and you should be able to turn it in. Turn it in (CW) about 2 full turns to start. My final adjustment was about 2.5 turns in. Refer back to the pic of the upper stop bolt.
11. Tighten up the lock nut to set the position of the bolt.
12. Now, check the position of the clutch cylinder actuation rod. You should find that it’s depressing the clutch cylinder piston in partly now. Back off the actuation rod by turning it (screw in towards the pedal). It’s still CW rotation if you’re looking at it from the firewall, but you’ll be upside down looking up from the floor, so experiment.
13. Adjust the rod until it’s clear off the piston, and there is a slight bit of freeplay (I set mine up with just a pubic hair of play).
14. Tighten up the locknut with the 12mm wrench. The rod will rotate a bit CW due to friction of the threads but this just increases the free play so it’s okay. Compensate for it by not rotating the actuator rod quite as far as you actually wanted to, so that when you tighten the lock nut it will rotate into the desired position.
15. Eyeball your handiwork, make sure the locknuts are tight, then take it for a drive. This is important – test and adjust, test and adjust. I went through 4 adjustment cycles until I was satisfied the clutch was disengaging and engaging properly while giving the best action. I was learning as I was going so it may only take you 2 or 3 cycles.
16. To test the adjustment. Stop on level ground and fully depress the clutch while in gear. Release the brake and see if there is any sense of the car creeping forward. If so, you’ve adjusted the pedal too far in, so that it’s not pushing the cylinder piston in far enough to fully disengage the clutch. This is not good, and you’ll know because when you change gears you’ll grind the syncros. I’m not sure this is actually possible with the amount of adjustment available, and I didn’t experience it myself because I advanced it cautiously, but you’ve been warned! If this happens, back out that stop bolt a bit!!
17. You shouldn’t have any problems with making sure the clutch is fully engaged if you make sure there is some free play between the actuator rod and the piston. Unfortunately there is no easy test for this, except for maybe clutch slippage under hard acceleration or going uphill. More probably the mis-adjustment will be minor and result in premature failure of the throw out bearing, but you don't want to find out! Again take this as a big warning!
18. Repeat the above steps until you’re satisfied with the feel of the clutch, while ensuring that it fully engages and disengages.
One more time: Make sure you adjust the actuator rod so that there is a bit of free play before engaging the piston to ensure the clutch fully engages!!
Here’s a diagram of the parts in rough relation to each other:
Note that the actuator rod is above the stop bolt and only connected to the pedal arm (not below and connected to the piston, as shown in a previous diagram – note: it was a valuable diagram and inspired me to do this, so even if it wasn’t quite correct it was still appreciated). BTW, I noticed that I put the fixing point for the spring to the car frame in the wrong spot to try to illustrate the possible spring action. Move it to the left of the pedal arm instead of to the right. Now, try visualizing what the body of the spring will do when the top of the pedal arm moves to the left. The body of the spring will "shift", introducing non-linearities.
Now, to my theory and possible clues to identify differences in clutches. Look at this following picture.
I’ve identified the big coil spring that is used to return the clutch pedal. It’s mounted to the top of the arm. The arm pivots below where the spring mounts (see diagram above). Note my spring has white paint on it. Painting springs is a standard way of identifying springs of different strengths.
I believe, from looking at the system, that the big coil spring plays a major role in the spring rate we feel at the clutch pedal. It’s an easy part to change during assembly and it’s possible Mazda did a running production change due to negative feedback.
It would be interesting to get everybody to take a look up at their spring to see what color it is. If there are different colors, then it means that different rates are being used, accounting for the differing experiences. After this has been posted for a while maybe I’ll start a survey to see what color spring everybody has.
Now, here’s my analysis and hypothesis of why the clutch feels the way it did (but not anymore on my car):
After looking at the spring/pedal arm/pivot and pushing on the pedal with my hand while watching the coil spring, I came to the conclusion that due to the way the whole system of spring, spring fixing points on frame and pedal arm interacts, part of the motion is non-linear. This is due to the fact that the body of the spring will actually shift as the clutch arm moves and tries to wind it up. If there was a rod through the body of the spring this would not happen and the spring would be linear and act purely as a torsion spring, but the shifting of the body introduces a hump in the spring tension, making it non-linear in a portion of the clutch pedal’s travel.
