Like Tree104Likes
 Old 05-05-2017, 08:25 AM   #81
Name is longer than yours
Posts: 209   (View Stats)
Neutral  :  +2 score
2 weeks
The Following 14 Users Say Thank You to Matt@DamondMotorsports For This Useful Post:
AnimalMother (05-06-2017), danb (05-05-2017), impossible (05-06-2017), JSmith (05-09-2017), MD1032 (05-12-2017), MoMS3 (05-05-2017), monkey.bones.007 (05-05-2017), MunkieJunkie (05-05-2017), ryguy 3 (05-05-2017), sarm1084 (11-09-2018), spl (05-16-2017), Thor Hammer (05-10-2017), Vansquish (05-05-2017), [R]usty (05-23-2017)
 Old 05-05-2017, 08:27 AM   #82
Djohns's Avatar
Posts: 3,944   (View Stats)
Hell yea. DM is da man. Any idea on pricing?
sarm1084 likes this.
2010 black mica speed3
Soon:built motor
 Old 05-05-2017, 08:33 AM   #83
monkey.bones.007's Avatar
Posts: 3,853   (View Stats)
2 weeks
Dual caliper mod? 4 times the braking powwarrrrr!!!!!!!!
crapatalk it sucks for free
 Old 05-05-2017, 06:00 PM   #84
Voltwings's Avatar
Posts: 3,713   (View Stats)
Past:
-Sold-
-Sold-
Current:
2012 Loaded Speed3 - Stock
2001 Miata - Basically stock
The Following 3 Users Say Thank You to Voltwings For This Useful Post:
Matt@DamondMotorsports (05-09-2017), mituc (05-05-2017), monkey.bones.007 (05-06-2017)
 Old 05-06-2017, 12:47 AM   #85
AnimalMother's Avatar
Posts: 366   (View Stats)
AnimalMother is the leader of the worldAnimalMother is the leader of the worldAnimalMother is the leader of the worldAnimalMother is the leader of the worldAnimalMother is the leader of the worldAnimalMother is the leader of the worldAnimalMother is the leader of the worldAnimalMother is the leader of the worldAnimalMother is the leader of the worldAnimalMother is the leader of the worldAnimalMother is the leader of the world
2 weeks
Finally, I wasn't sure how much longer I could keep the secret in.
Juan on meth
AnimalMother is offline   Reply With Quote
The Following User Says Thank You to AnimalMother For This Useful Post:
 Old 05-06-2017, 04:29 PM   #86
impossible's Avatar
Posts: 733   (View Stats)
Groans: 30
2 weeks
I see that's a ms6, what about for ms3? Also will a bracket kit be made for the CTS-V 6 pot Brembo calipers from the gen2 V?
 Old 05-09-2017, 07:54 PM   #87
We'll be test fitting on the MS3 soon. Along with FoRS Brembos(I've had a set on order for awhile). The latter should directly bolt on, but rotors might be a little tricky.
We'll most likely stay away from the 6 pots. Mainly as they're pricey and a bit overkill.
Not yet, but it'll be cheaper and less evasive than putting Evo Brembo's on a MS6
 Old 05-09-2017, 08:13 PM   #88
impossible's Avatar
Groans: 30
oh bummer. I see the FoRS Brembos are only around $185 a side and look a little more compact than the v1 CTS-V Brembos. I'm excited for sure about this release, have been waiting so long for someone to make this an option for the MS3's. I'll definitely be buying a bracket/adapter kit when you drop it!
 Old 05-09-2017, 08:15 PM   #89
acidplant's Avatar
Posts: 60   (View Stats)
acidplant has a brilliant futureacidplant has a brilliant futureacidplant has a brilliant futureacidplant has a brilliant futureacidplant has a brilliant futureacidplant has a brilliant futureacidplant has a brilliant futureacidplant has a brilliant futureacidplant has a brilliant futureacidplant has a brilliant futureacidplant has a brilliant future
This is Great news...From Damond MotorSports......I'll keep ah eye for when it is officially out.
acidplant is offline   Reply With Quote
 Old 05-11-2017, 07:43 PM   #90
I won't know til I get the RS stuff... hopefully this weekend, but I'm pretty sure they're actually gonna be bigger in all dimensions than the CTS-V ones.
