> MazdaSpeed 6 - How-To's
Like Tree11Likes
 Old 11-05-2012, 03:31 PM   #41
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
What is the T-case CASE made of?
5 letters and a dash.
Or are you talking about the t-case housing? 90% sure it's just normal aluminum.
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
aviator79 (11-05-2012), p057 (06-24-2013), SIXual Panda (11-05-2012)
 Old 11-05-2012, 04:02 PM   #42
Captain
Lol, it was only a joke Andy... no reason to groan me... sheesh buddy. Hahaha.
www.permtuning.com
 Old 11-05-2012, 11:43 PM   #43
SIXual Panda's Avatar
Posts: 2,363   (View Stats)
Groans: 56
Woah! Wtf.. Meant to thank. Haha it made me giggle
Damn phone and fat thumbs.
I envy your ass raping.
The Following User Says Thank You to SIXual Panda For This Useful Post:
bcmurphy87 (11-07-2012)
 Old 11-07-2012, 07:05 PM   #44
Dovydas's Avatar
Posts: 5   (View Stats)
Dovydas is a jewel in the roughDovydas is a jewel in the roughDovydas is a jewel in the rough
...another Cx7 TC has been successfully installed into Speed6. We'll see how it will do. Thanks everyone!
Dovydas is offline   Reply With Quote
The Following 2 Users Say Thank You to Dovydas For This Useful Post:
bcmurphy87 (11-07-2012), SIXual Panda (11-08-2012)
 Old 11-08-2012, 09:58 AM   #45
qtrmile beast's Avatar
Posts: 2,423   (View Stats)
So far i have about 200 miles on mine...
track weight 3220
street weight 3370
 Old 11-16-2012, 12:14 AM   #46
aviator79's Avatar
Posts: 3,934   (View Stats)
Edit:
I believe these are all just from the bad casting as the CX-7 had similar issues.
TiGraySpeed6 (11-16-2012)
 Old 11-16-2012, 11:01 AM   #47
I dont know but i think you could still use this case... not too sure about pic #1 and 3 though
track weight 3220
street weight 3370
 Old 11-19-2012, 09:06 AM   #48
aviator79's Avatar
Im sure I could have, but I picked up a cx-7 case with 48K for $187 in RI two days ago. Now trying to figure out how the engine slipped timing and if I can still use it. Looking at your threads trying to figure it out. Need the cam alignment tool though.
 Old 11-19-2012, 09:35 AM   #49
Heres a trick and you don't need the cam alignment tool!!! Take a long screwdriver and put it in the number 1 cylinder and rotate the motor til the screwdriver reaches TDC. Then take the valve cover off and look at the indention in each of the cams from the driverside where the cam alignment tool goes and see if they are even with the line on head. If not then you are out of timing.... ALso the CX7 case is slightly different than the speed6 one FYI...
track weight 3220
street weight 3370
 Old 11-23-2012, 06:22 PM   #50
aviator79's Avatar
That is what this thread is about, so I will be swapping the shafts, but does the rear drive flange really need to be swapped? Holes of ms6 line up with threaded holes on cx7. Cx7 flange is more robust. Just have to get new bolts. Drive shaft should have no issue if flange sticks out a half inch further back I would think...
SonicNutrition likes this.
 Old 11-30-2012, 01:19 PM   #51
aviator79's Avatar
So I bought the wrong seals. Note you must replace the seals on the passenger side of the case as the MS6 shaft is smaller than the CX-7. $38 bucks for the seals. (Edit, more like $8 as dont need the more expensive outer seal (see below)).
LN01-27-238 (Edit, this is the only seal that must be replaced to account for the smaller OD of the shaft. CX7 has two seals in transfer case but the MS6 only has one (on drivers side that mounts to trans). This inner seal LN01-27-238 is all that must be replaced. The ID of this seal is smaller for the smaller OD of the shaft. Take 2 CX7 seals out and replace with this one. Must measure depth as if you press it all he way down to the step you will install too far. I measured mine at adepth = 13.4mm so that is what I aimed to install the new on at. I had a hard time installing as I had nothing that mesured 67mm OD except for a can of olives and chefboyaredee, which did not work very well as I could not keep it square. Ended up using my press to "inch it down" around the edge of the seal. Best way to do it would be the right way, but trying to just happer it down would likely lead to disaster. The way I did it worked but tooK a long time....blablabla...ANYWAYS, looking at the shaft for the MS6 the seal does not have to be placed exactly compared to the CX-7.)
