> MazdaSpeed 6 - How-To's
Like Tree4Likes
 Old 08-18-2014, 01:26 PM   #1
myarbro1's Avatar
Posts: 39   (View Stats)
myarbro1 has a reputation beyond reputemyarbro1 has a reputation beyond reputemyarbro1 has a reputation beyond reputemyarbro1 has a reputation beyond reputemyarbro1 has a reputation beyond reputemyarbro1 has a reputation beyond reputemyarbro1 has a reputation beyond reputemyarbro1 has a reputation beyond reputemyarbro1 has a reputation beyond reputemyarbro1 has a reputation beyond reputemyarbro1 has a reputation beyond repute
Default MAZDASPEED 6 PROPELLER SHAFT CV BOOT
I recently asked if anyone knew jack about the CV joint on the driveshaft, aka propeller shaft, in our Speed6’s on FB.
I have those answers and thought I would share what I have learned.
To begin, my CV boot was ripped and leaking. The joint and/or boot are not available separately; Mazda only sells the whole driveshaft. I found a post and picture once of someone who had installed a Subie boot on his, so I went that route. Beck Arnley PN#1032824. I do not know who to credit with that finding.
Looking at the joint once removed from the TC you’ll notice it is a heavy steel part with a soft thin metal at the rear. This part is the boot. The rubber boot part is actually inside; I later figured that the metal part protects it from the nearby downpipe.
The trick to removing the joint is the take a chisel and hammer, and place the chisel on the shoulder of the soft metal part. Whacking it with the hammer will drive the joint backwards, and the metal cap on the end will get popped off by the shaft. I used a chisel as opposed to hitting the flange directly with a hammer to avoid bending it.
Inside you will find a circlip that will need to be removed, and the joint will pull off. I took the joint apart and cleaned it in mineral spirits to get rid of the stickiest grease on the fucking planet. DO NOT wipe that shit on your arms; it laughs at GOJO and every other soap/hand cleaner. Keep notice of how the cage comes out; it will physically fit and seem to work with the cage frontwards or backwards, but there is only 1 “right” way. It’s very easy, just pay attention.
The OEM boot is a bitch to get off. Shown by arrows in the pics, the boot is crimped into that groove on the CV joint. I carefully used a grinder and chisel to thin the metal in two places so I could chop and peel it off.
Reassemble like you would any other CV joint and boot and you’re done. The rubber boot is close to the downpipe, so we shall see how long it lasts. My dad made a template for a heat shield to slip between the DP and CV; we will get that cut out of some thin metal and give it a go to see if it helps protect the boot long-term.
Mica Black '06 Speed6 GT #02871: E85 tune by Purple Drank - AT internals - Damond RMM - WW FMM - MF CBE - eBay DP - RamFab 4" intake - Custom FMIC - GS EBCS - TS BOV - CS stress bars - CD rotors - EBC Redstuffs - H&R Sports w/ Koni Yellows - Redline hood struts - PnP IM - MS OCC's - Full Race exhaust mani - GTX2867r - CP-e rear diff mount - SURE Juggernaught - Diff caps - DSS axles - EVO 8 Brembos - lots fucking more
myarbro1 is offline   Reply With Quote
The Following 20 Users Say Thank You to myarbro1 For This Useful Post:
Amnesiac (08-18-2014), aviator79 (12-15-2015), cam1391 (04-18-2015), Code Monkey (08-19-2014), Downmented (08-20-2014), f15ms6 (04-30-2016), friedricebob (08-20-2014), Funkster777 (07-31-2016), Hargarbl (08-20-2014), KiwiFlavor (03-28-2016), Mazdazilla6 (08-20-2014), meelo88 (08-18-2014), Micha (05-27-2015), phate (08-19-2014), Rich990 (03-23-2015), rob ms6gt (12-05-2015), siegsuwa (06-12-2015), TiGraySpeed6 (08-19-2014), Tomas (12-16-2015), Vansquish (08-19-2014)
 Old 08-19-2014, 06:49 AM   #2
TiGraySpeed6's Avatar
Posts: 3,981   (View Stats)
Nifty
I've never seen a 6 that hadn't sprayed grease out of that joint... I'll have to take a good look the next time I'm down there and see if it's time for a rebuild
340hp / 371tq
 Old 08-20-2014, 06:13 AM   #3
Hargarbl's Avatar
Posts: 642   (View Stats)
Groans: 51
Wanna do mine next lol?
