| ![]() | LinkBack | Thread Tools | Search this Thread | Display Modes |
![]() | ![]() | #1 | ![]() |
(Thread Starter) | ![]() ![]() ![]() In the past this meant trying to find an overpriced sensor,usually in the range of $90-$125, and then having to cut the OEM plug off and solder the wires for the correct plug. There was a premium price since the MAP used by Mazda not only reads boost pressure, but has a built in Temp sensor, which even now, years later, is a nice touch, and fairly unusual in the USA. Frankly, it was both expensive & a PITA, and that kept many people from making a very intelligent upgrade. NO MORE- 3 BAR MAP + PNP Harness no soldering, plug n play, completely reversible to stock, and can be re-sold later as a kit if you stock out. Under $100 for everything! Ballenger Motorsports Bosch 3 BAR MAP with Temp - $29.99 their PN SNSR-03085 Bosch # 0 281 002 845 Home » Shop » Sensors » Pressure Sensors » Bosch 3 Bar TMap Map Sensor with IAT Plug-n-Play Mazdaspeed MAP Harness - $60 shipped The OEM Mazda MAP sensor uses a proprietary connector. This harness will convert that connector into a more standard Bosch connector for use with a wider range of MAP sensors. Mazdaspeed MAP Harness - Bitwise Motorsports Corrections to the tune must be made! For ATR (not sure if VT is same terminology) If you run the HT, you're out of luck... -> Bring the laptop to your car, fire up ATR and connect it through your AP to the ECU. Through the View menu, set Dashboard so you can view Boost. Dashboard gauges can be set through Options>Gauge List. With the Key On & Engine Off (KOEO) note what it reads for boost. Mine read -0.16. on the stock MAP sensor. You're going to want to end up with your KOEO boost as close to 0 as you can get. For the 845 MAP sensor, you need to change three sets of MAP Scaler tables, found in the Sensor Cal folder. These are all those other tables in the same place as where you make the MAF Cal changes. Three sets of tables, EM, Log & OBD, make the same changes in all three set, 9 individual tables. ========================= UPDATE: Much of the remainder of this post is dedicated to finding the best values to enter in the Offset table. While this manual process still works as well as ever there is also a new set of values which have been in use for months now and have proven to be consistent & accurate. Later in this thread @rfinkle2; shares the math he used to define these numbers, and they've worked well across the country. You can feel free to just use these and know you're probably going to be more accurate than the original values were with the stock MAP sensor... Scalar A - 296 Scalar B - 0.22 Offset - 5.444 Thanks Rob! Working magic like always! ========================= -=> The original method: Scalar A - 65.78 Scalar B - 1 Offset - will end up somewhere between 8.35 to 5.44 The Offset is the one that you need to change to find which value gets you closest to 0. After testing the three most common, I ended up using 6.00. Those three common used reference values are 5.44, 6.50 & 8.35. Below are the values I found. oem: -0.16 5.44: +0.06 6.50: -0.08 8.35: -0.37 6.00: -0.01 <--- Where I ended up after testing the common values Here's an example of the dashboard boost gauge when I had the 5.44 scaler loaded- *remember, key on, engine off* These settings are also discussed in the ATR Help File. You've read the help file, right? (stern look.....) So, start by getting the stock KOEO Boost reading so you have a baseline, then go ahead & swap the map sensor. Next load a map with updated scaler & offset values and check the KOEO Boost. Since it's doubtful you'll be close to 0 with this first revision change just the three offset tables to another of the three baseline values, flash the map, check the KOEO Boost again. Repeat till you determine what offset gets you closest to 0. The offset value needed seems to be slightly different from car to car. It only takes a few moments to make the offset changes & flash the map, so go ahead & try all three common values to get a feel for how they change the KOEO boost reading. You want a offset value that gets you close to 0. The three common used reference offset values again: 5.44, 6.50 & 8.35, and you may well end up using an offset value of your own like I did. I used a offset value of 6.00 to get a KOEO Boost reading of -0.01. All told, it took me ~30-40 minutes from on ramps (to save my back) to off ramps & test drive, including testing the four different versions of offset listed above, to complete this project. Once your set you'll have a accurate boost readings up to about 30psi. If you're feeling particularly froggy, they make a 3.5 BAR, even a 4 BAR....
