| MazdaSpeed 3/6 - Suspension & Brakes Discussion for suspension items like coilovers, springs, sway bars, mounts,chassis bracing and brakes. |
(Thread Starter) | Not Ranked : 0 score The brakes are in good shape, no rocks stuck between the rotor and backing plate. I have checked the usual suspects, and everything is tight on the strut, and endlinks. I have CPE RMM, TRZ Trans mount. Checked the rmm when I did the strut install, have not checked TRZ. Bolt is bathed in Loctite and was new when I installed. Last checked about 6-12 months ago I have searched, and all points are leading to the strut bearings. I reused them at 68K miles, as well as the cracked/broken factory bump stops, as I did not get the GS or FC ones. I am thinking that it is indeed the friggin bearings, which sucks. I don't want to take shit apart an then realign-again. For those who replaced the strut bearing, what were your symptoms? |
| patrick failman ![]() Join Date: Mar 2009
Rep Power: 2905 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,275
Groans: 74
| Not Ranked : 0 score did the strut bearings looked fucked up when swapped in the konis? wonder if the cracked bump stops helped lead to their demise. this was mine after 15k...
__________________ 2012 ingot silver mustang gt w/ 6 speed, 3.73 rear end, bama 93 tune, cat deletes, boss 302 oil cooler, roush cai, dynotech aluminum driveshaft, ford racing strut tower brace, dampers & springs, boss 302 sway bars, gt500 strut mounts, lower control arms & axle backs, j&m adjustable panhard bar, steeda upper control arm & 3 point braces, jlt catch can, barton short shifter & shift bracket |
(Thread Starter) | Not Ranked : 0 score Mine did not have a cold beer in them, that might be it! I did not see em, but one did come open. I bet that was it. They seemed fine. |
Groans: 74
| Not Ranked : 0 score one strut bearing opened up? is that the one making the noise? i was scared one of mine would open up.
(Thread Starter) | Not Ranked : 0 score I think it was the passenger side, but yeah. It snapped back together and seemed fine. Forgot about it. Looks like I'll be ordering new strut bearings. Good thing I own a spring compressor. Wonder how long I can put this off. |
![]() Join Date: Apr 2011 Location: Vallejo, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,478
| Not Ranked : 0 score How are you dealing with your, er, dealers? I took my clunking car to the dealer twice, and both times they double that all the relevant bolts were tightened down to spec. They've heard the clunk, but they can't seem to pinpoint the cause of it themselves. They seem to dismiss the idea of the strut bushing/bearing when I mention it, since "things on the internet can be a bit misleading". The tech I've been talking to is a nice guy, but he says the JBR motor mounts are giving him trouble in starting a warranty repair. Did you guys have the same hassle? This is perfect (read: not) timing, as I was trying to remove and reinstall my RMM today to rule out a bad RMM, and now I'm finding the bolt that mounts the RMM to the tranny bracket is bent/stuck, and not tightened to spec...
__________________ (310whp, 341 ft/lb wtq) 91 octane + 100% methanol JBR RSB, Stage2 OCC, Stage 2 SSP, IM TIG, 70D RMM, 70D PMM // DevilsOwn Stage 2 WMI kit + DO7 nozzle (MSF-prize) // COBB AP (Self-tune), XLE BPV // Corksport TMIC, SRI, TIP // Racing Beat Cat-back Exhaust // Denso Iridium ITV22 Spark Plugs // SURE TB TIG // Ultimate Racing Test Pipe // KMD HPFP Internals // TSW Nurburgring 18x7.5 ET45 Matte Black // SWIFT Spec-R Lowering Springs // |
![]() Join Date: Dec 2011
Rep Power: 0 ![]() Thanks: 0
| Not Ranked : 0 score I'm an ASE certified auto technician and I own a MS3 and I have experienced this problem and it is indeed the bearing that is rattle. It is more prone with cars that have lowering springs with the stock struts. I just recently replaced my bearings and the rattle went away. |
![]() Join Date: Nov 2010 Location: northwest arkansas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,067
Groans: 103
i had a bad strut mount/bearing replaced under warranty. the same thing happened to me, the dealer couldn't figure out what was making the 'thunk' i had on slow speed turns like parking lots and such. i had them try to fix it 3 times. then finally, when i was heading on vacation for a week, i gave them the car, told them 'i know what the odometer reads and it shouldn't be much higher when i get back', and insisted that they find and fix the clunk by the time i got back. i also told them i thought it was the strut bearing (didn't say i had read that on the internet) and suggested to the particularly nice tech that he start there. that's what it was. probably a long time. i bet the annoyance factor will be the impetus for fixing it well before any mechanical catastrophe occurs.
__________________ 2008 ms3 mit: hypertech tune, pg sri, corksport tip, jbr(80 tmm, 88 rmm, 80 pmm), jbarone bushings + heavy shift knob, diy sts, sure ssp, sensen shocks, jbr rsb, ford transfluid, aura 5 channel amp, jbl gt speakers, 6" bazooka sub, diy mudflaps, DDM 3000k HID fog kit, 6000k lows [SIGPIC][/SIGPIC] Last edited by tddvrrn; 12-04-2011 at 03:31 PM. Reason: MSF Database - Automerged Doublepost | |
![]() Join Date: Mar 2008 Location: Chicago
Rep Power: 4020 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10,876
| Not Ranked : 0 score Those things are a wear item. They're not really ever worth re-using, especially if they've been opened up. Consider this a lesson learned.
__________________ Stance is not a verb. 2008 MS3 GT 2016 MX-5 Club |
| The Following User Says Thank You to Nliiitend1 For This Useful Post: | rfinkle2 (11-28-2013) |
| Another strut bearing blown | kwsmithphoto | MazdaSpeed 3/6 - Suspension & Brakes | 27 | 01-30-2018 09:10 PM |
| Chain-like / bearing sound from engine | 3starmagnum | 2010 MS3 - Troubleshoot/Diagnostics | 12 | 05-28-2012 12:44 PM |
| clink sound from suspension | HaigDaniel | 2010 MS3 - Troubleshoot/Diagnostics | 3 | 07-29-2011 02:20 PM |
| Sound from front suspension | sesquis | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 0 | 05-18-2009 12:35 AM |
