  • 1 Post By Db09ms3
 Old 04-23-2019, 07:53 AM   #1
tinycafe1972's Avatar
Posts: 7   (View Stats)
tinycafe1972 is an unknown quantity at this point
Default Lower Control Arm Replacement
Hello,
I need to replace the driver side lower control arm on my Speed 3. Going to keep it easy and just replace the entire arm. I see Rock Auto has a Moog and a ACDelco branded replacements.
https://www.rockauto.com/en/catalog/...trol+arm,10401
I know Moog is the standard, but what are everyone's thoughts on the ACDelco? Less than half the price in comparison to the Moog. Also can anyone confirm those part numbers are correct for the speed 3?
Thoughts on only replacing the one bad side vs doing both?
Thank you!
Sent from my Moto G (5) Plus using Tapatalk
tinycafe1972 is offline   Reply With Quote
 Old 04-23-2019, 08:16 AM   #2
Wcdfmt510's Avatar
Posts: 40   (View Stats)
Wcdfmt510 will become famous soon enoughWcdfmt510 will become famous soon enough
I'd just get OEM. They are not that expensive. I always hear bad things about rock auto
Sent from my Moto Z (2) using Tapatalk
Wcdfmt510 is offline   Reply With Quote
 Old 04-23-2019, 01:04 PM   #3
Db09ms3's Avatar
Posts: 536   (View Stats)
Groans: 105
I'd say give it a go and report back.
Just do both sides, I bet the other arm is just as fucked or soon will be.
danb likes this.
Stockish
 Old 04-23-2019, 05:11 PM   #4
rgurleyjr's Avatar
Posts: 21   (View Stats)
rgurleyjr has a spectacular aura aboutrgurleyjr has a spectacular aura aboutrgurleyjr has a spectacular aura about
If it were me, I'd try it. I noticed a lot of speed owner's recommend OEM parts a lot, even for basic stuff like this.
rgurleyjr is offline   Reply With Quote
 Old 04-23-2019, 06:48 PM   #5
MSF's Punishing Member
Pu Manchu's Avatar
Posts: 2,992   (View Stats)
Groans: 546
Searching onlinemazdaparts it looks like Mazda and Moog have separate part numbers for Turbo and Non-turbo, but the ACDelco uses the same part number for Turbo and Non-turbo. Not sure what the differences in the arms are, but it makes me wary.
If it were me, I'd do both at the same time, I didn't find it to be a difficult job.
94 M
MS6
IS350
 Old 04-24-2019, 05:34 AM   #6
07MS3TrueRed's Avatar
Posts: 23   (View Stats)
07MS3TrueRed is an unknown quantity at this point
I replaced both front lower control arms on my 07' Speed3 with the AC Delco ones from Rock Auto last summer. No issues fit is perfect. For some reason there are less control arm options on Rock Auto for the speeds, but if you cross reference a base Mazda 3 AC Delco part # to a Speed3 part number on Rock Auto they are the same.
07MS3TrueRed is offline   Reply With Quote
 Old 04-25-2019, 10:57 AM   #7
I think I may try to ACDelco unless someone else chimes in. I was quoted $321 each from Mazda which is a lot for control arms
 Old 04-25-2019, 11:01 AM   #8
Wcdfmt510's Avatar
I saw them at less than $180 each
The difference between non speed and speed are probably a slightly stiffer bushing
http://mazdapartsestore.com/2008-maz...r_control_arm/
 Old 04-25-2019, 12:35 PM   #9
ThorOtheBIG's Avatar
Posts: 56   (View Stats)
ThorOtheBIG has a spectacular aura aboutThorOtheBIG has a spectacular aura aboutThorOtheBIG has a spectacular aura about
From my past experience, ACDelco isn't the greatest. I'm partial to MOOG. If you are concerned, try to look at pictures of both of their ball joints and bushings. That should give you an idea of quality.
ThorOtheBIG is offline   Reply With Quote
MS3 Lower Control Arm same as MZ3? Obey the Speed MazdaSpeed 3/6 - Suspension & Brakes 50 11-26-2018 10:58 AM
Lower Control Arm Turbosuby MazdaSpeed 3/6 - Suspension & Brakes 4 08-20-2016 09:07 AM
DIY Front Lower Control Arm Replacement spl 2010 MS3 - Suspension & Brakes 1 09-18-2015 10:28 PM
lower control arm replacement on a CX-7? Cx-7man CX-7 > Issues & Troubleshooting 2 09-11-2014 05:39 AM
Mazda3 Front Lower Control Arm Replacement Problem iraklic MazdaSpeed 3/6 - Suspension & Brakes 2 09-03-2014 08:00 PM
Page generated in 0.30282 seconds with 26 queries
