  • 1 Post By Clintb3astwood
 Old 08-30-2016, 01:29 PM   #1
dead-zone's Avatar
Posts: 442   (View Stats)
dead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the world
Groaned at 53 Times in 17 Posts
Default Rear Control Arm
Need some help, advise, etc. So long story short, was changing rear sway bar endlinks, bushings, and the rear springs. Everything went well, though the outer bolt on the lower control arm is seized with the bushing and I cannot take it out. Also, the bushing itself is "gone" so it def needs a replacement. So, any idea where I can find a cheap control arm or bushing (the whitelines a bit expensive at $71). Any ideas how to remove the bolt without cutting are appreciated too.
P.s. Rockauto has one control arm for $35, under speed3:
More Information for MEVOTECH CMS76155
Under regular 3, they have more options, including MOOG, though I am not sure if it is going to fit the speed3:
More Information for MOOG RK641468
dead-zone is offline   Reply With Quote
Rear suspension lower control arm Dasleeper MazdaSpeed 3/6 - Troubleshoot/Diagnostics 12 08-09-2014 03:07 PM
Adjustable Rear Lower Control Arms? redboat MazdaSpeed 3/6 - Suspension & Brakes 4 12-25-2013 10:03 AM
Pass rear lower control arm mikelevi MazdaSpeed 3/6 - Suspension & Brakes 3 09-06-2013 06:19 PM
Page generated in 0.29404 seconds with 24 queries