 Old 08-20-2014, 06:23 AM   #4
Downmented's Avatar
Posts: 3,040   (View Stats)
Groans: 493
i dont think my driveshaft has ever had that boot on it. Also, out of curiousity, how much grease did you pack into the new boot?
700HP CLUB
11.479@124mph
#DIX
 Old 08-20-2014, 08:29 AM   #5
myarbro1's Avatar
I would be willing to bet the boot is there @Downmented, it just doesn't look like a regular CV boot that we are accustomed to. The light grey metal at end of the flanged joint is the boot. Its metal on the outside and the rubber "boot" is inside. Presumably the metal outside protects it from the extreme heat radiating from the downpipe.
Mine is devastated looking because I used a BFH to try and remove it. I was expecting a snap ring instead of a circlip, so the BFH is not at all the right tool for the job.
As far as how much grease, I used the whole container that came with the new boot.
The Following User Says Thank You to myarbro1 For This Useful Post:
Downmented (08-21-2014)
 Old 08-20-2014, 10:50 AM   #6
Mazdazilla6's Avatar
Posts: 3,657   (View Stats)
I was hoping you would post this on MSF. Thanks again!
VersaTuner = Versatune
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Autotech = HPFP Internals
Grimmspeed = EBCS
 Old 08-20-2014, 11:23 AM   #7
myarbro1's Avatar
you don't live far away at all @Hargarbl; surprised I've never seen you around. I am only aware of one other black and 2 red MS6's around here. Never seen a Ti Grey one!
 Old 08-20-2014, 11:41 AM   #8
'cause we're stealthy...
340hp / 371tq
 Old 08-20-2014, 08:05 PM   #9
Hargarbl's Avatar
Groans: 51
I live at 60 and mt carmel. I have only ever seen 2 other ms6's since Ive had mine, another ti grey, and once every couple of weeks or so on my way to work I see a lowered red one on county line rd. Im ti grey, stock height with black dipped stock wheels.
 Old 08-20-2014, 08:54 PM   #10
myarbro1's Avatar
Two TiGreys here, WTF? How have I missed you both?
I live in Providence Lakes; off Providence between Lumsden and Bloomingdale. If the red one you see has a lip, it likely belongs to a member of TBMC (tampa bay mazda club) His car is clean. Another red one runs down Boyette Rd. all the time, and his only visible mod is a sharkfin antenna. Actually, both red one's have a sharkfin I do believe.
 Old 08-20-2014, 08:56 PM   #11
I'm tellin' ya- stealthy...
340hp / 371tq
myarbro1 (08-20-2014)
 Old 08-20-2014, 09:03 PM   #12
myarbro1's Avatar
sneaky bastids!
TiGraySpeed6 (08-20-2014)
 Old 08-20-2014, 09:49 PM   #13
Hargarbl's Avatar
Groans: 51
lol well according to Tigrays location he is in tally so i doubt you will see him around here. Although Im kinda surprised with 4 other known ms6's around here i havnt seen another one at all.
 Old 08-20-2014, 10:01 PM   #14
friedricebob's Avatar
Posts: 102   (View Stats)
friedricebob has a reputation beyond reputefriedricebob has a reputation beyond reputefriedricebob has a reputation beyond reputefriedricebob has a reputation beyond reputefriedricebob has a reputation beyond reputefriedricebob has a reputation beyond reputefriedricebob has a reputation beyond reputefriedricebob has a reputation beyond reputefriedricebob has a reputation beyond reputefriedricebob has a reputation beyond reputefriedricebob has a reputation beyond repute
This is great, thanks for the write up.
Replaced my driveshaft with a boneyard unit once already.
