> MazdaSpeed 6 - How-To's
Like Tree8Likes
 Old 08-08-2014, 11:06 PM   #41
JgamB's Avatar
Posts: 2,566   (View Stats)
Originally Posted by BigjohnB20 View Post
God damn that thing is buried in there huh? Ive been fighting for like an hour and still haven't even got that yellow clip off. The "clips" on mine are facing the block and impossible to get to.
Noob questions... If I detach one of the coolant lines from the throttle body is coolant going to spill everywhere? Do I need something to clamp the line? Then once I put it back together do I need to do anything to purge the air from the system?
I had almost zero drip from the TB coolant lines when doing my bypass. That yellow clip facing the block would be a slut - I'd imagine you've already tried two small flat head screwdrivers to push the little claws back? It may help to pull that 8mm bolt out of the hardline and the two 10mm bolts out of the end of the fuel rail - be ready for a few ounces of gas to come out - but it should give you a little flexibility to maybe get on that clip. It gives you enough clearance to easily use a regular 17mm wrench instead of the HDMF adapter outlined in the thread.
If you pull that rail out of your way (gently!) you should be able to get that half a rotation you need on the PRV to expose the correct side of the yellow clip.
BigjohnB20 (08-09-2014)
 Old 08-09-2014, 07:11 PM   #42
BigjohnB20's Avatar
Posts: 779   (View Stats)
Thanks @JgamB; I finally managed to get the clip off last night. What a pain in my ass. I ended up using two pieces of metal clothes hanger that I cut and bent a hook on the end. I was like a damn arthroscopic surgeon blindly fishing the hooks around the back of the clip. Some how by the grace of god I hooked them both at the same time and was able to pop the clip off. The 7 beers I had before/during this process really helped things along...
I had to call it a night after that though. just got back from harbor freight with the tools from OP. Hopefully these will work for me. I guess plan B will be what you outlined and taking that hardline off to use a regular wrench. Thanks again
2006 BCM MS6 GT
CS SRI/TIP
Jbarone SSP/bushings
cp-e RMM, TMIC, Stiff Diff
AP
KMD V2.whatever
Ebay Catless DP
Grom Ipod
The Following User Says Thank You to BigjohnB20 For This Useful Post:
JgamB (08-09-2014)
 Old 08-13-2014, 08:46 PM   #43
diepanthony's Avatar
Posts: 63   (View Stats)
diepanthony is a jewel in the roughdiepanthony is a jewel in the roughdiepanthony is a jewel in the roughdiepanthony is a jewel in the rough
Nice write up thanks gonna do this soon
diepanthony is offline   Reply With Quote
 Old 08-14-2014, 12:12 AM   #44
dougefresh_'s Avatar
Posts: 4,489   (View Stats)
Superskates loves wops
 Old 10-02-2014, 04:41 PM   #45
Police - Grammarhead
Vansquish's Avatar
In case anyone's interested, I just had my RV fail, and I'm in the process of installing a new one. When I called to order one, it turns out that there are only 11 in stock, in the country!
Anyway, so far, I've stripped everything out except the valve (I'm trying to decide if buying the adapter is a worthwhile proposition.).
 Old 10-02-2014, 04:42 PM   #46
Gr8Speed's Avatar
Posts: 5,702   (View Stats)
I managed to change mine with a box wrench.
 Old 10-02-2014, 04:59 PM   #47
[R]usty's Avatar
Posts: 2,204   (View Stats)
I'm going to swap one of these out on a friends speed 6 tonight. I don't have the adapter in OP but I do have a ton of tools that should work. I'll post my findings.
2010 Mazdaspeed3 w/tech
 Old 10-02-2014, 05:05 PM   #48
Vansquish's Avatar
I decided to quit being a pussy and pull the hard line off the rail so that I could fit a box wrench in there. Once I did, it came out, easy-peasy.
In any case, I hope someone starts carrying more of these things for a lower price.
Also, you're supposed to be able to blow through either end of the valve and have air pass through...right...?
 Old 10-02-2014, 06:09 PM   #49
swd120's Avatar
Posts: 126   (View Stats)
swd120 has a reputation beyond reputeswd120 has a reputation beyond reputeswd120 has a reputation beyond reputeswd120 has a reputation beyond reputeswd120 has a reputation beyond reputeswd120 has a reputation beyond reputeswd120 has a reputation beyond reputeswd120 has a reputation beyond reputeswd120 has a reputation beyond reputeswd120 has a reputation beyond reputeswd120 has a reputation beyond repute
You're joking right? When that happens its definitely dead
Vansquish likes this.
swd120 is offline   Reply With Quote
The Following 5 Users Say Thank You to swd120 For This Useful Post:
Gr8Speed (10-02-2014), JgamB (10-02-2014), Vansquish (10-02-2014), white beast (10-02-2014), Xenios (05-21-2016)
 Old 10-02-2014, 06:41 PM   #50
Gr8Speed's Avatar
+1 ^
 Old 10-02-2014, 08:00 PM   #51
Vansquish's Avatar
OF COURSE I WAS JOKING!!!! Jeeez guys.
