| MazdaSpeed 3/6 - Suspension & Brakes Discussion for suspension items like coilovers, springs, sway bars, mounts,chassis bracing and brakes. |
![]() Join Date: Dec 2012 Location: Portland, OR
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 800
(Thread Starter) | Not Ranked : 0 score Ok, So I had a set of these on my SVT Focus, and I know a lot of the suspension parts swap from the Focus to the MS3 platform. My first question, will these swap over to the MS3? Can someone make a set for the MS6? Ford Focus Rear Adjustable Lower Control Arms / Dominant Engineering |
![]() Join Date: Oct 2012 Location: Gresham, OR
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 40
| Not Ranked : 0 score Corksport makes rear adjustable camber arms for the ms6. They just released them.
__________________ 06 MS6 Sport 290whp/295wtq sold 11/2013 Little brothers 06 MS6 GT BCM : H&R CO's, CS - Front Sway bar, Front and rear strut bars, power series 3" TBE exhaust with catted DP, Power series FMIC kit (TIP, Intake), Full LED interior and exterior with LED fogs JBR - SSP and weight with shift bushings, cylindrical shift knob SURE - RMM, Rear Diff mountCarLED tails AutoTech HPFP internalsTuned by StratifiedHKS SSQV4 VTA |
__________________ -06 MS6 -Corn fed 07 MS3 - Sold ![]() www.mazdamotorsports.com <<--Mazda racer support program that is free to join and will save you a ton of money. |
| The Following 3 Users Say Thank You to phate For This Useful Post: |
![]() Join Date: Mar 2008 Location: Chicago
Rep Power: 4020 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10,876
At any rate, I've come to the conclusion that those arms that Dominic makes are more suited to the slammed/stance crowd. I wouldn't be too quick to throw his stuff on my regularly tracked MS3 after looking a bit further into his "track record" (I'm well aware of his dealings with the Focus world, as I was quite active in that community for several years): Interested in tubular, adjustable MS3 front lower control arms?
__________________ Stance is not a verb. 2008 MS3 GT 2016 MX-5 Club | |
| The Following User Says Thank You to Nliiitend1 For This Useful Post: | redboat (12-25-2013) |
| Interested in tubular, adjustable MS3 front lower control arms? | Nliiitend1 | MazdaSpeed 3/6 - Suspension & Brakes | 128 | 08-02-2019 09:55 PM |
| Cant find bolts for rear lower control arms | whenning232323 | MazdaSpeed 6 - Engine, Transmission & Driveline | 4 | 11-16-2013 07:22 PM |
| CorkSport Adjustable Tubular Control Arms | CorkSport | CorkSport | 59 | 01-19-2013 04:30 PM |