The CTS-V calipers are a really good size for this cars, all in piston sizes and we're using a rotor that should match them very well.
Doing the 6-pots could potentially negatively effect braking performance, and the cost is high, so we're staying away from those.
macdiesel and sarm1084 like this.
The Following 4 Users Say Thank You to Matt@DamondMotorsports For This Useful Post:
Mattyhawk1 (05-12-2017), MD1032 (05-12-2017), monkey.bones.007 (05-11-2017), sarm1084 (11-09-2018)
 Old 05-13-2017, 05:32 AM   #91
ChaunceyM's Avatar
Posts: 948   (View Stats)
ChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the world
What rotors would you be using on the Gen2? I'd love to get something beefier than stock to help deal with the heat on the track. Any chance you're also working on a adapter to mount up some cooling ducts to the knuckle....
Corksport: SRI & TIP, Strut Tower Brace, Coilovers
CP-e: RMM
JBR: Rear Sway Bar (with Moog End Links)
TWM: Full Replacement Shifter
Cobb: AP
AutoTech: HPFP Internals
Ebay: Test Pipe
ChaunceyM is offline   Reply With Quote
 Old 05-13-2017, 05:28 PM   #92
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
I have the ATS setup ready to go for my FR-S.
nothing constructive to add to the thread though, feggits.
"Exclusivity" - CP-enis
Demodded.
The Seals
Matt@DamondMotorsports (05-15-2017), monkey.bones.007 (05-13-2017)
 Old 05-15-2017, 08:06 PM   #93
No idea yet. We'll know soon enough once we start playing around with test fitting. We plan on using the rotor thickness the CTS-V calipers were intended to, like we have on the 6. And the rotors we're using there have directional vanes, so added bonus!
Actually waiting on some ducting to arrive in a couple days.
The Following 2 Users Say Thank You to Matt@DamondMotorsports For This Useful Post:
monkey.bones.007 (05-15-2017), sarm1084 (11-09-2018)
 Old 05-15-2017, 09:51 PM   #94
Djohns's Avatar
Lemme know if I can lend a hand on test fitting or anything.
Soon:built motor
 Old 05-23-2017, 10:51 AM   #95
DougNuts's Avatar
Posts: 4   (View Stats)
DougNuts will become famous soon enoughDougNuts will become famous soon enough
I'm interested in a set of brackets for a Mazda3/5. I had a CTS-V a few years ago and the brakes were one of the best parts about that car. Where are you guys purchasing the calipers from? Ironically, since it was cheap, I had purchased a spare caliper back when I had the car but now forgot where I got it from.
Edit: N/M, I just ordered a set from RockAuto. Hopefully someone comes through with a bracket.
DougNuts is offline   Reply With Quote
The Following User Says Thank You to DougNuts For This Useful Post:
 Old 05-23-2017, 10:53 AM   #96
MoMS3's Avatar
Posts: 235   (View Stats)
MoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond repute
Check out amazon, they've got them for about $150 per caliper. I think they're bare aluminium, so may or may not match what you've got already.
2012 Velocity Red Mica MS3 Tech
For Powah: JBR Tru 3.5" WP, CP-E TMIC, UR V3 Catless DP/Reso. TP, CS Resonated CBE, CS HPFP Internals, Cobb AP, DM PMM, DM TMM, CS Stg 2 RMM, CS Shifter Bushings, CS Dual VTA BPV, South Bend Stage 3 Endurance clutch, Damond Motorsports SSP, CS 3.5bar MAP, Stratified S-OTS+ Stg 3 E85 tune for summer, Pump S-OTS+ Stage 3 for winter, for now
Handling: JBR .250 RSB w/ billet brackets.
