| MazdaSpeed 3/6 - Suspension & Brakes Discussion for suspension items like coilovers, springs, sway bars, mounts,chassis bracing and brakes. |
![]() Join Date: Jan 2011 Location: Toronto, Ontario
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 937
(Thread Starter) | Not Ranked : 0 score There are two otions for the front and back. Both otions have the same art number top spring clip back spring plate i searched and found no answers 2007 ms3 |
![]() Join Date: Sep 2011 Location: Pearl River, NY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 328
| Not Ranked : 0 score i wuz wondering the same thing, cmon speed whores a little help here
__________________ GenWin Mazdaspeed 3: HTP 3", CP-E RMM: HKS SSQV : masonville knob, JBR SSP, bushings, RSB: COBB AP: STRATIFIED: Saikou Michi OCC: CP-E DP & FMIC: Autotech Internals: Koni FSD's: DO Meth A La WW tank style |
![]() Join Date: Mar 2008 Location: Chicago
Rep Power: 4020 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10,876
| Neutral : +1 score These are the correct part #s: Hawk HPS Front: # HB549F.702 Rear: # HB478F.605 Front pads look like this (minus the paint chipping): Rear pads look like this:
__________________ Stance is not a verb. 2008 MS3 GT 2016 MX-5 Club |
| The Following 6 Users Say Thank You to Nliiitend1 For This Useful Post: | Arnie1229 (01-07-2015), breakfasteatre (11-05-2011), DuBz (11-07-2011), helmetface (11-03-2011), rfinkle2 (11-03-2011), SJP0tato (11-05-2011) |
![]() Join Date: May 2011 Location: bo$ton, MA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,199
Groans: 219
| Neutral : +1 score ^ So many people have run into problems here, including myself, the picture above should be stickied..
__________________ |
| The Following User Says Thank You to helmetface For This Useful Post: | breakfasteatre (11-05-2011) |
(Thread Starter) | Not Ranked : 0 score thanks!!! |
| KW V2 Spring Binding | chieftjs | MazdaSpeed 3/6 - Suspension & Brakes | 33 | 07-16-2011 08:03 PM |
| Spring consensus | expoz3d | MazdaSpeed 3/6 - Suspension & Brakes | 8 | 05-24-2011 04:25 PM |
| Spring is Here! | redMS308 | MazdaSpeed 3/6 - Appearance | 16 | 05-11-2011 11:01 PM |
| Possible track spring spring setup for use with Koni yellows | stretch | MazdaSpeed 3/6 - Suspension & Brakes | 154 | 04-18-2011 12:18 PM |
