> MazdaSpeed 6 - How-To's
Like Tree19Likes
 Old 05-01-2013, 07:25 AM   #81
Mandinca's Avatar
Posts: 1,700   (View Stats)
Mandinca is the leader of the worldMandinca is the leader of the worldMandinca is the leader of the worldMandinca is the leader of the worldMandinca is the leader of the worldMandinca is the leader of the worldMandinca is the leader of the worldMandinca is the leader of the worldMandinca is the leader of the worldMandinca is the leader of the worldMandinca is the leader of the world
Groaned at 7 Times in 5 Posts
Yes indeed. That transfer case being in the way is all that stopped me. I've since heard that it's possible to get to the bolts if you remove the plastic cowl under the bulkhead and use a stubby ratchet with a short extension. I have someone coming to help with that hopefully. By the time I'm done pulling everything off I'm just about toast mentally and not in the mood to F around with those bolts. There's a good chance I'll just unbolt it from the block but that makes me nervous...imagine shearing one of those...
Add to that I just had to drop $700 for a replacement radiator (incl labor).
A word of advice, if you ever need one in a MS6 make sure the one you order is definitely the correct one. Mine showed up with the wrong fittings for the fans and a hose connection missing. Online it specifically said it was for the 6, I ended up ordering it from a dealer. FML.
Mandinca is offline   Reply With Quote
 Old 05-04-2013, 11:51 PM   #82
himurax13's Avatar
Posts: 4,585   (View Stats)
Groans: 255
Sent via stockish Black Mica Pu
Pickles Tune in progress
The Following 5 Users Say Thank You to himurax13 For This Useful Post:
aromig (05-10-2014), BrianB6 (05-27-2013), Micha (11-03-2013), MrPrime (05-06-2013), Orimar (07-16-2018)
 Old 07-01-2013, 11:04 PM   #83
Matrix311's Avatar
Posts: 2,133   (View Stats)
So how many total bolts are there that need to be removed? I'm doing this on my MS3. Just having a hard time getting it to come out so i must be missing one. If anyone could chime in on the total amount of bolts that need to be removed! Thanks
 Old 07-02-2013, 04:11 AM   #84
6Y MAZDA's Avatar
Posts: 1,775   (View Stats)
The 5 bolts on the top plate. And the OP says theres one bolt near the front of the transmission (lined up with the shaft). I undid those 6 bolts and got it out.
1996 Miata
 Old 07-02-2013, 06:34 AM   #85
Mandinca's Avatar
I thought there were only 4 bolts on the top plate plus the one on the front....anyhow, like that ^^^
 Old 07-02-2013, 07:30 AM   #86
6Y MAZDA's Avatar
yes there are 4 on the plate itself, but theres one more bolt attached to the shift cable swivel that attaches to the plate. I couldnt get it out of the way so i just removed it.
1996 Miata
Last edited by 6Y MAZDA; 07-02-2013 at 07:30 AM. Reason: MSF Database - Automerged Doublepost
 Old 07-02-2013, 06:28 PM   #87
XsillyputtyX's Avatar
Posts: 8   (View Stats)
XsillyputtyX is an unknown quantity at this point
has anyone compared that toyota seal with the mazda seal? i dont care about the price difference. but just wondering about the material used for each.
XsillyputtyX is offline   Reply With Quote
 Old 07-03-2013, 06:15 AM   #88
Mandinca's Avatar
Of course, it's been a while since I did mine. Your pic also shows the extra bolt which must be removed, down behind the wire.
Also worth mentioning, use some gasket sealant on the top plate when putting it back together, I didn't at first and it leaked.
 Old 10-09-2013, 09:36 AM   #89
AKmac11's Avatar
Posts: 277   (View Stats)
AKmac11 is the leader of the worldAKmac11 is the leader of the worldAKmac11 is the leader of the worldAKmac11 is the leader of the worldAKmac11 is the leader of the worldAKmac11 is the leader of the worldAKmac11 is the leader of the worldAKmac11 is the leader of the worldAKmac11 is the leader of the worldAKmac11 is the leader of the worldAKmac11 is the leader of the world
Im having a hell of a time getting this assembly back in. Does the bearing below the bolt on the front of the trans have to come out? Because with it in, the assembly seems to be getting stuck right before the shaft goes into the hole. Full homo. If I push the shift plate towards the firewall it drops right in but then the linkage hits the shift plate. Any advice would be great. Tried to attach pics, but wouldn't upload for some reason.
