| MazdaSpeed 3/6 - Suspension & Brakes Discussion for suspension items like coilovers, springs, sway bars, mounts,chassis bracing and brakes. |
![]() Join Date: Nov 2015
Rep Power: 0 ![]() ![]() Thanks: 3
(Thread Starter) | Not Ranked : 0 score Hey guys, so don't know if the mounts are still good (car has 87k on it), but thinking of replacing them since will be replacing the shocks anyway. Thoughts? thanks |
![]() Join Date: Aug 2012 Location: Middle Coast
Rep Power: 263 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 436
Groans: 126
| Not Ranked : 0 score Most guys replace the top mounts while they're in there, but it's also possible to rebuild/repack the bearings if you'd rather go that route. There's a how-to on the forum that you can find; I followed it when I replaced my shocks earlier this year and haven't noticed any issues thus far. Takes lotsa grease but isn't a difficult process. |
![]() Join Date: Feb 2011 Location: Chicago
Rep Power: 365 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 183
Groans: 74
For rear mount you will most likely need new bump stops but I don't see how that rear mount could fail other than the bump stops. Sachs makes a kit for like $35 and they come with boots too.
__________________ 2007 TR MazdaSpeed3:Autotech FP inernals, CorkSport Turbo, TR8 Front Mount w/CX piping, JBR 3" intake, COBB EBCS, Cobb AP, Toyota Injector Seals, FR stud mod, Fidanza flywheel/LUK clutch, Forge BPV v2, cp-e xFlex stage 2 RMM, Wiseco .20 Pistons/Manley Rods/BSD, Dual DM catch cans, Koni Yellows/H&R springs, FD wheels, eBay downpipe, stock CBE 2005 Mazda 3 SP23: mods include rusty quarter panels and grinding 3rd gear. It does have a fusion motor, so I guess that's a mod too. | |
Groans: 126
| Not Ranked : 0 score Derp, you sure are correct; apparently I didn't fully read the thread title! Rear bumps hold up much better than front and may be reusable if you're on a tight budget; mine were still okay after 80k even though the fronts were like dry, crumbling toast. The rear mounts themselves shouldn't have any problems unless you somehow managed to crack one or something. |
Groans: 126
| Not Ranked : 0 score I think the popular choice is to just get new OEM bump stops in the rear, although the front bumps are known to be garbage and should be replaced with a set from Ground Control. |
![]() Join Date: Oct 2013 Location: Snohomish, WA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 12
Groaned at 39 Times in 10 Posts
| Not Ranked : 0 score I just replaced my suspension and with over 100k miles the rear mounts and bump stops were fine and completely reusable. Fronts, not so much.
__________________ 2007 Mazdaspeed3 |
| putting air bags in rear for track? | Sal's_MS6 | MazdaSpeed 3/6 - Suspension & Brakes | 47 | 04-19-2013 11:27 AM |