__________________ Was a Mazdaspeed6 GT #3476 TiGray slicktop Now in a BMW 135i - double the turbos, double the fun! E82.N54 2009 / BSM / A/T / Drop-in / PR CP / Berk Street / MHD / xHP 340hp / 371tq Last edited by TiGraySpeed6; 10-31-2014 at 04:39 PM. |
The Following 105 Users Say Thank You to TiGraySpeed6 For This Useful Post: | 2.0t03speed (12-28-2013), 802MS3 (10-30-2012), Agent_Orange (06-20-2013), Alpha (06-02-2013), altaprecision (05-02-2014), aromig (12-23-2014), atvfreek (10-30-2012), Axel907 (03-30-2013), AZSPEED3 (11-01-2012), big angry bird (04-10-2013), BlueStreak (11-01-2012), boostdmazda3 (04-27-2013), Boosted Beluga (06-02-2013), Boost_creep (10-30-2012), brandonlee (02-19-2014), breakfstincluded (07-10-2013), bstover17 (12-27-2013), Castillo817 (02-15-2016), ccspeed3 (10-30-2012), Cevaes_64 (06-05-2013), Code Monkey (10-30-2012), Dahouse702 (07-14-2013), dantes5823 (10-31-2012), DaUberSchwebel (08-14-2014), DISIindahead (11-01-2012), dot584 (07-28-2013), Dr. Speed (11-19-2012), dshrek (11-01-2012), DuBz (08-20-2013), EdgeAutosport.com (02-14-2014), El_Diablo (07-14-2013), Eric28243 (11-01-2012), ericrapp0507@gmail.com (04-16-2016), Fonsi (01-03-2017), forgedzoomzoom (02-03-2013), Franky-5-Fingaz (04-21-2017), FSRRM (05-10-2016), Funguy7 (02-01-2016), GunGuru727 (10-30-2012), Haltech (10-30-2012), helmetface (11-01-2012), Hush (05-24-2014), IamJamen (05-18-2013), IMASA (10-30-2012), ItsNox (05-28-2014), Javi (04-27-2013), JeffroMS3 (03-16-2014), Jh8909 (10-30-2012), JTMS3 (06-15-2013), Keko (10-30-2012), Kellerspeed3 (03-16-2014), Kfunk (04-27-2013), LatinKraze (01-10-2013), littleloogy (07-18-2015), Lost hawaiian (11-01-2012), MattJackson86 (01-19-2013), Mazda2012 (12-14-2015), MD1032 (05-11-2015), meelo88 (04-16-2013), meicalnissyen (01-01-2017), MicaBlackMS6 (11-01-2012), Micha (02-17-2013), mike w (02-09-2013), Mike@Stratified (02-15-2014), mituc (11-01-2012), moomooz12 (04-22-2013), MS3-a(sore)ASS-rex (11-01-2012), ms3blackmica (03-13-2013), ms6mil (07-15-2013), nesiospeed (04-06-2015), Outlaw4shrt (04-08-2013), ozziewog (08-03-2013), pbonn617 (02-22-2013), phate (10-30-2012), PhorB13 (04-18-2015), Playaj (12-21-2013), Pointless (10-30-2012), Poohster (11-02-2012), Randallpw (09-10-2015), Rich990 (07-05-2013), SamiChicago (08-04-2014), shadesofgray19 (08-02-2013), Sid3wayS (10-30-2012), sleeperstang1994 (02-15-2014), Sleepin6 (01-06-2016), SLOWHATCH (10-30-2012), Snappy (11-22-2015), spals (06-27-2014), SpeedRebirth (10-31-2012), sporkbomb (03-18-2015), The Nut (09-16-2013), thricestrat (09-16-2013), Tomas (07-18-2013), Tommyspeed3 (05-29-2017), torquemaniac (11-04-2013), trf5000 (11-01-2012), txmedic512 (08-22-2014), udntknw (08-30-2015), UnknownSuperhero (10-30-2012), UrbanGiftShop (11-01-2012), Vader (10-30-2012), Vansquish (04-10-2019), WetzMS3 (07-24-2014), Z32_MS3 (06-21-2014), Zdraveca (10-30-2012) |
![]() | ![]() | #2 | ![]() |
Banned ![]() Join Date: May 2011 Location: Louisville, KY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 23
