Like Tree8Likes
 Old 10-31-2014, 12:55 PM   #81
aviator79's Avatar
Posts: 3,934   (View Stats)
IDK. I am going with yellowstuff in fronts.
Just bought a pair of front rotors from advance auto for $75 after $50 off $100 with code MISSUL44 (added a can of caliper paint as filler).
I got rear autozone rotors for $40 (pair).
I will see if I can get a MS3 over to compare when I do mine.
 Old 10-31-2014, 01:23 PM   #82
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
We talked about this in my build thread. Front pad SHAPES are identical. The inner pads have identical clips. The outer pad on the MS6 does not have any clips, where the MS3 outer pad does have them iirc.
-06 MS6
-Corn fed 07 MS3 - Sold
aviator79 (11-03-2014), Code Monkey (11-03-2014), Nliiitend1 (10-31-2014)
 Old 11-03-2014, 01:28 PM   #83
aviator79's Avatar
Thickness too I assume. Just want to make sure because its sort of important.
Thanks phate.
phate (11-03-2014)
 Old 02-21-2015, 03:43 PM   #84
season_of_ages's Avatar
Posts: 290   (View Stats)
season_of_ages has a reputation beyond reputeseason_of_ages has a reputation beyond reputeseason_of_ages has a reputation beyond reputeseason_of_ages has a reputation beyond reputeseason_of_ages has a reputation beyond reputeseason_of_ages has a reputation beyond reputeseason_of_ages has a reputation beyond reputeseason_of_ages has a reputation beyond reputeseason_of_ages has a reputation beyond reputeseason_of_ages has a reputation beyond reputeseason_of_ages has a reputation beyond repute
Yellowstuff ms6 front: Dp41773R
no yellowstuff rears (called EBC said a new part number was created so maybe they will be making some, told me to go with redstuff rears).
Yellow rears now available DP41766R
season_of_ages is offline   Reply With Quote
The Following 2 Users Say Thank You to season_of_ages For This Useful Post:
highwayrun (03-19-2015), phate (02-21-2015)
 Old 03-18-2015, 07:16 PM   #85
Todd@TCE's Avatar
Posts: 159   (View Stats)
Todd@TCE has a reputation beyond reputeTodd@TCE has a reputation beyond reputeTodd@TCE has a reputation beyond reputeTodd@TCE has a reputation beyond reputeTodd@TCE has a reputation beyond reputeTodd@TCE has a reputation beyond reputeTodd@TCE has a reputation beyond reputeTodd@TCE has a reputation beyond reputeTodd@TCE has a reputation beyond reputeTodd@TCE has a reputation beyond reputeTodd@TCE has a reputation beyond repute
Please note that the Wilwood factory 13" front kit is nowhere neeear $1995. In fact that listed price is hundreds over Wilwoods own web page price. Final dealer costs can also be far less that that. We've packaged this front kit with a full compliment of ss hoses (with shipping included) for under $1100. Nearly $900 less than the posted price.
Also TCE/Wilwood 14" front kits can be had well under $2k starting at only $1709.
TCE also has a rear 'big rotor kit' listed for $597 to compliment the front kits above.
Peace. Carry on...
TCE PERFORMANCE PRODUCTS
Your one stop....for Wilwood Brakes.
* Corvette * Lightning * Impala SS * Focus ST * Marauder * 350/370Z * MINI * Challenger * WRX *Super Duty * SHO * Mustang *...and more!
Todd@TCE is offline   Reply With Quote
 Old 03-19-2015, 11:56 AM   #86
Nliiitend1's Avatar
Posts: 5,749   (View Stats)
This option should probably be added to the OP as well:
Powerbrake PB44L Big Brake Kits
Powerbrake Catalog
Not sure on exact pricing (I got mine set second-hand, but I know the kit PB44L I have was north of $2K new), and they're still in process of getting their USA facility up and running, but they can be purchased by contacting them directly or by going through Carbotech, if I recall correctly.
Stance is not a verb.
2008 MS3 GT
2016 MX-5 Club
 Old 04-26-2015, 06:36 PM   #87
ZacMoxley's Avatar
Posts: 3   (View Stats)
ZacMoxley is an unknown quantity at this point
Thinking about buying the Stoptech kit, I dont want to make a bunch of orders and find different parts, is this a good idea? 2008 speed3
ZacMoxley is offline   Reply With Quote
 Old 04-26-2015, 08:58 PM   #88
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
Yeah, I can confirm they are a good idea. The car stops very well. The initial bite when cold is OEMish, but you really need to apply the brakes lightly 2-3 times at a stop light and it's fixed.