So I can see/be seen better: DDM LED for Nagare Accent lights, DDM Switchbacks Front turn signals, Osram CBI's, ADVmonster LED Fogs
To-do List: BNR S4, maybe S5...bottom end build, probably should do brakes/suspension at some point. Shooting for a 450-500whp daily driver.
MoMS3 is offline   Reply With Quote
The Following User Says Thank You to MoMS3 For This Useful Post:
 Old 05-25-2017, 08:19 AM   #97
DougNuts's Avatar
Originally Posted by MoMS3 View Post
I don't think they'd be able to use the same brackets given that the 4 piston setup specs a 12.75" rotor vs 6 piston on 14" rotor, to me it would seem the brackets would mount the 6 piston caliper further out from the hub to accommodate the .625" increase in radius of the rotor. Not to mention the mounting points for the 6 piston look completely different in their location
Responding to a few months old post.......
The 4 piston (1st Gen) CTS-V uses 14" rotors (355x30mm) and the 6 piston (2nd Gen) CTS-V uses 15" rotors (370x34mm). The calipers are interchangeable on the CTS-V assuming you use bigger rotors, so the additional radial spacing is designed into the caliper.
'10 Mazda5 GT
'15 Subaru Outback 3.6R
 Old 05-25-2017, 11:53 AM   #98
MoMS3's Avatar
That is correct, however I was referring to the rotor sizes used by those who were installing on Nissan/Subaru applications. The thing with our situation is we don't share the same geometry on our steering knuckle as the CTS-V (I'd assume its the same across the board for the CTS), and as a result we can't simply upsize the rotor diameter.
For our application we have a lot more variables to take into account due to the fact we are using random rotors that have similar dimensions to the CTS-V rotors. So while we may be able to adapt a bigger rotor for 6 piston, the offset may be such that a different bracket is required for everything to line up properly. In other words, the radial spacing isn't really the main issue here. Plus based on what Matt said, it sounds like the 6-piston calipers aren't going to play nice with the brake bias on our car.
I personally hope that the FoRS calipers work out for our car since they're monoblock design, and should in theory have minimal adaptation required to fit the MS3.
 Old 05-28-2017, 07:13 AM   #99
DougNuts's Avatar
I'm ready.
'10 Mazda5 GT
 Old 05-28-2017, 04:40 PM   #100
JakeMS3's Avatar
Posts: 1,164   (View Stats)
Groaned at 7 Times in 5 Posts
I've missed so much over the last year. So ready for this!
2013 LSM w/tech
Cobb AP V3, CBE
CS Turbo tuned by PD
JBR FMIC Pipe Kit w/TR8
CP-E TIP/3.5" Intake
DM OCC/TMM
Forge V2 BPV
Bilstein B8 w/Swift springs
Wilwood 6 pot BBK
EBC RedStuff rear pads
Konig Hypergram 18x8.5"
 Old 06-04-2017, 12:26 PM   #101
DougNuts's Avatar
Anyone hear of any progress on someone making an adapter for CTS-V or RS calipers?
Has anyone looked at the RS calipers or have a link to where someone has and shared what they saw? I'd would be great if we could just buy this kit, find some similar rotors with the correct bolt pattern and bolt it on: http://www.cjponyparts.com/ford-perf...2017/p/M2300W/
'10 Mazda5 GT
 Old 06-04-2017, 01:24 PM   #102
Djohns's Avatar
This thread kinda outlines that DM is working on it....
monkey.bones.007 and sarm1084 like this.
Soon:built motor
 Old 06-08-2017, 06:32 AM   #103
We'll be getting another trackday of testing tomorrow, last time was wet, so we weren't able to fully thrash the brakes. We're also playing around with the ATS calipers after seeing how inexpensive those are. We're going to start test fitting and mocking up for the 3 next week.
