  • 1 Post By MAZDAMARK
 Old 07-04-2017, 04:37 PM   #1
turbskies's Avatar
Posts: 178   (View Stats)
turbskies is a splendid one to beholdturbskies is a splendid one to beholdturbskies is a splendid one to beholdturbskies is a splendid one to beholdturbskies is a splendid one to beholdturbskies is a splendid one to beholdturbskies is a splendid one to behold
Groaned at 9 Times in 6 Posts
Default Creaking/popping noise from rear, when accelerating. PLZ HELP!!!
Just as I thought I fixed all my suspension I am now getting a creaking/ popping noise when accelerating from a stop or slower roll. I just finished installing both rear SURE mounts, bilstien b8's, h&r springs, whiteline rear sway bar, racing beat endlinks and a passenger side differential/ axle seal. I'm not sure what it is, but this car is really starting to annoying me. I feel like when I fix one think another thing breaks.
turbskies is offline   Reply With Quote
 Old 07-05-2017, 09:02 AM   #2
turbskies's Avatar
Please, not all at once...
 Old 07-05-2017, 09:15 AM   #3
Djohns's Avatar
Posts: 3,944   (View Stats)
Do you have a video of the noise? Could be the diff.
2010 black mica speed3
Soon:built motor
mr_mazda329 (07-31-2017)
 Old 07-05-2017, 09:17 AM   #4
turbskies's Avatar
No I could take one later today. It also seems to grow louder the longer I drive it, almost like it gets worse with heat.
 Old 07-05-2017, 11:41 AM   #5
monkey.bones.007's Avatar
Posts: 3,853   (View Stats)
Have you checked your PTO fluid level?
crapatalk it sucks for free
 Old 07-05-2017, 12:19 PM   #6
turbskies's Avatar
Just replaced it with amsoil when I did the rear end work about 1-2 weeks ago.
 Old 07-08-2017, 12:45 PM   #7
MIAPLAYAMS6's Avatar
Posts: 11   (View Stats)
MIAPLAYAMS6 is an unknown quantity at this point
What setting is your sway set to? I had a similar noise which ended up being the rear part of the sway bar hitting the spring bucket. Solution for me was to move the setting to the softer one (rear most hole) and raise the rear spring height adjuster a couple more threads. Not sure if you have the H&R coilovers set up or not. If not moving the sway bar setting might be all that's required. I have the Whiteline Rear Sway and Racing Beat Endlinks as well
2007 MS6: H&R Coilovers, Whiteline RSB, Corksport Rear Diff and Engine Mount, SPC RCAs, SPC Ball Joints, Corksport Exhaust, Racing Beat Endlinks, Amsoil Fluids
2011 F150 FX4 EB: Fox Coilovers / Rears, Icon UCAs, RCI Full Skid Plates, Turbosmart Kompact BOVs, Alpine Restyle FD001
(Past) 2004 350Z: Turbonetics Single Turbo, NISMO Rear Diff, ACT Clutch, JWT Flywheel, Hotchkis RSB, Cusco UCA, HKS Coilovers, Apexi WS2 Exhaust, SPC RCA, Motordyne Plenum Spacer,
MIAPLAYAMS6 is offline   Reply With Quote
 Old 07-08-2017, 12:48 PM   #8
turbskies's Avatar
I have the whiteline on the stiffest setting with h&r springs, but I read about this so I cut the softer setting off.
 Old 07-08-2017, 12:51 PM   #9
Interesting, well, just to make sure it's still not hitting you might consider painting the cut off end and drive it for a day, see if the paint gets scraped off. I noticed that with mine at the stiffest setting the end links were at a very acute angle and might have been binding as well. Moving to the softer setting at least after a few "on ramp laps" seems to leave them a more normal/natural angle.
 Old 07-08-2017, 01:30 PM   #10
turbskies's Avatar
Thanks for the reply will do.
I was wondering, maybe it is not the sway bar maybe it is bushings? It sounds like the noise is coming from the back right and I look at the bushings and they looked like they have seen better days.
Last edited by turbskies; 07-08-2017 at 01:30 PM. Reason: MSF Database - Automerged Doublepost
 Old 07-13-2017, 10:32 PM   #11
turbskies's Avatar
Think I found the problem,looked under the car and the rear lateral links bushings look torn to shit. Ordered replacement ones off Rock Auto.
I'll update when I get them installed and get an alignment done.
The Following User Says Thank You to turbskies For This Useful Post:
Shwaykid (07-14-2017)
 Old 07-26-2017, 10:07 PM   #12
turbskies's Avatar
Nope wasn't it, back to the drawing board.
 Old 07-31-2017, 03:40 PM   #13
Speed3Pedro's Avatar
Posts: 111   (View Stats)
Speed3Pedro is a jewel in the roughSpeed3Pedro is a jewel in the roughSpeed3Pedro is a jewel in the rough
Groaned at 8 Times in 4 Posts
Have you checked the rear trailing arm bushings? That's what it was for me with my MS3
Sent from my SM-G900T3 using Tapatalk
Speed3Pedro is offline   Reply With Quote
 Old 07-31-2017, 03:44 PM   #14
turbskies's Avatar
Yeah they didn't look bad to me, but the metal around the bushings did look slightly bent/ rusty. But the bushings didn't have any tears or anything.
Do you have to get an alignment after doing the trailing arm?
 Old 12-15-2019, 11:38 PM   #15
MAZDAMARK's Avatar
Posts: 6   (View Stats)
MAZDAMARK is an unknown quantity at this point
Sorry to bring up old post but did you ever find it? im having the same issue rn.
turbskies likes this.
MAZDAMARK is offline   Reply With Quote
 Old 12-15-2019, 11:48 PM   #16
turbskies's Avatar
Yes, it was the trailing arm bushings, replaced it and no more noise.
Sent from my SM-N950U using Tapatalk
MSMS3 (12-16-2019)
Weird metal creaking noise in the rear when getting off the brake Speed3Pedro MazdaSpeed 3/6 - Suspension & Brakes 2 11-03-2016 10:42 AM
Creaking noise from rear when parked in e-brake? furinax MazdaSpeed 3/6 - Suspension & Brakes 1 07-11-2016 11:06 AM
Creaking noise from kw's I_AINT_RICE MazdaSpeed 3/6 - Suspension & Brakes 5 10-24-2014 12:03 AM
Creaking noise coming from the right-rear of back window Flaverre MazdaSpeed 3/6 - Troubleshoot/Diagnostics 5 10-20-2013 05:57 PM
Creaking Noise boost2dms6 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 3 10-27-2011 08:49 AM
Page generated in 0.36289 seconds with 25 queries