A610-27-397 (EDIT, this is not needed. This goes in trans. )
Inner passenger side is (NO.2) 27-238, which is LN01-27-238 and outer passenger side is 27-622A, which is A610-27-397
The Following 5 Users Say Thank You to aviator79 For This Useful Post:
Don06speed6 (11-30-2012), phate (08-15-2014), TiGraySpeed6 (11-30-2012), Tomas (02-13-2014), xliquidx (03-04-2014)
 Old 12-02-2012, 11:53 AM   #52
aviator79's Avatar
This shows how you get the shaft out of the front cover. As I explained you remove the bearing cap then the thin "shim" or spacer can be slid out. You can lift up on it thru the slots in the other spacer.
The Following 6 Users Say Thank You to aviator79 For This Useful Post:
jmhinkle (01-20-2013), Mistersix (02-23-2013), phate (08-15-2014), RichieRichness (03-31-2014), TiGraySpeed6 (12-02-2012), Tomas (03-03-2013)
 Old 02-21-2013, 07:55 AM   #53
redboat's Avatar
Posts: 634   (View Stats)
redboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the world
Any way to verify the Vin of a CX7 to know if it the correct style transfer case?
redboat is offline   Reply With Quote
 Old 03-13-2013, 10:27 PM   #54
Boltz's Avatar
Posts: 19   (View Stats)
Boltz has disabled reputation
After reading this I am not sure if you guys swapped the MS6 PTO shaft with the bevel gears on it along with the drive shaft flange, or simply left the CX7 PTO shaft but installed the MS6 drive shaft flange + Nut only.
Next... why does it really matter about the "Riveted" CX7 transfer case... why cant you have it removed via "insert persuasion tool here", and simply swap in the entire MS6 internals. If all you are after is the casings? This could open up more options?
Boltz is offline   Reply With Quote
 Old 04-14-2013, 09:01 PM   #55
soapisclean's Avatar
soapisclean is just really nicesoapisclean is just really nicesoapisclean is just really nicesoapisclean is just really nicesoapisclean is just really nice
i just put a cx7 case into my 6, about 200 miles on it. works fine. also if i had to do it again i wouldnt swap drive shaft flanges, there is more than enough room for the thicker flange and you dont have to worry about pinion preload then.
soapisclean is offline   Reply With Quote
The Following 2 Users Say Thank You to soapisclean For This Useful Post:
phate (08-15-2014), SonicNutrition (01-23-2014)
 Old 06-24-2013, 11:30 AM   #56
Thaad's Avatar
Posts: 31   (View Stats)
Thaad is a jewel in the roughThaad is a jewel in the roughThaad is a jewel in the roughThaad is a jewel in the rough
I am very much a noob to thread although I've had car quite some time, had went abroad for buisness purposes and when I got back my brother had destroyed much of my 2006 speed 6 I left him with. Had the clutch completely replaced now onto the transfer case...1 question, does the transfer case coming from the cx7 have to be a manual or can it be automatic. Thank a bunch fellas
Thaad is offline   Reply With Quote
 Old 06-24-2013, 11:58 AM   #57
the public enemy's Avatar
Posts: 1,133   (View Stats)
the public enemy is the leader of the worldthe public enemy is the leader of the worldthe public enemy is the leader of the worldthe public enemy is the leader of the worldthe public enemy is the leader of the worldthe public enemy is the leader of the worldthe public enemy is the leader of the worldthe public enemy is the leader of the worldthe public enemy is the leader of the worldthe public enemy is the leader of the worldthe public enemy is the leader of the world
I'm pretty sure there aren't any manual cx7s but I could be stupid
Sent from my SGH-T769 using Tapatalk 2
2006 Mazdaspeed6 GT Pearl Whitewater
"A life lived at half throttle is a life half lived."