The RS brake will bolt right up... after the knuckle mounting points are bored, and getting the rotor machined for the correct hub bore and bolt pattern. Do that and it's direct fitment. Also buying all the parts separately, RS kit is around $600
Djohns (06-08-2017), MoMS3 (06-08-2017), monkey.bones.007 (06-08-2017), sarm1084 (11-09-2018)
 Old 06-08-2017, 08:11 AM   #104
Djohns's Avatar
Will those fit a 16" wheel?
Soon:built motor
mituc (06-08-2017)
 Old 06-08-2017, 09:33 AM   #105
MoMS3's Avatar
I take it there aren't any 5x114.3 rotors out there that can be adapted? I've done the redrill rotors in the past, granted that was taking a 5 lug to 4 lug. I was always concerned that adding those extra holes could turn the hub of the rotor into a weak point, granted I'm sure that the planets would need to be aligned and pigs to sprout wings before any sort of catastrophic failure occured.
 Old 06-08-2017, 10:45 AM   #106
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
Well, in this case I guess we can use some of the aftermarket large brake disks (330+mm) for the mazdaspeed and Focus RS/ST (gen2) platform. And of course use some brake pads that will fit.
If the RS brakes will clear some winter 17" wheels I have these may become a pretty good option.
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
 Old 06-08-2017, 11:38 AM   #107
hahahahahaha... no
Hell, they won't clear any 17's that I know of.
I'm sure there might be a rotor that could work. I haven't done much searching for a 5x114 rotor that would work with RS calipers.
 Old 06-08-2017, 11:56 AM   #108
ChaunceyM's Avatar
I'm really looking forward to the track report on these. Especially if you can run them hard for 20-25 without boiling fluid. My wilwoods and stock-sized DBA rotors are like tiny suns that can boil any fluid.
CP-e: RMM
Cobb: AP
Ebay: Test Pipe
 Old 06-08-2017, 12:44 PM   #109
Djohns's Avatar
hahahahahaha... no
Oh. My bad, I guess I misjudged that picture. At first glance those looked like 17" wheels, I thought the tire wall was taller than it actually is.
Soon:built motor
 Old 08-01-2017, 02:28 PM   #110
HardCruise's Avatar
Posts: 5   (View Stats)
HardCruise is an unknown quantity at this point
Any updates for speed 3s
HardCruise is online now   Reply With Quote
 Old 08-01-2017, 02:58 PM   #111
Bexar's Avatar
Posts: 195   (View Stats)
Bexar is a splendid one to beholdBexar is a splendid one to beholdBexar is a splendid one to beholdBexar is a splendid one to beholdBexar is a splendid one to beholdBexar is a splendid one to beholdBexar is a splendid one to behold
Groaned at 18 Times in 8 Posts
Interested for MS3 - it's been a few months !
Cobb: APV3, shiftknob, TIP Corksport: intake, SSP, HPFP, strut tower bar, hoodscoop
JBR:
rear sway bar + big brackets, recirc hose, shifter bushings CP-E: stage 2 RMM GFB: blow off HKS: filter
To install: downpipe, Damond EGR delete
Bexar is offline   Reply With Quote
 Old 08-01-2017, 03:00 PM   #112
MoMS3's Avatar
Two weeks...but seriously, I'm also interested for MS3 now I can't run RS brakes.
 Old 08-02-2017, 01:47 PM   #113
Bexar's Avatar
So was the conclusion that MS3 and MS6 can run RS calipers as a bolt on with a fitted rotor ?
And you can't run RS brakes due to wheel fitment or something?
JBR:
 Old 08-02-2017, 02:55 PM   #114
mituc's Avatar
Groans: 111
FoRS brakes = direct bolt-on.
FoRS brake disks = need to be drilled. There is no known 5x114.3 alternative to them so far to match the calliper offset and then our hubs.