I put together three diagrams plotting spring tension vs clutch travel. This is just my guess and is based solely on conjecture. The spring rate curve is pure fabricaton based on my guess at what the spring rate might look like, but I hope it serves to convey what I’m talking about.
The first diagram shows what the stock settings look like. Note that the clutch engagement range is smack dab in the non-linear region of the curve, just where it ramps up quickly and then tapers off just as quickly.
The second diagrams show what it looks like after doing the adjustments described in the steps above. Note that by moving the pedal arm closer to the firewall it’s pushed the spring into the more linear region of it’s curve, and then readjusting the actuator rod to compensate moves the whole engagement range into the more linear part of the curve.
The third diagram is the one you must AVOID doing, where the stop bolt is moved in but the actuator rod has not been backed off to compensate. You’ve effectively and permanently set the clutch up as if you were “riding” it, or in other words, resting your foot on the pedal so that it’s partially depressing the pedal resulting in reduced clamping force on the clutch disc. DO NOT DO THIS!!
Whew, I hope this helps. This took me a while to put together, so apologies for any typos, etc, etc. Again, I’m posting this for informational purposes only, and do not make any claims as to how this may work for you. You accept all responsibility for whatever happens if you try this out.
The Following 34 Users Say Thank You to bova For This Useful Post:
757CX7 (11-30-2016), 86AmishMs3 (07-05-2012), alexwlwsn (10-30-2015), bfak66 (12-12-2014), Cheapspeed (10-29-2013), darkcherry (07-05-2012), dot584 (07-22-2012), ESB Jiu JItsu (07-10-2012), FaceGrenade (01-24-2015), forcedinduktion (03-13-2012), Guyverspeed3 (11-13-2013), IamJamen (07-05-2012), Jh8909 (07-22-2012), MadMaz (11-17-2017), MATT DAMOND (01-10-2012), meelo88 (05-11-2013), MS6FL (04-07-2012), Myspeed6 (05-20-2015), MZRSpeeder6 (04-09-2012), nlgiebel (12-24-2015), phate (05-28-2015), Pointless (07-24-2012), Raider (04-12-2015), roguemazda (02-18-2016), SLOWHATCH (07-22-2012), speed23 (03-20-2012), spikeanoid (09-18-2014), TheSchimann (02-06-2012), theschrum (05-28-2017), TiGraySpeed6 (01-10-2012), Tokay444 (10-18-2013), Tomas (07-21-2012), TWENTY1 (08-11-2013), Weston (08-05-2012)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f111/how-clutch-pedal-adjustment-101838/
???? ????? - ???????? ? ??? ?????? - ?????? ?? ???????? ? ?????????? ????? 6 2.0 ?????? 2002 This thread Refback 02-16-2014 10:48 AM
Are some clutch pedal pulsations normal? - Page 2 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Refback 09-29-2012 07:57 AM
Clutch Pedal Adjustment? 08 MS3 Bulgdoom MazdaSpeed 3 - Engine, Transmission & Driveline 2 01-02-2012 03:52 PM
Clicking from clutch pedal IMASA MazdaSpeed 3 - Engine, Transmission & Driveline 3 09-05-2011 09:42 PM
Clutch adjustment LiEast MazdaSpeed 3 - Engine, Transmission & Driveline 7 04-29-2011 11:42 AM
Pedal Adjustment for Heal/Toe?? RacerX78 2010 MS3 - Engine, Transmission & Driveline 11 04-16-2010 03:03 PM
Wow FML my clutch pedal broke!!! thabigo MazdaSpeed 3 - Engine, Transmission & Driveline 12 03-28-2010 08:41 PM
Page generated in 0.68077 seconds with 43 queries
