 Old 07-30-2011, 01:11 PM   #1
super_pablo_'s Avatar
Posts: 1,648   (View Stats)
Default pads arent parallel to rotor, suggestions?
So, im going to the track tomorrow, and I borrowed some USED HP+ pads from jroc to check em out before buying some new ones of my own.
Long story short, brake pedal feels weird, i have little brake modulation, and i figured it could be multiple things like, pads settling in, needed to bleed brakes, simply different feel to pads.
I finished bleeding brakes, and after having the pads on for a few days, i snapped a couple of pictures to show u how the angle at which they wore on jrocs car, is slightly different than the angle on my rotor, so basically they sit at an angle
now.... its not a huge deal, but, i wanted to know if there were any suggestions or concerns u could think of?
again, im gonna track the car tomorrow, probably gonna take it easy for the first couple of sessions to get the feel for em, and to help em settle in.
heres some pics
looking at it from on top of the rotor
 Old 07-30-2011, 01:21 PM   #2
so, thinking about it in terms of brake modulation, this would definitely explain why i have little brake modulation right?... i mean, its like... little piston compression, little pad contact... or, lots of piston compression, lots of pad contact...
i think in terms of graphs cause thats what i do every day, maybe this explains what i mean...
 Old 07-30-2011, 01:41 PM   #3
bump. sorry for the lame thread, just looking for some input before tomorrow.
 Old 07-30-2011, 01:53 PM   #4
jroc's Avatar
Posts: 1,482   (View Stats)
Hmm interesting. Honestly, I probably wouldnt run them like that, and if I had known they were sitting angled like that, I wouldnt have given them to you. Sorry bud. Didnt know I hate to say it but you might wanna throw the stock pads back on. Hopefully it wont take you 2 hours a side again.
I could bring my brake bleeder to the track tomorrow also.
if you wanna switch them out lemme know if you want help later
JDMFresh.com 1990 Mazda Miata
Last edited by jroc; 07-30-2011 at 01:53 PM. Reason: MSF Database - Automerged Doublepost
 Old 07-30-2011, 01:59 PM   #5
im gonna go for a drive since I just bled the brakes and see how the car feels. The brakes are working fine, they are just not as easily modulated as the stock ones, but from thursday to friday they got a lot better, im gonna go hit the brakes hard on a lonely road, and check em again at night, if they still look like this, ill swap em out.
The stock ones dont look that great either lol
stock paid fail. I think they got fucked after Musselman honda track. that track was a bitch on the brakes and tires.
its hard to appreciate on the pictures, but, they are like... eaten out, wherever u can see its not shiny, theres actually some material missing, like a cavity
Last edited by super_pablo_; 07-30-2011 at 02:00 PM. Reason: MSF Database - Automerged Doublepost
 Old 07-30-2011, 02:04 PM   #6
jroc's Avatar
I wonder if your rotors are worn unevenly. Looking at those stock pads, it looks like the top portion was getting used more than the bottom based on the wear pattern. Which may by chance explain the hawks arent sitting parallel? Possibilty?
The Following User Says Thank You to jroc For This Useful Post:
super_pablo_ (07-30-2011)
 Old 07-30-2011, 02:06 PM   #7
note, the entire pad DOES hit the ENTIRE rotor when i hit the brakes... i can tell cause some marks i put all along it got completely removed. Its just that it doesnt hit the rotor in a parallel fashion, so it makes it tricky to do the smooth braking in the city. When I slam on it (like I will at the track), the fuckers stop the car fast!
definitely a possibility, im not blaming the pads. it could be my rotors. Ill go get em checked at brake masters before I purchase the new pads.
Last edited by super_pablo_; 07-30-2011 at 02:07 PM. Reason: MSF Database - Automerged Doublepost
The Following User Says Thank You to super_pablo_ For This Useful Post:
jroc (07-30-2011)
 Old 07-30-2011, 02:24 PM   #8
certainly. im not too worried about that though, as these will be very temporary. I will purchase new pads soon, I just wanted to geet a feel for these before buying em. My thoughts are... after a few easy sessions at the track, they will wear more evenly. Its a private track day, so i can have 20 sessions at the track if i want.
