> MazdaSpeed 6 - How-To's
Like Tree4Likes
  • 2 Post By TiGraySpeed6
  • 1 Post By TiGraySpeed6
  • 1 Post By mrshimon
 Old 10-10-2012, 07:39 AM   #1
TiGraySpeed6's Avatar
Posts: 3,981   (View Stats)
Neutral  +2 score
Default How-To: MS6 & MS3 Oil Change
Shamelessly pilfered from a post originally created by @AtTheDriveIn on m6c years ago...
The 2.3 DISI engine's oil filter consists of a cartridge style filter. It's not the traditional "tin can" spin-on type. So therefore, there will be a couple of more steps involved. Not to worry, this how-to should hopefully guide you along the way so you can save yourself some time, money for more beer, and the many possibilities of screw ups the dealerships can inflict on your beloved MS6 (Don't ask me how I know) Don't forget to drive the car to normal operating temps before you do this. Alrighty, so you will need the following:
1. Equipment to raise your car. (Jack w/stands, ramps, lift, etc, etc.)
2. 10mm socket (Belly pan)
3. 17mm socket (Oil drain plug)
4. 6mm Allen key (Oil filter cartridge drain plug)
5. 76mm w/14 flutes oil filter wrench (Self explanatory. A MUST FOR EASY REMOVAL!)
6. Flathead screwdriver or similar tool (O-ring removal)
7. Container for used oil
8. Your oil of choice
9. Your oil filter of choice (MAKE SURE it comes with 2 O-rings!)
10. Safety gogg..... wait, what the hell am I thinking?
Step 1:
Raise the car at a comfortable working height using the equipment of your choice. I had the luxury of a lift at the base's auto hobby shop, then again I live in an apartment.
Step 2:
With a 10mm socket and ratchet remove the belly pan to expose the cars guts underneath.
Step 3:
Use the 17mm socket to remove the oil drain plug with the container underneath. There's plenty of oil in there so it's going to be a while. Meanwhile, inspect the condition of the crush washer. If it looks in bad shape, it might be a good idea to replace it. Looks good? Reuse it!
Step 4:
When the oil rush comes down to a trickle, screw in the drain plug by hand and move the container under the oil filter. It's the black cylinder shaped object forward of the car
Step 5:
On the center of the oil filter cartridge, there's a recessed hex slot. With the 6mm Allen key, remove the plug to drain the oil out the filter itself. If you're lucky, the dealership hasn't stripped yours out like mine!
Step 6:
Once the oil from the filter is gone, use the oil filter wrench to remove the cartridge. After removal, slide out the old filter.
Step 7:
With the O-rings that came with the filter replace the 2 O-rings on the cartridge by removing them with a screwdriver or similar tool. The smaller O-ring goes on the filter drain plug (picture not shown). Lube them up really good. Some people skip this step, from what I've read and heard. I went ahead and replaced mine. Shit, they're new, right?
Step 8:
Slide in the new filter and screw the oil filter cartridge on, then tighten snugly.
Step 9:
Now go back to the oil drain plug that was screwed by hand and take it out one last time. More oil will come out. After the last of the oil has came out screw and tighten the drain plug. Was the crush washer in good shape?
Step 10:
Add you oil of choice. The manual says 5.7 gts. I added about 5.5 and it was a bit overfilled to where it said "MAX" on the dipstick. Check for any leaks upon filling.
(7 qts for those who have done the BSD)
Step 11:
Drive the car around a few blocks and raise it up to check for any leaks. No leaks? Alrighty, put the belly pan back on! Done!
Edit to add: Specs!
Per the MS6 Fluid Notes & DIY Pictures post
5.5 - 6 qts
7 quarts with Balance Shaft removed
'06 MS6 Manual - 5W-30
There's a strong argument being made that 5W-40 is better
as the slightly thicker viscosity will not seep past the seals
in the turbo and may help prevent the smoking turbo syndrome.
Oil Filter - cartridge style
Oil Filter Part Numbers:
FL-2017B - Motorcraft/Ford OEM cartridge oil filter
L321-14-302-9U - Mazda OEM cartridge oil filter
7203 - Napa Gold cartridge oil filter (made by Wix)
57203 - Wix cartridge oil filter
L15505 Purolator Premium Plus cartridge oil filter
PL15505 Purolator Pure One cartridge oil filter
GL15505 O'Reilly's/Microgard cartridge oil filter
P7313 - Baldwin cartridge oil filter
HP-7013 - K&N cartridge oil filter (made by Champion Labs)
84203 - Carquest cartridge oil filter (made by Wix)
LF594 - Hastings cartridge oil filter
CH9641 - Fram cartridge oil filter
P960 - Champ cartridge oil filter (Champion Labs, makes oil filters for other companies)
S9641 - STP cartridge oil filter (made by Champion Labs)
M1C153 - Mobil1 cartridge oil filter
Oil Filter Wrench - 76mm/14 flutes
Crush Washer-
Mazda OEM - part# 9956-41-400
Drain Bolt torque specs - 23-30 ft-lbs
**NOTE - Short interval oil changes- fuel shear from DISI is bad mojo
roppy84 and sarm1084 like this.