The only downside is that the disks corrode a bit faster when the car is not used for a long time and it's moist outside (not used for like 3-4 days of rain), but again, that goes away quickly.
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
 Old 04-27-2015, 03:24 AM   #89
Stoptech, Powerslot, and Centric blanks are the same. Centric owns them all.
Nliiitend1 (04-27-2015)
 Old 04-28-2016, 09:36 AM   #90
mikelevi's Avatar
Posts: 362   (View Stats)
mikelevi is the leader of the worldmikelevi is the leader of the worldmikelevi is the leader of the worldmikelevi is the leader of the worldmikelevi is the leader of the worldmikelevi is the leader of the worldmikelevi is the leader of the worldmikelevi is the leader of the worldmikelevi is the leader of the worldmikelevi is the leader of the worldmikelevi is the leader of the world
Has anyone tried the Brembo rears yet?
Manufacturer Part #: P24131N
Brembo Ceramic Brake Pads
Current Build: 2006 MS6 GT
Power: BNR S3V2, Freektune 3.5" Intake, PnP Intake Manifold PC Wrinkle Black, Custom 3" Magnaflow CBE, M2 Ebay DP, CS Injector Seals, TR8L FMIC, Autotech Internals, GFB BOV 70/30, JBR OCC, EGR Delete and Block Plate, GS EBCS, Cobb AP v2, NGK IX @.026, Bosch 3 Bar MAP and Harness
Looks and Feels: AWR 80 Duro Trilogy Mounts, Bilstein B6, CPE and TT diff mount, Whiteline RSB, LED Tails, 18x8 +43 MB Battles Gunmetal, PC valve cover and IC piping Black Chrome II
mikelevi is offline   Reply With Quote
 Old 07-06-2016, 10:55 AM   #91
mituc's Avatar
Groans: 111
Ok, so I'm looking for an advice from someone who knows these brakes and/or went through the same issue as I do now.
the stoptech brakes I have are superb as I said. However, now that the summer is on I felt they faded a bit on me with two occasions so far during spirited driving on my favourite street course. So I need a slightly more aggressive pad (because probably the rotors are ok), but not too much more aggressive than what the stoptech street already is, just slightly (I still need the cold usability because we have 5-6 months of cold weather per year).
So what is the pad I'm looking for and is more aggressive but still street friendly like the stoptech street ones are? Some Carbotech or Hawk? Stoptech Sport?
 Old 07-06-2016, 11:13 AM   #92
ChaunceyM's Avatar
Posts: 948   (View Stats)
ChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the world
I was using EBC Yellowstuff for track and street and was happy. I might have been seeing a bit of fade at the track at the end of the 20min sessions, but if any it was minimal. That was on stoptech high carbon rotors and summer tires. And on a fairly warm day (mid-80s).
They were great on the street, even in winter. Much better cold bite than the Hawk HP plus.
Corksport: SRI & TIP, Strut Tower Brace, Coilovers
CP-e: RMM
JBR: Rear Sway Bar (with Moog End Links)
TWM: Full Replacement Shifter
Cobb: AP
AutoTech: HPFP Internals
Ebay: Test Pipe
ChaunceyM is offline   Reply With Quote
The Following User Says Thank You to ChaunceyM For This Useful Post:
mituc (07-06-2016)
 Old 07-06-2016, 02:34 PM   #93
mituc's Avatar
Groans: 111
I kept recommending the yellowstuff pads to various people to use with the OEM rotors even if they are a bit more aggressive and abrasive with them. I can't understand how I failed on thinking to get them. I ordered a set, we'll see how they work with a brand new set of stoptech slotted rotors.
 Old 08-05-2016, 01:27 PM   #94
qtrmile beast's Avatar
Posts: 2,423   (View Stats)
Any research on replacement pads and rotors for the brembo BBK?
I am currently running ferado fcp1348h.... just dont want to spend another 200 on pads of i dont have to...
Just found the hawk pads cross reference number
HB191F.590 I have not bought any with this part number though...
track weight 3220
street weight 3370
 Old 08-05-2016, 05:29 PM   #95
blackms3_71's Avatar
Posts: 2,250   (View Stats)
all you guys with bbk I hate you lol I don't have it in me to spend that much on brakes but I sure am jelly.
