> MazdaSpeed 6 - How-To's
Like Tree7Likes
 Old 12-31-2011, 03:00 PM   #1
Werm's Avatar
Posts: 157   (View Stats)
Werm has a reputation beyond reputeWerm has a reputation beyond reputeWerm has a reputation beyond reputeWerm has a reputation beyond reputeWerm has a reputation beyond reputeWerm has a reputation beyond reputeWerm has a reputation beyond reputeWerm has a reputation beyond reputeWerm has a reputation beyond reputeWerm has a reputation beyond reputeWerm has a reputation beyond repute
Groaned at 8 Times in 3 Posts
is a oil filter wrench necessary? I plan on buying a quik valve on my next oil change
Werm is offline   Reply With Quote
 Old 12-31-2011, 03:21 PM   #2
TiGraySpeed6's Avatar
Posts: 3,981   (View Stats)
doesn't the quick valve replace the oil pan drain bolt? That has nothing to do with removing the oil filter housing to remove the cartridge. Because of the o-ring seal torque is often more than hand tight like you can get away with for a spin on filter, so I'd say yes, you proa'lly want a filter wrench
Originally Posted by keymaster View Post
Spin on: Wix 51516 is what I am using, it's a longer filter so it will probably hit the under tray if you use the sandwich plate...
With the size increase, does it increase the amount of oil needed, and have you done a BSD Delete?
It's always a nice bonus to hold an extra bit of oil
340hp / 371tq
Last edited by TiGraySpeed6; 12-31-2011 at 03:21 PM. Reason: MSF Database - Automerged Doublepost
 Old 12-31-2011, 07:24 PM   #3
keymaster's Avatar
Posts: 397   (View Stats)
keymaster is the leader of the worldkeymaster is the leader of the worldkeymaster is the leader of the worldkeymaster is the leader of the worldkeymaster is the leader of the worldkeymaster is the leader of the worldkeymaster is the leader of the worldkeymaster is the leader of the worldkeymaster is the leader of the worldkeymaster is the leader of the worldkeymaster is the leader of the world
It is a little bigger, probably takes it to the total 6 quarts instead of the standard 5.7, but it's not too much. I have not done the BSD. I also only have had to hand tighten these and they seem to seal just fine. If you need to wrench it, it should only be half a turn or so is my guess. I also have one of the Fumoto valves in place of the oil pan bolt, they are pretty cool and make oil changes a lot cleaner.
2007 Mazdaspeed 6 GT
keymaster is offline   Reply With Quote
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f111/mazdaspeed-6-fluid-notes-diy-pictures-100877/
Mazdaspeed6 2007 la 3iem griche ??? This thread Refback 10-29-2015 06:25 PM
quel huile vous utilisez dans votre transfer case + diff? This thread Refback 05-05-2015 07:23 PM
entretien 136 000 km This thread Refback 06-20-2014 04:23 AM
Fluides MS6 This thread Refback 03-05-2014 11:48 AM
VVT Fix Notes and Observations tkephart MazdaSpeed 6 - Engine, Transmission & Driveline 8 12-28-2011 11:29 AM
Chevy Suburban Transmission Fluid, Using CO2 to Fill a Tire, How To Unclog Windshield Wiper Fluid Spouts, Dead Battery A Haltech Automotive News 0 05-15-2009 04:10 PM
v1.03 Map Notes? BlackT5
Cobb Access Port/Maps
3 02-15-2009 08:24 PM
More upgrades, notes,& reviews melan47 MazdaSpeed 3/6 - Suspension & Brakes 13 11-05-2008 01:00 PM
Page generated in 0.28880 seconds with 24 queries