RIP
friedricebob is offline   Reply With Quote
The Following User Says Thank You to friedricebob For This Useful Post:
myarbro1 (08-21-2014)
 Old 08-29-2014, 01:02 AM   #15
meelo88's Avatar
Posts: 557   (View Stats)
meelo88 is the leader of the worldmeelo88 is the leader of the worldmeelo88 is the leader of the worldmeelo88 is the leader of the worldmeelo88 is the leader of the worldmeelo88 is the leader of the worldmeelo88 is the leader of the worldmeelo88 is the leader of the worldmeelo88 is the leader of the worldmeelo88 is the leader of the worldmeelo88 is the leader of the world
I just did this to mine, I'll drive it around for a bit and report back
"If I can't fix it, it was meant to be broken"
[SIGPIC][/SIGPIC] 2007 MazdaSPEED 6 Titanium Grey
TUNED BY NISHAN
POWER
SpeedPerformanc3 Wiseco Pistons (88mm)::Manley Forged H-Beams::BNR S3::Bosch 3Bar Map Sensor::CP-E Ex Mani::SBC Stg 2 Clutch::JBR RMM 80a::JBR STG II SRI::JBR Boost Tubes::JBR BPV Return::JBR SSP::CS TMIC::CS DP::Stratified 3 Port EBCS::Stratified Guardian Angel::TurboXS RP::Custom 3" Catback Exhaust::KMD 2.1::Flex Innovations Ground Kit::Turbosmart BPV::MD OCC::TWM Stage 1::BC Coilovers::Hawks HPS::EGR Delete::SURE Dreadnaught::SURE Juggernaut::SURE TIG
COSMETIC AND AUDIO
Mori H1 Proj Retrofit::DDM 3k HID Fogs::RPM Rear LED Reflectors::RPM Side LED Reflectors::Morel Elate 6 2W 6.5" Components::Morel Maximo 5C 5.25" Coaxial::Arc Audio KS300.4::Arc Audio KS1000.1::Audison BitOne.1::Zapco ST4
meelo88 is offline   Reply With Quote
The Following 2 Users Say Thank You to meelo88 For This Useful Post:
myarbro1 (08-29-2014), TiGraySpeed6 (08-29-2014)
 Old 08-29-2014, 04:03 AM   #16
myarbro1's Avatar
So far so good with mine; looks perfect a few hundred miles later. Time will tell how the heat affects it. Your install go smooth @meelo88?
 Old 08-29-2014, 12:24 PM   #17
meelo88's Avatar
Yup I had a bit of fun going through the grease to get all the parts out but once i figured out how they come apart it was much easier.
Your instructions are good. I think the boot is a bitch...i used a Dremel to shave off the boot with a chisel and locking pliers to peel off the back strip.
I kinda tugged on the whole boot to get it off after I got the c-clip off. Not sure that was the best way to do it but it worked...
Cleaned the crap out of everything with mineral spirits (BTW that stuff is awesome!!!)
My only real snag was after getting everything packed in grease again I had to use a punch to tap the center piece back onto the shaft so i can get the clip back on without getting grease everywhere (I failed...got grease everywhere).
TUNED BY NISHAN
POWER
COSMETIC AND AUDIO
The Following User Says Thank You to meelo88 For This Useful Post:
myarbro1 (08-30-2014)
 Old 11-17-2014, 06:42 PM   #18
myarbro1's Avatar
**UPDATE**
Well, I got a P0037 CEL last night. What the hell does a rear O2 sensor CEL have to do with a drive shaft boot? More than one would think...
First things first, I check the plug for the O2 sensor...hey, only the plug on the main harness is present. Hmmmmm. Well would you look at that, the entire wire running to the rear O2 sensor is straight GONE.
I then noticed the boot on the drive shaft CV was pretty much gone too.
My assessment is this: I initially thought heat was an issue, but for me it was probably installer error on the big clamp.
The big boot clamp came off, I ignored it for a few days, the boot ripped off during a run to Mexico. The boot ripped, splayed open and grabbed the O2 wire and wrapped it around the drive shaft, which promptly removed the wire from the car. I am thankful it left the plug on the main harness!
Get the right tool to fasten the boot clamps!!!!
Carp. Time to try again.
 Old 11-17-2014, 06:47 PM   #19
Hargarbl's Avatar
Groans: 51
Damn I was afraid that might have been an issue, but deep down was hoping the boot could handle the heat. Thanks for the update though.
 Old 11-17-2014, 07:09 PM   #20
meelo88's Avatar
Mine has survived so far, about 1k miles on it, maybe my DP Is ceramic coated to keep it a bit cooler? I'll check mine again to see...
TUNED BY NISHAN
POWER
COSMETIC AND AUDIO
Funkster777 (07-31-2016), Micha (05-27-2015)
 Old 11-17-2014, 07:35 PM   #21
myarbro1's Avatar
You and me both.
 Old 11-17-2014, 08:00 PM   #22
myarbro1's Avatar
Attachment 182317
Yours still looks perfect. Got my fingers crossed for ya!
