![]() Join Date: Jul 2009 Location: South Florida
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,578
(Thread Starter) | Neutral : +1 score Thanks again to Skates for helping me out this weekend. Before you start, you'll need to remove your throttle body, intake manifold, and fuel rail cover. Jimmer307 already did a great "how to" that covers all this here: How-To: Injector & Intake Manifold Removal. Remember to be careful with the hard fuel line when you pull the fuel rail off. In the "how to" link above, after you take out the two screws holding it in (green dots in that thread), carefully pull the hard line out to the right, just far enough so the fuel rail clears it. I'm just going to go over how to do the injector seal upgrade, using studs + nuts to replace the stock torx bolts, and the egr block off (because I did this at the same time). If you're upgrading your seals, and you haven't already deleted the egr, this is a great time to do it. Just pull the battery and remove your tip/sri and you can get at the egr tube easily. I went w/ the SU EGR Block off plate StreetUnit EGR Block Off Plate: MAZDASPEED 6, MAZDASPEED 3, CX-7 and it worked great. I also removed the dumb tube altogether, and plugged the mani w/ a 1/2 NPT plug that Skates had kicking around (not sure of length, and not pictured, but I'd guess about 3/4" long or so. I went with the CPE upgraded injector seals (only ones I know of) found here: CPE MZR 2.3 DISI SAFEseal™ Injector Seals for Mazdaspeed 3 / 6 / CX-7 - Revolution Performance Motorsports! I got the studs and nuts from Fastenal (you can get them elsewhere), but here are the ones I used, including the part numbers: 0349266 (Qty =5) M8x1.25 x 50 Metric Alloy Steel Stud 1 $3.15 =$15.75 90701 (Qty =8) M8-1.25 DIN 6923 Steel Class 8.8 Zinc Flange Nut 1 $0.1597 =$1.28 You only need 4 studs and 4 nuts, but I got an extra stud and twice as many nuts just in case. So here are the CPE seals, the injector removal tool that comes with them (we needed it for one), and the SU EGR block off plate: So here's a pic with some shit labeled and an overview in case you haven't seen this stuff before: Closer shot of 2 of the 4 bolts and crows feet: One injector didn't come out (also don't forget to unplug each injector from the wire harness from below the fuel rail): So we used the tool that came w/ the CPE seals to tap it out. It works very well and got the injector out in less than a minute. EDIT: To use the CPE injector removal tool, you just slide the block end of it over the injector that is stuck in the block (you'll see how it fits), and then slap the metal cylinder up along the long bolt to the top a bunch of times and the force gently pulls the injector out. Don't rape the thing.. it doesn't take a ton of force... just start out like Adam Sandler "at a medium pace" and you should be fine. Okay, as shown in the pic w/ the writing above, we're removing the 4 torx bolts, which hold the crows feet in, which hold your injectors in. YOU NEED TO KEEP THE WASHERS FROM THOSE 4 BOLTS TO RE-USE, AND YOU HAVE TO CUT THE TORX BOLTS TO GET THEM OFF. So, unscrew them, and here they are: NOTE that the washers are cupped so you can't just buy them. They also don't slide off, but Anthony will happily fly himself out to your house (at his expense) to cut them off for you if you don't have tools: You must also drill the washers out a tiny bit with a 5/16" bit. It barely removes anything, but you need to take a little off so they will fit over the studs. Okay, so now the washers ready, and it's time to put the studs in. We used some Loctite Red on the studs, so they won't go anywhere: Hand