| ![]() ![]() ![]() I need to order one! I can't PM anyone yet =X Please PM me? |
![]() | ![]() | #3 | ![]() |
(Thread Starter) | ![]() ![]() ![]() Who- Me?? I'm not selling anything- There are links up there for both the plug n play harness adapter and for a great deal on the MAP sensor that will take you right to the vendor - easy peasy ![]()
The Following 2 Users Say Thank You to TiGraySpeed6 For This Useful Post: | stonecold0469 (01-07-2015), UrbanGiftShop (11-01-2012) |
![]() | ![]() | #4 | ![]() |
![]() Join Date: May 2010 Location: Colorado Springs, CO 80915
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 921
| ![]() ![]() ![]() Glad I saw this. Now I understand a little more about what's available. Great write up. @sassyspeed3 installed my 3 bar last night and thanks to @rfinkle2 for continuing to tune me. I need to catch up with the wife. No way will I let my own wife make more power than me lol Sent from my Motorola DynaTAC 8000X
__________________ 2010 Mazdaspeed 3 - Built Motor - GTX3071: SOLD 2012 Jeep Wrangler Unlimited Sport: Current DD |
The Following 2 Users Say Thank You to DISIindahead For This Useful Post: | ms3blackmica (11-02-2012), rfinkle2 (11-01-2012) |
![]() | ![]() | #5 | ![]() |
Rep Power: 1237 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,288
Groans: 111
| ![]() ![]() ![]() For those who are tuning with VersaTuner this is the section that you need to look at: The MAP Scale Additive corresponds to the Offset value above, MAP Scale Base Multiplier is the Scalar A and the MAP Scale Second Multiplier is the Scalar B.
The Following 10 Users Say Thank You to mituc For This Useful Post: | keridil (11-05-2012), manselainen (02-15-2014), meicalnissyen (12-19-2016), ms3blackmica (06-12-2013), Project_dog (06-26-2016), rfinkle2 (11-01-2012), SarcasticOne (01-08-2013), SpeedRebirth (03-09-2013), TiGraySpeed6 (11-01-2012), UrbanGiftShop (11-01-2012) |
![]() | ![]() | #6 | ![]() |
![]() Join Date: Dec 2009 Location: San Antonio, TX
Rep Power: 5050 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 28,143
Groans: 146
The Following User Says Thank You to pzr2874 For This Useful Post: | dshrek (11-01-2012) |
![]() | ![]() | #7 | ![]() |
![]() Join Date: Apr 2011 Location: Nahant, MA
| ![]() ![]() ![]() Thanks a lot for this write up, I just came from my tuner's shop on a mission to find an upgrade to the stock MAP sensor, as I'm having issues running boost levels over 21psi, and I didn't want to splice wires or anything like that. You have saved me time and money! |
The Following User Says Thank You to guerrero1977 For This Useful Post: | TiGraySpeed6 (04-27-2013) |
![]() | ![]() | #8 | ![]() |
![]() Join Date: Dec 2011 Location: Virginia
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 715
Groans: 30
__________________ Stance will make her dance, but boost will make her sploosh
2014 Mustang GT | ||
![]() | ![]() | #9 | ![]() |
(Thread Starter) | ![]() ![]() ![]() relevant now as the day it was drafted. Glad it was of assistance!