 Old 01-10-2015, 03:00 PM   #23
DocBrown's Avatar
Posts: 167   (View Stats)
DocBrown is the leader of the worldDocBrown is the leader of the worldDocBrown is the leader of the worldDocBrown is the leader of the worldDocBrown is the leader of the worldDocBrown is the leader of the worldDocBrown is the leader of the worldDocBrown is the leader of the worldDocBrown is the leader of the worldDocBrown is the leader of the worldDocBrown is the leader of the world
Groaned at 6 Times in 4 Posts
My wallet thanks you @myarbro1; !
06 Speedsex - built engine - JBR Stage 2 intake - Unicorn 2013 K04 - Stratified OTS stage 2 - Autotech internals - Cx FMIC - JBR RMM - Forge V2 - VTCS delete - EGR delete - BSD - JBR OCC - JBR TIGs + coolant bypass
DocBrown is offline   Reply With Quote
The Following User Says Thank You to DocBrown For This Useful Post:
myarbro1 (01-10-2015)
 Old 01-10-2015, 04:00 PM   #24
DocBrown's Avatar
By the way, do you guys think the drive shaft needs to be re-balanc3d after installing the new boot or is it good to go? Anyone have problems with balance?
 Old 01-10-2015, 04:42 PM   #25
myarbro1's Avatar
I wouldn't think a boot would affect the balance at all. I noticed no vibes personally.
DocBrown (01-12-2015)
 Old 03-23-2015, 09:37 AM   #26
Rich990's Avatar
Posts: 274   (View Stats)
Rich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the world
For the guys that have done this - how's the boot holding out?
2007 Velocity Red MS6
Go... BNR S3v2 / COBB APv3 / Snow Performance WMI + DO7 / nator'd DP / test pipe / HTP 3" SRI & TIP / 3 bar MAP / Autotech HPFP / NGK LTR7 / Stratified 3 port / Custom 3" TMIC / EGR delete / CP-E RMM / Turbine Tech FDM / CP-E RDM / Whiteline RSB / H&R springs / Powerbrake GT rotors / Endless MX72 Brakepads
Parts stockpile... Wiseco 88mm's / Manley H beams
Turbo stockpile... Borg Warner S200SX 7670 / GTX3071 / K04
Ex: 2007 Black Mica MS3 - stage 2 mods - 280 whp, 306 tq (321 whp / 358 tq before "stockout", on BNR S2 + meth)
Ex: 2010 Velocity Red MS3 - Stage 1 mods + Meth... 260 whp, 306 tq, stock exhaust
5500 ft altitude FTL
MSF in South Africa
Rich990 is offline   Reply With Quote
 Old 03-23-2015, 11:03 AM   #27
meelo88's Avatar
I haven't had my O2 sensor taken out yet so i have reason to believe the boot is still there...
I haven't actually been under the car lately to see the condition of the boot however...
TUNED BY NISHAN
POWER
COSMETIC AND AUDIO
 Old 03-23-2015, 11:27 AM   #28
myarbro1's Avatar
you might be able to see it by looking over the rear of the engine and down. I was able to stick my arm down there and tear of the remnants of my most recent boot.
 Old 04-13-2015, 07:09 PM   #29
xliquidx's Avatar
Posts: 170   (View Stats)
xliquidx is the leader of the worldxliquidx is the leader of the worldxliquidx is the leader of the worldxliquidx is the leader of the worldxliquidx is the leader of the worldxliquidx is the leader of the worldxliquidx is the leader of the worldxliquidx is the leader of the worldxliquidx is the leader of the worldxliquidx is the leader of the worldxliquidx is the leader of the world
I did this a few hundred kms ago, it's held on so far at triple digit speeds no worries. I used a slightly different boot with the same clamps our oem boots use for the axles (not ss cable ties)
xliquidx is offline   Reply With Quote
The Following User Says Thank You to xliquidx For This Useful Post:
myarbro1 (04-15-2015)
 Old 04-18-2015, 01:04 AM   #30
xliquidx's Avatar
UPDATE: MY BOOT HAS TORN FINALLY AND RIPPED OUT MY SECONDARY O2 SENSOR. Same thing that happened to another guy when using the same boot and clamp (not the one posted here). I even did it up with the correct tool.
 Old 04-18-2015, 06:14 AM   #31
myarbro1's Avatar
Damn it man!!!