Pulling like a freight train whilst sounding like a tractor.
the public enemy is offline   Reply With Quote
 Old 06-24-2013, 12:49 PM   #58
over seas they made it a manual...Also mazdaspeed made a limited edition one over here but i think it was only one of its kind here..
http://www.seriouswheels.com/cars/to...Adrenaline.htm
track weight 3220
street weight 3370
The Following 2 Users Say Thank You to qtrmile beast For This Useful Post:
Thaad (06-25-2013), the public enemy (11-24-2014)
 Old 06-24-2013, 01:27 PM   #59
v8 convert
p057's Avatar
Posts: 1,782   (View Stats)
p057 has disabled reputation
Groans: 220
I'll have to keep this in mind.
p057 is offline   Reply With Quote
 Old 06-24-2013, 01:33 PM   #60
I was going to do this to a customers car when we finish building his motor and adding a big turbo to it but it would have cost too much so he backed out..
track weight 3220
street weight 3370
 Old 06-24-2013, 02:14 PM   #61
SamiChicago's Avatar
Posts: 289   (View Stats)
SamiChicago is the leader of the worldSamiChicago is the leader of the worldSamiChicago is the leader of the worldSamiChicago is the leader of the worldSamiChicago is the leader of the worldSamiChicago is the leader of the worldSamiChicago is the leader of the worldSamiChicago is the leader of the worldSamiChicago is the leader of the worldSamiChicago is the leader of the worldSamiChicago is the leader of the world
@qtrmile beast; thoughts on that?
'07 MS6: HTP 3 Inch Intake.Cobb AP.CorkSport CBE.ATP DP.FMIC.AutoTech Internals.Bosch 3 Bar map sensor.GRIMMSPEED 3 PORT EBCS. BNR S4.WISECO 9:5 pistons. Manley H-Beam rods. Keyed Crank by APEX. SouthBend Stage 3 clutch kit. Bilstein shocks. H&R Springs.
SamiChicago is offline   Reply With Quote
 Old 06-24-2013, 02:21 PM   #62
What do you mean?
track weight 3220
street weight 3370
 Old 06-24-2013, 02:29 PM   #63
What do you mean?
Everyone has said to keep the ms6's due to fitment issues, or? Is he saying he bolted the cx7 case straight up, no modification needed?
 Old 06-26-2013, 09:39 PM   #64
swap the half shaft, the input shaft, and get new drive shaft bolts from the dealer, and youre done. the whole swap process shouldnt take more than ten minutes. also i used a case from a 2008 automatic USDM cx7. its a really straight forward process honestly.
Bill6639 likes this.
The Following 6 Users Say Thank You to soapisclean For This Useful Post:
Bill6639 (10-07-2014), phate (08-15-2014), SamiChicago (06-27-2013), Thaad (06-27-2013), the public enemy (06-26-2013), TiGraySpeed6 (06-27-2013)
 Old 10-08-2013, 06:12 PM   #65
MS6fr152's Avatar
Posts: 1   (View Stats)
MS6fr152 is an unknown quantity at this point
I have an '06 that needs work on the transfer case. I had the typical leak, tried the rubber coating without success and now it's making metal.
I found a CX7 TC from a 2007 that has the nut securing the output flange, not riveted. Here's the problem: The tech at the shop seems to know his stuff pretty well, and he says that the nut securing the flange also torques down on a crush spacer, P/N 27-171 in the breakdown. He says if you loosen the nut you also have to replace the crush spacer and torque it correctly--Mazda doesn't provide any numbers for how to do that, they say it can't be done in the field. Seems kind of ridiculous but that's where I am.
Does anyone know how to find out how to torque the flange nut back on? Other gearboxes I've worked on make a pretty big deal out of properly setting up the crush spacer. I'd hate to get the backlash or the bearing preload wrong and not find out for a couple thousand miles that the TC ate itself up.
Does anyone have thousands of miles on a CX7 TC yet?
MS6fr152 is offline   Reply With Quote
 Old 10-11-2013, 11:30 AM   #66
aviator79's Avatar
The internals dont need to be swapped. I was just showing that in case somone wanted to remove the shaft to replace the case cover.
Im pretty sure I just impacted the nut it back on. Other option is just leave the thicker flange on assuming it will fit. I was going to but didnt for some reason. I think it would work. Just need longer bolts I suppose...
And the seals are different and should be changed when you swap the shafts, so ya, its 10 min to swap shafts, but if you dont swap seals the old seal will not touch the smaller ms6 shaft:
How to make a Cx7 transfer case fit your Speed6
Its been a while so I dont recall everything I did. I dont know how many miles have been put on the T-case, but im sure others have put many miles. They are the same internals.
