Mazdaspeed Forums
-   MazdaSpeed 3/6 - Suspension & Brakes (http://www.mazdaspeedforum.org/forum/forum/f12/)
-   -   Rear Control Arm (http://www.mazdaspeedforum.org/forum/forum/f12/rear-control-arm-204992/)
dead-zone 08-30-2016 01:29 PM
Rear Control Arm
Need some help, advise, etc. So long story short, was changing rear sway bar endlinks, bushings, and the rear springs. Everything went well, though the outer bolt on the lower control arm is seized with the bushing and I cannot take it out. Also, the bushing itself is "gone" so it def needs a replacement. So, any idea where I can find a cheap control arm or bushing (the whitelines a bit expensive at $71). Any ideas how to remove the bolt without cutting are appreciated too.
P.s. Rockauto has one control arm for $35, under speed3:
More Information for MEVOTECH CMS76155
Under regular 3, they have more options, including MOOG, though I am not sure if it is going to fit the speed3:
More Information for MOOG RK641468
dead-zone 09-06-2016 11:07 PM
FYI, the MEVOTECH rear LCA listed for mazdaspeed 3 did fit.
Smus 09-07-2016 09:40 PM
If you run into any more problems with seized bolts, bar none, the best penetrating fluid is Seafoam's Deep Creep. Runs about $10/can but I'd trust that stuff to break loose a rusted engine. Just be sure to give it enough time.
Roman-dude 02-23-2019 11:38 PM
Quote:
thanks for updating your original post. How has it been holding up? thx
Clintb3astwood 09-17-2019 08:23 AM
Bump any word on the mevotech lower arms?
Anyone else know if the moog lower arms will fit the speed 3?
Db09ms3 09-17-2019 10:36 AM
They just confirmed they work.
Clintb3astwood 09-17-2019 10:38 AM
Quote:
The Moogs?
Sweet ill place an order. Are the side specific or no?
Db09ms3 09-17-2019 10:51 AM
Report back when you get them and be the guinea pig.
Clintb3astwood 09-17-2019 11:00 AM
:banghead:
Clintb3astwood 09-17-2019 12:00 PM
Quote:
Just received confirmation that it works!
Page generated in 0.17290 seconds with 11 queries