340hp / 371tq
The Following 16 Users Say Thank You to TiGraySpeed6 For This Useful Post:
6ixof1 (10-10-2012), Althepal (06-06-2015), Amnesiac (05-05-2013), ArmySpeed6 (06-15-2013), AtTheDriveIn (10-10-2012), Coats (09-17-2013), Escapist (05-04-2016), MATT DAMOND (10-10-2012), mczimer (10-10-2012), moomooz12 (01-01-2013), Murcielago311 (03-03-2014), PapaShultz (06-29-2013), sarm1084 (04-24-2018), We Are Ninja (02-16-2013), xI Leveler Ix (10-10-2012), Zoomer_Esiason (11-14-2015)
 Old 10-10-2012, 09:11 AM   #2
Two nuns and a pack mule
AtTheDriveIn's Avatar
Posts: 1,527   (View Stats)
AtTheDriveIn is the leader of the worldAtTheDriveIn is the leader of the worldAtTheDriveIn is the leader of the worldAtTheDriveIn is the leader of the worldAtTheDriveIn is the leader of the worldAtTheDriveIn is the leader of the worldAtTheDriveIn is the leader of the worldAtTheDriveIn is the leader of the worldAtTheDriveIn is the leader of the worldAtTheDriveIn is the leader of the worldAtTheDriveIn is the leader of the world
Hehe... back when I was a noob.
No wait. I'm still a noob.
AtTheDriveIn is offline   Reply With Quote
The Following User Says Thank You to AtTheDriveIn For This Useful Post:
 Old 10-10-2012, 09:21 AM   #3
3Gee Tee's Avatar
Posts: 1,533   (View Stats)
Good write-up. I plan on doing the spin-on conversion during my next oil change because I hate how messy the cartridge can get.
 Old 10-10-2012, 09:35 AM   #4
Neutral  +1 score
Added a bunch of cartridge filter part numbers and other specs
sarm1084 likes this.
340hp / 371tq
impossible (05-12-2016), sarm1084 (04-24-2018), xI Leveler Ix (10-10-2012)
 Old 01-22-2013, 04:00 PM   #5
PPD369Speed3's Avatar
Posts: 785   (View Stats)
PPD369Speed3 is the leader of the worldPPD369Speed3 is the leader of the worldPPD369Speed3 is the leader of the worldPPD369Speed3 is the leader of the worldPPD369Speed3 is the leader of the worldPPD369Speed3 is the leader of the worldPPD369Speed3 is the leader of the worldPPD369Speed3 is the leader of the worldPPD369Speed3 is the leader of the worldPPD369Speed3 is the leader of the worldPPD369Speed3 is the leader of the world
Groaned at 97 Times in 19 Posts
Neutral  -1 score
I did my first oil change today and my car does not have that type of oil filter. It has a screw on tin can. I have a 2011 Genpu. I actually looked up the part number and the dealership put on an oil filter to a regular Mazda 3.
Sent from my SGH-T989 using Tapatalk 2
2011 Speed3
BNR S3 / HTP 3" Intake / Grimspeed EBCS / AT Internals / Cobb AP / UR Catless TBE / ETS TMIC / Forge V1 BPV / JBR 88 Duro RMM / Eibach Pro kit / SPC Camber Arms
Freektune in progress
PPD369Speed3 is offline   Reply With Quote
 Old 08-27-2015, 05:49 PM   #6
mrshimon's Avatar
Posts: 10   (View Stats)
mrshimon has a little shameless behaviour in the past
I noticed that there's only a couple FRAM filters listed here. Does anyone have a clue if FRAM XG9641 is ok in the car? According to them it is supposed to be ok in the MS6.
mrshimon is offline   Reply With Quote
 Old 08-27-2015, 05:51 PM   #7
shurik's Avatar
Posts: 278   (View Stats)
shurik has a reputation beyond reputeshurik has a reputation beyond reputeshurik has a reputation beyond reputeshurik has a reputation beyond reputeshurik has a reputation beyond reputeshurik has a reputation beyond reputeshurik has a reputation beyond reputeshurik has a reputation beyond reputeshurik has a reputation beyond reputeshurik has a reputation beyond reputeshurik has a reputation beyond repute
That's what I used and it was fine
shurik is offline   Reply With Quote
 Old 08-27-2015, 06:08 PM   #8
mrshimon's Avatar
Thanks @shurik; I was afraid I bought a wrong part
shurik likes this.
 Old 09-24-2019, 08:24 PM   #9
aviator79's Avatar
Posts: 3,934   (View Stats)
I bought 10 wix for $45 from https://www.filter1.com/
Bought in Jan 2015.
Just ran out.
Just bought 9 for $50 same place. Code moparts gets $3 off so not as good a deal but still half price napa.
Drive 140mi/day now so I go thru them.
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f111/how-mazdaspeed-6-mazdaspeed-3-oil-change-127005/
How-To: MS6 & MS3 Oil Change - Mazdaspeed Forums | Zoom Zoom This thread Refback 07-30-2013 10:58 PM
Oil filter tool ? Mazda MPS Owners Club This thread Refback 02-07-2013 02:46 AM
Oil filter tool • Mazda MPS Owners Club This thread Refback 10-20-2012 05:11 AM
First oil change doctavus Gen2 MS3 General Discussion 54 02-27-2012 10:11 AM
Oil Change snOhio 2010 MS3 - How-To's 29 10-30-2011 01:47 PM
Went For Oil Change Silver Ecstasy CX-7 > Engine, Transmission & Driveline 4 07-07-2011 09:23 PM
Man buys truck with change, LOTS of change Haltech Automotive News 1 08-14-2008 09:15 AM
Page generated in 0.33758 seconds with 26 queries
