 Old 12-11-2011, 01:58 PM   #1
xtasy's Avatar
Posts: 685   (View Stats)
xtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the world
Groaned at 6 Times in 4 Posts
Default Can anyone figure out if my shocks blown?
Hey guys, yesterday the shocks was making some noise. It was the first time the weather reach 30 degrees. (car was bought used with 23k miles, right now it have 35,200)
The noise I was hearing was like Metal rubbing on Metal, plastic scraping on floor..
They were coming from the front left side of the car. Aside from that, it sounds like something is loose in the front end, when going over small bumps (it's been like that ever since I bought the car). Shocks does not feel blown at all.
You can hear it all within the first minute of the video. the clunking noise is at 24-25 seconds.
Mazdaspeed3 E85 ~ Sold 333/383
Mazdaspeed6 #10018 TiGrey
Forged Internals, PTE5858.
2015' Freektuned on 93Octane 322/337 (stock top mount and BPV)
2016' Freektuned on e85/93 480/444 (maxed out 3bar map sensor)
2017' Freektuned on e85/93 525/497 (maxed out pte5858 @ 35/36psi & fueling)
Mazda CX-5 AWD Daily
xtasy is offline   Reply With Quote
 Old 12-11-2011, 02:05 PM   #2
asall667's Avatar
Posts: 1,017   (View Stats)
asall667 is the leader of the worldasall667 is the leader of the worldasall667 is the leader of the worldasall667 is the leader of the worldasall667 is the leader of the worldasall667 is the leader of the worldasall667 is the leader of the worldasall667 is the leader of the worldasall667 is the leader of the worldasall667 is the leader of the worldasall667 is the leader of the world
Groans: 56
Groaned at 37 Times in 18 Posts
my rear left shock blew out at 57k miles. i would hit a bump and it would hit very hard like metal on metal sound.
could be a simple bushing tho. get under the car and check for leaks
2007 CBM MS3 GT 66K
Mods:
--Cobb SF SRI--Corksport TIP-- Speed Daddy FMIC Piping w/ TR8 Core--CPE 75A RMM--Test Pipe--Both res delete--TWM Short Shifter--Custom Fabric wrapped A pillars & Side Pillars--Gunmetal PC Genpu Wheels--Mazdaspeed Red Calipers (front & rear)--Laminx Fog Overlays--Foglight Mod--3M Gloss Black Roof--Custom Mudflaps--Evil Flying M--CPE Triple Gauge Pod--Propsort Boost-Oil Temp-Oil Pressure Gauges--Prosport Sammich Plate--SU Oil Spin On Conversion--Magnetic Drain Plug--Raceland Coilovers--SPC Rear Camber Arms--15MM H&R Spacers--Hawk HPS pads--Turbosmart Plumb Back BPV----
New VVT as of 50K miles Thanks Young Mazda
New K04 Turbo as of 57K miles Thanks Young Mazda
Last edited by asall667; 12-11-2011 at 02:05 PM. Reason: MSF Database - Automerged Doublepost
asall667 is offline   Reply With Quote
The Following User Says Thank You to asall667 For This Useful Post:
 Old 12-11-2011, 02:10 PM   #3
xtasy's Avatar
I checked already, there's no leaks. I'll be checking my sway bar bushings on monday. Hopefully it's not a blown shock. This car gotta last me another 3-4 months before it gets coilovers =|
 Old 12-11-2011, 02:16 PM   #4
asall667's Avatar
Groans: 56
good luck to sir. its prolly not if ur getting clunking over small road rash and no leaks...u would def noticed the leak too. The dealer spotted a puddle under my car when mine blew thats how I found out.
2007 CBM MS3 GT 66K
Mods:
 Old 12-11-2011, 03:04 PM   #5
silvapain's Avatar
Posts: 6,665   (View Stats)
Groans: 136
These cars tend to squeak and creak when it's cold out. My car did it in stock suspension, and still does it on coilovers.
Tapadatass
predapio (12-24-2011)
 Old 12-11-2011, 03:38 PM   #6
asall667's Avatar
Groans: 56
Tapadatass
After all, its a mazdas version of a "sports car". Car and Driver says if u want more luxury u should have bought a GTI lol FYVN
2007 CBM MS3 GT 66K
Mods:
 Old 12-11-2011, 03:47 PM   #7
chuckms6's Avatar
Posts: 1,618   (View Stats)
chuckms6 is the leader of the worldchuckms6 is the leader of the worldchuckms6 is the leader of the worldchuckms6 is the leader of the worldchuckms6 is the leader of the worldchuckms6 is the leader of the worldchuckms6 is the leader of the worldchuckms6 is the leader of the worldchuckms6 is the leader of the worldchuckms6 is the leader of the worldchuckms6 is the leader of the world
wait till it warms up then see if it goes away. the cold makes fluids thicker and closes tolerances in bushings so that may be where your noise is coming from
DIY SRI, DIY WAIC, VCTS Mod, Gutted Stock DP, Cobb AP, SURE TIG, KMD Internals, Denso ITV22's
SURE Dreadnaught, DSS Left Rear Axle, Custom in car SSP, JBR SSP, Powered by Max Shift Knob
Megan Racing Coilovers
13.7@ 96 w/1.8 60ft (SRI, AP)
13.4@ 102 w/1.9 60ft (SRI,AP,WAIC,TIG, Internals, ITV22's)
chuckms6 is offline   Reply With Quote
 Old 12-11-2011, 10:31 PM   #8
The Angry Goose
Hectik1's Avatar
Posts: 3,219   (View Stats)
Hectik1 is the leader of the worldHectik1 is the leader of the worldHectik1 is the leader of the worldHectik1 is the leader of the worldHectik1 is the leader of the worldHectik1 is the leader of the worldHectik1 is the leader of the worldHectik1 is the leader of the worldHectik1 is the leader of the worldHectik1 is the leader of the worldHectik1 is the leader of the world
Groaned at 9 Times in 6 Posts
When my shock (leaking)went bad I didn't have any noise. It felt unsteady while going through bumpy turns, but nothing else.