![]() | ![]() | #10 | ![]() |
![]() | ![]() | #11 | ![]() |
![]() Join Date: Jun 2009 Location: Riverside, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 11,560
Groans: 50
| ![]() ![]() ![]() Thank you. I'm getting a 3.5 BAR soon for the gtx3071. I plain on running around 30psi. ![]()
__________________ 08 Mazdaspeed 3 Fucking FREEK TUNED and shit |
The Following User Says Thank You to Boosted Beluga For This Useful Post: | TiGraySpeed6 (06-02-2013) |
![]() | ![]() | #12 | ![]() |
(Thread Starter) | ![]() ![]() ![]() You'll want different settings for a 3.5 BAR- These are from the ATR Help File: Bosch #: 0 281 002 456 Scaler A: 75 Scaler B: 1 Offset: -12.5 as a starting point (that's negative 12.5) note that you will most likely still need to tinker with the offset to get your car as close to KOEO boost pressure of zero as possible, and be sure to use the Dashboard function- the AP is nowhere near as accurate
The Following 2 Users Say Thank You to TiGraySpeed6 For This Useful Post: | Boosted Beluga (06-02-2013), torquemaniac (05-10-2014) |
![]() | ![]() | #13 | ![]() |
Groans: 50
| ![]() ![]() ![]() Thank you sir.
![]() | ![]() | #14 | ![]() |
![]() Join Date: Mar 2013
Rep Power: 0 ![]() Thanks: 3
| ![]() ![]() ![]() Can i use this sensor with the plug n play harness? Does this unit has the temp. Sensor included? Bosch 0 281 002 437 |
![]() | ![]() | #15 | ![]() |
![]() Join Date: Feb 2009 Location: Chambersburg, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,921
Groans: 338
| ![]() ![]() ![]() I believe so...iirc correctly there are 2 3bar sensors out there...and the 437 will require a different calibration.
__________________ Current: N54 135i DCI, DP's, Exhaust, FMIC 12.3@122 2009 Mazdaspeed 3: GT3076 - Corkey tuned Treadstone 3" MAF, HTP 3" turbo inlet, MSCBE, Turbo XS FMIC, CNT catted DP, CP-E HPFP, Tial QR BPV, SURE TIG's, ITV24's, CP-E Stage 2 RMM, Medefail Tranny mount, 18x8 245/40's 390whp/400wtq 12.8@114 Sold |
![]() | ![]() | #16 | ![]() |
| ![]() ![]() ![]() Will the pigtail fit this one? I will try this soon. I want 25 psi on my precision!!! |
![]() | ![]() | #17 | ![]() |
![]() Join Date: Oct 2012 Location: TAMPA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 962
| ![]() ![]() ![]() Just ordered mine... =) Moar Booost...
__________________ 2013 VRM MS3\ BNR S3v2\ 4GL E85 TUNED\ |
![]() | ![]() | #18 | ![]() |
Iron Man ![]() Join Date: Apr 2011 Location: Albuquerque, NM
Rep Power: 726 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,014
| ![]() ![]() ![]() Thanks for the write up. Just bought the 3 BAR MAP sensor to finish my BT build. Will be installing tomorrow
__________________ Precision 6266 Top mount Southbend Stage 3 Race clutch Water to Air Intercooler Methanol Injection-50/50 e85 mix Hulk Smash |
![]() | ![]() | #19 | ![]() |
![]() Join Date: Apr 2013 Location: Wilkesboro, North Carolina
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,221
| ![]() ![]() ![]() anyone know if you can use more than 5.44, 6,0, 6.5, and 8.35? Like for example can I set the offset for 6.65? |
![]() | ![]() | #20 | ![]() |
(Thread Starter) | ![]() ![]() ![]() Yes, you can, and you're encouraged to find the value that brings you closest to KOEO 0.00 boost pressure. nothing wrong at all with using the offset of 6.65
![]() | ![]() | #21 | ![]() |
| ![]() ![]() ![]() Thanks again for the write up. Very helpful!! I ended up with a 5.7 offset to get a -0.03. ![]()
![]() | ![]() | #22 | ![]() |
![]() Join Date: Apr 2008 Location: San Diego, CA
Rep Power: 493 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 666
| ![]() ![]() ![]() Going to try this. Thanks for the links. |
![]() | ![]() | #23 | ![]() |
| ![]() ![]() ![]() MAP swap = EGR delete? |
![]() | ![]() | #24 | ![]() |
![]() Join Date: Jun 2011 Location: Beach Park Illinois
Rep Power: 2610 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 46,278
| ![]() ![]() ![]() That looks nice ferd. |
![]() | ![]() | #25 | ![]() |
| ![]() ![]() ![]() I really need to find a place where I can run a bottle if seafoam up the brake line. I don't have the nerve to do it at my house. |
![]() | ![]() | #26 | ![]() |
![]() Join Date: Dec 2011 Location: Wooster Oh, 44691
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 17,721
Groans: 769
| ![]() ![]() ![]() Find a random parking lot in the next town over....