thread the studs in, and wipe down excess Loctite Red: Now remove the ghetto seals from your injectors, and clean the injectors. I forgot to take a pic of this, but if you really need one, I think I have some injectors in my storage unit somewhere. It's a super small black washer that's probably all blown out. The CPE seals are HUGE in comparison. After removing stock washers and cleaning injectors, the CPE seals may not slide right on. 3 of the 4 of mine slide right on, but one was a little too snug. Do not force it or hammer it.. just apply heat for about 30 seconds or so: After it was heated, the last one slide right on. Here's all 4 mounted & ready to go: Don't forget to put the crows feet back on, and it takes a little fanagling to get the rail back on. Mine wasn't lining up right away on the studs, so we decided to take the injectors off the rail, and put them back in first. They slid right in. Make sure to lube up the blue rings before pushing the rail back on afterwards: Also, make sure to put the black washers on top of the blue rubber rings (seen better in this pic): After you (carefully, firmly, and evenly) push the fuel rail back on to the injectors (while keeping the hard fuel line just out of the way), make sure to put some oil on the blue rubber ring on the hard fuel line so that it slides in nicely. We also used some air tool lubricant on the nut side of the studs for proper torque. Then plug everything back up, and you're done! Also, some people ask about that foam thingy under the intake mani. It is not necessary, although it may help quite down the racket. I ditched mine, as now you can see your injector bolts + studs you just put on from outside the car if you want to gawk at them, lol: ---------------------------------------------------------------------------------------------------- As for the EGR..... Here's a close up of my intake runners: And here's the primary culprit: Last time I had the mani off was before the ATR cel defeats were out, and I needed a sticker, so I couldn't do this at the time. Just remove that dumb tube, and re-use the two bolts and attach the SU plate to the top. Use some RTV Copper on the SU block off plate and here: And use some on the 1/2 NPT bolt that you use to plug the mani. We used some anti-seize at first, and I had a leak. We put some RTV copper on, and we tightened the shit out of it. It is pretty much completely flush to where it attaches... a couple turns tighter that this: That's all folks. If you do the EGR delete (and I hope you did), make sure to cut a map w/ the cel turned off. Just go to "edit" then "advanced parameters" then "toggles (base)" and UN-check P0401. I have no cel. Enjoy!
__________________ 2012 BMW 535i Alpine White/Beige (30K miles) N55 Dinan Stage 1 w/ Intake. Tech package w/ Bluetooth audio/streaming, SAT Radio, & 12.5G HD, Navi Sys Pro w/ Back-up Cam/sensors & Park Distant Control; Auto-Trunk, TPC, LED lighting interior (doors) and exterior (door handles), & tint. [SIGPIC][/SIGPIC] Last edited by dougefresh_; 04-19-2011 at 10:50 AM. |
| The Following 95 Users Say Thank You to dougefresh_ For This Useful Post: | -cj- (05-05-2011), 3mazdaspeed (04-27-2011), 801MS3 (05-16-2011), 802MS3 (04-19-2011), agentgordon27 (04-27-2013), AJ713 (04-21-2011), ak_spray (06-12-2012), Alpha (04-19-2011), amggilly305 (10-10-2012), anavrinIV (04-28-2014), Andrewbox (06-23-2013), Arnie1229 (02-27-2015), bertrand_CX_7 (04-19-2011), BlueStreak (04-19-2011), Boro (06-24-2012), Broxer (09-02-2011), Castillo817 (02-02-2016), Cataphract_40 (06-18-2011), Ckmazdaspeed3 (04-19-2011), cld12pk2go (04-19-2011), daztdMS6 (01-19-2012), dereeek (12-03-2011), djuosnteisn (04-19-2011), Docnox (06-12-2011), Domino81 (01-22-2012), doubleflusher (04-23-2011), efispeed (04-23-2011), EwMPS (06-19-2013), Fail_6 (12-07-2011), Fobio (04-24-2011), G Sp33dy (04-16-2012), ganque (07-19-2011), h.h.sk1nny (11-25-2011), H3R3TIC (03-30-2012), i8urgti (06-18-2011), impossible (01-09-2016), JacksonMS30 (04-25-2011), jack_hammer (05-31-2012), jracer (04-18-2011), Juyoung (07-06-2013), karl-hungus (04-18-2011), Kfunk (03-31-2013), kilo101 (10-26-2015), kpsoerensen (01-20-2012), LiEast (04-30-2011), LumberJack (10-19-2013), magicka (06-14-2011), mason (06-11-2011), Mast (11-24-2013), MATT DAMOND (04-20-2011), mazda.speed3 (04-19-2011), MD1032 (11-18-2015), Micha (10-14-2012), Miltron (04-04-2013), Mizzle (07-30-2011), Monotonous ONE (04-18-2011), ms3blackmica (11-25-2012), MS6FL (06-04-2011), ms6mil (04-04-2013), mtnrunner (04-19-2011), Muzzybud (05-09-2016), MZRSpeeder6 (04-09-2012), Night Wolf (04-19-2011), nlgiebel (08-03-2015), p057 (02-12-2012), PapaBruno (12-30-2016), Pointless (04-11-2013), QwkEVO (03-08-2012), Realgib3 (04-19-2011), rfinkle2 (04-23-2011), rigor (04-23-2011), rob ms6gt (05-11-2011), robry (01-02-2013), Sacrilicious (01-19-2012), Snyeed (04-22-2012), speed23 (04-19-2011), speedtoz (04-19-2011), Sterling (01-03-2014), superskaterxes (04-20-2011), thehead (03-29-2012), the_caruch (04-18-2011), Toddy22587 (04-19-2011), Tokay444 (11-02-2013), triplejumper18 (04-19-2011), turbo test (06-18-2011), turd burglar (04-18-2011), TWOptSL0W (07-27-2011), wankular (04-20-2011), wette460 (06-13-2011), wolly6973 (05-10-2011), xcoldricex (04-21-2011), XLT_66 (05-04-2011), xxdjfate76xx (04-18-2011), zpele (06-02-2011), [R]usty (09-24-2014) |
| patrick failman ![]() Join Date: Mar 2009
Rep Power: 2905 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,275
Groans: 74
| Not Ranked : 0 score yikes!!! nice work.
__________________ 2012 ingot silver mustang gt w/ 6 speed, 3.73 rear end, bama 93 tune, cat deletes, boss 302 oil cooler, roush cai, dynotech aluminum driveshaft, ford racing strut tower brace, dampers & springs, boss 302 sway bars, gt500 strut mounts, lower control arms & axle backs, j&m adjustable panhard bar, steeda upper control arm & 3 point braces, jlt catch can, barton short shifter & shift bracket |
| The Following User Says Thank You to karl-hungus For This Useful Post: | dougefresh_ (04-18-2011) |
(Thread Starter) | Not Ranked : 0 score Thanks man! Skates did all the injector work and I just helped when I could. I thought this may help some folks out though. I've taken my fuel rail off (for other reasons, lol), but I definitely would've liked some pics to do this. EDIT: I'm forgetting something minor here... we put air tool lubricant on something, and I can't remember what the hell it was. I asked skates to take a look through this for accuracy and to add/edit as he sees fit. Hopefully he'll get a chance tomorrow
__________________ 2012 BMW 535i Alpine White/Beige (30K miles) N55 Dinan Stage 1 w/ Intake. Tech package w/ Bluetooth audio/streaming, SAT Radio, & 12.5G HD, Navi Sys Pro w/ Back-up Cam/sensors & Park Distant Control; Auto-Trunk, TPC, LED lighting interior (doors) and exterior (door handles), & tint. [SIGPIC][/SIGPIC] |
| Axle Breaker ![]() Join Date: Mar 2008 Location: Rio Rancho, NM
Rep Power: 4000 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,595
Groans: 162
| Not Ranked : 0 score Probably put the air tool lube on the nut side of the stud for proper torque. Nice write up. I'm so glad I pulled the EGR when I first got the car and put up with the code for two years. My intake runners and valves are nice and clean.