COBB AP (Stratified E30 tuned)//AT internals//SURE Aeros V2//Amsoil filter//SURE Sidewinder//Ebay testpipe//JBR 88 duro RMM//Corksport SSP & weight//SURE Atom shift knob//GFB Respons BOV
AKmac11 is offline   Reply With Quote
 Old 10-09-2013, 09:51 AM   #90
Mandinca's Avatar
The bearing doersn't need to come out. It can be a bit of a bitch to get the assembly back in as everything has to be lined up correctly. As far as I can remember you can't actually put it in wrong.
The bolt on the front of the transmission should come out, that will help.
Line the assembly up in your hand, then, what I did was to reach down into the transmission and line the insides up by hand as well. Once you get it right it will take a bit of wiggling to get it in but it will go. Hope this helps.
The Following User Says Thank You to Mandinca For This Useful Post:
AKmac11 (10-09-2013)
 Old 10-09-2013, 10:23 AM   #91
AKmac11's Avatar
I backed the bearing out enough to drop the assy. the correct way, but when I tighten it back up, it locks the gear box. Like, the thing wont move at all.
 Old 10-09-2013, 11:08 AM   #92
Mandinca's Avatar
When you say "backed the bearing out" what do you mean, what bearing ?
IIRC the shaft assembly has a cotter pin that has to come out before you can remove the seal. When you put the assembly back together is there any way you could have re-assembled it incorrectly ?
 Old 10-09-2013, 11:26 AM   #93
AKmac11's Avatar
Theres 4 ball bearings in the housing. The one on the front of the trans is the one that seems to be making contact with the assembly. I removed the bearing and inspected it. It just threads into the housing and its spring loaded. Theres a shaft and a collar protecting the ball bearing and the spring allows it to move in and out. Wish I could upload pics.
I'm very confident I assembled it. I removed the roll pin thinking maybe I had done it wrong, and when I but it back together it just looked and felt wrong. So I put it back the original way I had it.
 Old 10-09-2013, 11:46 AM   #94
Mandinca's Avatar
What exactly is stopping the assembly from dropping all teh way downthe hole or are you saying that it does drop all the way in but the tranny is locked when you do ?
Just wondering, do you have the small plastic adapter that attaches to one of the cables ?
 Old 10-09-2013, 11:52 AM   #95
6Y MAZDA's Avatar
I had a similar problem when i did mine. Could not get it to go in for the longest time. took it apart/back together like 3 or 4 times before i realized one important thing...
(don't mind the circled pin...i took this pic from the OP) make sure the guide on the left side of the picture is lined up and locked into the other piece as pictured. (slides in like a door chain lock) When i put mine back together, i did not realize those pieces needed to be lined up and locked as one. I left them separate and that was my problem.
1996 Miata
The Following 3 Users Say Thank You to 6Y MAZDA For This Useful Post:
AKmac11 (10-09-2013), Funkster777 (10-09-2013), Micha (03-02-2014)
 Old 10-09-2013, 12:20 PM   #96
AKmac11's Avatar
If the bearing is in the housing it wont drop in. When I removed it, it sat flush but once I put the bearing in the housing, it locked up. I tried moving the shift plate and there is no wiggle room.
thanks 6Y, I will double check that.
 Old 10-10-2013, 06:18 PM   #97
Matrix311's Avatar
Its a bitch but just play with it and it will fall into place.
 Old 10-10-2013, 06:27 PM   #98
Mandinca's Avatar
Success AKMac ?
Black 2006 MS6 GT with Navigation // Cobb AP V2 // Cobb SRI // M2 Catless DP // Autotech internals // JBR 80 Duro RMM
 Old 10-11-2013, 10:11 AM   #99
btstarcher's Avatar
Posts: 4,852   (View Stats)
This whole process took me less than an hour. The only PITA was the cotter pin.
SnailTune in progress
Micha (11-03-2013)
 Old 10-18-2013, 04:43 PM   #100
AKmac11's Avatar
Success AKMac ?
Sorry for the late reply. Unfortunately, no success. Actually, total fuckin fail to be honest. I just couldn't get the damn thing in. Accepted my loses like a bitch and took to the dealer. The tech was telling me you have to have it at this angle, and blah blah fuck off. I was so pissed. I literally wanted to take a shit in that hole the assembly goes in and then light the car on fire.