 Old 07-30-2011, 02:34 PM   #9
jroc's Avatar
Originally Posted by Angr-E1 View Post
You also have to think about the brake pads bedding into jroc's rotors. If the wear on his rotors is different than the wear on your rotors then his brake pads would have a different contact patch when you put them on your car.
Fwiw, these pads have been on 3 different sets of rotors on my car (stock first, D/S second and now the daily, slotted 3rd/current set of race day rotors).
 Old 07-30-2011, 05:45 PM   #10
^^ well, while thats a possibility, I doubt its the case in this instance. I dont feel any vibration or anything like that... so yeah.
I went for a ride, going up to 50-60-80- and up to 90 mph and slamming on the brakes... they work pretty fucking well. they stop me fast, and the nice thing is... i felt like I could feel when the wheels were about to lock, and was able to stay on that verge nicely.... something i never felt on the stock ones...
I feel confident they will be fine tomorrow after a session or two. heres the contact patch ive seen in the past few days...
as i expected, the pad is probably just wearing down a bit more on the inside, helping it sit more parallel on the roto, and gaining area of contact. theres still a bit left untouched on the rotor, but im confident it will be ok by tomorrow.
 Old 07-30-2011, 05:49 PM   #11
jroc's Avatar
Nice. Well, see you in about 12 hours haha
 Old 07-30-2011, 06:57 PM   #12
jroc's Avatar
Well.........this sucks. Go ahead and keep the pads for next track day I guess.
 Old 07-30-2011, 07:41 PM   #13
update. track day was today. LOL
... FML. anticipated for 2 months, thought it was on sunday all along. just realized it was today, after seeing everyone in the thread on a different forum upload videos.
 Old 07-31-2011, 09:19 AM   #14
Nliiitend1's Avatar
Posts: 5,749   (View Stats)
All aboard the failboat!
Lol.
That sucks man. I didn't happen to see this thread yesterday but I'll chime in now anyway...
These cars are somewhat notorious for unevenly wearing the front brake pads (especially under hard use). It's pretty much a consequence of having such a huge pad (with a relatively large "circumferential area of contact") and only one piston. They tend to wear the leading edge substantially faster than the trailing edge of the pads.
I wouldn't worry about it beyond being aware that until they "even out" a bit, you may be dealing with less of an ability to modulate them (as you already figured out).
A lot of guys will actually swap from side to side each track day to get more even wear...
Stance is not a verb.
2008 MS3 GT
2016 MX-5 Club
The Following 2 Users Say Thank You to Nliiitend1 For This Useful Post:
Fobio (07-31-2011), super_pablo_ (07-31-2011)
 Old 07-31-2011, 09:55 AM   #15
rigor's Avatar
Posts: 2,399   (View Stats)
Groans: 40
Neutral  +1 score
always run new pads, with turned rotors, or new!
that could make for a very hot spot and cause rotor to come apart, also as you found out, undesirable stopping characteristics, pulsing wheel, grabby, list goes on!
not worth it
especially if your racing.....
at 104000 2 bent rods
tuned by nishan
The Following User Says Thank You to rigor For This Useful Post:
 Old 07-31-2011, 10:09 AM   #16
Bucker's Avatar
Posts: 2,856   (View Stats)
Groans: 451
You need a bigger hammer.
403whp/451ft/lb Dry Shot
The Following User Says Thank You to Bucker For This Useful Post:
rigor (08-01-2011)
Rotor Thickness and pads question. BranNutz MazdaSpeed 3/6 - Suspension & Brakes 2 05-01-2009 03:56 PM
From the archives: Students build their own parallel parking system Haltech Automotive News 0 01-04-2009 05:30 PM
Ford automates parallel parking for Lincoln MKS, MKT Haltech Automotive News 0 12-29-2008 10:20 PM
Page generated in 0.38004 seconds with 24 queries