 Old 05-21-2015, 09:00 AM   #32
siegsuwa's Avatar
Posts: 134   (View Stats)
siegsuwa is the leader of the worldsiegsuwa is the leader of the worldsiegsuwa is the leader of the worldsiegsuwa is the leader of the worldsiegsuwa is the leader of the worldsiegsuwa is the leader of the worldsiegsuwa is the leader of the worldsiegsuwa is the leader of the worldsiegsuwa is the leader of the worldsiegsuwa is the leader of the worldsiegsuwa is the leader of the world
I am about to attempt this. I have an extra shaft with a torn boot I'm going to rebuild, then rebuild the shaft I'm removing the same way and keep it as a spare for NATOR. How did your boots fail? Do we think heat is the primary factor or is the boot material the wrong application?
Anyone try to recycle the heat-shield / cowl for the boot, or make their own?
siegsuwa is offline   Reply With Quote
The Following User Says Thank You to siegsuwa For This Useful Post:
Micha (05-27-2015)
 Old 05-21-2015, 01:03 PM   #33
meelo88's Avatar
I just had some work done on my exhaust and I took some pics to check on it, looks solid still, I have a CS downpipe ceramic coated so maybe my heat is low enough not to cause an issue? I have some pics attached...
Installed about 5,400 miles ago a 8/24/14...
TUNED BY NISHAN
POWER
COSMETIC AND AUDIO
siegsuwa (05-22-2015)
 Old 05-21-2015, 02:48 PM   #34
xfeejayx's Avatar
Posts: 1,729   (View Stats)
Groans: 78
Where is your rust? Did you not get that option?
-Wetz
QFT
Micha (05-27-2015)
 Old 05-21-2015, 03:01 PM   #35
meelo88's Avatar
got the California option....no rust, deal with cops...
TUNED BY NISHAN
POWER
COSMETIC AND AUDIO
Micha (05-27-2015)
 Old 05-22-2015, 08:22 AM   #36
myarbro1's Avatar
Ceramic Coating FTW it seems. Glad someone's held up!
 Old 05-22-2015, 11:56 AM   #37
siegsuwa's Avatar
Thanks for posting up, dude. I pulled feejay's drive shaft out of his wrecked MS6 this week to replace my shaft with a torn boot, and I am pretty sure I tore the boot (or exacerbated an existing tear) in the process of getting the shaft out, so now I get to rebuild both!
Your boot looks really solid at 5k miles.
EDIT - so now that the boot interior volume is much larger than it originally was, did you just fill it up with CV grease?
 Old 05-22-2015, 03:11 PM   #38
myarbro1's Avatar
I think we all used the entire container of grease that comes with the boot siegsuwa.
 Old 05-22-2015, 05:31 PM   #39
meelo88's Avatar
I just loaded up the boot with the grease it came with... I suppose I could have put more in but I figured it was probably okay...
TUNED BY NISHAN
POWER
COSMETIC AND AUDIO
 Old 05-30-2015, 01:13 PM   #40
rndmheroxx's Avatar
Posts: 73   (View Stats)
rndmheroxx has much to be proud ofrndmheroxx has much to be proud ofrndmheroxx has much to be proud ofrndmheroxx has much to be proud ofrndmheroxx has much to be proud ofrndmheroxx has much to be proud ofrndmheroxx has much to be proud ofrndmheroxx has much to be proud of
Speaking of shafts.......
Any of you fellas happen to have an extra prop shaft laying around? My carrier bearing(s) have bit the dust and im on the hunt for a replacement
-93 Miata Turbo
Greddy manifold/turbo 18psi
15x8 6UL's Dunlop Direzza dz101
Kyb/FM suspension
FM sway bars
949 racing adjustable endlinks
Torsen swap
-2007 MAZDASPEED6 GT Ti Gray 55k miles #10026
Cobb AP V3, Cobb SRI/TIP, SU TMIC, AWR RMM , Magnaflow CBE , Forge BPV , TWM Shifter , Denso ITV22, Jugg/Dread
rndmheroxx is offline   Reply With Quote
u joints for propeller/driveshaft SyntheticAtmosphere MazdaSpeed 6 - Engine, Transmission & Driveline 5 06-28-2013 07:22 PM
Can we extend the life of our propeller drive shaft? goo Mazdaspeed3/6 General Discussion 0 01-03-2013 11:46 PM
Installed Redline shift boot, ebrake boot, and armrest cover... Hank3 MazdaSpeed 3/6 - Appearance 28 01-14-2009 04:27 PM
Page generated in 0.56901 seconds with 33 queries
