> MazdaSpeed 6 - How-To's
Like Tree8Likes
 Old 10-25-2011, 06:48 PM   #1
Default HOW-TO: Replace Relief Valve (RV)
ok people seem to make a big stink about this but i have found a die hard way to get this done with MINIMAL effort
ok heres the tools you need:
14mm flex ratcheting wrench
17mm deep 3/8ths socket
3/8ths wrench to socket adapter (from harbor freight, like $3)
first you need to remove the top mount and fuel rail guard (easy peasy, search for how-to's)
then remove the clip on the RV itself. it looks like this:
removed
next attach the adapter to the socket:
slip it over the RV:
flex your wrench and make sure its facing the correct way for unscrewing the RV
put it over the end of the fitting and turn. theres barely any torque on the RV so it should come off easy.
install is just reverse of the above steps.
happy modding!
rfinkle2 and Trebor379 like this.
The Following 50 Users Say Thank You to superskaterxes For This Useful Post:
06Speed6 (02-21-2012), ak_spray (03-25-2012), Alpha (10-25-2011), Awal (06-18-2015), Awesomesauce (05-08-2012), BlueStreak (10-25-2011), BudUMfan (10-26-2012), crazyp (10-25-2011), dale_gribble (03-06-2013), daztdMS6 (11-25-2011), dougefresh_ (05-04-2012), EdgeAutosport.com (02-22-2012), Erich (03-05-2012), G Sp33dy (05-26-2015), i8urgti (04-10-2012), impossible (02-25-2016), jracer (03-17-2012), JTMS3 (03-17-2012), karl-hungus (03-17-2012), kish89 (02-17-2013), kolosok17 (08-27-2014), KusteLokal (05-17-2013), laxplayermjd (10-25-2011), letzleta (04-24-2012), Micha (11-03-2013), Mike@Stratified (06-07-2013), MS3-a(sore)ASS-rex (10-25-2011), Ms3_Miami (10-17-2012), MS6FL (08-04-2012), Nataphen (03-24-2012), p057 (09-27-2012), paveltol (04-08-2012), Prodigalson (03-14-2017), redboat (01-24-2014), rfinkle2 (10-26-2011), RichieRichness (01-01-2012), Scoobs (05-11-2012), scubasteve711 (08-28-2012), SLOWHATCH (02-20-2012), SpeedSixxx (03-17-2012), Tedspeed6 (09-16-2014), TiGraySpeed6 (11-10-2011), Toddy22587 (03-16-2012), Tokay444 (10-25-2011), Tomas (03-16-2012), tooslow10 (10-26-2011), TriO (10-26-2011), triplejumper18 (10-25-2011), uncorked11 (05-04-2012), Ziggo (10-26-2011)
 Old 10-25-2011, 07:27 PM   #2
Alpha's Avatar
Posts: 3,711   (View Stats)
So the higher rated RVs can be ran safely without tuning correct?
It's only when you target 2050 psi via tuning when the performance gain is seen?
I'm only asking since I'd like to install it, yet am unsure when I can tune for it in the foreseable future.
The Following 3 Users Say Thank You to Alpha For This Useful Post:
ak_spray (03-25-2012), helmetface (03-30-2012), redboat (01-24-2014)
 Old 10-25-2011, 08:38 PM   #3
MS3-a(sore)ASS-rex's Avatar
Posts: 7,012   (View Stats)
Groans: 224
Way to keep this shit simple Ant!
NATOR PA
The Following 2 Users Say Thank You to MS3-a(sore)ASS-rex For This Useful Post:
dougefresh_ (05-04-2012), superskaterxes (10-26-2011)
 Old 10-26-2011, 06:39 AM   #4
well why would you want to run an upgraded valve w/o tuning for it?
 Old 10-26-2011, 07:09 AM   #5
Thanks for taking the time to do the write-up.
That wrenching trick could be used on more than just the relief valve.
Thanks for the tip!
Awal (06-18-2015), Micha (12-04-2013), SLOWHATCH (02-20-2012), superskaterxes (10-26-2011)
 Old 10-26-2011, 07:10 AM   #6
Alpha's Avatar
Just seeing if it can be done...
I'm prepping the car for EFR. Trying to gradually knock out all the support mods before I put the kit on to minimize the room for error often associated with changing too many things at once.
