  • 1 Post By Wistfullyod
 Old 01-10-2020, 07:40 AM   #1
bast525's Avatar
Posts: 487   (View Stats)
bast525 has a reputation beyond reputebast525 has a reputation beyond reputebast525 has a reputation beyond reputebast525 has a reputation beyond reputebast525 has a reputation beyond reputebast525 has a reputation beyond reputebast525 has a reputation beyond reputebast525 has a reputation beyond reputebast525 has a reputation beyond reputebast525 has a reputation beyond reputebast525 has a reputation beyond repute
Groaned at 3 Times in 1 Post
Default Necessary to trim KYB bump stops?
I had found a thread previously that recommended buying these for use with Koni shocks:
KYB SB125 - Strut Boot https://www.amazon.com/dp/B001FY56T0..._9SigEbB1QXQV8
If I remember right, one or two people in that thread had mentioned possibly needing to trim the bump stops so the car doesn't sit on them. I was unable to find photos or an example of exactly what/where to trim.
Has anyone used these that can tell me what needs to be cut or post pics of them after trimming?
'07 Speed 3 GT, Red, MSCAI with flow straightener, 2nd cat delete, JBR TMM, AWR RMM, and Cobb AccessPORT running custom 20% e85 tune.
bast525 is offline   Reply With Quote
 Old 01-10-2020, 08:12 AM   #2
tegxsi's Avatar
Posts: 1,281   (View Stats)
Groans: 87
Is your car on lowering springs? Maybe trim bump stop to match factory length? Why not reuse the factory bump stops?
2018 Audi RS3
2007 Acura TSX 6MT
 Old 01-10-2020, 03:30 PM   #3
bast525's Avatar
Car is on stock springs. Factory bump stops are pretty bad shape from what i saw of them. I haven't had a good look at them in a while but on that same thread I had found people mentioned the bum stops were in pieces upon removal, so I figured better to just have new ones on hand.
I'm not positive they need to be trimmed and I've tried to find that old thread again to confirm but I remember one or two guys saying they did trim them.
 Old 01-10-2020, 05:19 PM   #4
Db09ms3's Avatar
Posts: 536   (View Stats)
Groans: 105
I had to buy new ones as mine were in pieces but there was enough pieces to put together that I could measure how much to cut off on the new ones. I'm on factory springs and stock replacement shocks and struts. Drives fine for me.
Stockish
 Old 01-10-2020, 05:21 PM   #5
Wistfullyod's Avatar
Posts: 10   (View Stats)
Wistfullyod is an unknown quantity at this point
I used bump stops similar to these and trimmed up from the larger section to a little longer than my busted stock bump stops. I think I ended up trimming about two inches or so.
Wistfullyod is offline   Reply With Quote
 Old 01-11-2020, 12:41 PM   #6
bast525's Avatar
So I would trim from the "top" that goes into the mount? Or trim from the bottom that attaches to the dust boot? The top is form fit to the shock mount and presses in, the bottom I can only cut to the "ring" that the dust boot attaches to
 Old 01-11-2020, 01:13 PM   #7
I trimmed mine from the bottom that attaches to the dust boot. I guess it doesn't really matter too much as long as it stays in position. After all the bump stops are there to essentially prevent your shocks from bottoming out completely.
Db09ms3 likes this.
 Old 01-11-2020, 07:48 PM   #8
bast525's Avatar
Ok I'll trim the bottom all the way to the "ring" that the dust boot attaches to. Thanks!
MS3 rear suspension 0.5" from the rear bump stops before you even get in the car. Fronts only have 1" till bump stop. FreeFlyFreak MazdaSpeed 3/6 - Suspension & Brakes 223 09-07-2015 12:47 PM
What's up with front bump stops? gennacide 2010 MS3 - Suspension & Brakes 5 03-23-2014 02:54 PM
Bump stops=gone at 44,000 bigmike MazdaSpeed 3/6 - Suspension & Brakes 18 11-19-2013 09:14 PM
fat cat motorsports bump stops karl-hungus MazdaSpeed 3/6 - Suspension & Brakes 46 12-10-2011 03:23 PM
Page generated in 0.28650 seconds with 23 queries