The Following 2 Users Say Thank You to aviator79 For This Useful Post:
qtrmile beast (10-13-2013), TiGraySpeed6 (10-11-2013)
 Old 10-13-2013, 04:27 PM   #67
Ive got about 20000 miles on my 2009 cx7 transfercase currently without issue fyi... it would have been in my car for 1 year in about 10 days!!
track weight 3220
street weight 3370
The Following User Says Thank You to qtrmile beast For This Useful Post:
TiGraySpeed6 (10-14-2013)
 Old 01-09-2014, 10:44 AM   #68
mrQQ's Avatar
Posts: 1,164   (View Stats)
^^^ this - can we assume that both type tcases work fine, with one needing a bit more work?
and what's about all the pictures with tcase differences - still doesn't matter does it?
edit: i assume only awd models of cx-7 have this? does it need to be DISI?
mrQQ is offline   Reply With Quote
 Old 01-21-2014, 04:35 PM   #69
ms6ale's Avatar
Posts: 2   (View Stats)
ms6ale is an unknown quantity at this point
I just dont understand how I can fit the cx-7 TC in my MS6, the gear on the TC is bigger than the original gear on the MS6 Transfer case.
ms6ale is offline   Reply With Quote
 Old 01-21-2014, 04:59 PM   #70
ms6ale's Avatar
Default Larger Gear
How do I deal with the larger head on the cx7 transfercase? I cant get it to fit on my MS6!! please help
 Old 01-22-2014, 11:11 AM   #71
AccuTec's Avatar
Posts: 210   (View Stats)
AccuTec has a reputation beyond reputeAccuTec has a reputation beyond reputeAccuTec has a reputation beyond reputeAccuTec has a reputation beyond reputeAccuTec has a reputation beyond reputeAccuTec has a reputation beyond reputeAccuTec has a reputation beyond reputeAccuTec has a reputation beyond reputeAccuTec has a reputation beyond reputeAccuTec has a reputation beyond reputeAccuTec has a reputation beyond repute
I'm in the process of hunting down a CX7 TC myself. I've been over this thread and others time and again. What doesn't make sense is the insane price difference between the CX7 and a Speed6 TC! Looking at $299 with miles ranging between 40k - 64k. My issue is the pinion gear lost some teeth and I'm still not sure how that happens. Wish they made a heavier duty set of gears for upgrading torque and horses!
'07 MS 6 GT Black/Black
- BNR S4 Turbo
- HTP 3.5" Intake System
- CorkSport Catless Turbo Back Exhaust
- Cobb AP V3 Freektuned by Justin
- Auto Tech HPFP Internals
- Oil Restrictor Bolt (Damond)
- Vented and Sealed OCC (Damond)
- PERM Dual PCV Plate
- TurboSmart BPV
- Denso ITV22 Plugs
- SPEC Stage 3+ Clutch Kit w/Fidanza Flywheel
- EGR Delete Kit
- Bosch 3 Bar TMap Map Sensor with IAT
- JBR 3-Port Electronic Boost Control Solenoid
- CP-E DeltaCore Top Mount Intercooler
- JBR Trilogy Motor Mount Package 80A
AccuTec is offline   Reply With Quote
 Old 01-22-2014, 11:57 AM   #72
Amnesiac's Avatar
Posts: 315   (View Stats)
Groaned at 6 Times in 4 Posts
I'm not sure what you're having problems with after reading this thread. Most people replace the driveshaft flange and you are replacing the input shaft with the one from your broken MS6.
Amnesiac is offline   Reply With Quote
 Old 01-22-2014, 03:19 PM   #73
I can get one cheaper than the 299 between 60-80,000 mile on it... if you are interested...
track weight 3220
street weight 3370
AccuTec (01-22-2014), Tomas (01-22-2014)
 Old 01-22-2014, 04:19 PM   #74
AccuTec's Avatar
I went ahead and ordered one out of NJ this afternoon. 62K, 2009 CX-7, $325 shipped ($250 for the TC). Hoping to have her back on the road mid week next week or by the weekend. Would love to make it to Nator DC Meet for February.
Edit - Just realized where you are out of... I checked Brandywine and they wanted $1,000! I will definitely keep you in mind if I need anything in the future. Might be looking to do the rear too at some point to get rid of the whine.
- BNR S4 Turbo
- TurboSmart BPV
- Denso ITV22 Plugs
- EGR Delete Kit
The Following User Says Thank You to AccuTec For This Useful Post:
qtrmile beast (02-27-2014)
 Old 02-13-2014, 03:49 PM   #75
Bob Ross Fanclub
Tomas's Avatar
Posts: 3,811   (View Stats)
This dude is partially right.