 Old 02-20-2012, 11:35 AM   #7
Alpha's Avatar
Bump for a quick question.:
I'm doing this very soon and was wondering if any kind of teflon tape would be a good idea on the threads to avoid fuel leaking? No need?
Thanks!
 Old 02-20-2012, 11:40 AM   #8
COCKSTRONG
SofaKingAwesome's Avatar
Posts: 8,447   (View Stats)
Groans: 890
No need, but if you do use it, get the yellow label (for gas lines), not blue.
06Speed6 (02-21-2012), Alpha (02-20-2012), rfinkle2 (02-21-2012)
 Old 02-20-2012, 08:07 PM   #9
use this:
i dont know if 592 is the right version but this shit has worked flawlessly on all my gas lines.
@SilverDemon can comment on the correct # as he gave it to me haha
Awal likes this.
Alpha (02-20-2012), Awal (06-18-2015), rfinkle2 (02-21-2012), SLOWHATCH (02-20-2012)
 Old 02-20-2012, 09:23 PM   #10
spnkr21's Avatar
Posts: 2,827   (View Stats)
Groans: 105
I wouldn't use any.
There should be a crush washer.
2012 WRX HB w/mudflaps yo!
The Following 2 Users Say Thank You to spnkr21 For This Useful Post:
 Old 02-20-2012, 09:33 PM   #11
HPFPUPGRADE's Avatar
Posts: 403   (View Stats)
HPFPUPGRADE is the leader of the worldHPFPUPGRADE is the leader of the worldHPFPUPGRADE is the leader of the worldHPFPUPGRADE is the leader of the worldHPFPUPGRADE is the leader of the worldHPFPUPGRADE is the leader of the worldHPFPUPGRADE is the leader of the worldHPFPUPGRADE is the leader of the worldHPFPUPGRADE is the leader of the worldHPFPUPGRADE is the leader of the worldHPFPUPGRADE is the leader of the world
Groaned at 22 Times in 17 Posts
Thanks!
Nope, just swap the washer over from your OEM valve and tighten it down. I would give you the TQ spec, but you can barely get a wrench on the valve. so the specs would be useless.
Make sure you get it tight and everything should be leak free.
use this:
Don't use this. I will foul the seat and ball that releases the pressure from the system causing an internal leak.
It works great on fittings and what not, but the DI system doesn't like liquid sealers or any Teflon tape.
Last edited by HPFPUPGRADE; 02-20-2012 at 09:33 PM. Reason: MSF Database - Automerged Doublepost
HPFPUPGRADE is offline   Reply With Quote
The Following 3 Users Say Thank You to HPFPUPGRADE For This Useful Post:
 Old 02-20-2012, 09:37 PM   #12
Alpha's Avatar
Will do, thanks John!
 Old 02-21-2012, 03:14 AM   #13
SilverDemon's Avatar
Posts: 3,034   (View Stats)
Hahahahah!!!
Recent turn of events are sooooo disappoint......
- Douglas Adams
- Mark Twain
READ THIS----
2nd Amendment
The Following User Says Thank You to SilverDemon For This Useful Post:
spnkr21 (02-21-2012)
 Old 02-22-2012, 10:26 AM   #14
@superskaterxes This is an awesome writeup if I had a 6. On my speed 3 I have my throttle body coolant line running right past the relief valve not allowing me to get the wrench on the socket. FML Fuck that damn RV
G Sp33dy likes this.
Atticaz (03-29-2017), rfinkle2 (03-27-2012)
 Old 02-22-2012, 10:38 AM   #15
Alpha's Avatar
Thumbs up
Silly rabbit... 6 FTW!
 Old 02-22-2012, 10:42 AM   #16
It looks like i will just cut that nipple coming out of the block so I can get my wrench on and just delete my throttle body coolant lines completely
Alpha (02-22-2012), rfinkle2 (03-27-2012), superskaterxes (02-22-2012)
 Old 03-30-2012, 03:18 PM   #17
G Sp33dy's Avatar
Posts: 337   (View Stats)
G Sp33dy is the leader of the worldG Sp33dy is the leader of the worldG Sp33dy is the leader of the worldG Sp33dy is the leader of the worldG Sp33dy is the leader of the worldG Sp33dy is the leader of the worldG Sp33dy is the leader of the worldG Sp33dy is the leader of the worldG Sp33dy is the leader of the worldG Sp33dy is the leader of the worldG Sp33dy is the leader of the world
Groaned at 7 Times in 3 Posts
does anyone have a stock RV part # I am trying to search the part on mazda-parts.com with no luck. Good writeup too! RIght now I'm getting a slight FP drop in the lower rpms after autotech install.