__________________ 2011 Mazdaspeed 3- AccessPORT V2, Autotech HPFP Internals, 3 Bar MAP Sensor, 3" Catless Downpipe, CPE Stage 2 RMM, CPE TMM, Custom Saikou Michi OCC, CXR FMIC, Devils Own DVC-30, Forge V2 BPV, 3.5" HTP Intake, JBR TIG's, MME Shifter Bushings, NGK LTR7IX-11's, PNP Intake, SPEEDPERF6MANC3 Valve Cover Breather 2004 Mazdaspeed Miata #3142- Stock, but not for long. ![]() Equal rights for all, special privileges for none. ~ Thomas Jefferson |
The Following User Says Thank You to El_Diablo For This Useful Post: | Mauro_Penguin (08-13-2013) |
![]() | ![]() | #27 | ![]() |
| ![]() ![]() ![]() for some reason my map voltage never goes above 1.01v. Last log i done it ranged from .11v to 1.01v. I have to have something off? I used: A - 65.78 B - 1 Offset - 6.6 6.6 will read -.06 KOEO. |
![]() | ![]() | #28 | ![]() |
(Thread Starter) | ![]() ![]() ![]() Does the boost psi read accurately? That's the key question, and can be answered by comparing logs from just before and just after your install and configuration of the MAP sensor. As for MAP Voltage- that's not something the AP logs. Are you thinking of MAF Voltage? Do you have a log of this behavior you could post?
![]() | ![]() | #29 | ![]() |
| ![]() ![]() ![]() my AP monitors MAP voltage? |
![]() | ![]() | #30 | ![]() |
(Thread Starter) | ![]() ![]() ![]() Actually, the Gen2 does log MAP Volts. It's not an item I've ever had a need to log, and therefore not part of my default items I have people log. Had to pull up a copy of the gen2 ATR and double check. Unless you've got logs from before where it's reading higher, or your boost is reading off from what you're expecting I wouldn't worry about it. That said, anybody with a gen2 willing to log MAP V and share what you see & what MAP sensor you're using?
![]() | ![]() | #31 | ![]() |
Groans: 769
| ![]() ![]() ![]() Does anyone happen to know if the 03085 sensor will work with the Speedperf6manc3 plug and play harness? They don't currently show the 03085 as being compatible.
The Following User Says Thank You to El_Diablo For This Useful Post: | superskaterxes (09-06-2013) |
![]() | ![]() | #32 | ![]() |
(Thread Starter) | ![]() ![]() ![]() Yes, it does- order it up! Ballenger shows their own internal part number (03085), which is the sensor commonly referred to here as the Bosch 845, and is shown on SP's page with the full number (0 281 002 845) So no problem- have at it! ![]()
The Following 3 Users Say Thank You to TiGraySpeed6 For This Useful Post: |
![]() | ![]() | #33 | ![]() |
![]() Join Date: Apr 2012 Location: Los Angeles
Rep Power: 426 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 956
| ![]() ![]() ![]() So happy I just found this thread. I've been wondering how accurate my boost readings are since I started logging again for the new Corksport BPV and the fact that I'm showing spiking. Been thinking about this upgrade and thanks to OP, it seems really straight forward. Mahalo!