There is a "collapsible spacer" part# 27-171 that needs to be replaced but IMO only when you change out the bearings for the pinion gear where you then have to readjust for pinion gear height. The process should be the same as the one used for the rear diff since the collapsible spacers in both have the same part number. The only difference is that in the rear diff the companion flange is only coupled to the input shaft which sits inside the coupling unit which is spline connected to the pinion whereas the companion flange on the T case is directly bolted on the pinion gear.
So 27-171 in the T case below is the collapsible spacer.
Which is also 27-171 in this drawing of the rear diff
which is number 9 in this drawing
which is sqashed between these two angular roller bearings in this drawing of the pinion gear in the rear diff.
Now this is where it gets tricky.
The clamping load for the companion flange on the rear diff WHICh DOES NOT DIRECTLY BOLT ONTO THE PINION GEAR but only onto the output shaft is 124 to 166 lbs TQ.
The clamping load on the lock nut that goes on the rear diff pinion gear on the other hand has a clamping load of 177 to 556 lbs of TQ. It's a big difference and a very wide range of clamping load. Don't ask me why.
So tldr if you ask me, the companion nut on the T case needs to clamped down to 177 - 556 lbs of TQ. You will need a spanner for this of course.
Here are the two torque specs
aviator79 (05-21-2014), phate (08-15-2014)
 Old 02-26-2014, 10:30 AM   #76
dynamho's Avatar
Posts: 7   (View Stats)
dynamho will become famous soon enoughdynamho will become famous soon enough
Replaced with CX-7 transfer case today.
Thanks to soapisclean's hindsight notes, we were able to keep the flange on and use longer fasteners for a reasonably quick swap.
In case any one is curious what went wrong with the previous t-case, one of the conical helical gears got chipped and the piece was swirling around. My car has 67k miles. I believe one of previous owners used to run some big numbers as evidenced from left over AP logs. Perhaps that and possible hard launches contributed to early demise.
The attached image isn't my photo. I got it online, but the red marking shows where it chipped.
The noise it made was similar to worn wheel bearing noise - like an old airplane.
dynamho is offline   Reply With Quote
 Old 05-12-2014, 09:19 PM   #77
xliquidx's Avatar
Posts: 170   (View Stats)
xliquidx is the leader of the worldxliquidx is the leader of the worldxliquidx is the leader of the worldxliquidx is the leader of the worldxliquidx is the leader of the worldxliquidx is the leader of the worldxliquidx is the leader of the worldxliquidx is the leader of the worldxliquidx is the leader of the worldxliquidx is the leader of the worldxliquidx is the leader of the world
That's pretty much exactly what happened to mine... Did you replace any seals as shown a few posts above? I'm about to get a CX7 case and do the swap
xliquidx is offline   Reply With Quote
 Old 05-19-2014, 10:25 PM   #78
dynamho's Avatar
Sorry xliquidx for the delayed reply. The forum is not allowing me to reply to PMs unless I have 15 posts, so I'm posting here.
After the replacement around March, there was burning oil smell emanating from the bonnet. It turns out one of the TC shaft seals (feels like rubber) started leaking, so I had it replaced only a few weeks ago. No problems since, but I'll report if anything happens.
BTW, no need to swap the output shaft flange. Just get longer fasteners and you're set.
That car in your sig looks mean!
The Following 2 Users Say Thank You to dynamho For This Useful Post:
Bill6639 (10-07-2014), xliquidx (05-20-2014)
 Old 05-21-2014, 07:47 PM   #79
aviator79's Avatar
As I said somwhere above you have to replace seals because the shafts are different sizes so if you dont it will leak.
dynamho (05-22-2014), xliquidx (05-21-2014)
 Old 05-21-2014, 11:54 PM   #80
xliquidx's Avatar
Yep just checking thanks guys..
Its just the one seal right?
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f111/how-make-cx7-transfer-case-fit-your-125736/
Olde Guy w 2007 MazdaSpeed6- new to this "Forum" / "Thread" media- have questions - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Refback 02-26-2015 04:54 PM
Transfer case still leaking....need advice - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 10-01-2013 01:50 PM
transfer case ms6 This thread Refback 09-29-2013 08:27 AM
Has anyone rebuilt a PTO? - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 12-19-2012 10:21 PM
Transfer case? titaniumspeed MazdaSpeed 3/6 - Troubleshoot/Diagnostics 2 05-14-2012 03:11 PM
transfer case pic 06speed MazdaSpeed 6 - Engine, Transmission & Driveline 9 01-11-2010 07:13 AM
Page generated in 0.63072 seconds with 40 queries