The Following User Says Thank You to AKmac11 For This Useful Post:
BrianB6 (10-19-2013)
 Old 10-24-2013, 10:45 PM   #101
RogerH's Avatar
Posts: 68   (View Stats)
RogerH has a reputation beyond reputeRogerH has a reputation beyond reputeRogerH has a reputation beyond reputeRogerH has a reputation beyond reputeRogerH has a reputation beyond reputeRogerH has a reputation beyond reputeRogerH has a reputation beyond reputeRogerH has a reputation beyond reputeRogerH has a reputation beyond reputeRogerH has a reputation beyond reputeRogerH has a reputation beyond repute
Groaned at 3 Times in 1 Post
Thanks so much for this! The local dealer told me they had to pull the trans to do this. I knew they didn't because I've replaced this seal on cable shifted VW's I've owned. this has happened to me twice now. first time it was covered under extended warranty. now its leaking again and I'm going to do it when I replace the trans mount on my car.
RogerH is offline   Reply With Quote
 Old 10-25-2013, 06:38 AM   #102
Mandinca's Avatar
Fucking dealers.
 Old 10-28-2013, 10:07 AM   #103
xj-boonie's Avatar
Posts: 5   (View Stats)
xj-boonie is an unknown quantity at this point
The dealer just called me - said our 06 Speed6 is leaking out the sifter seal, and it's $1700 to replace. Reading through this thread it looks pretty straight forward to do it. I haven't done much work on our Speed6, but I have completely swapped out the suspension on our Jeeps (along with cooling system, header, motor mounts, axles, etc.) so I should have the skills to do this and save myself some $$, right?
xj-boonie is offline   Reply With Quote
 Old 10-28-2013, 10:17 AM   #104
Matrix311's Avatar
Um yes this is a cake job. You could fly me out to where you live and wine and dine me to replace that seal for less then that ass raping quote from the dealer.
Just order the parts which is like $6 and set an hour a side and hammer it out yourself.
Micha (03-02-2014)
 Old 10-28-2013, 10:19 AM   #105
xj-boonie's Avatar
Where did you get the seal from?
I just called back to confirm, and they are telling me I need to replace the whole shfter assembly - it's a non-servicable item.... I think I know what I'm doing this weekend...
Of course these are the same people who told me that I needed to replace the EGR valve for $750 when the engine was throwing a cyl #1 missfire and a new coil pack fixed it up....
 Old 10-28-2013, 10:20 AM   #106
almcbs's Avatar
Posts: 267   (View Stats)
almcbs has a reputation beyond reputealmcbs has a reputation beyond reputealmcbs has a reputation beyond reputealmcbs has a reputation beyond reputealmcbs has a reputation beyond reputealmcbs has a reputation beyond reputealmcbs has a reputation beyond reputealmcbs has a reputation beyond reputealmcbs has a reputation beyond reputealmcbs has a reputation beyond reputealmcbs has a reputation beyond repute
Pretty easy job just did it yesterday, took 2-3 hours, mainly because i was taking my time and took a couple beer breaks. Just follow this how-to and you will be fine
you can get it from the dealer, cost 6-8 depending on the area you live in
07 Speed6
ETS TMIC | HTP 3" Intake | Turboxs Hybrid BOV | JBR RMM | Ralco RZ STS | CP-E Triple Dash Pod | Prosport Gauges | Bilstein HD Shocks | H&R Springs | SPC Adjustable Ball Joints | Corksport Strut Bar | CP-E Diff Mount | Whiteline RSB | Autotech HPFP | Cobb AP V3 | M2 DP | PU Rims | Unicorn Jizz | Rotella T6 Blood
Next to come : ???????????
Last edited by almcbs; 10-28-2013 at 10:20 AM. Reason: MSF Database - Automerged Doublepost
almcbs is offline   Reply With Quote
 Old 10-28-2013, 10:22 AM   #107
Matrix311's Avatar
Bought it from a local dealer. You have proof from this thread that you can replace just the seal and not the entire assembly. Seal should be under $10
btstarcher (10-28-2013)
 Old 10-28-2013, 11:03 AM   #108
xj-boonie's Avatar
I'll see if their parts department can get it for me.
Should be ok to drive the car till sunday when I can tackle this, right?
 Old 10-28-2013, 11:05 AM   #109
Mandinca's Avatar
I repeat.....fucking dealers.
No special tools required, hardest part I found was undoing the bolt on the transmission engine mount due to the tools at the dealer tightening it up to about 500 foot pounds. Assholes.
Other than that it's cake. Really. 3 hours max.
