Like Tree3Likes
 Old 11-11-2008, 09:27 PM   #1
The Kamikaze King!
FreeFlyFreak's Avatar
Posts: 4,156   (View Stats)
Groans: 754
Originally Posted by levitron View Post
I like where this thread is headed.
I wish people would only post when they knew for sure.
There shouldnt be guessing/speculation in a thread like this. IMO
Suspension:
 Old 11-12-2008, 02:14 PM   #2
redspeed's Avatar
Posts: 230   (View Stats)
redspeed has a brilliant futureredspeed has a brilliant futureredspeed has a brilliant futureredspeed has a brilliant futureredspeed has a brilliant futureredspeed has a brilliant futureredspeed has a brilliant futureredspeed has a brilliant futureredspeed has a brilliant futureredspeed has a brilliant futureredspeed has a brilliant future
Welcome to the internet!!
07 TrueRed Mazdaspeed3>> SOLD
03 BlueByYou Evolution VIII
Autronic PNP StandAlone, 264 BC Cams, Unorthodox Cam Gears, 720cc Injectors, AEM short intake, GReddy IC, HKS IC pipes, HKS Boost controller, TB exhaust, DNP DP, DNP 02 pipe, Megan exhaust manifold, Ported Turbo, Light Flywheel, Triple Carbon clutch, TorqueSoutions engine mounts.
redspeed is offline   Reply With Quote
The Following User Says Thank You to redspeed For This Useful Post:
ImpulseGT (09-24-2009)
 Old 01-30-2009, 03:35 AM   #3
This needs a bump, i want FERODOS... Im bringing in a brake expert.
 Old 01-30-2009, 03:31 PM   #4
Posted in an email by Chris at Raceshopper
Kevin,
Well the pads for the MS6 that the guy in post 33 shows are in pad shape and part# the same as the MS3. If you look at the inboard pad (the one with the rosebud clip) at the very far top right and left of the pad. You can see that there is a small quarter circle of the metal removed. The S60 pad goes straight across, so you may need to grind that. Also if you look at how the sides of the pad taper in towards the radius at the bottom, the S60 pad does this at a different angle. Lastly the overall height is about 1/8" less, so you would have 1/8" of unswept rotor near the hub. The rosebud clip that goes into the piston is slightly different, the S60 pad may be a little loose but the clip is just to aid in installation. Now for the outboard pad, the one shown has no clip on the back. Hawk makes the pad with a clip, however Ferodo does not but if those are factory pads shown there I do not see an issue. Other than that the outer pads taper is off just like the inner. Looking at all of these pads on a table next to each other I would say that if the rosebud clips do not factor into this at all, you can make these S60 pads fit with less that 15 minutes of grinding. I do not have the Ferodo pad in stock at the moment, but I can order it. They ship from Italy so it will be a few weeks. If you want to see it for yourself, in your hands I would go to your local Kragen, Pep Boys, Autozone.... Buy a front pad for a 2002 Volvo S60 w/285mm diameter front rotors, and compare them. I am sure if they are not installed they can be returned. The reason these are slightly different is not because of the caliper, but rather the carrier that the pads ride in when the caliper is bolted on. The calipers are probably the same design as the Volvo, if not the same exact caliper. Hope this helps.
Chris
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f12/oem-mazdaspeed-3-brakes-volvo-s60-brakes-12248/
Any idea where to find Mazdaspeed3 brakes? Story/description inside. : mazda3 This thread Refback 03-19-2014 04:22 PM
SUSP and Brakes Rican219 MazdaSpeed 3/6 - Suspension & Brakes 1 04-05-2010 10:35 AM
A jittery industry stomps on the brakes Haltech Automotive News 0 07-27-2008 10:10 PM
GM puts brakes on SUV, truck redesigns Haltech Automotive News 0 06-19-2008 06:30 AM
Honda testing ABS brakes on CBR600RR Haltech Automotive News 1 06-14-2008 01:14 PM
Chirping from...brakes? TotallyNotAmused MazdaSpeed 3/6 - Suspension & Brakes 4 05-07-2008 07:59 AM
Page generated in 0.30001 seconds with 23 queries
