| MazdaSpeed 3/6 - Suspension & Brakes Discussion for suspension items like coilovers, springs, sway bars, mounts,chassis bracing and brakes. |
![]() Join Date: Aug 2011 Location: Minneapolis, MN
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 28
(Thread Starter) | Not Ranked : 0 score To save time and trouble, is it possible to keep the strut attached at the bottom, and compress spring while on the car to replace the mount on top, or is it necessary to completely remove the strut? When I attempted to change the front struts a year ago, I couldn't get it free at the bottom, had to take to a shop. Any advise appreciated, thanks!
__________________ 2008 MAZDASPEED3 Bilstein Sport Shocks - Cobb Springs - JBR RSB - JBR 70 RMM |
![]() Join Date: Nov 2009 Location: Dallas, Texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 31,116
Groans: 549
| Not Ranked : 0 score Probably, but could be tricky
__________________ it's fun to do bad things |
| The Following 2 Users Say Thank You to jack_hammer For This Useful Post: | MARKSPEED3 (04-15-2013), Raider (04-15-2013) |
![]() Join Date: Oct 2012 Location: Golden, CO
| Not Ranked : 0 score Technically you can remove the entire lower arm and drop the spindle out, but to get it out enough to work on you'd also have to remove the brakes. Not worth it IMO. There are a number of threads on removing the struts. I bought an 1/8" thick steel chisel and used the bolt trick to spread it open. Came out super easy.
__________________ 2011 PB EVOX GSR | FBO + E85 ![]() (Sold) 2008 Black Mica MS3 | Cobb AP | UR DP+TP | HTP 3" | CS TMIC | CS BPV | Autotech HPFP | CPE RMM | JBR SSP | Koni Yellows | Cobb RSB | SPC Camber Arms | E40 Self Tune - 295whp/327wtq Uncorrected @ 5600' ASL 2014 Triumph Street Triple R |
| The Following 2 Users Say Thank You to asrautox For This Useful Post: | MARKSPEED3 (04-15-2013), SLOWHATCH (04-15-2013) |
(Thread Starter) | Not Ranked : 0 score Thanks for your input. I'll count on removing them completely. Should be easier this time around knowing the tricks.
![]() Join Date: Jan 2011 Location: Midlothian, Va
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 12,042
Groans: 274
| Not Ranked : 0 score Not much room up there. Plus you will need to make sure the top hat is properly positioned before you tighten it down. |
| The Following User Says Thank You to SLOWHATCH For This Useful Post: | MARKSPEED3 (04-15-2013) |
![]() Join Date: Jul 2009 Location: Keene, NH
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 53
| Not Ranked : 0 score It's very easy with the reverse bolt trick and a bit of WD-40. Once you crank open the arms, just squirt a bit of WD40 down between the arm and shock body on all sides. With a little bit of downward pressure, the shock will pop right out.
__________________ 08.5 Mazdaspeed 3 - Cobb AP w/ Boost Targetting at 17psi, CP-E Nano SRI, ETS 3.25" TMIC, SU Test Pipe, CP-E RMM, Bilstein Sports, Cobb Springs, Progress RSB, Short Shift Plate, SU Solid Shifter Bushings, Dashhawk, Gold 18x8.5 Rota G-Force's, 235/40/18 Hankook Ventus V12's 253WHP/274WTQ on a Mustang Dyno before tune, 282WHP/318WTQ in VD after tune 97 Suzuki TL1000S Naked - LeoVince Slip-Ons, K&N Filter, PCII, fully custom naked setup 89 Kawasaki 650SX Stand-Up Jetski |
| Daily Driver ![]() ![]() Join Date: Dec 2008 Location: Tampa, Fl
Rep Power: 880 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 576
| Not Ranked : 0 score I dont like lubing the shocks it helps them hold better |
| Not Ranked : 0 score Or just remove the strut from the base by using the emergency jack to pop it out. Works every time for me. |
| The Following 2 Users Say Thank You to Raider For This Useful Post: | dh5077 (04-23-2016), jack_hammer (04-15-2013) |
Groans: 549
| Not Ranked : 0 score Just watch the speed sensor if you use the jack. Our even remove it. If you f it up, though, i have one for sale.
| The Following User Says Thank You to jack_hammer For This Useful Post: | MidwestSpeed3 (04-18-2013) |
| Strut Mounts Front + Rear (?) | jjm | MazdaSpeed 3/6 - Suspension & Brakes | 6 | 04-09-2013 11:13 AM |
| ? on bolt at bottom of strut. | iammike | 2010 MS3 - Suspension & Brakes | 27 | 01-26-2013 10:03 AM |
