 Old 06-29-2011, 02:38 PM   #1
Alpha's Avatar
Posts: 3,711   (View Stats)
Thumbs up MS6 Aftermarket Suspension Braces Worth It?
Hey guys, I'm looking to stiffen things up handling wise and drop some weight if/where I can.
I've seen Corksport/SU Rear Trunk Braces, GT-Spec components, and then the Full Auto-Exe suspension brace kit which looks pretty badass.
Are these worth it? Can any of them save weight by replacing parts or are most of them additions to the factory suspension?
Any info would be great.
My car currently has RPM Minimum drop springs, Koni FSDs, and a Whiteline Rear Sway Bar set to stiff.
Thanks!
 Old 07-09-2011, 01:50 AM   #2
meh, no ideas
Jedyboyrokr's Avatar
Posts: 528   (View Stats)
Jedyboyrokr is the leader of the worldJedyboyrokr is the leader of the worldJedyboyrokr is the leader of the worldJedyboyrokr is the leader of the worldJedyboyrokr is the leader of the worldJedyboyrokr is the leader of the worldJedyboyrokr is the leader of the worldJedyboyrokr is the leader of the worldJedyboyrokr is the leader of the worldJedyboyrokr is the leader of the worldJedyboyrokr is the leader of the world
Groaned at 20 Times in 4 Posts
i have all the GT Spec bracing underneath, but i bought the car with it so i have no input on how it felt before or after, i know i dont feel any flex really....and im not about to take them all off to see sorry lol
89 toyota supra 1JZ Twin Turbo---Sold
2006 MS6 GT few mods ---Sold
Monaco White '13 Genesis 2.0T R-Spec-- ISIS downpipe/testpipe, Agency Power CBE, Injen SRI, Forge BOV, JBR Heavy Shift knob should be 240ish wheel right now, tune coming April 27th
Jedyboyrokr is offline   Reply With Quote
 Old 07-09-2011, 02:19 AM   #3
jroc's Avatar
Posts: 1,482   (View Stats)
I have the trailing arms, megan h brace, and rear seat brace. I got all of them used/cheap, the rear brace I literally got for a 6 pack of good beer.
Way less creaking of the car, I did notice the trailing braces helped out with the squating of the car through a corner, and the h brace felt like it tightened the front. Could be placebo affect, but I dont spend too much time in corners since thats what slows you down on track.
JDMFresh.com 1990 Mazda Miata
The Following 2 Users Say Thank You to jroc For This Useful Post:
Alpha (07-09-2011), dexter_5000 (07-10-2011)
 Old 07-09-2011, 09:04 AM   #4
Alpha's Avatar
Dicked, I understand haha thanks anyway man.
The "H Brace" is an additional brace right? It doesn't replace anything, just bolts on over the existing bracing?
I'd definitely be down for reducing those famous MS6 creaks haha.
jroc (07-09-2011)
 Old 07-09-2011, 09:41 AM   #5
meh, no ideas
lol i will say this they are well built and put on snug, there is a ton of construction/road work around my house right now and one night i was on my way home and i guess they dropped a little pile of asphalt which i didnt see, and i hit it, and kinda bent the front brace but its still attatched!
 Old 07-10-2011, 11:21 AM   #6
MEE
MEE's Avatar
Posts: 14   (View Stats)
MEE has a spectacular aura aboutMEE has a spectacular aura aboutMEE has a spectacular aura about
Sorry to threadjack but curious how you like the fsd's. I have same suspension as you except still running OEM shock. Been running them for about 35k since spring upgrade and its getting close to retire them. Was planning on Koni yellows but have always been curious about the fsds.
2006 MazdaSpeed6 GT (50k on the ticker as of Dec'10) TiGray
__POWER: Cobb AP (Stg2 91 v106 MAF cal'd for Fujita), ETS TMIC, Fujita CAI, SLS TP
__HANDLING: RPM Sport Springs, SPC Adj Ball Joints, Whiteline RSB, MB Boost (18x7.5) with Hankook Ventus V12 EVO (225/45)
__REST: SU Rear Motor Mount, TT Lower Diff Mount, CX-7 Shorty Antenna, Chiss DIY MP3 Adapter
MEE is offline   Reply With Quote
 Old 07-10-2011, 11:28 AM   #7
Alpha's Avatar
The FSDs are a great median DD shock. I needed something softer than the yellows due to my wheel setup and 30 wall tires, but if you're sticking with a 35 - 45 wall tire and like a more aggressive damper, the yellows are cheaper and perform better than the FSDs IMHO.
Yellows are nice and firm whereas the FSDs are comfortable and adaptive. It depends on what you want.
 Old 07-12-2011, 08:18 AM   #8
MEE
MEE's Avatar
Thanks for info. I liked idea of fsd adaptability for DD but was worried they'd be under damped when paired up with higher rate RPM springs & WL RSB. But it sounds like they're working out for you though. With your lower sidewall your effective spring rate is probably higher than what I'd see with my 45's. Do ever feel underdamped with the fsd's?
 Old 07-12-2011, 08:22 AM   #9
Alpha's Avatar
On occasion, but I'd rather have that than bent $4k wheels.
ITT: MS6's with stock suspension and aftermarket rims KruV MazdaSpeed 3/6 - Wheels & Tires 1 04-06-2011 12:00 PM
AX and GT Spec braces Obey the Speed Auto-X / Road Racing / Time Attack 16 01-19-2011 08:09 PM
aftermarket suspension bushings johnheer MazdaSpeed 3/6 - Suspension & Brakes 3 03-31-2010 05:05 PM
Industry braces for postelection era Haltech Automotive News 0 11-05-2008 09:20 AM
Page generated in 0.29609 seconds with 23 queries
