> MazdaSpeed 6 - How-To's
  • 1 Post By Javi
 Old 08-04-2013, 07:46 PM   #1
Javi's Avatar
Posts: 589   (View Stats)
Javi is the leader of the worldJavi is the leader of the worldJavi is the leader of the worldJavi is the leader of the worldJavi is the leader of the worldJavi is the leader of the worldJavi is the leader of the worldJavi is the leader of the worldJavi is the leader of the worldJavi is the leader of the worldJavi is the leader of the world
Default How-to: Replace/remove starter
Tools needed
3/8" Ratchet with short extensions and the following sockets 8mm,10mm,12m and 14mm
Step 1: Remove your cold pipe,discharge pipe this may require you to remove your TMIC.
Step 2: Remove all four of 8mm bolts holding the TB, get ready to ctach the gasket
Step 3: Remove all three of 10mm bolts hlding this bracket
Step 4: Remove 14mm bolt holding the coolant pipe and may want to use a pry bar or screww driver to move it out of the way as you will need to get to the bolt/stud below the pipe to remove it aswell
Step 5: Remove 14mm bolt located below started
Step 6: remove cap protecting the bolt terminal, then remove the 14mm bolt holding terminal on starter and also remove the connector by pressing on the tab.
Now pull the starter straight out, replaced with new one and install everything in reverse order.
34Mbuilder likes this.
Javi is offline   Reply With Quote
The Following 10 Users Say Thank You to Javi For This Useful Post:
34Mbuilder (09-07-2019), ABolewski (08-11-2013), Boosted Beluga (08-04-2013), ItsNox (08-05-2013), markos213 (07-06-2015), MrPrime (08-06-2013), mxlplx71 (08-04-2013), psychophyr (08-20-2013), Turtle (10-12-2014), Yukon Mudder (08-30-2016)
 Old 07-06-2015, 03:54 PM   #2
Douggievee's Avatar
Posts: 71   (View Stats)
Douggievee is just really niceDouggievee is just really niceDouggievee is just really niceDouggievee is just really niceDouggievee is just really nice
great write up, thank you.
2006 Mazdaspeed6 GT: Autotech Fuel pump, GT3071R, Cobb AP FreakTune, 3" Custom Magnaflow Turboback Dual Exhaust, Mazdaspeeed intake/turbo inlet tube, NGK XI 1 step colder plugs, Fidanza Flywheel, EGR/VTCS Delete, Cobb EBC, Cross drilled rotors, Corksport BPV, TSW Nurburgrings, Techna-Fit SS Clutch Line
Douggievee is offline   Reply With Quote
 Old 07-06-2015, 03:59 PM   #3
SuckSqueezBangBlow's Avatar
Posts: 266   (View Stats)
This is gold... thank you so much for taking the time to do this.
 Old 05-08-2017, 10:04 AM   #4
Rajeee's Avatar
Posts: 4   (View Stats)
Rajeee is an unknown quantity at this point
Thank you so much for taking the time to do that!
Rajeee is offline   Reply With Quote
 Old 09-25-2017, 03:44 PM   #5
turbskies's Avatar
Posts: 178   (View Stats)
turbskies is a splendid one to beholdturbskies is a splendid one to beholdturbskies is a splendid one to beholdturbskies is a splendid one to beholdturbskies is a splendid one to beholdturbskies is a splendid one to beholdturbskies is a splendid one to behold
Groaned at 9 Times in 6 Posts
Need some help, I can't get the bracket for the coolant hard line off the stud.
I've tried prying it and pulling on it but it won't budge more than about half the length of the stud.
Sent from my SM-N950U using Tapatalk
turbskies is offline   Reply With Quote
 Old 01-25-2018, 02:21 PM   #6
Speed3Pedro's Avatar
Posts: 111   (View Stats)
Speed3Pedro is a jewel in the roughSpeed3Pedro is a jewel in the roughSpeed3Pedro is a jewel in the rough
Groaned at 8 Times in 4 Posts
Did you end up figuring something out for this? cause I cant get it out of the way either,
Sent from my SM-G955U using Tapatalk
Speed3Pedro is offline   Reply With Quote
 Old 01-25-2018, 02:34 PM   #7
turbskies's Avatar
No, luckily I just had to clean the connections for the ground and other clips ( I think there were two) and it has worked since.
 Old 01-05-2019, 05:36 AM   #8
AccuTec's Avatar
Posts: 210   (View Stats)
AccuTec has a reputation beyond reputeAccuTec has a reputation beyond reputeAccuTec has a reputation beyond reputeAccuTec has a reputation beyond reputeAccuTec has a reputation beyond reputeAccuTec has a reputation beyond reputeAccuTec has a reputation beyond reputeAccuTec has a reputation beyond reputeAccuTec has a reputation beyond reputeAccuTec has a reputation beyond reputeAccuTec has a reputation beyond repute
Reviving an old thread..... Thanks for the write up as I need to tackle this myself in the near future. Nothing like a starter locking up on ya far from home. Freaked out thinking it was the motor with less than 5K on it!
'07 MS 6 GT Black/Black
- BNR S4 Turbo
- HTP 3.5" Intake System
- CorkSport Catless Turbo Back Exhaust
- Cobb AP V3 Freektuned by Justin
- Auto Tech HPFP Internals
- Oil Restrictor Bolt (Damond)
- Vented and Sealed OCC (Damond)
- PERM Dual PCV Plate
- TurboSmart BPV
- Denso ITV22 Plugs
- SPEC Stage 3+ Clutch Kit w/Fidanza Flywheel
- EGR Delete Kit
- Bosch 3 Bar TMap Map Sensor with IAT
- JBR 3-Port Electronic Boost Control Solenoid
- CP-E DeltaCore Top Mount Intercooler
- JBR Trilogy Motor Mount Package 80A
AccuTec is offline   Reply With Quote
 Old 08-23-2019, 08:38 AM   #9
GalaxyBurito's Avatar
Posts: 1   (View Stats)
GalaxyBurito is an unknown quantity at this point
i just bought my speed 3 and have a 2.0 sedan. i appreciate the write up, but for a newbie like me i can't follow along because the lack of detail
GalaxyBurito is offline   Reply With Quote
remote starter axela2004 2010 MS3 - Car Audio & Electronics 20 02-15-2011 12:03 PM
How to Replace a Car’s Starter Motor Haltech Automotive News 0 07-12-2010 05:10 PM
Page generated in 0.31230 seconds with 27 queries