08 MGM::BNR S3:: PG-TR8 FMIC::Autotech HPFP:: Yota Injector Seals:: HTP 3.5":: Grimmspeed ECBS::gutted DP and TP:: FREEKTUNE:: 3bar:: Forge V1:: Koni yellows and corksport springs::: TB & IM thermal gaskets:: CNT cat back:DM 6k:: 30% tint:: shaved doors:: RPF1 17x8:: MD OCC::
'99 XJ, 3.5" lift, ARB front bumper, magnaflow exhaust on 31's
G Sp33dy is offline   Reply With Quote
 Old 04-29-2012, 06:30 AM   #18
Decepticon's Avatar
Posts: 1,221   (View Stats)
Decepticon is the leader of the worldDecepticon is the leader of the worldDecepticon is the leader of the worldDecepticon is the leader of the worldDecepticon is the leader of the worldDecepticon is the leader of the worldDecepticon is the leader of the worldDecepticon is the leader of the worldDecepticon is the leader of the worldDecepticon is the leader of the worldDecepticon is the leader of the world
Groaned at 43 Times in 28 Posts
the part # is L3K9132J0
06 MS6, Cobb AP, -TUNED on corn mix, KMD v2 fp internals, NGK Iridium IX sp, Cp-e Xcel NANO, PG tip, SU bpv, AWR rear MM, Jbarone shifter plate and bushings, ATP catted dp, Corksport catback, Altered Custom fmic, H&R springs...
R.I.P. 08.5 MS3, Cobb Ap, KMD v2 fp internals, Denso ITV22 sp, Cobb Sri, TurboXS bpv, SU rear mm, SU shifter bushings, ETS TMIC, SU boost tubes, Cp-e catted dp, Enkei EKM3.
Decepticon is offline   Reply With Quote
The Following User Says Thank You to Decepticon For This Useful Post:
 Old 05-04-2012, 09:31 AM   #19
you cant buy the RV by itself, you have to buy a whole new rail.
 Old 05-04-2012, 03:33 PM   #20
It looks like you can order just the valve....
- Douglas Adams
- Mark Twain
READ THIS----
2nd Amendment
The Following 3 Users Say Thank You to SilverDemon For This Useful Post:
Micha (11-03-2013), Ms3_Miami (10-17-2012), rfinkle2 (07-25-2012)
 Old 05-04-2012, 03:43 PM   #21
WTF!!!!
i called jason @ onlinemazdaparts like 2-3 months ago and you couldent get it then. ugh FML
 Old 05-04-2012, 04:05 PM   #22
dougefresh_'s Avatar
Posts: 4,489   (View Stats)
Just stumbled upon this. Nice write up Ant!
 Old 05-04-2012, 04:21 PM   #23
WTF!!!!
Well, it's apparent that Jason does not like you.....hahaha
- Douglas Adams
- Mark Twain
READ THIS----
2nd Amendment
 Old 07-25-2012, 02:04 PM   #24
himurax13's Avatar
Posts: 4,585   (View Stats)
Groans: 255
Subbed for later.
Pickles Tune in progress
Alpha (07-25-2012)
 Old 10-26-2012, 12:19 AM   #25
SleeperHatch's Avatar
Posts: 3,138   (View Stats)
Bumping this thread...do you guys just buy a new OEM RV or and upgraded one?
2009 CWP Speed3
 Old 03-06-2013, 02:22 PM   #26
dale_gribble's Avatar
Posts: 4,720   (View Stats)
Thanks for the write up dude. I picked up the stuff at harbor freight for this swap tonight using your exact recommendations.