__________________ |
| The Following 2 Users Say Thank You to jmhinkle For This Useful Post: | dougefresh_ (04-19-2011), superskaterxes (04-20-2011) |
![]() Join Date: Jul 2009 Location: Sardinia, Ohio
Rep Power: 4725 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,721
| Not Ranked : 0 score Nice wright up....but make a change to the drill size for the washers...it is 5/16" not 5/8"
__________________ I am my own After Market Company. A common mistake that people make when trying to design something completely idiot proof is to underestimate the ingenuity of a complete idiot. - Douglas Adams Better to remain silent and be thought a fool than to speak out and remove all doubt. - Mark Twain Cops carry guns to protect themselves, not to protect you. READ THIS---- 2nd Amendment A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed. I've learned that pleasing everyone is impossible, but pissing everyone off is a piece of cake. |
| The Following 6 Users Say Thank You to SilverDemon For This Useful Post: | Alpha (04-19-2011), djuosnteisn (04-19-2011), dougefresh_ (04-19-2011), impossible (01-09-2016), rfinkle2 (02-03-2014), superskaterxes (04-20-2011) |
guh, seeing that pict with the face shield makes me regret ever having grinded metal without googles in the past. 2 hour ER visit with tiny vibrating knife to get metal shard out of your cornea FTL
__________________ 2006 Mazdaspeed 6 GT Black Mica #4126 KILLAH Built/SPEED PERF6RMANC3 (SP) 10.6:1 Pistons ~ SP 11mm H11 Head Studs ~ K1 rods ~ SP CNC Head Work ~ Crower 65lb Valve Springs ~ Fully Keyed/Pinned Motor ~ GTX35R w/Tial .82AR Hotside ~ JMF IM w/1000cc PI Injectors ~ SP 75mm TB ~ SP In-Tank FP w/Dual DW300's ~ AEM FPR ~ SP Custom PI Fuel kit ~ CPE 4" MAF ~ CPE SAFEseals ~ TR1035 FMIC ~ CPE Atmosphere DP/Ex Manifold/Oil/Water Lines ~ Tial MV-R EWG VTA'd ~ Denso ITV-24's ~ CPE Dual CBE ~ CPE BT TIP ~ CPE RMM ~ JBR TMM ~ JBR PMM ~ TTFMM ~ CPE RDM ~ Sonic Tuning CO's ~ LED Tails ~ Sonic Tuning HID's ~ Whiteline RSB ~ ACT 6 Puck w/unicorn dust First K04 in the 12's First MS6 in the 11's Certified RichTune E-Tuner | |
| The Following User Says Thank You to superskaterxes For This Useful Post: | dougefresh_ (04-20-2011) |
. Thanks again for the help bro ![]() Other than me losing a clip Ant luckily had a spare of, this install was butta. I wonder where that blue clip went? lol Me wonders if it jumped into my intercooler and hitched a ride home, haha.
__________________ 2012 BMW 535i Alpine White/Beige (30K miles) N55 Dinan Stage 1 w/ Intake. Tech package w/ Bluetooth audio/streaming, SAT Radio, & 12.5G HD, Navi Sys Pro w/ Back-up Cam/sensors & Park Distant Control; Auto-Trunk, TPC, LED lighting interior (doors) and exterior (door handles), & tint. [SIGPIC][/SIGPIC] | |
![]() Join Date: Oct 2008 Location: Phoenix Az
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 80
(Thread Starter) | Not Ranked : 0 score Nope. Just one of those pita + wallet mods that are a necessary evil . I can't tell you how psyched I am that both of those things are done though. Wait, yes I can... I'm very psyched!
| The Following User Says Thank You to dougefresh_ For This Useful Post: | bbogue4 (04-20-2011) |
Groans: 162
| Not Ranked : 0 score Real men pull them out with tweezers in the bathroom mirror. Been there done that. I still didn't learn to wear safety glasses until my job made it a requirement. Once I paid for my bionic eyes out of my own pocket I started wearing safety glasses regularly at home.
Groans: 239
| Not Ranked : 0 score you bitch, you beat me to this diy. fuuuu
__________________ [07:25 PM] Pu Manchu: the second rule is "don't tell anyone" [07:25 PM] Pu Manchu: the first rule of tranny fucking is "don't do it" |
| The Following 4 Users Say Thank You to dooderek For This Useful Post: |
![]() Join Date: Jul 2008 Location: Houston
Rep Power: 472 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 138
| Not Ranked : 0 score Thanks. I hadn't done mine yet. But, I intend to this weekend. It looks like a bitch though. I'm apprehensive. I bought new stock bolts from the dealer so that I could do that part first before even taking apart the car. So, when I get done, I'll have used stock bolts to give away. I also bought the gromets that jmhinkle I think it was that recommended.
__________________ 360 AWD HP/380 TQ Cobb Mustang Dyno: 3071 .83 A/R, Steedspeed manifold, CPE FMIC, Cobb AP/tuning, CP pistons, Pauter Rods, CPE DP hacked to have V-band, GHL exhaust |
| The Following 2 Users Say Thank You to Speedie6 For This Useful Post: | dougefresh_ (04-19-2011), Grab21 (11-25-2011) |
Slow ass . It never hurts to have more than one write up, and you may run into issues I didn't that others will as well. When I first did the fuel rail myself last year, I was looking at THREE how to intake mani removals at the same time, lol. They all helped. I kinda glazed over the fuel rail and didn't mention buying new grommets.