__________________ 2012 BLACK MICA w/TECH Go: Cobb- AP(v2)//AT- Internals//ETS- TMIC//CorkSport- True 3" Intake/Camber Plates/BPV/Boost Tubes/Recirc Tube//Denso- ITV22's//NATOR- TP//JBR- 80a Duro TMM & PMM/SSP/Counterweight/Anchors//CP-E- Stage II RMM//Tri-Point- RSB w/Monster Endlinks//GT-Spec- 4 Points Ladder Brace/Mid Chassis Brace/Front 4-Point Brace/Front & Rear Lower Tie Bar/Trunk Reinforcement Brace//Bosch- 3 Bar MAP Sensor//Technafit- SS Brake Lines//KW- v3 Coilovers//Swift- Springs (8K front/6K rear)//BC- Rear Spring Perches Shoes: MB- Battles (Matte Gunmetal) 18X8 +43 wrapped wit Michelin PSS's 245/35/ZR18 Rice: Tint//Blacked Out Badging//CorkSport - Hoodlifts/Engine Compartment LEDs//JBR- Special Edition Cylindrical Knob Stereo: Full Custom Mobile Audio/Video Entertainment System 91 & Corn diagnostics by: ![]() |
![]() | ![]() | #34 | ![]() |
![]() Join Date: Apr 2012 Location: Manchester, NH
| ![]() ![]() ![]() Any idea if the following connector is what you need in place of the $65 piece you linked in the original post? Bosch 4-way sealed Plug BSK Connector Pigtail for Bosch MAP Sensor Saw it listed with the Bosch 3 bar map sensor on Edge and wasn't sure due to lack of a picture..
__________________ Flow Student '07 Speed6 TiGrey: SURE ID300/Shift Plate+Weight/Breather Hose, Forge BPV v2, CX-7 Antenna, ProSport Boost Gauge, Block8Head's MS6 Pod, Cobb AP v3, ITV22 1SC Plugs, TWM Short Shift, Stage 2 Clutch, JBR Shifter Bushings/Shift Knob/RMM/EGR Delete, Euro LED Tails, AutoTech FP Internals, M2 DP, ETS TMIC, Techna-Fit SS Brake Lines/Clutch Line, Hawk HPS Pads, ATE 200, MD OCC VTA v2, 3-Bar MAP, AWR TMM, CP-E RDM, Whiteline RSB, RB Rear Endlinks, Moog Front Endlinks, Bilstein HD6 Shocks, Corksport Springs. ![]() |
![]() | ![]() | #35 | ![]() |
![]() Join Date: Jul 2012 Location: Oceanside, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,654
| ![]() ![]() ![]() @Emew; I'm pretty sure that's just a standard Bosch connector to the sensor and four wires naked ready for soldering. Honestly that's the route I'm going since I am no longer stock-out-able anyway. Lol
__________________ 2010 Alternative Lifestyle Blue Mazdaspeed3 (sold)2008 Chevy Colorado. The only truck that comes with a lifetime guarantee... |
![]() | ![]() | #36 | ![]() |
(Thread Starter) | ![]() ![]() ![]() At that price I'd presume it's not the completed pigtail assembly. Bitwise sells just the connector assembly for $25
![]() | ![]() | #37 | ![]() |
| ![]() ![]() ![]() Just curious, but after reading the help file in ATR it shows that the offset used for the Bosch 845 sensor should be -5.41. Obviously it's incorrect, since everyone who's following the steps here are getting good results with positive numbers, so why is it so far off?
