| MazdaSpeed 3/6 - Suspension & Brakes Discussion for suspension items like coilovers, springs, sway bars, mounts,chassis bracing and brakes. |
| aspiring turbo guru ![]() Join Date: Dec 2008 Location: Minnesota
Rep Power: 240 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 245
(Thread Starter) | Not Ranked : 0 score FYI the posi-quiet pads p/n 104.09152 may be too thick. these are semi-metallic pads for the front brakes on the ms3. i purchased / installed them and they had to be sanded to fit. i tried to do the install, and, when i had issues, i had a dealer do it. they also found the pads to be too thick. it may be an isolated issue, or it may be the wrong part altogether. i purchased them from r1 concepts. the next time around i will most likely purchase pads from SU or PG. i deviated from my trusted mazda vendors and got burned as a result |
| The Following User Says Thank You to 08_ms3_gt For This Useful Post: | rodrigo (12-14-2009) |
Groans: 356
| Not Ranked : 0 score thanks for giving us a heads up about this product
![]() Join Date: May 2008 Location: West Chester, PA
| Not Ranked : 0 score I have these pads on my MS3, they installed perfectly, perform great, have less dust and are completely quiet. no offense to the OP but I hate it when a product gets a bad rap based on ONE review (like hawk HPS). so for the record, these pads worked great for me--- OP check the box and the pad to make sure you got the right part number.
__________________ 2007 Mazdaspeed3 Sport, True Red |
(Thread Starter) | Not Ranked : 0 score After the install headaches, I have been happy with the pads. They perform well. I did verify the part number with 2 vendors, r1 and tri-point. I'm not trying to prevent ppl from buying these, but I think it's fair to communicate that I had an issue and did everything I could before realizing that the idiot working at posi quiet one day screwed up my pads. It's just a fair warning, or at least if someone else has this problem they'll know to request a new set. |
| The Following User Says Thank You to 08_ms3_gt For This Useful Post: | ElBartoRex (12-29-2009) |
![]() Join Date: Feb 2009 Location: Dupont wa
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,527
| Not Ranked : 0 score thanks for the info
__________________ |
![]() Join Date: Mar 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
| Not Ranked : 0 score I can vouch for the OP that the pads were too thick. They sent me another set. Same problem. I had to sand about 2-3 mm off each side to get it to fit. Before you ask, the piston was compressed all the way. I'm glad that you like the pads but I hated them. Their stopping power was pathetic compare to OEM. On the good side that are almost dustless. |
| The Following User Says Thank You to LiamT For This Useful Post: | 08_ms3_gt (01-13-2010) |
| quiet exhaust? | Jessed87 | MazdaSpeed 3 - Engine, Transmission & Driveline | 7 | 09-10-2009 07:55 PM |
| Do you run on 17's and is it more quiet and the ride smoother? | lengbros | MazdaSpeed 3/6 - Wheels & Tires | 6 | 04-13-2009 04:49 PM |
| Quiet BOV? | Ftaz1 | MazdaSpeed 3/6 - Turbo Induction | 13 | 12-22-2008 03:44 PM |
| Mitsubishi union keeps strike vote quiet | Haltech | Automotive News | 0 | 08-04-2008 03:20 PM |
| NHTSA vows research on quiet-car threat | Haltech | Automotive News | 0 | 06-23-2008 03:00 PM |