I also didn't mention bleeding off pressure... I went through 3 hpfp's last year, so I didn't even consider it a step, lol. There's several ways to do this.. we just undid the rail, and hard fuel line and bleed pressure from where the hard fuel line detaches, and put some rags under it. You could also just loosen the 19mm nut just below the hpfp, which is what I always did w/ the hpfp swaps, but it's harder to catch all the gas. Just make sure to put a large zip tie a couple inches below that nut so it doesn't slide away if you go that route. I was only holding 200 PSI at idle back then, so it wasn't much fuel. Quite a bit came out of rail this time... just have some rages under it.
__________________ 2012 BMW 535i Alpine White/Beige (30K miles) N55 Dinan Stage 1 w/ Intake. Tech package w/ Bluetooth audio/streaming, SAT Radio, & 12.5G HD, Navi Sys Pro w/ Back-up Cam/sensors & Park Distant Control; Auto-Trunk, TPC, LED lighting interior (doors) and exterior (door handles), & tint. [SIGPIC][/SIGPIC] | |||
| The Following User Says Thank You to dougefresh_ For This Useful Post: | SilverDemon (04-19-2011) |
| Not Ranked : 0 score Excellent write-up. This is my new reference from now on
| The Following User Says Thank You to djuosnteisn For This Useful Post: | dougefresh_ (04-19-2011) |
![]() Join Date: Dec 2009 Location: layton, UT
| Not Ranked : 0 score Nice write up I'll be doin this when I get back from desert with turbo rebuild
__________________ In progress: Engine: Built long block by Keefover. Keyed crank,keyed cams/VVT,Crower 65lb valve springs,Wiseco pistons,Manley H beam rods,AFI t3 stock location mani,Comp turbo CT4x 53-56,Kozmic 6th port PI with 2200cc bosch injectors,N2MB WOT box,Relentless ported intake mani,Kozmic oil feed line,Custom oil return line,Ramfab 3.5" intake,Ramfab alum. crash bar,Ramfab IC piping,TR10 IC,Saiko Michi and JBR dual custom catch can setup, Guardian angel v3 with 4bar map sensor,Dual Deatschwerks in-tank fuel hat with bigger pickup,-6an nylon braided fuel lines,Fuel labs FPR,SP63 3 port EBCS,Mishimoto oil cooler, HKS SSQV1,BSD,Autotech FP internals,CPE injector seals EGR delete,TB coolant bypass delete,M2 Ebay DP Suspenion/Bracing: Sonic tuning CO's revalved by Feal Suspension, QA1 600lb rear springs, 750lb front Swift springs,AWR front and rear sway bar endlinks,Whiteline RSB,SPC front adjustable ball joints,GT spec ladder brace,SU rear interior brace,NRG harness bar. Drivetrain:SS brake lines,SS clutch line,Carbotech ax6 F&R, Southbend STG 3 endurance clutch and flywheel,SU rear diff mount,SU front rear diff mount,SP63 TC caps,DSS rear axles,AWR Trilogy mounts 70A,Hubcentric centering rings,2" brake ducting F&R,TWM STS stg 1 with bushing kit Interior:Redline custom shift boot,Redline custom steering wheel cover,Redline custom ebrake handle cover Bride Stradia V.2 rep seats,Corbeau seat brackets,JBR heavy shift knob,Custom LED gauge cluster,Custom Steering column dual gauge pod,AEM wideband failsafe,AEM oil pressure gauge,Schrothe Rallye 4 harnesses,Escort 9500ix with mirror mount and hard wired with external controller,DIY ipod adapter. Exterior: STI front lip,Enkei PF01SS 17x9 +48 wrapped in Bridgestone Potenza RE-71R's 245/45/17,Full clear bra,Muteki SR48 blue locking lug nuts,RHO side plate mount,Smoked side markers, Shark fin antenna |
| The Following User Says Thank You to MSP611 For This Useful Post: | dougefresh_ (04-21-2011) |
Groans: 162
| Not Ranked : 0 score Heading to our neighbood?