When my endlink loosened, it sounded like someone was banging a hammer on the underside of my car.
Hector
2014 Mazda 3
2008 Mazdaspeed3-SOLD
1979 Mazda Rx7
Hectik1 is offline   Reply With Quote
The Following User Says Thank You to Hectik1 For This Useful Post:
ak_spray (12-27-2011)
 Old 12-11-2011, 10:36 PM   #9
Lytheum's Avatar
Posts: 187   (View Stats)
Lytheum is the leader of the worldLytheum is the leader of the worldLytheum is the leader of the worldLytheum is the leader of the worldLytheum is the leader of the worldLytheum is the leader of the worldLytheum is the leader of the worldLytheum is the leader of the worldLytheum is the leader of the worldLytheum is the leader of the worldLytheum is the leader of the world
below freezing my suspension makes some awful noises. they go away once the temps go back up.
2008.5 MGM MS3
Cobb SRI, Cobb TIP, CP-E FMIC, Cobb Downpipe, CP-E HPFP, TRZ trans & RMM
Cobb AP, Forge BPV, Solid shifter bushings
Lytheum is offline   Reply With Quote
The Following User Says Thank You to Lytheum For This Useful Post:
 Old 12-11-2011, 10:46 PM   #10
tddvrrn's Avatar
Posts: 2,571   (View Stats)
Groans: 103
mine made some hideous thunks when it firsts started dropping below chilly. i took it in and was told everything seemed solid. it has since quieted down. not sure if it needed to adjust to the cold or if it will come back when it starts dropping down further in temp. we'll see.
 Old 12-11-2011, 11:32 PM   #11
Meder's Avatar
Posts: 1,065   (View Stats)
Meder is the leader of the worldMeder is the leader of the worldMeder is the leader of the worldMeder is the leader of the worldMeder is the leader of the worldMeder is the leader of the worldMeder is the leader of the worldMeder is the leader of the worldMeder is the leader of the worldMeder is the leader of the worldMeder is the leader of the world
Sounds Like strut mount. Its common for them to fail it seems
Meder is offline   Reply With Quote
 Old 12-24-2011, 02:32 PM   #12
2zz mr-s
dooderek's Avatar
Posts: 5,119   (View Stats)
Groans: 239
lol fwd sports car, hey what you using to mount your camera?
 Old 12-24-2011, 02:51 PM   #13
predapio's Avatar
Posts: 8,939   (View Stats)
Groans: 309
There is a thread on here from 3 years ago from yours truly, it explains what to watch for when it gets cold.
Too lazy to search for it.
What a lovable bunch we are!!
The Following User Says Thank You to predapio For This Useful Post:
kritz (12-24-2011)
 Old 12-24-2011, 03:15 PM   #14
smakdown61's Avatar
Posts: 1,069   (View Stats)
I replaced mine at 50k miles. Turns out they weren't blown but were extremely worn and couldn't rebound dampen worth a shit. Felt dangerous to drive.
smakdown61 is offline   Reply With Quote
 Old 12-24-2011, 09:15 PM   #15
I'd say end link, sway bar bracket, or strut mount.
 Old 12-24-2011, 11:38 PM   #16
xtasy's Avatar
Thanks guys, I'll probably fix this after winter. Going to find an aftermarket front sway bar and change it along with coilovers or strut/spring combo
 Old 12-25-2011, 09:55 AM   #17
I think you might need to check into ths sooner than later.
 Old 12-27-2011, 07:04 AM   #18
ak_spray's Avatar
Posts: 552   (View Stats)
ak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the world
This is exactly what happened to me. Couldn't have said it better myself.
As far as an Aftermarket front sway bar you might have to get both of them in a set. As far as I know JBR is the only one that sells sway bars separately and he only sells the rear. If its a bad shock you need to get it taken care of asap. I didn't know mine was leaking and I took a hard turn on the highway and the back end stepped out. If it was intentional it would have been cool but when you aren't expecting it, its not.