 Old 03-13-2017, 04:29 PM   #96
replacement rotor for the Brembo BBK (2000 mustang cobra r rotors)... Rotor cost about 35 bucks each.20170218_184327[1].jpg
track weight 3220
street weight 3370
The Following User Says Thank You to qtrmile beast For This Useful Post:
phate (04-13-2017)
 Old 03-30-2017, 10:48 AM   #97
So i have finally found some alternative brake pads for the Brembo BBK for the MS6... They are the rear brake pads for the 2005 CTS-v.. But i have a question for the brake gods out there..
Will this pads work for a replacement pad for the MS6 front pads? Will the slants on either end hurt performance? I only drag race so no auto crossing or rallying.
What i am concerned about is that slants on both sides of the pads if it makes any difference..
Sorry for the upside down pics...
track weight 3220
street weight 3370
 Old 03-30-2017, 07:11 PM   #98
Eth Fiend
phate's Avatar
I wouldn't worry about the bevel.
-06 MS6
Nliiitend1 (04-05-2017), qtrmile beast (03-31-2017)
 Old 04-05-2017, 06:21 PM   #99
Nliiitend1's Avatar
This.
2008 MS3 GT
2016 MX-5 Club
 Old 04-12-2017, 02:32 PM   #100
Ok fyi for those that were or are going to take your factory rotors off and use this rotor. There are a couple of things you need to know. The rotors works you just have to hone the center out because of the step in the hub. So just hone that out enough to fit over the step which is about a few 1000ths off voila!!!!!
track weight 3220
street weight 3370
The Following 2 Users Say Thank You to qtrmile beast For This Useful Post:
Code Monkey (04-12-2017), phate (04-13-2017)
 Old 09-20-2017, 05:31 PM   #101
lreyes66's Avatar
Posts: 133   (View Stats)
lreyes66 is a jewel in the roughlreyes66 is a jewel in the roughlreyes66 is a jewel in the rough
Groaned at 14 Times in 2 Posts
So I ordered powerstop OE daily driver solid rotor + pads kit for the front from rockauto. What I ended up getting was the performance vented/slotted/drilled rotors which cost like $100 more then what I bought but was charged for the DD kit.
I contacted rockauto and they told me I can order again and return what I have but that would mean I’d have to wait another week and only have time this weekend to work the on the car so I’m thinking of just keeping it. Will there be any problems on stock ms3 calipers?
lreyes66 is offline   Reply With Quote
 Old 09-20-2017, 06:04 PM   #102
I don't see how the performance rotors would be an issue. As long as the bolt patterns, outer diameters and widths all match up, you should be fine. As a matter of fact, I want in on this deal! I wonder if everything matches on the Speed6
Sent from my LG-H918 using Tapatalk
 Old 09-22-2017, 03:45 PM   #103
lreyes66's Avatar
Thanks.
I replaced my front pads and rotors and noticed that the front calipers didn’t have a dust boot cover that goes over the calipers pins. I’m guessing the shop I took it to last time to do brake work years ago never put them back on. The dust boots looks fine just doesn’t have a cover. Would the dust boot covers I pick up at auto stores like autozone work or would that require me to actually remove the old dust boot and put in the new ones? Are the covers even that important if the actual boot is ok? I mean I’ve driven for years without noticeable brake problems from the front.
Edit: went to AutoZone and got the duralast hardware boot kit for $10 just for the covers. 3 fit perfectly and one boot pin hole was looser then the rest so the cover receded inside more. Don't plan on getting under just to replace the boots so I have extras now.
The Following User Says NO Thank You to lreyes66 For This Un-useful Post:
mituc (09-23-2017)
 Old 09-23-2017, 01:14 AM   #104
mituc's Avatar
Groans: 111
Ok, and?
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f12/brakes-database-mazdaspeed-3-mazdaspeed-6-a-72761/
günstigste Variante Bremsen zu tauschen - Seite 12 This thread Refback 09-22-2014 12:21 PM
Brake rotors | SpeedForums.org This thread Refback 01-16-2012 10:44 AM
HOW-TO DATABASE MS6 MATT DAMOND MazdaSpeed 6 - How-To's 42 11-21-2016 07:07 AM
HOW-TO DATABASE MS3 MATT DAMOND MazdaSpeed 3 - How-To's 39 07-15-2015 07:29 AM
Cobb AP Map Database? DaAznKnight MazdaSpeed 3/6 - ECU Computer Tuning 12 11-30-2010 06:14 PM
2009 MS3 brakes vs. 2010 MS3 brakes Driver72 2010 MS3 - Suspension & Brakes 11 11-21-2009 10:34 AM
Page generated in 0.43535 seconds with 33 queries