__________________ JBR 3.5" whale penis intake, HTP polished battery tray, PnP stock intake manifold w/VCTS delete (by Kmac), Corksport TMIC, Forge V2 BPV, JBR TIG's, Kozmic EGR delete, Cobb AP, PTP HPFP internals, stock TBE w/gutted cats, JBR RMM, SU PMM and TMM, Koni Yellow Sport struts, Swift springs, Tri Point Engineering RSB, Whiteline Anti Lift Kit, PTP Injector Seals, GenPu transmission, Fidanza flywheel, 3 BAR MAP sensor, Posifab 10.5:1 CR 88mm sexy pistons, Molnar rods, sleeved block, PTP BSD SnailTune in progress ![]() |
![]() | ![]() | #38 | ![]() |
![]() Join Date: Apr 2011 Location: Chesapeake,VA
Rep Power: 901 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 672
| ![]() ![]() ![]() i think it varies from car to car. i installed my 3 bar today and had to use a offset of 6.8 to get -.01 koeo
__________________ ![]() ![]() |
![]() | ![]() | #39 | ![]() |
| ![]() ![]() ![]() I know it varies, but the range given by Eric is all positive numbers.
![]() | ![]() | #40 | ![]() |
| ![]() ![]() ![]() @TiGraySpeed6 ; Same A-B values, Offset of 7 in every table achieved -.01 Wouldn't have been easy if not for all the lessons you've given me in ATR, thanks again! Hopefully that higher offset is acceptable! Also not sure if anyone mentioned it but every .5 in either direction of offset is equivalent to .075, I had .14 at 6 offset, by going to 7 I achieved -.01
__________________ Flow Student '07 Speed6 TiGrey: SURE ID300/Shift Plate+Weight/Breather Hose, Forge BPV v2, CX-7 Antenna, ProSport Boost Gauge, Block8Head's MS6 Pod, Cobb AP v3, ITV22 1SC Plugs, TWM Short Shift, Stage 2 Clutch, JBR Shifter Bushings/Shift Knob/RMM/EGR Delete, Euro LED Tails, AutoTech FP Internals, M2 DP, ETS TMIC, Techna-Fit SS Brake Lines/Clutch Line, Hawk HPS Pads, ATE 200, MD OCC VTA v2, 3-Bar MAP, AWR TMM, CP-E RDM, Whiteline RSB, RB Rear Endlinks, Moog Front Endlinks, Bilstein HD6 Shocks, Corksport Springs. ![]() Last edited by Emew; 02-14-2014 at 02:31 PM. Reason: MSF Database - Automerged Doublepost |
The Following 3 Users Say Thank You to Emew For This Useful Post: |
![]() LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f111/how-painless-3-bar-map-sensor-upgrade-128850/ | ||||
Posted By | For | Type | Date | |
VersaTune - View topic - bosch 3 bar MAP sensor | This thread | Refback | 06-05-2015 02:50 PM | |
COBB AccessPort V3 - Seite 16 | This thread | Refback | 05-12-2015 04:07 AM | |
VersaTune ? View topic - bosch 3 bar MAP sensor | This thread | Refback | 08-24-2014 04:05 AM | |
AZ520 Budget turbo madness!! Build - Page 18 - Mazda3 Forums : The #1 Mazda 3 Forum | This thread | Refback | 01-07-2014 01:35 PM | |
3 Bar MAF & MAP Sensors - Page 3 | This thread | Refback | 06-23-2013 01:53 AM |
Stock Fitment 3 Bar Map Sensor Upgrade | JumpingJackson | MazdaSpeed 3/6 - ECU Computer Tuning | 529 | 02-23-2017 05:15 PM |
Fuel Rail High Pressure Sensor Upgrade | JumpingJackson | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 234 | 10-25-2014 01:54 AM |
3.5 Bar Map Sensor Upgrade help | Nitr0EngiE | MazdaSpeed 3/6 - ECU Computer Tuning | 9 | 12-05-2012 11:11 AM |
Fuel Rail High Pressure Sensor Upgrade | JumpingJackson | MSF KB - Mazdaspeed 3/6 - Fuel | 234 | 09-19-2012 01:53 PM |