07 MS3 Sport
CPe: Stage2 RMM, XcelNANO Short Ram, Nviscid TIP, HPFP
SURE: AGS ATOM Shift Knob, ShortCut, CounterShift, TB/IM TIG, Injector Halos (Coming Soon)
JBR: RSB
Cobb: Accessport
Corksport: TMIC
CNT: Catted Downpipe
ak_spray is offline   Reply With Quote
 Old 12-27-2011, 07:24 AM   #19
Domino81's Avatar
Posts: 5,081   (View Stats)
I'd see if you can get it up on a lift and check lower control arms, sway bars and links. Just to see if everything is still tight.
2008 CosmicBlue Mazdaspeed3
294whp/335wtq - Stock K04
370whp/370wtq - BNR stage 3
 Old 12-27-2011, 09:46 AM   #20
Nliiitend1's Avatar
Posts: 5,749   (View Stats)
Do you still have the OEM rear sway bar??
If not, I'd suggest replacing that before messing with the front...
Stance is not a verb.
2008 MS3 GT
2016 MX-5 Club
 Old 12-27-2011, 09:50 AM   #21
ak_spray's Avatar
Put this on last week, really enjoying it and no squeaks from the rear anymore. You'd be supporting one of the best guys in the business too.
Rear Sway Bar Kit 07'-2012 Black [MS3RSB-BLK] - $195.00 : James Barone Racing, Custom Fabrication
07 MS3 Sport
JBR: RSB
Cobb: Accessport
Corksport: TMIC
The Following User Says Thank You to ak_spray For This Useful Post:
Hectik1 (12-27-2011)
 Old 12-28-2011, 10:43 PM   #22
xtasy's Avatar
Yes, I currently have JBR RSB on the stiffest setting.
I've been debating on Used coilovers, but I think I'll settle with the following
Bilstein Shocks/struts
H&R or Eibach Springs
Hotchkis FSB
Some stiffer front and rear end links (haven't done much research on which to get yet)
and JBR Rear camber arms.
I was planning on purchasing Tigermack's Tein SS with 30k miles for a third of retail.
But knowing he's a hardcore autocrosser, I am currently having second thoughts about it.
Still unsure of what to do as of now.
What would you do? Opinions?
Options are:
Bilstein Shocks/struts + 1.8 lowering spring (900 ish)
Tein SS w/ 30k miles for 500 ish
BC coilover w/ 20k for 400 ish
 Old 02-10-2020, 10:48 PM   #23
Anaphra's Avatar
Location: Chico CA for school. Originally From the Bay Area
Posts: 36   (View Stats)
Anaphra will become famous soon enough
Did you ever figure out what the problem was? The attached videos sort of sounds like what i've got going on. But mine's more clunky and floor boardy
2009 CWP GT MS3
Damond Motorsports RMM PMM and TMM
Autotech HPFP
Cobb SF Intake
Cobb AP
Autotech HPFP
Corksport RSB+FSB
Corksport Adjustable Short Throw
Corksport Metal Skid Plate
Koni FSD
Anaphra is offline   Reply With Quote
 Old 02-11-2020, 09:09 AM   #24
Police - Grammarhead
Vansquish's Avatar
Good luck getting a reply. The guy hasn't been on the forum since August 2018, and the last post here in this thread was 9 years before yours.
 Old 02-11-2020, 11:07 AM   #25
Anaphra's Avatar
Eh, it was worth a shot.
2009 CWP GT MS3
Autotech HPFP
Cobb SF Intake
Cobb AP
Autotech HPFP
Corksport RSB+FSB
Koni FSD
 Old 02-16-2020, 08:25 AM   #26
Frequentflyer's Avatar
Posts: 1,959   (View Stats)
Knocking underneath the driver's feet is almost always the swaybar end links. If you are getting a clunking through the steering with what feels to be a little bit of "play", could be the strut bearings.
 Old 02-16-2020, 05:22 PM   #27
Anaphra's Avatar
I is ended up replacing the top hats to try and fix the the sound and feeling I was getting. It ended up fixing a 1 sound I had that i guess over shadowed another, or something. But last week I finally crawled under there and found that the sway bar to endlink bolt had backout slightly, but enough to make noise. And I also discovered the reason as to why I wasn't able to originally find it. When ever I had the car up in the air or the wheel turned so that I could shake stuff, the swaybar and endlink would bind on each other somehow and not produce the noise.
I know this thread is dead, but If anyone is interested I can post the video I got of the noise.
2009 CWP GT MS3
Autotech HPFP
Cobb SF Intake
Cobb AP
Autotech HPFP
Corksport RSB+FSB
Koni FSD
Help me figure this out..... Darksun280 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 117 06-08-2019 04:33 PM
Trying to figure out what this does. andrewpiro Mazdaspeed3/6 General Discussion 6 06-22-2011 03:34 PM
Everyone, Please help me figure out WTF this is volodya84 MazdaSpeed 6 - Engine, Transmission & Driveline 19 07-28-2010 09:31 PM
Low Boost .. cant figure it out .. johnnyspeed6 MazdaSpeed 3/6 - Turbo Induction 28 06-27-2010 09:30 PM
Page generated in 0.45231 seconds with 37 queries