| Not Ranked : 0 score Whatcha mean?? I live in Germany for now if thts wat u mean
Groans: 162
| Not Ranked : 0 score LOL. Your location said Utah and when someone speaks of the desert, they are usually referring to AZ or NM. Thought you were coming our way.
| Not Ranked : 0 score Nope I mean the real desert. And I wish I could come on by. I haven't changed my location cuz I've only had my phone here, no reg inet cuz I've been gone so much
(Thread Starter) | Not Ranked : 0 score OK, I'm going to have a bit of a problem here and so may you. The GreatNY was asking me if the CEL defeats leave the ECU in the ready state or not:
. If I move to FL next year, then it won't matter (no inspections), but that's not set in stone. I'd rather swap the egr back on than a dp, but now I gotta think about. FuuuhhhkkkNot sure if everyone is aware that ^that is how the cel defeats work. I hope they can change it to keep them in the 'ready' state :/
| The Following 4 Users Say Thank You to dougefresh_ For This Useful Post: |
| Not Ranked : 0 score Good info^
| The Following User Says Thank You to MSP611 For This Useful Post: | dougefresh_ (04-24-2011) |
![]() Join Date: Dec 2010 Location: Virginia Beach
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 40
| Not Ranked : 0 score nice write up. what is the reason behind using studs instead of the stock bolts?
__________________ 2008.5 cwp ms3-sold 2014 Black Mustang GT Premium w/track package |
| The Following 2 Users Say Thank You to paulwalll For This Useful Post: | dougefresh_ (04-21-2011), Phoenix Speed3 (03-20-2015) |
| Not Ranked : 0 score Fear lol. I think it's more of a "why not" thing, instead of a "why". Many of us have reused stock hardware, and only one person i can think of had them back out again.
| The Following 3 Users Say Thank You to djuosnteisn For This Useful Post: |
![]() | | #24 | ![]() |
| Two nuns and a pack mule ![]() Join Date: Jan 2010 Location: Virginia Beach, VA
Rep Power: 595 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 459
| Not Ranked : 0 score Awesome write up, Doug. Looks like I might have to pay Anthony a visit sometime soon. It looks like an easy install, but I don't have the right tools unfortunately
| The Following User Says Thank You to AtTheDriveIn For This Useful Post: | dougefresh_ (04-21-2011) |
![]() | | #25 | ![]() |
Groans: 162
| Not Ranked : 0 score Doug, good info on the codes for people. Something to consider is that most of them can be defeated with hardware except the EGR. If you solder in a diode, you can eliminate the 2nd O2 code. Worked fine for me for a long time before getting an AP. The VTCS can all be wired out quite simply with a relay. The only true not ready you will and should have to deal with is the EGR.
| The Following 5 Users Say Thank You to jmhinkle For This Useful Post: | djuosnteisn (04-21-2011), doubleflusher (04-23-2011), dougefresh_ (04-21-2011), Realgib3 (04-21-2011), superskaterxes (04-23-2011) |
![]() | | #26 | ![]() |
![]() | | #27 | ![]() |
This was news to me until a few weeks ago. And it's still not proven, just speculation, but very possible speculation lol. Is that diode still in there joel? We should pull it out, put some miles on the car, and see if your wot AFRs and fuel trims adjust. Would be an interesting experiment, and who knows, maybe your running richer than you think right now..... which would me we can safely lean it out some more and get mo powa
__________________ 500awhp 440awtq uncorrected ![]() EFR8374 ms6, no meth, 50/50 e85, and IDCs in the 90's @ 500+ awhp, with room to grow... fifth port winning. Count down to head lift.... 3.... 2.... 30r ms3 dd on deck, has fuel... needs top mount turbo lovin' next... Check out the hair Salon: www.permtuning.com | |
| The Following User Says Thank You to djuosnteisn For This Useful Post: | dougefresh_ (04-21-2011) |
![]() | | #28 | ![]() |
![]() Join Date: Feb 2010 Location: Philadelphia, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 323
