> MazdaSpeed 6 - How-To's
Like Tree19Likes
 Old 04-15-2017, 09:43 PM   #281
Lex2007's Avatar
Posts: 574   (View Stats)
Thanks for the pics and tips guys. Much appreciated. This requires no special tools or skills beside perhaps the punch to push the pin through.
I did this this afternoon after noticing the telltale gear oil leak at 120k on my 2007 Speed3. Didnt bother with the vent or bearing. What are the symptoms of a bad shaft bearing anyway?
Here are Speed3 specific photos in case someone else hasnt posted the link:
https://www.flickr.com/photos/129567...h/16344688469/
Mark the unit with a mechanics marker as you pull it out so you know how it goes back in and how all the parts align. The pics in the above link help if you didnt mark it.
The Following User Says Thank You to Lex2007 For This Useful Post:
JSmith (04-16-2017)
 Old 04-15-2017, 10:34 PM   #282
Lex2007's Avatar
Originally Posted by Mandinca View Post
Sorry, I didn't take pictures and there is no exploded view in the workshop manual that shows it.
It's about 3/4" long by 1/2" wide and is hollowed out on one side. The hollowed out part is round (to fit the end of the cable) and the other side is flat (to fit in the notch on the pivot shaft).
Just make sure you try to remove it from the end of the cable and if it's not there check the pivot shaft as it may have been left in the notch.
Shown here:
https://www.flickr.com/photos/129567...7650402177637/
 Old 05-23-2018, 10:56 AM   #283
Lim075's Avatar
Posts: 9   (View Stats)
Lim075 is on a distinguished road
Originally Posted by Guthrie View Post
Guys, you probably had a good look at the whole assembly while it was out. Which parts do you think are likely to casue this:
"Mazda's do have some problems with the "gates" for lack of a better word.. as you pull the shifter down to go into a gear two things occur, a gate goes down and another gate moves left to right when switching from 2-3 4-5 or the other way around... however, when going straight down, the horizontal gate tends to get in the way of the vertical gate. It's directly on top of the transmission where this happens and the springs / gates tend to warp because of heat and obviously, the warmer the vehicle gets, the weaker the metal gets not allowing it to force it out of the way like it was cold."
How do you deal with this? I think I have this issue.. I can't get into first and reverse..and probably fourth. I cant push it down in any position to drop it into reverse after replacing the seal and bearing
Lim075 is offline   Reply With Quote
 Old 05-23-2018, 03:29 PM   #284
Lim075's Avatar
Is the black rectangular plastic piece supposed to go in vertical or horizontal? For some reason.. my two pivot arms are a lot closer now than they were before taking it apart..
I didn't mark the long rod with the guide pin. Is there only one way it can fit back in, or two? Trying to narrow down my issue.. don't want to break it open again if I don't have to...
 Old 05-24-2018, 07:48 AM   #285
Lex2007's Avatar
Man I wish could remember. Its been too long. Hopefully someone else will chime in.
 Old 05-24-2018, 10:23 AM   #286
Lim075's Avatar
Got it. It's horizontal. It was vertical before and I couldn't get into 1st or 4th... And couldn't drop it down into reverse.
Anyone have the part number for it? It damaged it a bit driving with the plastic clip in the vertical position
 Old 08-18-2018, 07:47 PM   #287
Urbanski21's Avatar
Posts: 2   (View Stats)
Urbanski21 has a little shameless behaviour in the past
Old post i know just doing the seal going to put it back together and its(shifter link that goes into transmission) off by like an 8th of an inch. Be at war for a bit with it so close but so far..thanks
Urbanski21 is offline   Reply With Quote
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f111/how-shaft-pivot-seal-replaced-116267/
Google INTERIA.PL - szukaj: pivot shaft This thread Refback 10-12-2014 01:24 PM
HOW-TO: shaft pivot seal replaced - Mazdaspeed Forums This thread Refback 08-02-2014 09:23 AM
Oil between engine and transmission? Mazdaspeed 3 : mazda This thread Refback 07-16-2014 10:20 PM
What is leaking and why now ;-) - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 03-09-2014 06:22 PM
Does this look like an transmission leak? - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 03-02-2014 01:45 PM
Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum - Reply to Topic This thread Refback 02-12-2014 11:46 AM
What have you done to your Mazda today? This thread Refback 02-03-2014 10:27 AM
Shift plate: part that always leaks This thread Refback 08-01-2013 09:15 PM
Transmission Fluid Leaking (Help ID Seal) - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Refback 07-25-2013 03:43 PM
Whats New/General Speed 6 Discussion - Page 244 This thread Refback 06-22-2013 12:07 AM
Whats New/General Speed 6 Discussion - Page 243 This thread Refback 06-21-2013 05:05 AM
Mazda 3 MPS This thread Refback 01-31-2013 10:00 PM
Oil Leak? - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Refback 01-19-2013 11:57 AM
transmission: shaft pivot seal This thread Refback 09-05-2012 08:42 PM
Shifter Pivot/Seal Fix? Gru_Nuts MazdaSpeed 6 - How-To's 8 11-08-2014 12:03 PM
I think it called a shifter pivot seal nospeed MazdaSpeed 6 - How-To's 39 04-19-2013 12:51 PM
shifter pivot seal fluid rgvms6 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 7 05-22-2012 05:09 PM
Help me Seal the Deal! helmetface MazdaSpeed 3/6 - Wheels & Tires 17 03-08-2012 08:24 PM
Injector seal how to ?? jracer Mazdaspeed3/6 General Discussion 1 11-26-2010 03:26 PM
Page generated in 0.29855 seconds with 23 queries