1) don't drop anything down the hole once the top plate is removed
2) undo the bolt in the front of the transmission or the assembly won't come out
3) you might have to jiggle the assembly to get it back in, make sure it's all lined up
4) use metal gasket sealer on the top plate or it will leak - ask me how I know.
 Old 10-28-2013, 11:13 AM   #110
6Y MAZDA's Avatar
i'm pretty sure the part number is listed in the OP, or somewhere on page 1
1996 Miata
 Old 10-28-2013, 11:18 AM   #111
Matrix311's Avatar
Ya man for sure. Mine was probably leaking for a good 6 months or more before I noticed it was leaking. Keep on truckin and you'll be fine until its replaced.
 Old 10-28-2013, 11:20 AM   #112
Mandinca's Avatar
MANUAL TRANSMISSION CHANGE CONTROL SYSTEM. Fits: 2006 Mazda MazdaSpeed6 | Jim Ellis Mazda
17131 SEAL, OIL
Required: 001. $6.15 A60117131
 Old 10-28-2013, 11:20 AM   #113
xj-boonie's Avatar
Just ordered the part from the dealer (didn't have it in stock - 2-3 days for them to get it) $8.80...
 Old 11-19-2013, 02:02 PM   #114
shnouz's Avatar
Posts: 276   (View Stats)
shnouz is the leader of the worldshnouz is the leader of the worldshnouz is the leader of the worldshnouz is the leader of the worldshnouz is the leader of the worldshnouz is the leader of the worldshnouz is the leader of the worldshnouz is the leader of the worldshnouz is the leader of the worldshnouz is the leader of the worldshnouz is the leader of the world
Originally Posted by jrzy ms6 View Post
ok so i noticed trans fluid leaking and traced it to the rubber boot on the pressure plate on top of the trans. found some helpful threads to help pinpoint it but no "how to's" so hope this helps cause the dealer charges BUKU dollars to fix (yea what else is new). i'll start by saying that i consider myself a noob under the hood but i can figure stuff out. so feel free to chime in cause i cant name all the parts involved or dont know if there is a easier way to do it. all i can tell u is that this is what i did, everything works and best of all no more leaky leaks.
the seal from the dealer was only $6.50
part # A60117131
1. remove the air box for the intake (i'm all stock) and the battery, battery tray.
under this rubber boot is the seal. will be fluid all over this area
http://www.mazdaspeedforum.org/forum/foru...1&d=1339612652
2. disconnect the clutch cables. i used needle nose pliers to pop off the top one the other is connected to a bracket on the plate that has to come off anyway so i just pulled out the two 12mm bolts holding it
http://www.mazdaspeedforum.org/forum/foru...1&d=1339613359
3. remove the motor mount. before you do this you must set the front on jack stands and support the engine from under with a floor jack to release tension on the motor mount bolt.
(i'm on h&r's so i had to jack it from the side and slide a old rim with a box on top under the trans to support it.... had no jack stands).
at that point remove the bolt going thru the chassis(on top in pic) 18 mm i think and be sure not to lose the nut on the back side of the mount. then the other bolt going into the trans
2nd bolt going into trans, its under the clutch cables
3rd bolt going into trans, and the nut from the chassis bolt that u already dropped into the engine bay. mount should come right off now
4.pull the rest of the 12mm bolts out of the plate and break the seal holding it to the trans (i used a big flat head screw driver)
5. ok i'm not 100% sure this bolt had to come out but the shaft was fighting me to come out and seemed to come alot easier when i did. its located on the front of the trans and is lined up perfectly with the shaft. once it was out i was able to wiggle the shaft out (no homo)
shaft out
6. remove cotter pin, a punch is perfect if you have one. i dont so i used a
t25 torx driver and a hammer to tap it out.
7. once the pin is out slide it off. i think it only goes back on one way but be sur to keep an eye on how it came apart
once thats off the plate slides right off, the seal is right on top.
put on the new one and get her back together
Edit: some have popped off the shifter cable and had a small clip left on the plate. be careful not to lose it and set it aside for reassemble.
Also clean off the old sealant from the plate and trans and reseal with gasket sealant.
Just want to say thanks for the excellent write up. Did this about 6 months ago after the dealer telling me I had to replace the whole assembly. Quoted $1400 including labor. Appreciate the $6 alternate route.