 Old 10-03-2014, 01:12 PM   #52
[R]usty's Avatar
Total pain in the ass but I did this last night on a Speed6 without removing the fuel rail guard, egr line, or coolant lines. I used a Craftsman Max Axess 17mm socket and ratchet. The socket fit perfectly over the relief valve but it was a tad too short to grab the ratchet. I used a flat head screw driver to push the socket just enough to grab the ratchet while remaining on the relief valve nut. After that I was able to fully loosen and tighten.
JgamB likes this.
 Old 10-06-2014, 09:56 AM   #53
JgamB's Avatar
I knew there had to be a good use for those. I rarely ever reach for the max access stuff but this is definitely a smart place to save some time. Good tip, sir Rusty.
[R]usty (10-06-2014)
 Old 10-06-2014, 10:53 AM   #54
[R]usty's Avatar
haha funny you say that, I never use these either. They've been sitting in my tool box pretty much untouched since I bought them. I'm finally realizing how useful they can be. I used them to swap my suspension this weekend, made things a lot easier.
JgamB (10-06-2014)
 Old 08-01-2016, 09:18 AM   #55
jmen73's Avatar
jmen73 is a glorious beacon of lightjmen73 is a glorious beacon of lightjmen73 is a glorious beacon of lightjmen73 is a glorious beacon of lightjmen73 is a glorious beacon of lightjmen73 is a glorious beacon of light
What size crush washer fits on the RV? And, where did you source it?
Thanks in advance.
2007 Red MS3: 4" ported PTE 5858, HTP intake, HTP undermount, Treadstone TR8, HKS BOV (VTA), Custom exhaust mani, V-band dp, CNT exhaust, ACT clutch, ACT 6-puck PP, Damond PMM, RMM & TMM, Koni yellows, Eibach prokit springs, Damond OCCs (vented & not).
jmen73 is offline   Reply With Quote
 Old 03-30-2017, 05:30 PM   #56
Atticaz's Avatar
Posts: 621   (View Stats)
Atticaz is the leader of the worldAtticaz is the leader of the worldAtticaz is the leader of the worldAtticaz is the leader of the worldAtticaz is the leader of the worldAtticaz is the leader of the worldAtticaz is the leader of the worldAtticaz is the leader of the worldAtticaz is the leader of the worldAtticaz is the leader of the worldAtticaz is the leader of the world
Necro, to add how I did it:
Pull FMIC (cold pipe) coupler off the throttle body
Remove air filter
Removed hard line guard
Pull fuel line off (yellow clip... not hard line.)
Used 17mm offset wrench
Accessed the PRV by moving the SSP's position and went under the radiator hose. It's super easy. No special tools. It's all about the angle of the dangle.
2017 Mustang V6 - Soon to be Supercharged
2007 MAZDASPEED3 - SOLD
Atticaz is offline   Reply With Quote
 Old 08-03-2017, 04:48 AM   #57
Bryce99's Avatar
Posts: 112   (View Stats)
Bryce99 is a jewel in the roughBryce99 is a jewel in the roughBryce99 is a jewel in the rough
you cant buy the RV by itself, you have to buy a whole new rail.
Why did you replace this? What symptoms did you have? Sorry to bring back old thread
Sent from my Pixel XL using Tapatalk
Bryce99 is offline   Reply With Quote
 Old 08-03-2017, 08:35 AM   #58
Atticaz's Avatar
My HPFP started making a rattling noise, fuel pressure was very low are idle and got a P0303 code.
https://youtu.be/Gc_QfQxqBzM
The Following User Says Thank You to Atticaz For This Useful Post:
Bryce99 (08-03-2017)
 Old 08-03-2017, 08:44 AM   #59
Bryce99's Avatar
Dude mine is doing the exact same thing... I replaced the hpfp and it didn't fix so now o bought a relief valve hope it does it
Atticaz likes this.
 Old 08-03-2017, 09:03 AM   #60
Bryce99's Avatar
Why the misfire code though? I have a code for multiple cylinder misfires
 Old 08-03-2017, 05:21 PM   #61
Atticaz's Avatar
That I am not sure of. Maybe since there is an issue with the fuel delivery there is either too much or too little being delivered? *Shrug*
 Old 08-21-2018, 08:09 AM   #62
PHB
PHB's Avatar
Posts: 5   (View Stats)
PHB is an unknown quantity at this point
Thanks in advance.
I've installed a new RV and it leaks between the RV and the fuel rail, apparently I've lost the crush washer, any info available on finding a replacement?
PHB is offline   Reply With Quote
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f111/how-replace-relief-valve-rv-95418/
• View topic - Mazda 3 MPS relief valve This thread Refback 04-19-2012 07:30 AM
Relief valve is done for andre0121 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 6 10-12-2011 02:22 PM
Dissected Relief Valve SilverDemon MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 39 12-27-2010 12:33 PM
Page generated in 0.42236 seconds with 32 queries