And even if the FoRS hubs are also a direct bolt-on I don't think too many people would consider this as an alternative because by this time pretty much everyone is done with the wheel setups (rims, tires) and selling their beloved rims just to get some 5x108 may not be that easy.
 Old 08-02-2017, 03:20 PM   #115
tmillner's Avatar
Posts: 621   (View Stats)
So getting the rotors drilled to the 5x114.3 pattern?
Sent from my SM-G935P using Tapatalk
 Old 08-02-2017, 03:32 PM   #116
MoMS3's Avatar
Can't speak for the MS6, I think those are going to require you to go the route of adapter brackets and cts-v setup. The reason the MS3/FoRS interchangeability is due to the shared platform/similarity of steering knuckle, you just have to drill the rotor to 5x114.3. According to Matt@Damond, the RS brakes are too big to fit in a 17" rim, mainly due to disc size (FoRS has 19" stock).
Not quite direct bolt-on for the calipers, as the Brembos have a larger mounting bolt, requiring the caliper mounting holes to be bored out a bit larger.
Yeah, essentially you're increasing the size of the hole on the outer tangent by 3.15mm so it will be slightly oblong, but provided the machine shop does a good job assuring they drilled concentric to hub, there should be no ill effects
Last edited by MoMS3; 08-02-2017 at 03:32 PM. Reason: MSF Database - Automerged Doublepost
 Old 08-02-2017, 03:33 PM   #117
tmillner's Avatar
The calipers aren't really that cheap almost doesnt seem worth the hassle
 Old 08-02-2017, 03:51 PM   #118
Bexar's Avatar
Right but at least the idea is cool.
Which comes full circle to the cheaper CTS/ATS/GM whatever calipers being a more viable option. I would love a set of yellow calipers on the speed.
JBR:
 Old 08-02-2017, 04:06 PM   #119
MoMS3's Avatar
Yeah CTS-V calipers are cheaper, but without a bracket, MS3 isn't going to be able to fit them in situ. The main advantage with the FoRS is bigger rotor vs CTS-V setup, and the fact the calipers bolt up after boring out the steering knuckle mounting point.
If DM is going to be designing a bracket for the MS3 then I'd say absolutely go that route, but if they're only designing brackets for the MS6, then us MS3 guys are SOL.
Well if you're talking about the yellow 6-piston calipers, those are $310 apiece vs $100-150...that said, most of the 4-piston come bare metal, so that means you can powder coat them as you see fit.
Last edited by MoMS3; 08-02-2017 at 04:06 PM. Reason: MSF Database - Automerged Doublepost
 Old 08-02-2017, 04:47 PM   #120
tmillner's Avatar
I had the wilwood 4 piston calipers and the bracket was very basic. Nothing I couldn't have made, I'm tempted to get the ctsv calipers and make a bracket myself
Miata v8 swap vs rx7 v8 swap blake0521 Miata - General Questions 13 01-21-2015 07:05 PM
GREEK MAZDA 3 MPS XYZ 6-POT BRAKE KIT SERVICE - NEW BRAKE PADS FERODO DS 2500 & NEW CASTROL REACT SRF RACING BRAKE FLUID dgiannitakis MazdaSpeed 3/6 - Suspension & Brakes 5 05-05-2014 01:30 PM
New big brake possibilities? We share front brake calipers with audis/vws breakfasteatre MazdaSpeed 3/6 - Suspension & Brakes 15 11-03-2012 09:18 PM
Hawk HPS brake pads & Goodridge brake lines in stock for the 07-11 MS3. Chris@Xtreme Mazdaspeed3/6 General Discussion 3 08-06-2011 08:56 PM
Hawk Pads, Racing Brake Lines, and ATE Brake Fluid! Race Roots Mazdaspeed3/6 General Discussion 11 09-25-2009 02:04 PM
Page generated in 0.61812 seconds with 36 queries