07 VRM Speed6 Sport
Cobb AP V2//HTP 3.5"//CPE Catless DP// Corksport CBE // KMD v2s//HKS VTA//Denso ITV22
H&R Springs//Koni Yellows//Corksport RSB//Megan Ladder Brace//UltraRacing Trailing Braces//Michael Rey Rear Camber Arms// CS + SURE rear diff mounts // JBR RMM/TMM/PMM//JBR SSP//JBR Shifter Weight//JBR Shifter Bushings//JBR Heavy Knob//Optima Red in the trunk//GT Leather seat swap
Tuned by boostcreeep + 9/3 E85 mix
shnouz is offline   Reply With Quote
 Old 12-06-2013, 07:14 PM   #115
ginger6ninja9's Avatar
Posts: 46   (View Stats)
ginger6ninja9 is a name known to allginger6ninja9 is a name known to allginger6ninja9 is a name known to allginger6ninja9 is a name known to allginger6ninja9 is a name known to allginger6ninja9 is a name known to all
I'm gonna have to jump on replacing mine soon. I'm pissed because my dealer warranty expired before I found the problem. You can't see it leaking with the stock airbox on. So when I put my Cobb short ram on I found it.
ginger6ninja9 is offline   Reply With Quote
 Old 12-06-2013, 07:25 PM   #116
Is there any way to check transmission fluid levels? I've looked all over for a dipstick but I can't find one.
 Old 12-07-2013, 08:39 AM   #117
Mandinca's Avatar
The fill plug is a 23 or 24 mm on the front of the tranny. Pull the plug and fill until it starts pouring out of the fill hole. When it stops pouring out your at the right level. There is no dipstick.
ItsNox (12-10-2013)
 Old 12-07-2013, 10:43 AM   #118
Cool man. Thank you for that nifty little bit of information.
 Old 12-07-2013, 12:03 PM   #119
Boosted Beluga's Avatar
Posts: 4,859   (View Stats)
Groans: 50
@Koke382;
08 Mazdaspeed 3
Fucking FREEK TUNED and shit
 Old 01-03-2014, 05:21 PM   #120
guitarcal's Avatar
Posts: 25   (View Stats)
guitarcal is an unknown quantity at this point
Hi all,
My dad and I attempted to replace this seal earlier today. Our hope was to pull the shaft by loosening the motor mount bolts and lowering the transmission. Unfortunately, we were unable to loosen the two nuts mentioned in the original post:
We tried loosening with an air impact gun. If there was more room, we probably could have removed using a cheater bar.
Has anyone else here ran into the same issue?
guitarcal is offline   Reply With Quote
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f111/how-shaft-pivot-seal-replaced-116267/
Google INTERIA.PL - szukaj: pivot shaft This thread Refback 10-12-2014 01:24 PM
HOW-TO: shaft pivot seal replaced - Mazdaspeed Forums This thread Refback 08-02-2014 09:23 AM
Oil between engine and transmission? Mazdaspeed 3 : mazda This thread Refback 07-16-2014 10:20 PM
What is leaking and why now ;-) - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 03-09-2014 06:22 PM
Does this look like an transmission leak? - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 03-02-2014 01:45 PM
Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum - Reply to Topic This thread Refback 02-12-2014 11:46 AM
What have you done to your Mazda today? This thread Refback 02-03-2014 10:27 AM
Shift plate: part that always leaks This thread Refback 08-01-2013 09:15 PM
Transmission Fluid Leaking (Help ID Seal) - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Refback 07-25-2013 03:43 PM
Whats New/General Speed 6 Discussion - Page 244 This thread Refback 06-22-2013 12:07 AM
Whats New/General Speed 6 Discussion - Page 243 This thread Refback 06-21-2013 05:05 AM
Mazda 3 MPS This thread Refback 01-31-2013 10:00 PM
Oil Leak? - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Refback 01-19-2013 11:57 AM
transmission: shaft pivot seal This thread Refback 09-05-2012 08:42 PM
Shifter Pivot/Seal Fix? Gru_Nuts MazdaSpeed 6 - How-To's 8 11-08-2014 12:03 PM
I think it called a shifter pivot seal nospeed MazdaSpeed 6 - How-To's 39 04-19-2013 12:51 PM
shifter pivot seal fluid rgvms6 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 7 05-22-2012 05:09 PM
Help me Seal the Deal! helmetface MazdaSpeed 3/6 - Wheels & Tires 17 03-08-2012 08:24 PM
Injector seal how to ?? jracer Mazdaspeed3/6 General Discussion 1 11-26-2010 03:26 PM
Page generated in 0.61436 seconds with 34 queries