MINI H1 6.0 - CAR LED TAILS
 Old 03-06-2013, 02:35 PM   #27
stuntz89's Avatar
Posts: 169   (View Stats)
stuntz89 is the leader of the worldstuntz89 is the leader of the worldstuntz89 is the leader of the worldstuntz89 is the leader of the worldstuntz89 is the leader of the worldstuntz89 is the leader of the worldstuntz89 is the leader of the worldstuntz89 is the leader of the worldstuntz89 is the leader of the worldstuntz89 is the leader of the worldstuntz89 is the leader of the world
if there's no harbor freight near you and you dont want to buy(or steal) a whole wrench set, you can get similar results with a flex head ratchet handle and a deep 17mm
#3527. On genpus for winter >=)
5zigen Hyper 5ZR for summer
Magnaflow CBE, CPE Catted DP, Corksport stage 2 SRI w/Corksport TIP, Turbosmart Dual Port BOV, 8000k HID Foglights,Block8head Vent pod w/52mm Prosport Boost Gauge, AWR RMM, AWR Passenger Side MM, JBR TMM, Bilstein HD Shocks Rear, Koni Sport Shocks Front, H&R Sport Springs, STI front lip, 35%Tint all around, Cobb AP, ACT 6 Puck Disc w/ ACT prolite Flywheel, Motul M300 Trans Fluid,PTP CDFP internals, Whiteline RSB, Corksport Rear Diff Mount, JDMGOODIE OEM Vent Visors, Mirimoto Mini HD Bixenon Projectors, ETS TMIC, Tuned by boost_creep ...
Tune in progress 8)
im on my way
h
stuntz89 is offline   Reply With Quote
 Old 03-06-2013, 02:48 PM   #28
kish89's Avatar
Posts: 292   (View Stats)
kish89 is the leader of the worldkish89 is the leader of the worldkish89 is the leader of the worldkish89 is the leader of the worldkish89 is the leader of the worldkish89 is the leader of the worldkish89 is the leader of the worldkish89 is the leader of the worldkish89 is the leader of the worldkish89 is the leader of the worldkish89 is the leader of the world
I removed RV just with 17mm open-end wrench, so you probably don't need to buy anything..
But instructions were really helpful, because I didn't have a clue what RV was
06 MS6, Versatuner, Stratified Tuned
BNR Stage 3 turbo, Eagle con. rods, HTP Full 3" intake + AEM DryFlow filter
Autotech HPFP internals, Forge V1 BPV
Custom 3" cat-back with stock mufflers, M2 3" catless Downpipe
Grimmspeed EBCS + Stratified Boost Dial, 3BAR BOSCH MAP
NGK Iridium IX one step colder plugs, CPE SafeSeals & studs
Custom FMIC with 2.5" piping and Treadstone TR8 IC
SnowPerfomance WMI, Stratified Guardian Angel
Eibach pro kit lowering springs
kish89 is offline   Reply With Quote
The Following 3 Users Say Thank You to kish89 For This Useful Post:
redboat (01-24-2014), superskaterxes (03-08-2013), Varomnia (03-31-2017)
 Old 03-08-2013, 12:04 PM   #29
i also just removed this with a shorty ratcheting wrench using the closed end.
kish89 (03-09-2013), redboat (01-24-2014)
 Old 06-07-2013, 09:40 AM   #30
Aero's Avatar
Posts: 24   (View Stats)
Aero is a splendid one to beholdAero is a splendid one to beholdAero is a splendid one to beholdAero is a splendid one to beholdAero is a splendid one to beholdAero is a splendid one to beholdAero is a splendid one to behold
Hey, I've been trying to remove this and can't seem to get at the valve to remove the fuel line or put a socket on it. How exactly am I supposed to remove the fuel rail guard (aluminum thing covering the hard fuel line)? You mentioned searching and reading a how-to on the subject but I didn't find one
Aero is offline   Reply With Quote
 Old 06-07-2013, 10:02 AM   #31
mrmonk7663's Avatar
Posts: 2,997   (View Stats)
There are I believe 3 bolts that hold the fuel rail guad on. Remove the bolts and wiggle the thing off.
2011 Speed3-BT and shit
TEAM LBN BEERS -- FYCN
TEAM MUMFORD -- FYCN
 Old 06-07-2013, 10:17 AM   #32
Aero's Avatar
How hard of a wiggle are we talking? I already removed the three bolts, but it seems to be very solidly stuck still. I also got the fuel line off, I'm just still having an issue with getting the valve off. I can get a ratchet on it, but I can't get enough movement for the ratchet to click.
