Closed Thread
 Old 03-14-2012, 01:03 PM   #1
mazdaspeed4life's Avatar
Posts: 93   (View Stats)
mazdaspeed4life is infamous around these partsmazdaspeed4life is infamous around these partsmazdaspeed4life is infamous around these parts
Groaned at 108 Times in 27 Posts
Default Which brakes to go with
Bout that time to get new rotors and pads. Need opinions on what to do with . I want slmethig that gives off minimal brake dust..suggestions welcome
((SLIK-6))
mazdaspeed4life is offline
 Old 03-14-2012, 01:05 PM   #2
vballbwing's Avatar
Posts: 174   (View Stats)
vballbwing has a brilliant futurevballbwing has a brilliant futurevballbwing has a brilliant futurevballbwing has a brilliant futurevballbwing has a brilliant futurevballbwing has a brilliant futurevballbwing has a brilliant futurevballbwing has a brilliant futurevballbwing has a brilliant futurevballbwing has a brilliant futurevballbwing has a brilliant future
FWIW, I went with the Carbotech Bobcats. They bite better. But in warmer weather, they squeal at low speeds.
vballbwing is offline
 Old 03-14-2012, 03:56 PM   #3
Eh want something that's good year round...
((SLIK-6))
 Old 03-14-2012, 10:18 PM   #4
Caldwell's Avatar
Posts: 112   (View Stats)
Caldwell has a brilliant futureCaldwell has a brilliant futureCaldwell has a brilliant futureCaldwell has a brilliant futureCaldwell has a brilliant futureCaldwell has a brilliant futureCaldwell has a brilliant futureCaldwell has a brilliant futureCaldwell has a brilliant futureCaldwell has a brilliant futureCaldwell has a brilliant future
I just replaced my Fronts w/
DBA Slotted Rotors + Hawk HPS Pads
Once they are worn in, these feel fantastic !. Im gonna go with Centric Blanks for the rear with Hawk HPS Pads again...
They can squeal a little bit at very low speed, but they emitt almost no brake dust compared to OEM Pads...
the front combo I have is well worth the money i spent...
South Philly 08' Cosmic Blue
Caldwell is offline
The Following User Says Thank You to Caldwell For This Useful Post:
MSFer87 (03-16-2012)
 Old 03-14-2012, 10:47 PM   #5
vballbwing's Avatar
((SLIK-6))
Well, I will say that my fail is probably sticking with OEM rotors. I don't think I'd do that with the Carbotechs when I replace the ones that I have. Other than that, I've been happy with them since they dont dust quite so fast, and the dust is lighter, so it's less noticeable over the OEMs.
The Following User Says NO Thank You to vballbwing For This Un-useful Post:
zpele (03-15-2012)
 Old 03-14-2012, 11:12 PM   #6
Nliiitend1's Avatar
Posts: 5,749   (View Stats)
There is nothing wrong with OEM rotors. IMO, they're one of the best options.
Stance is not a verb.
2008 MS3 GT
2016 MX-5 Club
Nliiitend1 is offline
 Old 03-14-2012, 11:16 PM   #7
Mizzle's Avatar
Posts: 2,829   (View Stats)
Groans: 324
Akebono pads.
You know, like we mention in the brake thread.
Mizzle is offline
SWAY (03-15-2012)
 Old 03-15-2012, 12:10 AM   #8
SWAY's Avatar
Posts: 2,517   (View Stats)
SWAY is the leader of the worldSWAY is the leader of the worldSWAY is the leader of the worldSWAY is the leader of the worldSWAY is the leader of the worldSWAY is the leader of the worldSWAY is the leader of the worldSWAY is the leader of the worldSWAY is the leader of the worldSWAY is the leader of the worldSWAY is the leader of the world
Groans: 190
Groaned at 60 Times in 43 Posts
Awaiting install with my akebono's, dba slotted rotors next month.
~2011 Liquid Silver MS3~ ---->> ZZB
TEAM LBN BEERS -- FYCN
TEAM MUMFORD -- FYCN
SWAY is offline
 Old 03-15-2012, 02:46 AM   #9
How much were they
((SLIK-6))
 Old 03-15-2012, 02:47 AM   #10
Post pics
((SLIK-6))
 Old 03-15-2012, 02:48 AM   #11
Also hear that slotted / drilled rotors wear down pads easy
((SLIK-6))
 Old 03-15-2012, 07:42 AM   #12
Mouse's Avatar
Posts: 24   (View Stats)
Mouse will become famous soon enoughMouse will become famous soon enough
I originally ordered a set of the akebono's but the ones I received were the totally wrong part. So I needed to get pads on that day so it was either bend over at Mazda dealer or
Posi Quiet Semi-Metallic Brake Pads from a local parts place. They have been on for about 7 months and they work great. They may have a bit less bite than the original pads but they are low dust and no noise and only $56 2007 Mazda 3 Posi Quiet Semi-Metallic Brake Pads, Posi Quiet Pads - Videos, Installations & Reviews
07 Speed3. Hypertech, Cobb intake with big Amsoil Ea dry filter, CS turbo inlet, HKS BOV in recirc, Cobb short Shifter w/ weight, CS mount inserts, Dashhawk, Koni FSDs, EM Stage 1 Clutch.
Mouse is offline
 Old 03-15-2012, 08:54 AM   #13
MS6_Newb's Avatar
Posts: 105   (View Stats)
MS6_Newb has much to be proud ofMS6_Newb has much to be proud ofMS6_Newb has much to be proud ofMS6_Newb has much to be proud ofMS6_Newb has much to be proud ofMS6_Newb has much to be proud ofMS6_Newb has much to be proud ofMS6_Newb has much to be proud ofMS6_Newb has much to be proud of
Groaned at 7 Times in 3 Posts
+1 on the Hawk HPS.
MS6_Newb is offline
 Old 03-16-2012, 06:51 PM   #14
Caldwell's Avatar
i got my front components thru ( JSC Speed ) as they are local to me...
you may be able to find better pricing
Caldwell is offline
 Old 03-16-2012, 09:03 PM   #15
ManMan's Avatar
Posts: 35   (View Stats)
ManMan is just really niceManMan is just really niceManMan is just really niceManMan is just really niceManMan is just really nice
Hawk HPS work great ... squeal like stuck pigs, but stop SOOoo much better
2007 MS3 - Koni 4040 FSDs, Cobb SRi, Cobb AP Stage 1+, DIY shifter bushings, CorkSport RMM inserts, Hawk HPS, Slotted rotors, SS Lines.
ManMan is offline
 Old 03-17-2012, 05:57 AM   #16
Wow, finally a fucking brake thread. Never seen one before.
Raider is offline
ak_spray (03-17-2012), Mizzle (03-17-2012), Sid3wayS (03-17-2012), Spirry (03-17-2012)
Closed Thread
OEM MS3 brakes = Volvo S60 brakes? levitron MazdaSpeed 3/6 - Suspension & Brakes 109 03-02-2012 06:14 PM
Brakes brandonms3 MazdaSpeed 3/6 - Suspension & Brakes 19 06-06-2011 08:09 AM
2009 MS3 brakes vs. 2010 MS3 brakes Driver72 2010 MS3 - Suspension & Brakes 11 11-21-2009 10:34 AM
Page generated in 0.34825 seconds with 29 queries
