| ![]() | LinkBack | Thread Tools | Search this Thread | Display Modes |
![]() | ![]() | #1 | ![]() |
![]() Join Date: Jun 2010
Rep Power: 0 ![]() Thanks: 0
(Thread Starter) | ![]() ![]() ![]() |
![]() | ![]() | #2 | ![]() |
![]() Join Date: Nov 2009 Location: Flushing, NY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10
| ![]() ![]() ![]() whats the code number? wait sorry, if you dont have a cobb/dash hawk/etc, how do you know its a coolant temp problem?
__________________ 2007 MS6 GT Black Mica - Forge BPV - SU TP - DH Last edited by sno328; 08-01-2010 at 11:29 PM. Reason: MSF Database - Automerged Doublepost |
![]() | ![]() | #3 | ![]() |
![]() Join Date: Dec 2010
| ![]() ![]() ![]() the cheaper obd2 readers wont read abs codes and yes the more expensive ones like the actron scanner will....not sure about the cobb accessport but yeah what is the code number your throwing?
__________________ [SIGPIC][/SIGPIC]2008 Mazdaspeed3 GT - CPE Nano Intake, Cobb Turbo Inlet Hose, James Barone Short Shifter, James Barone Solid Shifter Bushings, TurboXS Test Pipe, HKS Catback Exhaust. Prosport Boost Gauge |
![]() | ![]() | #4 | ![]() |
![]() Join Date: Jan 2011 Location: sanford, fl
| ![]() ![]() ![]() ive been getting the po128 and ive already replaced my ect sensor didnt fix it now im doing the thermostat and we'll see if that fixes it
__________________ MODS: AP V3, 3.5" intake, 3bar, gt3076 atp ewg, 38mm wg, SS turbo lines, 3" catless dp, 3" exhaust dp, hpfp, egr delete, vtcs delete, Mac 4port, lil intake mani port work, cxracing fmic, 51R battery cut stock battery tray, Toyota injector seals |
![]() | ![]() | #5 | ![]() |
![]() Join Date: May 2011
| ![]() ![]() ![]() I had the same issue. Replaced the sensor and the car threw the same code after a week. Replaced the Thermostat and haven't had an issue since. When changing the thermostat, It's easier to get to if you move the power steering pump to the left. Keep the hoses on the thermostat until you remove the 3 bolts on the thermostat. It'll make it easier to remove the hoses. Overall, it's a pretty straight forward fix. I'm a rookie when it comes to fixing cars and was able to finish in about 2 hours. |
![]() | ![]() | #6 | ![]() |
Banned ![]() Join Date: May 2012 Location: Harrisonburg, VA
Rep Power: 0 ![]() Thanks: 4
| ![]() ![]() ![]() I keep getting the code P0571, but I get no CEL. I know what the code means (brake switch/cruise control malfunction ... I can't seem to figure out how to repair the problem. Anyone have an idea?! |
Mazda OBD-II Trouble Codes | Haltech | MazdaSpeed 3/6 - ECU Computer Tuning | 9 | 06-18-2019 05:12 PM |
Please help trouble codes P0012,P2187,P2088!!!!!!!!!!!!! | gt5 | MazdaSpeed 3/6 - Turbo Induction | 7 | 02-25-2010 07:43 PM |
Trouble Codes is there a list? | Arrowpoint | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 6 | 02-01-2009 02:21 PM |
Link to trouble codes...... | winniep | MazdaSpeed 3/6 - ECU Computer Tuning | 2 | 03-20-2008 07:22 PM |