 Old 06-07-2013, 11:14 AM   #33
mrmonk7663's Avatar
If all bolts are off then it should seperate from manifold. Use pull it towards u with a quick tank. Once it separates then it will pass over line and u can take it out. For the rail valve...use a wrench. I've swapped this thing like 5 times. I like wrench for this job. I use one from lowes that has the box end perpendicular to square end. Gives just the right amount of clearance. Something like this... http://m.lowes.com/product?langId=-1...30&view=detail
 Old 06-07-2013, 12:58 PM   #34
it might be 4 bolts, keep searching for one.
 Old 06-07-2013, 01:30 PM   #35
Etipp98's Avatar
Posts: 1,947   (View Stats)
Groaned at 7 Times in 4 Posts
Yes there are 4 bolts. Look by the egr tube port on the intake manifold that one likes to hide.
 Old 06-07-2013, 10:48 PM   #36
Aero's Avatar
Thanks for the help, guys. I did manage to replace the valve. What I ended up doing was leaving the rail guard on, and using a universal to reach it. I took a couple pictures, just in case anyone has a similar problem finding the elusive 4th bolt holding the guard on.
Parts list
17mm deep socket
Universal
6" (or so) extension
Ratchet (ended up using stubby since it's not torqued down hard, but any would work)
The only extra reqs are having to remove part of the intake and having to pull out the battery (2-5 mins). I feel like if I really tried though, I could've done this without pulling the top mount, since I didn't really have to touch anything by it. Anyways, once the fuel line is removed, just put everything together in this order: ratchet > extension > universal > socket. You should get a really good bite on the valve and get it off in no time.
In the picture, I have a small radiator hose pulled off that would normally go above the big one. Removing it turned out to be a bit unnecessary, but it may make it easier if you are having space issues.
 Old 10-29-2013, 02:26 PM   #37
Vegasspeeed's Avatar
Posts: 274   (View Stats)
Vegasspeeed has a reputation beyond reputeVegasspeeed has a reputation beyond reputeVegasspeeed has a reputation beyond reputeVegasspeeed has a reputation beyond reputeVegasspeeed has a reputation beyond reputeVegasspeeed has a reputation beyond reputeVegasspeeed has a reputation beyond reputeVegasspeeed has a reputation beyond reputeVegasspeeed has a reputation beyond reputeVegasspeeed has a reputation beyond reputeVegasspeeed has a reputation beyond repute
Groaned at 8 Times in 7 Posts
this part # will work for a gen1 speed3 right?
sure test pipe, both resonators deleted, RL coilovers, XXR 521's machined silver, muteki gold lug nuts
Vegasspeeed is offline   Reply With Quote
 Old 01-24-2014, 02:37 PM   #38
redboat's Avatar
Posts: 634   (View Stats)
redboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the world
mine just went out on my MS6, is this a part that normally goes out the MS6?
redboat is offline   Reply With Quote
 Old 01-24-2014, 03:17 PM   #39
mrmonk7663's Avatar
The rail valve should be the same for speed 6s, speed 3s and cx7s.
 Old 08-08-2014, 10:44 PM   #40
BigjohnB20's Avatar
Posts: 779   (View Stats)
God damn that thing is buried in there huh? Ive been fighting for like an hour and still haven't even got that yellow clip off. The "clips" on mine are facing the block and impossible to get to.
Noob questions... If I detach one of the coolant lines from the throttle body is coolant going to spill everywhere? Do I need something to clamp the line? Then once I put it back together do I need to do anything to purge the air from the system?
2006 BCM MS6 GT
CS SRI/TIP
Jbarone SSP/bushings
cp-e RMM, TMIC, Stiff Diff
AP
KMD V2.whatever
Ebay Catless DP
Grom Ipod
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f111/how-replace-relief-valve-rv-95418/
• View topic - Mazda 3 MPS relief valve This thread Refback 04-19-2012 07:30 AM
Relief valve is done for andre0121 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 6 10-12-2011 02:22 PM
Dissected Relief Valve SilverDemon MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 39 12-27-2010 12:33 PM
Page generated in 0.59559 seconds with 43 queries