| Not Ranked : 0 score I was going to buy the seals but I dont think I would be able to do this myself. ANyone wanna help that in the PA/NJ area let me know.. LOL
__________________ 2009 Metro Grey Numbers Fully Bolted. Nator Pa Dyno Day: 311HP 328TQ Pump 93 Nator Pa Dyno Day: 310HP 329TQ Pump 93 End of Drive 9/24/2013 2012 Liquid Silver Cobb AP |
![]() | | #29 | ![]() |
![]() Join Date: Mar 2008 Location: W. Suffield, CT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 674
| Not Ranked : 0 score just have him put a HF cat on there and be done with it. |
![]() | | #30 | ![]() |
![]() Join Date: May 2009 Location: Clw/ NPR Florida
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10,516
Groans: 89
| Not Ranked : 0 score i use two anti foulers on my 2nd o2 and no cell..i have a catless atp downpipe
__________________ [SIGPIC][/SIGPIC] 2013 EVO X GSR Wicked White w/Areo H&R springs/H&R 15mm spacers MAP modified 3" Magna Flow cat back MAP catless testpipe MAP UICP Grimmspeed 3 port Cosworth filter SSP relay kit TWM Desert Eagle shift knob AEM wideband gauge Prosport boost gauge EvoX piller pod 30%Tint Slowpoke Tuned 339hp/336tq **** SOLD ***** 2006 speed6 " A woman's asshole is like a 9-volt battery..U know its wrong, but sooner or later ur gonna put ur tongue on it !! " |
| The Following User Says Thank You to jracer For This Useful Post: | dougefresh_ (04-21-2011) |
![]() | | #31 | ![]() |
(Thread Starter) | Not Ranked : 0 score Wouldn't anti-foulers possibly have the same effect as the 2nd 02 is seeing less as well? EDIT: Here's a link for 'how to- anti-fouler 02" for the anti-fouler challenged like myself: http://forums.evolutionm.net/evo-how...ouler-how.html. I'm just gonna pop those in for inspection time, and then remove them and disable the CEL as to avoid any possible secondary 02 sensor calibration rigamarou.
__________________ 2012 BMW 535i Alpine White/Beige (30K miles) N55 Dinan Stage 1 w/ Intake. Tech package w/ Bluetooth audio/streaming, SAT Radio, & 12.5G HD, Navi Sys Pro w/ Back-up Cam/sensors & Park Distant Control; Auto-Trunk, TPC, LED lighting interior (doors) and exterior (door handles), & tint. [SIGPIC][/SIGPIC] Last edited by dougefresh_; 04-21-2011 at 07:19 PM. |
| The Following User Says Thank You to dougefresh_ For This Useful Post: | djuosnteisn (04-25-2011) |
![]() | | #32 | ![]() |
Groans: 162
| Not Ranked : 0 score The anti fouler changes your cat efficiency code to a slow to react code. They are stupid and useless. Dustin, no I don't have the diode anymore. Pulled it back when I got the AP a few years ago now. If I had to get emissions, I would probably put it back in to get down to one code though.
| The Following User Says Thank You to jmhinkle For This Useful Post: | djuosnteisn (04-25-2011) |
![]() | | #33 | ![]() |
| Not Ranked : 0 score doug, you have the AP, why would u want to fuck around with any of this?
| The Following User Says Thank You to superskaterxes For This Useful Post: | dougefresh_ (04-23-2011) |
![]() | | #34 | ![]() |
Groans: 162
| Not Ranked : 0 score Reading>you? Did you not catch all the not ready code issues for emissions? LOL
| The Following User Says Thank You to jmhinkle For This Useful Post: | dougefresh_ (04-23-2011) |
![]() | | #35 | ![]() |
| Not Ranked : 0 score lol what not ready codes? thats the point of the AP haha
![]() | | #36 | ![]() |
![]() Join Date: Mar 2008 Location: Pittsburgh, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 17,174
Groans: 45
| Not Ranked : 0 score the AP is the one setting them to not ready. when you deactivate a code it sets that sensor to not ready. to pass inspections in certain places you are only allowed to have one not ready. i don't think there is any way around this, even with the AP. |
| The Following User Says Thank You to bova For This Useful Post: | dougefresh_ (04-23-2011) |
![]() | | #37 | ![]() |
| Banned ![]() Join Date: Jun 2008 Location: NY Baby!
