| MazdaSpeed 3/6 - Suspension & Brakes Discussion for suspension items like coilovers, springs, sway bars, mounts,chassis bracing and brakes. |
![]() Join Date: Mar 2008 Location: Chicago
Rep Power: 4020 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10,876
| Not Ranked : 0 score I wouldn't worry too much. That new spring is going to compress a LOT less than the old one at static height... Are you gonna use simple flat Torrington/needle bearings on the perches in the front?
__________________ Stance is not a verb. 2008 MS3 GT 2016 MX-5 Club |
| The Following 3 Users Say Thank You to Nliiitend1 For This Useful Post: |
| Suspension/combo or coilovers?? | gurusev | 2010 MS3 - Suspension & Brakes | 35 | 07-31-2013 11:06 AM |
| BC Coilovers or Bilstein Dampers/H&R Springs | Bleupit80 | MazdaSpeed 3/6 - Suspension & Brakes | 6 | 02-12-2013 07:35 AM |
| BC BR Extreme Low Coilovers vs KSport Kontrol Pro Coilovers | Doberman | MazdaSpeed 3/6 - Suspension & Brakes | 9 | 07-28-2012 08:35 AM |
| Suspension Techniques Coilovers? | asiandude74 | MazdaSpeed 3/6 - Suspension & Brakes | 6 | 02-06-2011 12:15 AM |
| MSD Dashhawk Data Logger Data Base | JimmyMac | MazdaSpeed 3/6 - ECU Computer Tuning | 2 | 06-30-2008 10:43 AM |
