> MazdaSpeed 6 - How-To's
 Old 11-14-2018, 10:45 AM   #1
njdurkin's Avatar
Posts: 68   (View Stats)
njdurkin is an unknown quantity at this point
Default New caliper, soft pedal
My front left caliper had a seized piston. I replaced the caliper. Easy enough. Bled the brakes extensively. Started it up, soft pedal. Pumped it a few times, drove it around, soft pedal. Bled brakes again, no air bubbles coming out. pedal firm. Start engine, pedal immediately soft. What did I do wrong?
njdurkin is offline   Reply With Quote
 Old 11-14-2018, 11:17 AM   #2
Thor Hammer's Avatar
Posts: 1,847   (View Stats)
Groans: 211
You still have air in the system. Try bleeding all four corners starting with the furthest to the closest caliper in relation to the master cylinder.
 Old 11-14-2018, 11:39 AM   #3
njdurkin's Avatar
Okay I will try more bleeding tomorrow starting with rear. The other thing I noticed is that if you slam on the brakes the car pulls hard the the right. It didnt do that before. Idk what that means.
 Old 11-15-2018, 08:32 AM   #4
SSinstaller's Avatar
Posts: 3,989   (View Stats)
Groans: 60
That means there is air in the line of the caliper you just replaced.
 Old 11-15-2018, 08:43 AM   #5
njdurkin's Avatar
I have completely flushed that line by now though. Ok, I guess I will try to flush it again.
 Old 11-15-2018, 09:42 AM   #6
Groans: 211
Jack up the front of the car and put it on jackstands. It will help any air bubbles in the line rise to the top. Hopefully.
Sometimes it can be a bear to get all the air out. You may want to try using a bleeder bottle. Amazon carries them.
 Old 11-15-2018, 10:11 AM   #7
njdurkin's Avatar
Okay tell me how far I'm supposed to crack the bleeder bolt. Do I turn it to where I barely get anything out and pedal is firm? Or do I crack it a tiny bit more where I can push the pedal to the floor and get more fluid and bubbles, but also some fluid is coming out around the threads which makes me think the bubbles are just being introduced into the system. There is no happy medium. I have been bleeding using the barely cracked method which has gotten me nowhere. So I will try the method where I am getting bubbles I guess and see what that does.
 Old 11-15-2018, 02:25 PM   #8
Groans: 211
TLDR;
I'm sure you already know the proper procedure but....
You should connect a piece of tubing to the end of the bleeder valve and direct it into a bottle.
Then have someone in the car pump the brakes not too fast but firmly around 5-6 times to build pressure. Then have them hold it firmly to the floor and open the bleeder valve a quarter turn.
That should allow the fluid to rush out along with the bubbles. Don't just crack it. Open it enough to allow the fluid to rush out. Then close/tighten the bleeder, release the brake pedal. And repeat.
 Old 11-15-2018, 05:43 PM   #9
Fstrnyou's Avatar
Posts: 2,498   (View Stats)
If the bleeder valve is still open when the pedal hits the floor, there is a chance air can get back in.
So when I'm doing the bleeder, I only have it open for a quick second.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
 Old 11-16-2018, 09:45 AM   #10
Groans: 211
This thing works awesome. Bled my entire clutch circuit from completely dry to full bled in no time.
https://www.amazon.com/Allstar-Perfo.../dp/B00F9XHVKA
 Old 11-21-2018, 11:59 PM   #11
highwayrun's Avatar
Posts: 11   (View Stats)
highwayrun is on a distinguished road
If you didn't clamp or plug the brake line when you changed the caliper, air could have gotten into 1) the ABS pump, or 2) into the master cylinder.
1. A cool trick I picked up from Eric the Car Guy for bleeding the ABS pump is to invoke ABS on a loose surface a few times -- works like a charm and so easy to do. This alone will make the pedal firmer; and then you'll go ahead and bleed the brakes to purge the air that the ABS pump has forced into the calipers.
2. If bleeding the ABS pump doesn't work, then you're looking at bleeding the master cylinder. I find bleeding a master cylinder to be an art that takes practice to master. Plus, on the MS6 it's in a really inaccessible position; I'm not sure about the MS3 location.
My guess is you'll only need to bleed the ABS pump and then the brakes, in that order, and you'll be fine.
2007 MazdaSpeed6 GT, Black Mica
SU TMIC | Sure Aeros SRI | CS CDFP Internals | COBB AP - Freek OTS plus | SURE Dreadnaught | CPE RMM | AWR Mounts | Sparco Torino 2 | P235/40R18 Hankook RS-3 | 18 x 8.5 / +45 ET Spyn Mod5 | Carbotech 1521,XP10,12,20
highwayrun is offline   Reply With Quote
Soft brake pedal feel texasboy21 2010 MS3 - Suspension & Brakes 33 09-05-2019 02:52 PM
Soft clutch pedal wes3id MazdaSpeed 3/6 - Troubleshoot/Diagnostics 1 03-10-2016 03:49 PM
Soft brake pedal after service Fobio MazdaSpeed 3/6 - Suspension & Brakes 12 12-20-2015 10:20 AM
Cracked clutch pedal bracket caused pedal to crack firewall which pierced my master cylinder Marcus Mazdaspeed3/6 General Discussion 0 10-17-2015 06:14 AM
brake question... pedal soft at top of travel natmad MazdaSpeed 3/6 - Suspension & Brakes 1 03-13-2011 04:56 PM
Page generated in 0.30506 seconds with 24 queries