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 48
yea doing the egr delete with the AP the right way may not be possible. in order to delete the EGR fully without setting the monitor permanently to "not ready" requires manipulation of the duty cycle of the valve. you need to put it so low that removing the EGR wont trip the cel due low flow. but also shows as still functioning to the ecu. i havent seen a table in ATR that can manipulate this to that point or that precise. but to be honest, its not something that you would get the first time either. as it will be different inputs for every vehicle. being as the egr functions at part throttle only, that leaves a lot of MAP area to manipulate. i have personally only seen two or three type of software flashing methods that could do this. unless i missed something in my research. the other way to disable it, well moreso trick it. would be logging only the EGR. that way you can get as much resolution as possible to what its doing and where. you would then need to make a circuit that can mimic that as closely as possible to most of the cruising range (the area where you do 90% of your part throttle driving). im in the middle of making my circuit for my car, but need to do some more logging. its possible but just tedious. being as i hadnt made one since my mustang builds, im a bit rusty on what parts i needed, so im calculating from scratch.
i find it hard to believe that the rear O2 effects the calibration of the upstream. that just makes no sense being as they are two separate entities and only correlate to each other in term of cat efficiency by determining the difference between the AFR before the cat and after. and check to see if it within the buffer to not trip a code. if it anything it would be the other way around imo. having the Wideband influence the downstream. but even that doesnt seem much plausible. but again, we are dealing with mazdas here. so you never know. interested in finding out tho for sure. | ||
| The Following User Says Thank You to The Great NY For This Useful Post: | dougefresh_ (04-23-2011) |
![]() | | #38 | ![]() |
![]() Join Date: Jan 2012 Location: westland , mi
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 517
| Not Ranked : 0 score Subbed for reference
__________________ 2012 Cadillac CTS-V ![]() 2014 focus st ![]() 2010 Taurus sho- sold 2009 speed 3 gt cwp -was once a monster -sold |
![]() | | #39 | ![]() |
![]() Join Date: Nov 2009 Location: Dallas, Texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 31,116
Groans: 549
| Not Ranked : 0 score instead of bumping an old thread for your "reference", you can go to the top of the page, where it says "thread tools". under there, you can select "subscribe to this thread".
__________________ it's fun to do bad things |
| The Following 2 Users Say Thank You to jack_hammer For This Useful Post: | ak_spray (07-05-2012), Don06speed6 (07-05-2012) |
![]() | | #40 | ![]() |
Groans: 239
| Not Ranked : 0 score ill take pics of the stock injector seals when i get back, its a real "lol"
| The Following 2 Users Say Thank You to dooderek For This Useful Post: | djuosnteisn (04-25-2011), dougefresh_ (04-23-2011) |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f111/how-cpe-injector-seals-studs-egr-delete-78250/ | ||||
| EGR ventil pomoc! Zablokujte - Mazda 6 Mazda 6 fórum: Fórum / Fórum Mazda Atenza | This thread | Refback | 08-26-2013 01:35 AM | |
| Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum - How to: Top mount turbo set up!! | This thread | Refback | 11-18-2012 07:54 AM | |
| EGR valve help! Block off - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum | This thread | Pingback | 03-18-2012 04:51 PM | |
| How To TOP MOUNT TURBO SET UP! Easy, Breezy, Beautiful MS6 only because Race Car | SpeedForums.org | This thread | Refback | 12-06-2011 12:14 PM | |
| HOW TO: Top Mount Turbo Set Up | This thread | Refback | 07-07-2011 07:02 PM | |
| How to: Top mount turbo set up!! - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum | This thread | Pingback | 06-14-2011 03:09 PM | |
| Club de Usuarios de Mazda • Ver Tema - Sabeis Bloquear EGR en MPS? | This thread | Refback | 05-09-2011 11:28 PM | |
| CP-e Injector Seals | ak_spray | Revolution Performance Motorsports | 11 | 01-25-2012 10:20 PM |
| Injector seals | essejkcamraw | MazdaSpeed 3/6 - Turbo Induction | 703 | 05-17-2011 09:12 PM |
| Injector seals... how do you know you need them? | MS3 Ventura | MazdaSpeed 3 - Engine, Transmission & Driveline | 2 | 03-09-2011 01:29 PM |
